PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 [41] 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Information
  2. f22a1 block with a h23a1 head
  3. Tranny install on my b20
  4. What's the best swap for me
  5. JDM F22B into 95 Accord having problems
  6. Any good? SpecR Fastbrakes Rotors?
  7. Wiring A B18 Into A 86 CRX, Please Help
  8. CEL 36??
  9. Engine harness woes
  10. f22a into 94 prelude Si
  11. Code 9 CYP sensor
  12. K23A1... AKA RDX engine.. anyone got info on this swap has it been done?
  13. SOHC turbo / NA B16
  14. H22 EG Swap
  15. OBD2 H22 motor into a EK Civic OBD2
  16. ls vtec question
  17. swap
  18. 95'GSR chassis w/TYPE r/s H22?
  19. Tranny help from a h22 i bought
  20. Any have a B.A.R cert B-Series in CA?
  21. 97 LS head onto b18A1 converted to obd-1, any changes needed??
  22. How to tell motor is OBD1 or OBD2?
  23. CRV awd 5 speed manual tranny
  24. B20VTEC, CRVTEC, LSVTEC with GSR, ITR, B18C1, B18C5 oil pan, which dipstick?
  25. Check engine light in H22 EK civic.
  26. CRX OBD II conversion?
  27. h2b kit with power steering and ac?
  28. I just bought a b20b with 9:6:1 CR from HMO
  29. Tried searching and cant find it
  30. help me plez
  31. YS1 Cable Tranny in a EG, Anybody running this?
  32. s2k (s-2000) with rsx 6 speed in a 88 crx
  33. looking for a fuel rail fitting for a b-series w/ aftermarket fpr ? where can i find one?
  34. problem GSR swaop on a 1994 civic hit the gas and it wants to stall
  35. oil pan ? for a LsVtec turbo
  36. k20a swap to eg civic
  37. EK-K-series question
  38. B18C1 into crv?
  39. Not succeeding at this...any theories?
  40. LSVTEC kits?
  41. k20 z3 hybrid
  42. overheating is pissing me off
  43. a few ecu codes need advice
  44. Innovative mounts- EG-Kseries steel kit just released !
  45. need help car wont start no spark
  46. what do i need to make a poor mans type r
  47. I keep breaking Gator Racing Axles!! 3 Sets now and Im finished with em!!!!!!!
  48. so sick of searching about cable b-series trannies!!
  49. Dowels for Girdle?
  50. B16 SIR-II swap on a 93 CX hatch
  51. SPEEDOMETER NOT WORKING AFTER LS VTEC SWAP
  52. please help cel check engine light code 16 ek civic lsvtec swap no spark
  53. My b18b swap...
  54. what timing belt do i use?????
  55. B18C5 swap into a 90 DA integra
  56. ek b18c1 swap
  57. 1990 integra b16a2 need vacuum help
  58. b series axle
  59. k20??
  60. A20 engine, any other trannies?
  61. Neew Help Which Ac Bracket for LsVtec Swap?????
  62. Honda engine into a Type 1 VW
  63. Project: H22 into EJ6
  64. which wiring harness
  65. ecu question h22a
  66. anybody using Infinite Auto mounts?
  67. b18c into Eg guide
  68. Poor mans type R help
  69. b20 with a b16 head turbod?
  70. s2000 swap/ eg hatch?
  71. I have a JDM H22a and I want to make 350hp on boost
  72. F22 to F23 questions
  73. white smoke coming out of exhaust?
  74. hmm b18 swap runs great on the road, no CEL, no codes either...but idle is irratic
  75. b18c or b18c5 ek
  76. noob clutch question
  77. h23 motor in a crv with h2b adapter using awd, info needed??
  78. which spark plugs?
