f2b FTW crx
Old Apr 18, 2011 | 10:36 PM
rexracer626's Avatar
Default f2b FTW crx
well my rex has been sitting for about a year with now work done since i worked and went to school but now i got laid off so got plenty of time to work on my car. so its going to be slow because i have to save money but here it goes!!
1991 crx si
i have already done......
all energy suspension polyurethane bushings
polyurethane rear trailing arm bushing
skunk 2 rear camber kit
spc rear toe link
Full Race traction bars
steel braided lines
extended wheel studs
what im planning to do.....
SPC front upper control arms
AIM sports cluster
s2000 start button
wire tuck
rywire brake line tuck kit
Roll Bar
Rywire engine wiring
lights wiring
walbro intank fuel pump
T1 battery disconnect
AEM PNP Engine Management
AEM EPM
AEM TWIN FIRE
AEM CDI PENCIL COIL
planning on building an all motor f2b hehe F20B
but first wiring!!!
ripped out all of my crx wiring a decided on a wiring kit for a "hot rod" its called EZ wiring a lot like Painless wiring everything is labeled every 5 inches i believe.
example of labeling on wire
Pics of my dirty a@@ engine bay
Fuse box mounted
tail lights wire routing mock up
made connectors for easy removal of wiring harness
one on the right is for the front lighting and the one on the right is rear lighting
now got to solder these together this the combination switch plug for the turn signals and headlights
mock up of the front wiring
what do you guys think of the rear shade things? keep them?
extended studs haha
still not fully mounted
that was a few months ago i havent worked on it much but i started buying stuff to get everything ready
thanks to julio@bisimoto!!
booom
also got hush 22 hydro conversion legit kit comes with everything
and just got this today
got my balance shaft eliminator kit and alternator bracket today thanks to julio@bisimoto and bisi!
also got my new softball bat
Old Apr 19, 2011 | 04:11 AM
JayWest's Avatar
Default Re: f2b FTW crx
looks good
i like that wiring kit, seems like it would save a good bit of weight
Old Apr 19, 2011 | 09:49 PM
Originally Posted by JayWest
looks good
indeed also i wanted to get rid of everything im not using so it worked out
Old May 8, 2011 | 05:12 PM
booom all honda
i picked up the beast f20b on saturday from hmotorsonline.com
so we started ripping the motor apart to put the balance shaft eliminator kit in
balance shafts out!
out and labeled
all for now
Old May 20, 2011 | 01:41 AM
so sir julio did the honors and pulled the rest of the motor apart but we found some bad news
now the bad
the pistons have been damaged i was told due to either low quality oil or not enought oil
weak so im getting some new pistons hopefully haha
Old May 20, 2011 | 05:33 AM
Rude Awakening's Avatar
Daughter not possible
shouldn't hmotors replace the motor? I wouldn't rebuild it if I have a warranty. Unless you plan to upgrade.
Old May 20, 2011 | 10:12 AM
turtleman321's Avatar
Yea I would call them. Not sure how they would handle it. But they should help you out
Old May 21, 2011 | 03:27 PM
i am upgrading the pistons now lol but yea i think i will contact hmotors and see if they can help out
Old May 21, 2011 | 04:02 PM
jr_deleon's Avatar
What pistons are planning to use? Have a custom set in mind?
Old May 21, 2011 | 09:13 PM
tagperformance's Avatar
I would have the block honed to 87mm and get some high compression wisecos and call it a day. That motor looks like it had waaaaaayyy more than 35k on it. I'd call them and send picks or tell them to give some of your money back.
Old May 23, 2011 | 10:03 PM
i think im going to do a custom piston thru Bisimoto see what he can come up with for me. what pistons did you use in your build?
yea i contacted Steve from Hmotors and i will be receiving some compensation.
Old May 24, 2011 | 07:26 AM
f20b jones's Avatar
That is a great block for a f23 crank and 87mm piston set up. Just threwing ideas out there . Its already got steal sleeves you could bore to 86mm and run k20 pisotns on a f23 crank and have a nasty all motor build . What ever you decide im sure it will turn out nicely . I have two f23 crank builds going right now . One completed and the other im starting on . If you need any info ley me know . 97mm stroke equals lots of power but if your going to auto cross it stay with the f20b crank it will work better for that good luck.
Old May 24, 2011 | 05:00 PM
jr_deleon's Avatar
I used a custom set of pistons made by CP centered around an Eagle universal rod made for a B series
Old May 29, 2011 | 05:12 PM
got some stuff this weekend
new shift linkage
and a new clutch thanks to Julio@bisimoto
Old May 29, 2011 | 05:55 PM
H2BJON's Avatar
looking good, always wondered how good the hasport shift linkage is.
Old Jul 2, 2011 | 02:03 PM
Blk_EJ1's Avatar
looks like a promising build! Cant wait to see it finished!
Old Jul 16, 2011 | 04:58 AM
low13da9's Avatar
need pistons for f20b
Old Jul 16, 2011 | 04:59 AM
low13da9's Avatar
and where can i get a headgasket
Old Jul 16, 2011 | 06:37 PM
kingofbattle909's Avatar
Hows the build going?
Old Jul 17, 2011 | 06:26 AM
you can actually get any size piston ranging from 85-87mm and if you decide to go with a 87mm piston you can use a stock h22a head gasket.
Old Sep 17, 2012 | 10:00 PM
i got updates on my signature
rexracer626
107
Sep 16, 2013 09:06 AM
rexracer626
Appearance Build Threads
Mar 26, 2010 06:01 PM
mrchris1979
Mar 5, 2006 11:09 PM
jsaye01
Feb 18, 2005 09:09 AM
range
Feb 2, 2004 11:48 AM
