PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Exhaust Header Leaking
  2. 98' spec ITR motor into EK with 96' spec ITR suspenion
  3. b16a5 or b16a
  4. JDM H22 and DSS Stage 2 Axles not fitting in EG Hub !!
  5. Gas Mileage K vs. B
  6. GSR Swap - No spark, new distributor, cap has small crack, I hate myself
  7. runability. New swap. Take a peek. TPS and fuel questions.
  8. wiring help... shops?
  9. Mini-Me question need HELP!!!
  10. attn: all those knowledgable about the h22 EK
  11. H22 Ek Civic Axle Building????? How To???
  12. obd 0 and obd 1
  13. p28 runs fine while p13 runs like shit on a (h22)
  14. GSR Block with B16 Head
  15. b18c1(94-97) into 1995 civic dx
  16. Attention wiring gurus: Upstate New York
  17. H22 into Integra and Auto to Manual...Few Questions
  18. b16a2 swap
  19. H22 civic cable shifter alignment and grinding problems
  20. B18C into 98EX. Header, Wiring, IAB, and O2 sensor questions *pics*
  21. obd2b or obd2a p72 ecu for my GSR swap??
  22. obd1 b18b into 96 dx hatch need help asap!!!!!!!!!!!!
  23. crank sensor question
  24. Need help on modifications on b18s5
  25. b18a in a 90 civic si
  26. h22a into 93 hatch
  27. help me tear my motor down....
  28. LSVTEC write up 1991 civic si project
  29. 97 coup si swap
  30. Checking ECU?
  31. LS/Vtec oil supply input
  32. b18a1 and b18b1 Oil Pan question, need help
  33. obd2 gsr in 93 civic wiring questions?
  34. Problem with tach and redline
  35. can a 97 prelude h22 complete swap fit in a 96-00 civic
  36. car boging and not starting.help
  37. Need help with Mounts for H22 into a Honda Accord. Thanks
  38. 89 CRX B16 Swap (Help Please!)
  39. ob2 cat better for smog?
  40. H22 TYPE S price installed???
  41. Price h22 typeS??
  42. internals on my ITR
  43. B18C5 with Fluidyne Half-sized radiator?
  44. h22 f22 wiring info
  45. Driver side post mount ek, need help
  46. probably asked before, but....
  47. H22 running lean? Picture of spark plug.
  48. B18A/B throttle body & intake manifold compatibility (no map sensor)
  49. Will an obd2 itr motor work in a 99-00 civic si?
  50. F22 in eg vtec problem
  51. the biggest promble
  52. b18 Swap into 88 civic DX - crummy idle and misc questions
  53. LS transmission grinds!!!! ripping my hair out my head
  54. H22 alternator problem
  55. Swap mounts different between cable and hydrolic?
  56. 1st post obdo B15D question
  57. Where/who did you get your conversion harness from?
  58. RWD shift linkage setup for a b series or h series swap
  59. oil/water pumps obd specific?
  60. P75 OBD2a which version?
  61. H22 Automatic Problems
  62. 99 itr into a crx / speed sensor question
  63. Are P13s and P28s "hot swappable?"
  64. H2B questions...I searched...
  65. k24 potential?
  66. ac on ls/vtec..........
  67. H22A EGR simulators
  68. h22 carbon problem
  69. k23a swap ?
  70. b18a1 simple starting problem, please help me!
  71. b20 EK question
  72. Poor Man's Type R Build: Some newbie questions.
  73. lsvtec ? arp rod bolts bolt torque spec specs cap stretch
  74. NSX piston rings
  75. hybrid motor: b18c1 block b16 head
  76. Osaka Jdm Motors
  77. From H.to.B
  78. k20 fuel system opinions.
  79. DESPERATE for an answer!!! H22A EGR vaccum trouble!
  80. Can I use the JDM H22 wiring harness?
  81. da shiftlinkage fit 95 integras ls ?
