PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. obd0 dizzy on lsvtec?
  2. my lsvtec
  3. Will A K20 fit in a 92 civic?
  4. H22A Powered 92 Accord
  5. I have a flooded 91 integra! Its flooded
  6. bogging problems
  7. axle issue
  8. HELP!!! Alternator problems
  9. need help in building custom zc hybrid hyrdo tranny ATTN: Mista Bone
  10. What wiring harness and ECU?
  11. v-tec conversion on obd2a to obd1 p28
  12. can a 0b1 b16 distributor fit on a 0b1 LS?
  13. what is everything i need for the swap
  14. viper+integra=what the?
  15. Question about VIN and serial number for motors...
  16. raw gas smell out of exaust need to know asap
  17. 1978 Honda Accord CVCC w/ B series swap
  18. 2000 Civic B16 Wiring Harness Problem! HELP!!!!
  19. Axle Options
  20. LS VTEC AUTO ????POSSIBLE??
  21. del-sol ecu???????????
  22. delsol, turbo, b18a starts then stops??????????????
  23. Right steering h22a into Left steering civic
  24. Interbreeding Brands
  25. are d and b - series tranny bolts interchangeable?
  26. obd1 sohc non vtec distributor on a obd1 dohc vtec engine
  27. i want to swap a jdm gsr hows tht
  28. Motor problem! i need help asap!!!!!!!!!!!!
  29. gsr motor. si ecu?
  30. Longshot: 99 Passport 3.5 into 94 Acura SLX
  31. ls/vtec or b16?
  32. H22 manual tensioner conversion
  33. Will DA integra rear brakes fit on an EK civic coupe (DX)
  34. Richeeee's hatchback visit's the emmisions center
  35. civic with gsr swap but no fuel prime?
  36. h22 intake question
  37. Trying to bypass the imobilizer in a K20 to 98 civic coupe swap
  38. quick ?
  39. parts from rsx into 96-00 civic
  40. What mounts would you use to swap ls vtec in a del sol???
  41. Whic CF hood to use for h22 into ED9 CRX?
  42. torque engine bolts down to spec or just hit them with the impact gun
  43. Did a swap and unsure where some things go
  44. Going VTEC with my b20... which head produces more power?
  45. which wiring harness to use???
  46. megan header, omni test pipe review!!
  47. HELP! What ECU for a '99 B18B1 ???
  48. sway bar question typeR control arms
  49. Check "codes" on Civic/H22 swap doesnt work??
  50. Which chassis/engine harness should I use? H22A4>>1996 LS
  51. Hey what center caps are these on the rotas???
  52. search is down. need to know LS/vtec wiring info asap!
  53. B16a mounting Q?
  54. 2 questions.......
  55. 92' H22A Civic Springs/Coilovers Suggestions
  56. what year b16
  57. 92' Civic H22A Hatchback; Supercharger options?
  58. parts list need for rear disc change
  59. I WANT TO go K-series
  60. EF with B18a1 rubbing crank pulley....help please?
  61. Can anyone help me out with mounts?
  62. need assistant...... k 20 A for honda city vtec (fit aria vtec)
  63. B16 with stock d15 tranny cable/hydro?????
  64. How important is the purge control solenoid?
  65. Are all B-Series Half shafts the same?
  66. b16 swap
  67. front brake upgrade on EK
  68. turbo manifold in a b16 crx
  69. K20 Overall height Question
  70. b16 tranny
  71. My Hybrid Build F22a1 bottom end H23a1 head!
  72. Need AC belt Help!!
  73. H22 crank sensor code cant get rid of
  74. Bay Area
  75. gsr throttle cable 92 hatch
  76. 1st gen B16a in a 92 2dr vx question??????
  77. obd2 HX ENGINE/ECU into 98 civic dx oxygen sensor question. searched........
  78. B16A...to...B18C
  79. ROCKET'S "CLUTCH 101" Article Rehosted
  80. will b16 headstuds fit a b18?
  81. B18C swap VAFC rewiring
  82. k20a2 k20a Swap into DC's with HASports- Verified Oil Pan Clearance?
  83. distributor help
  84. get code 4 only on obd2 ecu
  85. Where to tap into ECU/wire to install a monster tach
  86. putting 94+ b-series gears in a 92-93 tranny, is it possible?
