View Full Version : Hybrid / Engine Swaps
- Valve clearance on B20/VTEC
- But it wasn't leaking last time !?!?! WTF ?
- n Which motor?
- hi-cap oil pump for ZC?
- Which OE exhaust pieces to use with a B18B + 92 CX?
- hydro imtermidiate shaft on cable tranny?
- ODB1 P72 w/ Hondata on H series motor?
- Rear brake question
- rsx-s and s2000
- Need help on b16a teg swap.
- H22 into 95 4dr Integ - general maintenance question.
- i need help with my swap. i have a 91 civic and i put a SOHC D15B in.
- Electrical Load sensor?
- Clutch Cable for B18B in 91 CRX
- Steering rack swap question
- going SOHC to DOHC
- 2nd Gen B16a in my 98 LS?
- What are drag rules about breaking into 13's 12's etc...?
- goin hybrid in Eg what motor?
- I need vac hose digram for b18c1
- Looking for New Head
- Looking for a PCV valve setup for crvtec's?
- What are the best steetable cams for crv/ls vtec?
- ls/vtec question
- whats needed to drop an ITR engine into a del sol?
- Diagram of shock tower plugs...
- Just got the new swap to the track
- wiring a teg dash to a vx civic?
- Just bought B16, water in spark plug...
- wat Numbers/Letters to look for on b18b block?
- codes 14,41,54
- Help with small motor build up.
- Please help on these JDM motors.
- Teflon tape on LS/Vtec oil line?
- Running Vtec solinoid wire?
- code 22 after b18c6 install
- what kind of cams for a zc?
- GSR swap in LS
- Question about b18c and cat. converter...
- 94+ GSR tranny internals in a 92/93 case?
- b18c into crx swap almost complete.
- Intermediate shaft questions.
- need help on my swap ASAP
- axle question
- 2000 Si Tranny, 97 B20 bottom, 95 GSR head and 97 Civic CX wiring harness...What Helms to buy?
- Road Racing my H22 Civic on stock suspension....
- can a MT fit on a rota?
- aftermarket LCA
- Technical Q about erg valve on a jdm 94 h22a
- shift linkage Q
- B20 vs. H22
- Hybrid exhaust question
- best swap for my 92 dx hatch
- Injector resistor boxes?
- what stock trans mount works?
- Need help!!!, JDM B16 swap
- Machine Shops in Dallas area?
- b16 dyno runs
- need help with wiring a vx
- best mount kit for H22 in EG?
- Help!!!
- California Legal B20 swap
- am I okay????
- 2 H22 swap questions
- who's all going to MIR on the 12th
- b21?
- are the skunk2 and mugen programs similar?
- LS/VTEC oil line question
- need help with b16a first gen
- ls vtec in a coupe?
- safest big bore?
- Decking block to make perfect R/S ratio?
- how to ID 99-00 engine harness
- I want wanna these...
- New to forum....Sup !!
- what motor mounts to use when putting a d16z6 in a 90 civic dx hatchback?
- what motor in rex???
- Clutch cable????
- what should i get???
- Lookin for LS swap
- What AC bracket for EH2 B'series?
- b20/vtec rod/stroke ratio
- Planning a H22a swap
- problem with LS/VTEC hehe..
- DC JDM ITR header flange?
- Throttle Bodies???
- Will I get a CEL with a USDM ECU on a JDM B18C?
- Where can i get a b16 trans?
- what is the deal with gsr
- b16 potential in guater mile
- still won't start. code 15 faulty igniter
- Will a GSR intake manifold fit on a B20???
- Help, it is hard to put it in 3rd and 4th with out grinding gears.
- opinions on budget setup
- Do i need to buy aftermarket vavles to rev up 9k?
- Need help quick!!
- crx MODEL???
- Swap instructioins
- Car Shaking bad
- anyone had problems with crvtec?
- major oil problems in my gsr motor!!! a little advise on what to do????
- Look what I got! (First Step)
- accord tranny problem
- what clutch and flywheel to use with 89 JDM SIR b16a
- Another problem...throttle cable TOO short (JDM B16A into '94 EX Civic)
- 5th gen Civic motor in a 2nd gen CRX... Wont start...
- OBD0 to OBD1 wiring...
- EK suspension on an EF/EG
- H22a into 93' civic help out...please
- 89 CRX DX with a 95 B18B1, Wiring Problems
- B16a2 into cx HB
- whats the best engine to put in a 94 integra ls and 90 crx
- Anyone purchase from JDMhondaparts.com???
- is this setup worth the money???
- Is Hondata Stage 2 good for NA??
- b16a1? which axles
- 74hc373 chip needed when chipping ECU?
- Has anyone had to add a MAP sensor to a JDM B16?
- JDM confusion
- Who does swaps?
- What does a B18C5 block have that a B18B does not have?
- starting a swap 95' b18c1 in 94 DX?
- turbo b20??
- What is everone's favorite swap?
- CM flywheel horror stories?
- engine harness help
- Can somebody post a pic of the passenger side engine mount above the transmission
- Auto-manual parts list?
