View Full Version : Hybrid / Engine Swaps
- check engine lights?
- what muffler to use on an h22?
- B18c swap for a b16a2 into 94 obd1 EG?
- arp studs
- honda crank sensors interchangeable?
- bigger diameter = bigger power......???
- just finished swap, need help
- comp clutch any good? link...
- HELP! WAS I SCAMMED BY A SHOP??
- My first swap - GSR in EG
- I need help
- d16z6 head fit on y7 block?
- obd0 b16 head on gsr block
- Reputable shops for K swap - Northern Cali
- ZC Head to D15B bottom end????
- B16b 0r gSR
- im about to Al-Qaeda on my car
- B20 Turbo
- cel
- b18b swap. Please help
- 94 integra motor mounts for a b16a into an eg????
- ECU mounting question - H22 EG
- Taking full loom and ecu from donar car?
- b16a in EG info
- Need recommendations on a good place to tune in Kansas City
- best and cheapest non V-tech engine to swap?
- rsx type s engine in my 92 civic Hatch...help
- Any Turbo K20 Hybrids out there?
- alternator help
- Wiring harness question?????
- Question about OBD0-1 conversion in EDM car.
- What Engine Mount Kit to use?? H22 into GSR
- What magazine had a Honda K series 5 speed to 6 speed conversion?
- d16y7 to d16y8 mini me swap
- JDM D15B vtec swap into 96 civic ex D16y8
- b18c5 rod and crank torque specs???????? help
- Eclipse w/ K24 swap?
- OBD1 injector difference's?
- jdm h22a probably help plz
- HELP! CEL CODE 15 give me some opinions
- obd2 b16 motor in a 1994 civic coupe
- b16 swap in a da integra
- motor mount Q??
- My EuroR swap is done and running.
- few auto to manual B series swap questions
- iacv adapter plate
- Enine and transmission line ups
- B16 Mount Question - Please Help!
- Need help w/ls swap into 98 civic!!!!
- 1990 LS teg w/ B16 swap hesitating at lower RPM's!
- f22 into a civic...ECU question
- ******REALLY IMPORTANT QUESTION......
- wiring k20 swap from scratch??????????
- H22 trannys
- apex-i exhaust
- Swapping B20b into an EK...automatic?
- few plugs left b4 swap done..help. have pics.
- eg si to si-r II swap problems
- No cel and no vtec on a minime?!?!?!?!!
- B18C5 into EG2 Del Sol need lots of help, please!!!
- F20B Headgasket
- a few d16z6 questions
- 1994 DEL-SOL - D15B engine SWAP???
- H22 into GSR??
- need help, car won't start!!!
- Hooking up fan switch in K20 EG
- H23 Vtec?
- b20z into G2 integra questions
- What speedometer cable do I use for my h22a civic?
- ep3 stock shift linkage work in k20/eg swap
- Engine Swap Help in San Diego
- easy and quick vtec fix!!
- Motor Mounts??
- Wiring Herness Question...
- FINALLY its done...my h22a in my ferio
- which cams
- wire harnesses
- need help with h22 swap
- Cant check cels! (EG hatch + B18C JDM + Civic SI engine harness
- why is my b16a1 misfireing at 5000
- vtec not kicking on
- whats the difference between a d16a6 FPR and a b series FPR?
- where do these connectors go?
- A/C Pulley Question p54 clicky
- Header for B18C1/EG Civic?
- i need help with people who know compressions from experience on their built gsr blocks....
- dc2 stock shocks with skunk2 coilovers in a ek???
- Please HELP..n00b sensor question...
- RWD Del Sol lives again, picts and video
- Crx Dx to d15b vtec help
- How to tell what mounts/axles/intermediate shaft I have for h22 swap in civic EK
- Driveshaft ceased to the hub
- NEED HELP! PLEASE! H22a in civic problem
- Help me with my swap please, PICTURES INSIDE
- h22 swap in a 98 civic hb
- have chipped p72 (obd2) and want to go to stock P13 (jdm obd2) for a ek hatch w/h22a
- High Comp Ls/Vtec... Turbo possible???
- ITR w/ GSR tranny???
- Drive belt for a k24/k20
- Cams for LSVTEC
- possible to swap an obd2a engine into an obd1 car?
- Gsr swap tranny gears ??
- h22 accord hot weather problem
- EK reverse lights wiring
- 95 b18b into an EK chassis
- GS300 @JZGTE swap info needed.....
- water pump
- how to tell if iacv is working??
- h22a rpms too high??
- h22 ek swap axle problem
- Stock DC2 ITR muffler in an EG hatch?
- K20A2 BAR Legal ??
- Gemini Project: Mid engine RWD H22 Turbo Del Sol
- b18b swap
- CRV rad in a delSol?
- Type r water neck
- Confused about b16 wiring
- ls/vtech
- acura 3.0L v6 in an eg ??
- alt belt
- transmission exchange
- engine conversion
- ECU burned up. This common?
- EK engine harness removal
- Attention EK owners!!! What exhaust fits??
- b20vtec tranny/head
- k20a swap plz help
- Air Conditioning Belt - 92 GSR w/ B16
- crx ef8 with 93gsr front brakes ??
- 93 Prelude A/T Park shift stuck.
- Tranny leak. Axle issues?
- 98 civic hx-wires on distributor, colors and what they go to?
