View Full Version : Hybrid / Engine Swaps
- Finished swap, but have a few Qs.
- CEL came on tonight...what could be wrong?
- Anyone here go from a GSR tranny to a JDM ITR one?
- ?89 Honda Civic q?
- Anyone swapped H23 for a H22A?
- Wuts the difference in ABS and non-ABS axles?
- crx motor swap progress
- Help with vtec soleniod troubleshooting
- HELP. Idle going up and down 800 to 1800 rpm back down etc.!
- Dual ZC
- which ecu?
- search didnt help Insight hybrid
- Homemade VTEC Indicator Dash Lights
- recomended engine supplier
- Chicagoland BBQ
- The choice is killing me!!
- what else do I need for CRVTEC besides block and head?
- pwo ecu???
- weight?
- Will a 92-95 cat-back for a hatch fit a 96+ EK with b-series swap?
- no VTEC on my hybrid??
- What ECU for an LSVT ? Kenji ? Any opinions ?
- putting si mount on motor for EK swap
- putting a turbo on a h22a hatch???
- 99 gsr question
- about to get my b18
- I just bought a B18B to boost in my 94 si. Gots some ?s
- b18c in to a 99 Integra
- Believe it or not...someone actually wants my 1.5L CX engine/tranny!!! :o
- Worth putting a H22 in an EK?
- Testpipe.com = bad customer service + bad product support. (long)
- You might think its junk, but I need it. please take a look.
- very good wiring question. Take a look.
- A/C problems with my gsr in my eg
- Engine Mount Retrofit
- What part is the most problematic while doing swaps?
- all motor b20(non-vtec) vs. b18c1
- how to clean grease from intermediate shaft
- JDM H22A Tranny In a USDM H23 Car?
- I need part numbers
- I need a b18b
- Need opinions for a 88 civic hatch
- 93 civic dohc vtec swap. OK to Use the DX Harness???
- do I need air tools for swap?
- Del sol rear disk swap
- hyrdo to cable problem??
- do I need the del sol ac bracket for b series into ek?
- Zc Vacuum Hoses????
- Fuel Pressure Setting on b20vtec motor
- 96 honda civic hb si for sale $2800 cash call hurry
- fluidyne radiator fitment with hybrid 5th gen?
- Civic EX front brakes...same size as Integra (non ITR)??
- Debate: B20/VTEC vs. B18C1
- need some help. =)
- turbo or super or n/a
- 00 ITR Into 96 CX - Long
- how hard it will be to just drop a b20bnon vtec with gsr tranny? what will i need?
- *THIRD GEAR GRIND!!!! how do i get rid of it?
- Which CAI do i need to get for my swap?
- Going b20 need info
- Wiring:OBD2 B18C1 to OBD0 harness, how?
- Anyone with an H22 in a 3G Integra??
- how to tell what year b18c1 gsr motor is??
- 94 GSR short block on Ebay No Reserve
- 16.4 with the b20...ouch
- Would a del sol rear trailing arm swap in to a 97 civic ex??? (rear disk swap)
- I know, I know not a turbo question, but...
- 2000 Civic Coupe/GSR hybrid
- h22a in dc2 question (suspension)
- jun distributors?
- might replace b18c1 longblock for b16 longblock, will everything else fit?
- s2000 fwd coming soon!!!!!
- knock sensor wire. GSR in an EG 92'
- Figured it out!!!!!
- help, bogging or stumbling issue,,coil or igniter?
- intake dont fit???
- www.importjdm.com???
- Looking to upgrade my hondata TODAY! PA people please help!
- Shop Question, for ya'll tech guys
- Anybody Know Jake About Installing Suspension On Hybrids in DC Area?
- going rate for used 92 cx...and where to get it in the bay area
- possible fried pr3?
- ehxuast help, finishing swap
- Dyno Today.. does this sound right?
- need your advice: GSR swap PLEASE!
- Where can i get a B16A2
- NEED HELP, POS car wont start!
- How much have you guys paid for your swaps?
- 1st gen b16 o2 sensor which goes where?
- Will a cx harness run an ex engine???
- B20 VTEC head combinations
- ENGINE swap questions: 86 CRX
- 90 Civic EX
- b16 into 92 cx.??
- Which AC Bracket for a 93 Civic with B18C1
- Invite to NY Motor Swap on Aug. 17
- ATTN ppl with B20/B18B swaps in EKs...what intake do u use?
- 00 Si motor into 96 civic EX....need help with wiring.... PLEASE~!!!!!
- questions on brake conversion for 96 civic
- Hatch STD ECU?????
- H22 Tranny Bracket Help
- 92 hatch with Integra stock integra shifter.... hard to get into 4th???
- d16z6 vs. mini-me
- Honda motors Online... bad motor :(
- Need Advice for my 80,000 mi. B18B1
- VTEC Experts -- Please read this!
- Honda car weights
- H22A in DC2? links?
- all motor people
- Which valve clearances?
- Need wiring diagrams for 99 Civic LX and 00 Si??
- Need help!!!! 00 Si b16a2 in 99 Civic LX, need pinouts on LX wiring, or diagrams.. Where can I find
- HASport mounts came today!!!
- question for people who did the auto->manual swap
- ls/vtec faster than stock type r?
- P/S, and A/C issues concering H22 into 95 Civic Hatchback??
- anyone in mpls, mn area please read
- obdII gsr swap into 92 cx
- time for a nice header, any reviews/suggestions?
- ftps location?
- How much were your ARP head bolts??
- B16 CRX, o2 sensor??