  82. ECU question for a b18c obd2
  83. Which VTEC harness for B18C1 -> Hatch CX (my first swap)
  84. H22A4 TDC and CKP question
  85. implications of bisimotos tranny adapter plates
  86. b16/b20 help
  87. build a motor
  88. B16 sir2 Motor Swap what PS Pump and hardware to use in a 99 civic ex---HELP!!!
  89. 94 Del Sol B16 into EG
  90. What intake tube do you use for a b18c in an eg???
  91. good swap for a 97 civic coupe. opinions wanted
  92. b18c in 94 eg. Wiring. Searched, need reassurance. WIRING CAR NOW!!!
  93. oh please someone help! 93 hatch b16
  94. hybrid
  95. JDM p30 or USDM p30?
  96. B16 CRX Si, want to put in d15b vtec to get it on the road
  97. 91 dx w/ b16a swap rev limits at 2.5k
  98. What AC Bracket/Mount for EK with Si swap?
  99. Please Help! 98 integra Ls trans problem
  100. obd2 gsr into 93 dx hatchback wiring problems
  101. zc tranny
  102. h23 head on f22 block
  103. OBD 0 to OBD2b
  104. b16b or b18c
  105. how to tell if its a GSR tranny.....
  106. Itr cluster on Eg6 with H22
  107. B-series swap: Suspension springs
  108. Looking for a axle to replace a 90-93 thats longer
  109. the almighty b16
  110. b20vtec question
  111. Quick ECU question
  112. jdm b18c5 into 97 ex
  113. H22A Accord - Name that Plug Game
  114. 96 GSR motor, 97 civic EX...what cat do I run?
  115. NOYAN USA
  116. bisimoto F2D H2D adaptor plate questions, anyone running it?
  117. what radiator to use with H22 civic with a/c
  118. Si heads, OBD0 vs. OBD1
  119. OBD1 GSR in a 97 DX help plz
  120. what chasis is similar to a type r?
  121. okay, hybrid experts...which ecu to use w/ obd2a wire harness?
  122. obd0? or obd1? need help
  123. How Do You Wire Up A K24a4 With Jdm Ecu To Ek Without Hybrid Harness ?
  124. b16a block with b18b ls head???
  125. no spark on B18cR......
  126. b16 and b20
  127. Is the IACV(EACV) supposed to have voltage?
  128. H22 civic swap with a/c Idle issues
  129. Motor Swap Honda website
  130. EGR CEL WHERE IS THE EGR LOCATED
  131. k20 into a insight
  132. Acura 3.2 Type S Swap ever been done?
  133. f22 swap in EG
  134. CRX to Legend
  135. swap question: ecu
  136. Easiest way to wire OBD2 GSR swap into 98 EX?
  137. Help! h22 won't rev high or idle good.
  138. H22 Turbo
  139. K swap opinion
  140. zero oil psi (warm) Please help swapped pumps, pickups, filter, lines...ect
  141. D-series Frankenstein?
  142. itr intake arm - work for EG's?
  143. 96 GSR motor, 97 civic EX...not getting any spark. HELP!
  144. 99-00 civic si guage cluster in a 91 hatch?
  145. Urethane inserts for h22 hcp mounts into EK Civic
  146. Full K series parts list?
  147. JDM G1 B16A Into EF HELP :(
  148. What ac bracket to use for a jdm b16 swap and a 99 ex d16 ac compressor......HELP
  149. Throttle cable?
  150. 94 GSR into -> 91 CRX Si - (couple small questions)
  151. a/c help
  152. Quick CA BAR question
  153. battery light stays off, but not being charged. plz help
  154. will a b16a2 head fit a b20a block?
  155. Questions about GSR swap
  156. FUEL VAPOR PIPE?
  157. Pics of h22 swaps in a 96-00 coupe
  158. PICs Of your 96-00 motor swaps
  159. How can I tell a dual core radiator from a single core?
  160. Need Help Auto 2 standard conversion on my DC2, Trany mount issues.
  161. 3rd Motor simular Knockin noise
  162. help on h23 vtec
  163. FS LS short block
  164. Fucking shit.....Axle troubles......
  165. H22 Swap for 93 integra???
  166. 500HP Axles....$489.00.......would you buy?