  79. Let's discuss - h2b header solutions
  80. k series swap question
  81. nice work
  82. My AWD swap
  83. Question about torque mount...
  84. Which Axles to use in an EK4 w/ ITR 36mm hubs when doing a K24 Swap??
  85. Some B16B ?'s
  86. PPL with H22 hybrids chime in! How did you fix hole 4 shift assembly so u dont c the ground!
  87. so i got off the phone with password
  88. Oil pan for a K series swapped EG
  89. i pulled a motor from the junkyard (OBD1 B18A) what harness could i use
  90. stoopit ?
  91. H22 IN 97 ACCORD
  92. H2B Torque Specs?
  93. 96-00 civic rear disk conversion
  94. quick question about gsr into ek, which radiator hose to use
  95. When turning car jerky and makes a grinding noise.
  96. which tranny to use
  97. swap theory
  98. B20 integra tech questions
  99. h22a firing issue
  100. Thought i'd give it another try... H22a4 - ej8
  101. Euro-R Intake Manifold on EG H22... fitment issue??
  102. Swap info.,.,.
  103. recent GSR swap in an EG
  104. main relay not getting power k20a ek
  105. B20VTEC coolent and vacuum routing...?
  106. noobi question
  107. B18B Hybrid
  108. Difference between stock mount bolts and Hasport bolts?
  109. Shifting linkage???
  110. First and only two Honda S2000's in the world with 2JZ engine!
  111. 92 CX WIRING ISSUSES OBD1 GSR
  112. B20 in DA Integra
  113. LTB: Complete Rewired/Rebuilt/premade OBD1 Harness to Use in a CRX with an ITR Engine Swap
  114. h22 civic GURU's, willing to pay cash for your help
  115. Complete Si to 96-00 Hatch swap!
  116. NEED HELP TO BAR'D state ref H22a1 into 92-95 civic
  117. p28 skunk2 ecu help
  118. help me out with new mount bushings, either materials to use or options
  119. ob0 to obd1 dizzy wireing
  120. BMC issues. DC non abs BMC on a EG civic...wont flow thru to proportioner
  121. Innovative motor mounts, got some questions.
  122. spark plug diagram
  123. Routing shifter cables Eg h22
  124. Vacuum issue... crx si, with p72 head and after marker im
  125. OBDII Engine Harness
  126. Swap done. Need some final advice
  127. Tool List??
  128. K20 Turbo Swap into 98 Civic Auto
  129. Quick question regarding swap
  130. All obd2 alternators same?
  131. swapped now wont run right
  132. hydraulic da tranny?
  133. b17a1 from integ gsr swap to 98 civic ex
  134. del sol k20a any ideas
  135. B18B Trans question
  136. Which ECU and Harness for B Series-CRX Swap?
  137. has anybdy heard of using 5 lug prelude suspension and retrofitting it to a eg?
  138. help obd2b motor in obd2a car
  139. Accord rims for JDM 4 lug type R ?
  140. chipped ecu questions
  141. Speed Sensor
  142. Identifying Calipers
  143. b16 swap question
  144. OBD2 d15b ecu?
  145. gsr w/ lsd jdm type r tran and hasport mounts
  146. fuel pump problems
  147. What VTEC solenoid to use
  148. Which LSVTEC Aftermarket Pistons - Arias, Wiseco, Other?
  149. crvtec piston question?
  150. EK COILOVERS ON A DA??
  151. VTEC question
  152. h22 engine cuts out at 6500 rpm and tach bounes!
  153. b18a1 engine problems
  154. motor wont shift?!?!?
  155. Is There a Complete "How To" swap a JDM ITR Engine into a Stock '91 CR-X DX?
  156. mis fire problems
  157. thermostat question
  158. cable to hydo conversion in my eg what halfshaft?
  159. k20 help
  160. gsr tranny with b20 need some help
  161. K series info
  162. Omg...Please Help!
  163. g23 passing smog?
  164. How can to find out if a motor is stolen
  165. 4x114 Conversion Questions!
  166. Just out of curiosity (swap related)
  167. help h22 swap CL ecu correct pinouts to p13
  168. please help me out motor wont stay on
  169. Q: CKF sensor
  170. D16z6 in a EK HELP FAST!!!
  171. Anyone know size/pitch of B-series oil pump plug?
  172. avid motor mount
  173. how to know if a B16 is properly swapped ?