- Finished and still surging
- j's racing intake for h22 civic coupe
- Power Steering with vtec swaps into an LS
- Wiring Harness for OBD0 B16A into a 97 Civic EX?
- OB2 JDM B18b into EG Help!
- Legend 2.7 V6
- h22/eg ----->CODE 15........... keep burning distributors
- LS/VTEC Header Question? VTEC or Non-VTEC?
- motor mounts.
- Hondata ECU not cranking up VTEC
- B18C5 into EK (97 Hatch DX)
- RL brakes on an integra?
- several swap complications (B18A1 into '94 DX)
- IAV's not working on my JDM H22A intake manifold in my 92 civic
- What is the benfit of gsr?
- head question
- Axels for Cable tranny B16w/LSD in 92 civic Hatch
- how do you tell the diffrence between resistor and non resistor injectors
- swaping an obd2 jdm gsr into a 94 CX hatch swap info (wiring,mounts,etc..)
- d16y8 into 88 crx hf?
- How well does a LS/Vtec handle boost with stock parts
- Overflow container
- Question on b16a2 into ej6
- swap questions
- manifold question??
- ls vtec with auto. How?
- F20B in a 1990 Civic (gen 4)
- Purchased h22 EK hatch and need help with things under the hood.
- Going to swap my OBD2 B16 to OBD1 JDM B16. Need some advice.
- 97 JDM ITR obd2 to obd1 using p30 issues???
- ls head on b16 block?
- For the Love of GOD!! (B16A2 or B18C Automatic swap info please?)
- Need help with ecu questions on k20a2 swap into ep3
- LS/Vtec ?
- z6 in 89 dx bogs and runs lean WTF!
- Can't Get Two motor mounts out!!!
- SRS flashing when trying to pull code (?)
- just fired up the crvtec........big problem, need ideas
- What CAI for GSR, VictorX IM 5th gen coupe EG
- D15B Swap issues -please help
- head porting and cleaning
- wiring problem, crank sensor???? help please!
- H22a in a civic dx
- fried ecu??.......
- SuperCh@arged automatic?????????
- good motor mounts for b18 into an EG?
- ?? LS vtec help
- H22 into EG civic questions IABs
- B16 Header on 1.8L GSR/LS-VTEC Motor? Doesn't Fit??
- 98 eK hatch rear wheel drive conversion
- info on k20a engine swap
- Which motor to get?
- B18c1 rods same as b16 rods
- Car starts but dies
- b18b into 1990 civic, no fuel/ no fire, need help
- H22 crx front crossmember??
- h22/civic question...
- JDM P30 and P72?
- possible mods for 95' teg
- Just bought a h22 swapped civic need help with a few things
- Energy Suspension Motor Mount Bushings
- b18 crank question
- What is the purpose of the knock sensor?
- JDM B16a Gen2 Axle driver passenger which is which?
- I NEED A PIC OF THE DIRECTIONS FOR obd0-obd1 CONVERSION HARNESS!!!!!!!!!!!!!
- 94 Jdm distributor connecter to obd1 connecters?
- Can It Be Done? If So, It Will...
- crx type r swap problems
- 1990 Integra LS with b16a1, need wiring diagrams.
- Wierd p72 problem ..Vtec comes in at 5600 ???
- how high can my jdm b16a2 safely rev
- CRVtec question.... please help..
- Honda heads: why won't this work??
- b16a CRX Map sensor
- ES motor mount inserts for EK w/gsr swap...I searched!!!
- JDM ITR engine harness on EUro B16a2 chassie harness with chipped P30 ECU?
- JDM Customs....if you thought about buying from them heres my story
- h22 radiator hose help
- Swapping Emissions
- ac help
- JDM Gen 2 Knock and Temp sensor wiring!
- Help needed....ls\vtec
- ?!!!Help with decision on clutch for jdm b16a!!!?
- K series into a 1G CRX?
- b20...in an itr?...not a performance question
- b16b
- b18b swap help
- Fuel Delivery Problem
- What Kinda Power am I Making? What E/T?
- B18C5 Engine swap
- EG JDM H22 not starting - help plz
- Where can i buy Rhd clips ?????
- Anyone order a swap from SOHFAST.com recently?
- h22a swap/2000 civic ex
- need some wireing help!
- a little advice?
- b16 price
- JDM P73 ECU Pin outs? *Importiant*
- 4th Gen prelude and 5th Gen prelude
- K24 Swap w/RSX tranny pics, Using Avid Racing mounts.
- name these sensors
- Cheapest place to get a K-series swap?
- AC in 93 si hatch with b16a
- Help 99 gsr into a 93 cx
- few questions about my b20vtec crx swap before i throw it in
- good place in canada to buy honda motor (specifically b18b)
- P06 convert to P28???
- b18a vs. b18b
- h.m.o is out of 98 spec itr motors, should i get 96-97 spec?
- LS/VTEC Head Bolts -- GSR or B16?
- Have you ever heard of this?????
- swapping a obd1 GSR into a 90-91 CRX
- H22 head on H23 block?
- H22 crx injector question.
- JDM B18c with JDM engine harness in to a Civic 92 with P30 ecu Uberdata
- ((( Swaping Blocks from OBD1 to 2)))
- EG H22 - would i need injector resistor box?
- ? on nonvtec head onto vtec block
