View Full Version : Hybrid / Engine Swaps
- What size injectors?
- WIRING: b16a2 in ek hatch
- Shift Linkage for 93 DelSol Si to LS ?
- (The Curtain Opens...)
- wanted: 1/4 mile times for b20 in 6th gen civic
- NEED HELP: Need info on a B16 OBD1 into a EK??? PLEASE HELP ME!!!
- About my xrx
- GOT QUESTION!!!! need help
- Some EF ???
- Axel combination for H22 Civic?
- Anybody using a wideband with obd0 to obd1 conversion
- What to check when engine comes in.
- b series cam diffrences
- bad idle HELP
- Which Rear Trans Mount Bracket?
- please help: rear tranny/mount bracket issues with clutch install????????
- Prelude swap into 97 coupe
- easy question about IAC
- Can a Type-R gearbox fit onto B20B block?
- stand alone
- I forgot who makes OBD harness converters??
- complete gsr => 94 dx hatch interior swap
- eg civic coupes or hatch with h22a websites??
- b18c5 in eg--->running weak??
- whats this swap gonna take...
- What do I need for a d16z6 swap?
- CRX wiring
- next mod for b20b.. Skunk2?
- arrghh... IAB help please....
- Having serious problems with HCP mounkit...!! h22/eg's check in..
- B-series injectors for D-series?
- whoa can line bore??
- h22a in 99 civic ex?
- B20 Injectors
- B20 A/C bracket
- quickest 0-60 time
- Anyone from ny or LI?
- hybrid update...somewhat long.
- Hondamotorsonline and engine mileage
- Older engine swapped into a new model car?? Legal??
- Where can I get an OBD1 JDM H22 Dist Cap and rotor set???
- Tranny Prices for B20
- F22 or F23 swap into a civic ??
- OBD0 to OBDI conv. needed to drop b18c into a CRX?
- what is the best AFFORDABLE engine swap
- Manual steering rack for H22 swap
- B21A1 Prelude motor swap into 91 CRX...........
- automatic dx 94 to with manual ex 95 motor mounts?
- Jdm Obd 0 B16a in 93 hatch
- What do i need to do to switch my 93 gsr motor into a 96 civic hatch????
- One more question b4 swap is done !!!!!!!!
- Frankenstien motor
- Setup Questions
- ATTN people who know stuff about the ZC tranny
- Free Beer!!!!
- Fuel pump
- AEM Cold Air intake for sale
- Wiring diagrams..Whatever you need
- piston to valve clearance on a b20/vtec with stock pistons
- Please help me with Smog
- LS in 95 CX HB, building and swapping
- knock sensor
- will Y1 LSD drop in YS1 trans?
- radiator?
- transmission swap
- The End All for out of bay Crank Bolt problems.
- d16y8 - 97 itr question
- Check Engine Code 45
- Retail Price for JDM ITR BLOCK???
- b18b wiring swap, hondata
- Difference between B20 Head and B18 head non-Vtec besides the intake manifold.
- Anyone know about Osaka JDM Motors???
- evap purge solenoid ?
- Can someone tell me what these wire are? obd1 & obd2 gsr
- H22 LSD, who the hell has one
- just broke my B20VTEC...
- B18A mounts same as B18B?
- Auto to Manual ex swap
- My Car
- I have LS Turbo but want to go B20 Turbo
- 96-98 ex wiring harness ? for swap pros
- what are the mods need for JDM into USDM
- 99 SI mounts w. Energy suspension inserts all 5 mounts $200 shipped.
- Which head to use on B20/Vtec?
- B18 HB
- i need som help
- whats more complicated?
- b16a swap done. Started then quit....
- Best place and price for a JDM ITR header??
- Alt belt for H22a w/o A/C....And yes I did search!
- OBD-2 conversion?
- Need starter for B16A2 tranny..... which ones??????
- need help finding a tranny for a swap in a 01 v6 accord
- 4 wire o2 conversion for a 93 cx for a jdm b16a motor
- b16a2 in eg wiring problems
- Short shifter noise and rattle.
- Swap finished now Problems
- 85k mile D16Z6 for $600 worth it?
- What intermediate shaft is this? PICS
- Wiring Dilema ! please help!
- ebay short shifters any good or are they junk?
- jdm b16a2 swap startup questions...
- Swapping sohc for B16A2-Gauges?
- newer motor in 91hb dx?
- Can someone please answer my damn question ?
- OBD2 engine in OBD1 car??
- LS VTEC Prelude? Worth the effort?
- port matched d16z6 manifold w/ 97 LS TB, work w/ p30 tb ?
- b20 with an afc
- What it takes to do H22 in a 98 hatch???
- Question about using GSR crank and rods in B20b block.
- Anyone ever heard of Osakajdmmotors.com?
- What tranny???
- How much $$ to resleeve/bore a b18b? What about cheap oversize pistons?
- Wiring harness question
- bay area folks with BAR stickers?
- type r oil pump on b20??
- Help with b16 problem......