  167. Adding A/C into H22 swaped integra. Need Help
  168. help.. distributer prob?
  169. just built ls vtec and its leaking at oil pump help....
  170. h22 into an ek
  171. What year is this head?
  172. GSR OBD1 swap - Smell fuel when fuel pump turns on, clutch is soft, coolant leaking from back of blo
  173. Engine cuts out at high revs!
  174. newbish ? but i need to know, losing sleep over it
  175. intake dosent fit!
  176. Who makes premade wiring harness for H22 swaps?
  177. New here... Si-R motor in my 1990 hatch
  178. F20C in EG's
  179. cel codes checked on my h22 ek HELP!!!!!!!!!!!!!!!!!!!!
  180. o2 sensor wires for a b18c1 in a 95 cx hatch? what do i do??!?
  181. Bought htis engine tell me what u think... (PICS)
  182. Ways to install Integra Rear Bracket into 93 EX coupe when GSR motor is already in?
  183. b16a2 fit into a d16 trany
  184. b16a into EK
  185. h22 ek swap axles on ebay
  186. JDM B18b1 & USDM B18b1 swap...
  187. accord with f23 , need to swap in h22 trans to use a quaife diff??
  188. 95 GSR motor into 96 EK? Engine harness question
  189. Type R Clutch In EK with B16
  190. CEL with a chipped ecu but none with a stock 94-95 gsr ecu
  191. code 9 and 10
  192. RHD engine in LHD car!
  193. Will OBD2 gsr harness work with JDM ITR motor?
  194. code 1
  195. Itr tranny in a gs-r?
  196. Swapping in new engine: California DMV registration forms?
  197. intake for a h2b swap eg???
  198. sohc head on dohc block?
  199. AEM CAI and AEM V2
  200. dpfi -> mpfi redo question
  201. ECU/wiring issue... the challenge
  202. Problems with my D16Y8....please help.
  203. throttle body
  204. d16y7 in a 91 hatch
  205. Z6 Head Y8 Block Question
  206. H22 ODB2 Wiring Question
  207. hybrid cross brand install b16 with b20 tranny into justy awd
  208. EP3 HYBRID's
  209. Questions about H22 Swap in EG
  210. Slim Cooling Fan opinions ...
  211. need help with wiring harness
  212. ls vtec swap with cable tranie into 98 honda civic
  213. Ls into mini ***Pics for ya :)
  214. EG H22 Swap - Can AC Fan be used for Radiator ???
  215. MAP Sensor Relay?
  216. replace b18a with b16?
  217. What ecu for a b20/b16 vtec i've searched!
  218. iab help
  219. EKH1 and EKH2 mounts?
  220. help: auto ek swap
  221. problems with the injectors
  222. Obd1 b16 intk obd2 ek question
  223. Having trouble checking Codes in OBD1 CRX
  224. k series swap questions, need help
  225. h22 in 94 coupe
  226. P72-2 head? What engine code is this?
  227. Tranny issue
  228. Do D16y7 blocks have oil control orifices?
  229. K24 accord?
  230. k24/k20
  231. check light and car idled after mini-me swap
  232. Removing Cali emissions wiring on h22
  233. b18c vtec problem
  234. what exhaust system are you sporting on your k swap
  235. Integra H22 Engine mount Height mod (lots of pictures)
  236. quick Question on swaping of b18b1 USDM To JDM b18b1
  237. What manifold!!!?/
  238. Day at the Dyno....
  239. ECT problem
  240. H22A No VTEC - Searched and did much testing look inside
  241. EG4 motor mounts ; auto vs manual
  242. New TL drivetrain in TSX?
  243. egk hatch with h2b kit finished !!!!!!!!!!
  244. B16B into a 98 EX questions...
  245. EG Hasport Mount Transmission Side Template anyone?
  246. Which Cold Air Intake do I need to get for a B20 in an EK???
  247. Whats the definition of a binding axle? (H22 Ek related)
  248. Running way to rich.
  249. CROWER STAGE 1
  250. Which JDM 1st gen B16A's had knock sensors?