- Simple Question: Can I use an ITR AEM CAI on my B20 swap?
- Are axles for B-series the same?
- Simple Question
- Need opinions on changing head bolts..
- **HELP Oil Spraying rom head!!!**
- Tools for swap
- can somebody post stock b20 outputs?
- Idle at 3-4000rpm, WTF and no codes... Please Help..
- got the b20 dialed in
- B20B1 axles
- Lets See Those EK Hatches - Post a pic of your EK Hatch!
- Type R camshafts and valvetrain, what parts do I need?
- Relist: FS: 1998 Civic EX/ITR Hybrid
- I need some swap help b18c-hatch deal
- twin turbo cost for 94 civic
- engine
- arp rod bolt for b16a 8mm or 9mm?
- Headers for LS/Vtec in 88 civic HB?? which one will fit properly or with little mods??
- help ls in 98 coupe?
- b18c1 throttle cable
- 88 (mite be 89) teg RS motor
- fast idle control solinoid valve on a ZC ??
- How high can I Rev a B20 with the following mods done to it
- B18c1 in a 4g hatch w/b16
- H22 into 6th Gen Accord
- Using EX intake on B20...any problems?
- Beware
- ??? b20b ,b20z difference ,with 1.7 vtec head also more?
- AC Compressor
- ls vtec???? help... feed back greatly needed!!! please?
- transmission question.
- what's the difference between PW0 and PR3 ??
- Just GOT MY SWAP TONIGHT :D Couple quick q's tho..
- type R swap in a 95 LS
- B20 questions
- trouble with mini-me set-up
- HF Trans replacement
- is there a way to figure out the year on jdm motors?
- Ideal springrate for EG hybrid
- Pics of my new motor from HMO
- Exhaust
- swap prices
- dohc zc in an 88' crx hf
- Compression vs. Horsepower
- Putting ls in on saturday, a few Qs.
- Difference between 94-97 98-01 B18c1
- B18C5 head on a B16A2
- JDM ITR conversion OR JDM GS-R conversion?
- Which intake for b16/b20 motor
- Dry weight of various hatchbacks....
- What kind of cold air intake for civic Hybrid???
- USDM ITR head + B20B
- How much more does B20B/B16A weigh than stock B16A?
- Stock ITR flywheel and clutch in my B18C1 '92 CX hybrid.
- has any one made a auto to stick conversion.
- Straight b20b w/ GSR tranny
- will this work jdm b16a into 99 civic dx hatch
- WOW!! my new b20 just caught on fire!
- B16 swap problems.......
- 2jz-gte in civic...???
- It's Alive!!
- which intake???
- b18c1 shift linkage in 92 hatch
- Stabilizing a B18C1 swap in a 96 Civic EX Coupe
- post all h22a into civic info here please
- EVAP on JDM b16?
- WTB: B series Mid-shaft!
- Over heating problem with B18C1
- new to swaping
- Distributor for LSVT with LS wiring harness ?
- 2001+7th Gen Civic now has RSX Type-S swap in it, running good.
- B18A in 4th gen
- Any difference between 95 usdm gsr motor and 99 jdm gsr motor???
- misc swap parts source?
- d16z6 distributor question,,,,help.
- Can someone IDENTIFY this Distributor?
- will a vtec distibutor work on a b18a?
- 1990 prelude swap options
- What kind of numbers am i gonna get?
- harness options for b16a2
- HELP!! trying to see if this will work. (b18c1)
- CRVTEC swap smog legal?
- b18b in 95 civic
- Check out my hatch in action
- Have a few q's about swapping.
- is a b16a a 99-00 si engine???
- need help choosing an engine!!!!!!!!
- My hatch is hurt. :(
- ECU and wiring Q's for a B16B in a Del Sol
- Where can i sell my old stock engine?
- 95 gsr fuel pump work in 89 crx hf?
- LS tranny for Ls/vtec (itr head)??
- CTR/ITR motor cost?
- code 22 on a 92 cx with a jspec gsr swap on a chipped p28?
- Help which axels and haifshaft!!!!!!
- ls swap costs
- wtd: hondata rom editor software
- intake for b18 in 92 h/b
- JDM Auto Tranny help????? and ecu ?'s
- Good frank machinists in the midwest??
- 1990 DX hatch question..
- questions on ls/vtec
- ****Need pinout for knock sensor on a PW0 quick****
- JDM B16 Injectors..what size are they?
- Doin my swap as I type!!! Need Help!!!!
- b17 crank in a b16 block, Anyone?
- CR-VTEC swap costs.....
- b20z bottom, gsr head
- cr-vtec. no power
- Ques on LS/Vtec setup...
- hondamotorsonline good price for B18C5 or What???
- Ok guys WTF am I doing wrong????
- how hard is it to drop a 1 gen b16a in a 92 cx hatch??
- It's in! It's in!!!
- 92-96 H22 block with 2000 H22 head?
- Milling SOHC head to 11:1 CR Clearance?
- SOHC VTEC 8,000 RPM Redline
- gsr head/b20 bottom..where the hell is the pcv?
- need help!!!!!!
- Dyno chart request...B16 with stock ecu vs. Mugen chipped ecu
- tranny mount
- hybrid help in jersey
- '96 CX EK + B20Z + JDM Type R 4-1 + what cat, and what 2.25" exhaust?
- better shell for hybrid..
- 94 gsr in 92 si help
- jg edlebrock intake man. in 4thgen hybrid
- what color connector does the knock sensoe have on a 1st gen jdm b16?
- where to find H22a swap info?