- clutch reservoir
- knock sensor
- ** GSR ehxaust manifold on LS REX???? HELP!!! **
- Swapping a B-series motor in an 83 Civic
- Swap help, d16z6 into a 94 DX Coupe
- H22 Vacuum hose routing....help!
- help on swap kinda lost
- B18C5 into a 93 integra
- H22a Distributor
- Needed: Stock H22a lower exhaust manifold pipe ASAP!
- ***Whats needed for power steering when doing a swap?***
- I live 10 minutes from them
- rsx base and type S motor into 7thgen civic.
- Found a EK shell...what do you guys think?? (Warning: large pics)
- Found a cheap motor supply company
- how reliable are the jdm engine swaps compared to the usdm engine swaps?
- B16A2 tranny: S21, Y21?
- Racing Port work Vs. Extrude Honing
- B17 cams??
- B16a distributor problem, which one?!!?!
- one pic...h22 in my dx...wo hoo
- b16 CRX,, VTEC not working,,where is the vehicle speed sensor?
- What radiator would be best
- someone should do a h22a-r into a 4ws prelude..that would be awesome
- How's this for a horror story, please read *LONG*
- H22 into 96 DX Coupe???
- doing jdm b16a2 swap...... got a question. (evap related).....
- h22????
- need b series listing
- Got My B18C1 Swap Today
- b18b with itr oil pump / t-belt cover question
- what 3" cai will fit a b16 eg?
- just got a 91 crx hf
- b161 tranny ?
- Integra Dash in 5G Civic
- hasport hydro-cable conversion kit. q for those that have done it...
- Hybrid H22a Accord For Sale...
- Inside H22 from HMO (lots of pics)...
- a few pre-swap questions
- no oil ?? please help
- f22a or h22a into an EF chassis.
- more b16 ?s
- anyone from ohio. where the dynos at?
- b16a to b20 parts interchangeablitity
- Can ya help a brotha out?
- ITR block stamp question
- 1st Gen B16a trans input shaft same as all B-series trannies?
- H22 Motor Mount Brackets and other swap questions
- H22 EK-- stupid coolant hose question
- best swap for a ls...
- p73 to a p72
- Stock b20 Head Gasket on 85mm bore LS/VTEC?
- Code 78??? WTF!?
- Bseries in a 94 VX
- need help click link....
- Which do I have GSR or Ls Tranny?
- Where is that Cr-Vtec site at?
- Need info ASAP, B18C5 IAC valve wiring
- good place to buy a tranny?
- cable conversion for hydro car?
- need help swaping a zc in a 1979 accord
- b16 with an LS trans
- H22 build-up N/A and Nitrous!
- Code 9 after obd1 conversion...
- B18C1 Tranny Internals in B16A Tranny Housing?
- 01 US ITR intake cam
- Need a motor for a 99 hatch
- does the jdm itr engine use a knock sensor?
- b16a running rich how can i change it
- help!!95 gsr throttle body and iac question???
- Swap time!!! B18B>>>98 hatch
- please help, or i'm gonna go nuts!!!
- H22
- anyone have a h22 w/lsd
- non-obd b16a into 1996 integra?? how can it be done?
- pre- obd distributor questions..
- Nitrous on H22's?
- ls/vtec kits...interested?
- h22 help please?
- ls/vtec conversion-need shopping list-i have many questions!!
- what cap, plugs wire for a b16a1?
- H22 ECU help. P13 4W..is this an auto ECU?
- ls/vtec questions?
- what can I expect?
- is this part same on LS
- are ls/vtec emissiond\s friendly
- H22 *NEWBIE* need H22 guru advise! (long)
- keeping stock EK A/C with b-series swap
- Do it myself? How hard can it be...
- JDM P73 ECU pinouts?
- how much does a vtec solenoid cost?
- Best way to wire my JDM B18C5 in to my 95 Civic SI hatch?
- intermediate shaft?
- LSD Cable B series tranny?
- Can someone tell me where these plugs go?
- cable to hydro for a 92 civic
- Y80 on a B16?any experiences?
- 96+LS to 92DX
- cai for gsr swap?
- vacum hoses on skunk 2 intake man
- B16a is in.Need a few misc. questions answered.
- Hello all I am back!!
- Out of curiosity
- H22 timing belt Q:
- where can i buy a header with 2 o2 bungs on it? or where can i get the bungs from?
- needed b20 info.....
- another mount ?
- obd0 to obd2 what do i need
- GSR 4-door Exhaust
- Where to get a swap in MA
- b20b and h22a long block specs?
- ZC swap code 9 (cyl sens) so close, yet.....
- will the jdm wiring harness work for a 96+ civic?
- done with it
- Motor swap
- h22a swap- external coil vs. internal coil
- integra to civic suspension question
- vtec working properly?
- Engine swap HELP.....
- GSR into an EG engine mount and bracket part number request
- 2000 CIVIC EX sedan, need some advise.
- my block is fubar!
- another dumb mount ?
- which distributor to use?
- need a LS swap
- re pinning harness
- new jdm swap burning antifreeze
- mount question for 96 civic
- B16a2 in 90Teg??? HELP!
- h22 in EG, with turbo...
- fuel question on b16a
- H22 ???
