97 Ex harness for 2000 B18C1? Need a clear answer please!
I need to know what modifications to make to my 97 ex harness so that everything plugs into my 2000 B18C1 swap and I can get my 1 million mpg's instead of 2 lol. I did a lot of searching and reading and got all kinds of different answers. I just need to know what wires/sensors to add/extend and how. I would greatly appreciate any help. Thank you.
Re: 97 Ex harness for 2000 B18C1? Need a clear answer please!
Thanks man. I have the motor in the car already and running on some janky cut up rywire that came with it but need to know exactly what wires to change on the ex harness so i can do it before I put the harness in the car.
Also starting with the thermostat ground is usually your best bet at getting started. Just a tip.
everything should plug n play since the harness and the motor are both obd2
plus the vtec, vtec switch, and the knock are all wired up on your factory 97 ex harness
you will have to wire up the IABS, if you want the black box to work or just run em without the box with one of the the vacuum lines on the intake manifold
brentl21
Engine Management and Tuning
02-19-2016 07:57 AM
jdm itr integra
04-02-2011 11:56 AM
PatrickGSR94
08-13-2003 03:44 PM
