View Full Version : Hybrid / Engine Swaps
- B18C into EG Question
- k swap obd2 emissions?
- obd1 conversion harness questions
- D15b2/d16z6 mini me 88 civic ef tachs at 3500
- 90 civic dx B18C1 swap wont start
- GSR Swap into 98 EK HB Dx
- need help with d series swap
- H2B Swap Suggestions
- h2b/h22/f23/g22/g23/h23 for slae thread?
- H23A VTEC blue top into 4g prelude (clarity post)
- F2B in an Integra
- Help with OBD1 B18C1 into 94 Hatch (CARB / Check Engine)
- h2b swap help in my crx!!!!!!! Need to find the right traction bar
- h23 swap in prelude type sh
- Does my left axle look wrong? h22 crx
- h from b swap
- Rpm problems
- NEED HELP ON LS/VTEC EMISSIONS!!
- civic b16a2 swap secondary o2 sensor?
- Pulling Cel Code on a 99 Hatch with JDM H22?
- OBD2 H22A4 Del Sol Swap help/write up
- B16 CRX
- H22 CRX inlet manifold options
- Obd1 car obd2 itr ecu with jumper harness, getting diagnostic codes
- plzz help i dont know what to do with my h22 swap
- ZC swap civic
- EF b16 idle issue
- 91 civic HB dx swep
- Obd2a jdm d15b motor in an obd2b civic hb
- gsr cams into b16lsv
- b20 into 97 ej coupe swap
- B18c1 ek no fast idle at cold start until warm
- Second Gen Prelude -b series swap
- engine swaps and throttle cables?
- H2F? or just do a rebuild
- H2B Crx
- code p1337
- CEL 10 (IAT) will not clear, B18CR
- B16a2 Turbo Build
- Can bad itr headlight wiring cause ecu to fry?
- Plan -> D14A1 to hybrid d16
- Is Partsgeek.com legit? (Some tech included)
- What is an ls swap?
- need help! !!! lsvtec
- OBD1-OBD0 and OBD0-OBD1 2 swaps, need answers.
- 90 integra with b20b
- H22a4 swapped EG intake manifold issues
- 2000 Honda civic si b18b1 Help me!
- Which clutch cable for UK chassis H22 88-91 CRX?
- B18C to EK throttle cable
- Fluctuating Idle
- 98 civic hx obd1 b16a issue
- 93 Si LS swap..
- NJ inspection passing with a 97 EX with a JDM B18C
- pass inspection in nj
- H22a combined with d series transmission
- 1996 Civic H23a Turbo Issues.
- New member engine swap question
- Domani MB5 4wd
- Red Permatex causing my B2/Z6 mini me swap coolant leak?
- How to swap d16y7 into d15b7..
- f22b2 and 5spd swap into '90 civic dx
- b18a1 to b20b swap quick questions
- Shifter Bushings for B series tranny in EG hatch
- F2D kits no longer available?
- i have a crashed BB1 \ H22A1 whats a good swap
- Temp gauge doesn't work right after type r swap!
- F22A6 swap for H22 or F22b2 vtech.
- Raise motor for tranny to clear subframe?
- is it possible to fry starters???
- H22a late vtec?
- Your experience with rywire/chasebays? other wiring questions.
- 94 si hatch/ls swap - antifreeze leaking from frame rail??????
- Need help with d16y8 replacement
- 92 civic/h22a swap with aem 30-6040 ecu - cluster and CEL problems
- 99 honda crv engine swap help
- b18c1 into ef wiring question
- ect sending unit?
- B16 alternator fit issues
- J-series pistons in to h22?
- so no1 wants to help huh?? gsr issues
- Swaped d15b7 with d16z6 and having idle problems. Need help.
- please help some1
- Got spark and fuel: non starting B18Cr saga continues
- I need help with swaping
- H2B in eg not starting HELP!
- 6 pin distributer (head scratching after swap)
- Accord OBD1 and Civic OBD1 Pin Outs Difference
- 1990 integra gs gsr swap cable to hydro clutch help!!!
- Fuel pump doesnt prime after jumping IACV connector
- usdm b16 intake manifild on jdm b18c???
- Torque specs for B20/VTEC
- Oil pressure change
- Swapping D16Y8 SOHC to B16A2 DOHC
- B20 or gsr swap
- CA smog H23 vtec
- LS VTEC Sputtering Issue
- Mishimoto rad plus sub freezing temps = heat's only warm?
- Quick LsVtec question
- 98 lx d16y8 swap
- HELP?!
- Slimline alternator plug? H22 crx turbo/alternator clearance
- gsr 98 swap into 96-98 ej8 chasis
- Piston side to side play in the sleeve
- which bracket is this one (Post Mount)
- F22B2 swap into Civic dx?
- 92 Honda civic
- H22, F20b and H23VTEC timing belt walk
- Stuck with old OBD2b grey cabin plug
- 01 CR-V B20Z2 usdm to a B20B8 jdm (aus)
- b18vtec build
- distributor mystery
- ??s on 1989 CRX dx w/ D16a6 swap
- has anyone used swap shop racing in covina,ca
- 1996 Del Sol b20 Swap?