  174. BATTLE SCARED HEAD
  175. male and female plug from distributor wire harness is frozen.. won't seperate!
  176. obd2 to obd1 ecu pins question.
  177. help guys need help with d16z6 swap in ek
  178. Swap Question ?
  179. Help W/ obd0 to obd1 conversion
  180. i found my emmissions report. :(
  181. k-serie swap help!!!
  182. ****HELP!!! SIR REAR & FRONT DISC CONVERSION QUESTION...*****
  183. help swapping in b16 with cable tranny into a 1993 del sol with hydro tranny
  184. different axles?
  185. ANOTHER SWAPPED EG....
  186. Hydro Transmission help
  187. ITR 5 lug + SOHC engine/axles = ?
  188. Which axles for h22 ek..
  189. would anyone care about this swap?
  190. help could i use my 94 eg vx 1.5 civic radiator on my ls swap?
  191. Swap Info...
  192. 93 Ls into 89 DX questions
  193. which wiring harness?
  194. Has anyone successfully tried to BAR certify a ZC DOHC engine in California?
  195. OBD 0 Rad Fan Switch To OBD1 Switch...
  196. Re: Mini Me Problem (Searched and Confused)
  197. V6 swap??
  198. F20B DOHC-VTEC cams
  199. Obd 2 motor into and obd 1 car
  200. ls/vtec wiring question?
  201. h22 with k20 shifter??
  202. FAQ: Who to buy engines and transmissions from
  203. hoping you guys can help more then 92-95 civic forum
  204. Daily driver CLUTCH.. NO PUCKS, maybe turbo, suggestions?
  205. More info on k24a2 swap with EG's
  206. Witch head for my b20?
  207. Limp mode b20 in a 99 civic
  208. Can i use a 92 civic ex OBD1 Vtec Engine harness for my 1992 civic cx with a b16a2????
  209. axle reverse threads??
  210. 90crx si w/ obd1 gsr swap, Do I have to use obd1 alternator?
  211. help with k24
  212. gsr engine into ls car
  213. Is it possible to swap b18 non-vtec rockers into a b18c1 vtec
  214. what do i do with the crank position sensor?
  215. ek coupe time slips
  216. Know what you're talking about?? click here..
  217. Just a quick h22-f22 wiring question...
  218. need Help,please. with manual conv...
  219. axle problem
  220. ls hybrids
  221. FAQ: OBD2 into OBD1 into OBD0 into vice versa (WIRING ONLY)
  222. CAR WONT START?
  223. IT'S ALIVE !?!?!?!?
  224. WTB 92-93 GSR tranny (YS1)
  225. h22 swap on my ek
  226. doing a obd1 to obd2b dizzy jumper harness need help plz
  227. problem with clutch pin size!
  228. ecu help!
  229. Really Weird Problem..98DX w/ B16
  230. Problem with LS swap into 92 civic
  231. b18 lsvtec vs. b16
  232. ok, weird problem with my vss in my b18 swap...
  233. Prelude to Civic Swap Interchangeable parts????
  234. d16y8 in an eg, remaining obd1
  235. 91 CRX looking for a new motor
  236. h22 civic turbo???
  237. EK 97 hatch GSR Swap Questions
  238. just got my swap back- ECT wired incorrectly?
  239. O2 Sensor
  240. Paging all Gurus - Buzzing/Rattling noise - revisited
  241. OBD0 To OBD1 Injector Wiring **Question**
  242. mounts to use in b-series swap
  243. D-SERIES THROTTLE BODY ON TO B16 IS IT POSSIBLE??
  244. b18c1 into my 97 civic which ecu to use???
  245. Fuel Pump..
  246. rotor problems
  247. anyone done any writeups on converting over to natural gas?
  248. help First Gen B16A 3 sensors in the back?
  249. Anyone use Innovative Cable to Hydro conversion in an EF?
  250. racing slicks(where to find them)