- B16A1 into EG civic, is 5th gear 4500rpm @ 75mph normal?
- B16A1 into EG civic, doesn't idle correctly
- B16b gone, now i wanna crvtec
- Header size on b16 ? ?
- Take advantage of spare D15?
- h22 axles breaking...
- Swap up and running
- B18A swap in CRX SI, what throttle cable???
- My new project hatch!!!
- EG Turbo/Hybrid
- Fluids I need for Hybriding?
- Eh ECU ?
- b20 auto
- OBD-II GSR --> 94 VX
- Where can I buy an ITR tranny
- Still having issues with restarting
- 93 Integra - B18B - B18C1 Swap
- p72 ecu plug question!
- which is better???
- 91crx-si hybrid suption question
- d16a6w/mini me
- Swapping gsr into my 99 ek. PLS HELP 3 SIMPLE ?'s
- si internals into ex
- Best Motor Mount Kit for H22 mtr,92civic
- stroker kit for b20
- Civic EX/ITR hybrid vs Z28.....
- is it possible to put turbo into a h22a civic
- ZC motor
- Shift linkage connects to Civic shifter??
- Why are b16 swaps in second gen teggies not popular?
- Post pics of you sir engines here
- Midwest guys!! Where is there a good REAL shop to car 91 teg for swap? NOT SP or speedworks
- does a ITR intake manifold fit a JDM B18C
- Who here has ordered a motor from JDMClub or knows anyone who has
- B16A swap into 92 civic si/ex
- Shift linkages cheaper then you thought
- jdm itr motor in cx hatch, what will it run?
- Second chip needed with Mugen chip?
- where can i get a OBD2-OBD1 harness?
- AC bracket
- type r swap ls/tev or turbo charge
- Restart issues with my B20
- Im ready to Are these the right parts for LS/Vtec oil line?
- Question for hybriders...
- On Japanese engines...
- Studdering...like it is not getting fuel. HELP
- What stage axle should I get????
- What axels in a b16 a rex
- D16Z6
- Which B16 is OBD1
- Reading ECU codes on a '90dx with sohc vtec swap running p28
- Axle question
- Taking the head apart on a b16a2?
- NEED HELP!!!! Tranny wont go into Gear!!!
- Halfshaft holder bolt shape?
- car wont rev past 6k
- swap for a 96 hatch
- where in the hell can we find out the truth behind the jdm b20??????????
- b18b questions
- Hybrid LS/VTEC swap b16 with b18
- has anyone swapped a si/ex cluster into an eg and it worked?
- 6th generation civic swap ????
- Cometic LS/Vtec head gasket vs. stock?
- 1st swap how hard?
- Worth port matching IM to P & P head?
- B18B/B18A alternator question
- Injen Intake for b18c1????
- No riceboys in this post please, only tuners
- hybrid intake/headers/cat/exhaust question
- HELP...trouble wiring JDM B16A into '94 Civic EX.!..knock sensor on ECU pinout??
- Proper tools for swap?
- d16a6 - d16z6 cam gears, are they the same?
- Having trouble! *cant slip car into any gear* need help ASAP !
- Having trouble with the hybrid (need help ASAP)
- Are these times normal or does my car suck?
- Hate to be the n00bie who asks but (b20 info)
- Who does mandrel bent tubing in the Bay Area???
- wierd noise
- B20 swap total cost
- 1/4 mile times for B18c1 hybrid CX hatchback inside. I'm pretty happy.
- where can i buy a usdm b18c1
- Z10 oil pump fitting for Vtec oil line?
- Does anyone have the phone number for Mark at JDMclub.com?
- Auto to Manual swap parts list?
- jdm s1 tranny... broken case
- Good muffler shop in socal?????
- b16 vs LS(b18b I think) in my crx. WHICH ONE?!?!?!
- did a search and nothing came up..
- How did you guys pass emission with your bolt ons and vafc and stuff
- 5th Gen SI Hatchbacks ! report here !!!!
- 1st mods to my new hybrid advice?
- Automatic to Manual
- Is this swap possible?
- Does anyone know anything about the B18C4
- pipes left over after b16a2-b18c5 swap
- Just finished B18c in ek
- Bouncy TACH.
- Attention Techs
- Parts on a B16B, need help...
- anyone recently completed swap in central ohio want to give me their engine
- 91 Accord LX swap???
- is anyone using neuspeed race springs with an h22 swap???
- high RPM miss?
- Rpm's
- How do I know if I have a LSD?
- type r lsd problems
- Help.......Overheating hybrid
- HT Site Enhancements, Percantage Points, and Limited Posting - PLEASE READ
- Which Clutch?
- Which Pistons/Rods fit this hybrid?
- any h22 swaps into 3rd gen teg's on here
- tps question
- B20B EG help...
- For all you H22A people
- 4 wire o2 sensor broke, can I use a 3 wire in the mean time?
- What engines fit in the '85 CRX?
- b16 different series ? ? ?
- h22 ek swap
- 6th gear!!!!
- hybrid transmission gearing
- ECU wires.... how come its so many?