- b18b1 swap in 99 civic fuel pump no prime
- Designing and Building a RELIABLE CRVtec with 'Respectable' Power Goals
- About to start b20v
- valve lash keep loosing randomly
- Some peoples builds b18a1.....
- H23a Vtec H2B halfshaft question
- tach problem on h22 civic
- Where did you guys get your engine from?
- Anyone use summit oil filter relocation kit?
- j swap info?
- ek swap...b20v...b16 head
- Oil on cylinder 1 spark plug
- Obd2 Gsr motor into obd1 ls. Need help
- going back from lsvtec
- 92 civic cutting out at 6000+ rpm
- Dose a b18c1 or a b18c5 if in a 97 honda hx
- b16b to b20v
- f20b lsd t2t4 transmission in 92-95 civic
- D16Y8 parts onto a D16Z6 block?
- JDM B18C Type R IACV Delete Questions
- Which side of the rear mount do I route the shifter cables? H22 CRX
- FULL SWAP VX TO EK 2000 HATCH
- F20b valve clearance issues
- element to crv swap
- 00 integra ls vtec motor mount fitment issues
- B18cr problem
- h22a high idle
- Which Car to do my swap in? Opinions
- 00 si h2b
- D16Y5 head on Z6 block swap
- obd2 civic swapping in 96 b18b1 quick question
- 2000 civic ex b18b1 swap help
- Ls vtec head plug keeps leaking
- limp mode no codes
- G23 hybrid H2b EF hatchback. H22 head modifications required?
- B16b swap CTR cluster help
- D16y8 head on y7 block
- B20v NOS - can a Cast Piston take it?
- first time
- 3.0 in a 1995 civic dx
- b20b swap, idle issues. HELP!
- 93 del sol b20b engine swap kinks
- difference in k20a and k20a2 as far as install?
- obd2 to obd1
- F20b into Prelude swap(ECU confusions)
- EF H22_Radius Rod hits crank pulley
- D16y7 to d16y5 swap
- 97 civic harness to 97 Ls
- Obd1 to Obd2a?
- best b20 vtec build?
- minime swap... no power
- Convert 98 Civic Auto to OBD1 while remaining auto
- turbo j swap ek past and present
- Honda fit
- B18c
- B18c1 in DA9
- SOMEBODY please help H22a4/ EG swapped????
- Valve Problem??
- full h22 swap to h2b
- D16 head swap and now no start
- jdm d15b with z6 head no start
- Problems with JDM b20b swap (help)
- EG swapped H22a4
- ** Have you ran a J series outside of a vehicle?
- 85 crx si d16a1 swap
- b16a reving high
- Trying to finish b18b1 swap
- Mini-me swap questions??
- EG swapped H22a4 help ?
- Engine swap on 87 accord lxi
- nevada bard information
- which rear mount? ys1 cable in 93 civic
- Any tips on doing an engine swap that already has AC and PS?
- H2b
- itr swap, power steering brackets
- 92 hatch D16Y8 swap
- Swap question
- Difference between d15b vtec and vtec e
- Honda Civic EJ2 (D15B7) to B16A1
- B16 swap questions.
- Eg saden b18 swap
- B18b1 with gsr trans
- B16b lost of power under light load 3k-4krpm
- F20b VTEC question
- H2b Gsr Reving Nightmare
- b18c5 swap problem
- Clearance issue EK civic H22A(Header)
- Will ebay solid motor mounts for integra fit on an eg?
- Vtec Wiring Help!
- H2b swap questions
- 1993 B18C swap cant find parts?
- any suggestions?? mini me vs b16 swap
- Why is my 37820-P75-A01 hitting fuel cut-off @ 5,750RPM?
- K20A3 / K24A4 Questions
- bogging after warm ej b20
- wiring and swap question
- Vacuum lines B18a1 si hatchback
- swapping a 95 ls b18b1 into 1990 integra
- Threw a rod in my d16y8
- 96-98 civic with gsr evap issue
- JDM b18c in eg no crank just a click
- LsVtec Rod Bearings and Oil Clearance ???
- H22 and F22 trans - Thoughts
- Automatic ls swap into 94eg 4dr
- P05 ecu with b18b1 swap
- B16B Type R: Vtec Question
- D16y7 to b16a2 need help wiring
- engine swap
- 94 civic build
- B20B in 2000 dc2 GSR confusion?
- F20B T2T4 build and swap into 98 Acura CL
- b18b1 swap into 2000 civic DX
- 96 d16y8 swap into 96 ek hatch,help?
- h22a7 obd2b engine harness into CD5 accord
- Cant find a set of headers for my model and need opinions!
- D17a1
- Using a Skunk2 intake manifold on a B20b
- H22 swap In accord, I'm desperate please help!!!!
- B Series Header that Clears the ac compressor
- b18c5 vtec sputtering
- Code4 issues gsr help please
- 98 integra rs 96 gsr engine swap HELP!!
- P30 running a ek4 b16a Wat do I need?
- Accord AWD conversion/engine swap
- flow modded J or built B into an EJ2 as a pro/street car?
- 98b18b1 running on p2e?
- obd2a GSR into EM1 - high idle
- h22 swap gone wrong
- d16y8 to d16z6 ! please help me my Honda people.
- Vx harness issue
- New to the Honda world
- H22 head on F22B1
- EF H22-SWAP Info-Do i need a front sway bar?