  87. Any info on Gen2 civic projects?
  88. 01 teg power steering rack vs stock 93si power steering rack
  89. K20 help, not sure if this belongs here....
  90. Will Type R ECU work with B16a2? ( searched)
  91. B20 swap into an EK...can I keep the stock radiator?
  92. ???????? K20 Or H22 Into my EK ????????
  93. DROPPING JDM ITR CAMS INTO US B16A2 HEAD
  94. Car broken :( only 2 weeks on road... Integra/H22A
  95. H22A4 into '98 CL - Runs, but has some problems
  96. How to tell a unmarked tranny? Like how many teeth what gears to count?
  97. Just spun a brearing on my JDM H22 DOHC VTEC [blue top]
  98. OBD2 Motor, want to convert it to OBD1, for an OBD1 car. How?
  99. over-heating
  100. Motor swap time.....
  101. After gathering info, my future setup is:
  102. Help! I did a H22A swap into my EG and now the speedo isnt working!
  103. what is need for an ls swap into a 90 hatch
  104. OBD differences: how do you tell?
  105. H22A into 92' Hatch, CEL issue.
  106. my mind is split between two different swaps...help me!
  107. cars ticking and won't start
  108. F22 in Civic.
  109. Getting Ready For Swap, Just A Few Questions...
  110. Mystery 4th connector on passenger shock tower with b18c5->EG swap
  111. Honda Civic Cx H/b
  112. What mounts for h22 with skunk2 intake manifol into eg Hasport, HCP, or other?
  113. b18b1 into 97ek... problems
  114. LS/Vtec Compression
  115. plz help b20vtec issue
  116. H22A (JDM) ECU Chipping Options?
  117. HELP juss did a swap.having idle or some shit problems and vtec aint kickin it
  118. rear disc
  119. obd2 to obd1 distributor wiring help
  120. Integra/ civic wagon... what swaps???
  121. H22 swap into 91 prelude SI
  122. obd1 gsr motor into obd2 gsr - can i smog it?
  123. Please help done over 20 pages of searchs and stuck!!!
  124. which halfshaft
  125. H22 Shifter gets harder to shift???
  126. SRI= Better top end vs. CAI?
  127. k20a2 into a 1996 civic
  128. i like to bay a b16 and i need soom info!!!
  129. b series into 96 ek
  130. Gsr swap cold idle problem
  131. Map Sensor Voltages
  132. best place to order k series motor
  133. Is this K24 longblock worth $1000?
  134. JDM H23A VTEC , better fit with T2T4 in accord..?
  135. h22 eg fuel filter problem
  136. LS swap into 99 EK Question
  137. help me swap
  138. HELP WITH B16 SWAP!
  139. mounts for ls swap into an std hatch
  140. Help Newbie to honda.....H23 into 96 Civic Ex....
  141. New here with questions about b20 swap into 91 civic.
  142. B18/B16 starter question
  143. Emission Problems any suggestions?
  144. Do H Braces Fit K Swapped Cars?
  145. B20 vtec build
  146. where to get swap done?
  147. gsr piston in b18a block???
  148. b18b1 into 92 civic vx..
  149. running problems
  150. dohc zc rods work in a z6 without modification?
  151. Kuwait, Euro CTR, and other vTEcHs
  152. b18a1 OBD-0 in a DC-2
  153. Full swap or not, I'm just about ready to pull the trigger.
  154. Just swapped a B20 into my 96 Ek hatch. Which Ecu should I use?
  155. will a D15 bolt up to a Z6 tranny?
  156. How much oil does a B20 hold?
  157. colors of obd1 map and tps wires.
  158. alxe binding
  159. B16 into 2G Civic swap?!?!?!
  160. Anyone with JRSC on 6th gen H22A accord? Will it fit?
  161. wiring question
  162. JDM H22 + JDM 4X114 TypeR Brakes = what axles?
  163. PIC REQUEST: swapped H22, oilpan clearance?
  164. ls vtec with auto tranny worth my time?
  165. Help,h22 swap into 93 cx#1 not igniting
  166. need help on obd0 to obd1 diagram
  167. RSX radiator in a k20a Eg6 95 civic hatch
  168. Car is acting up, I need help PLEASE. will bog down with more throttle... Civic LS swap
  169. EK NON-VTEC TO VTEC SWAP
  170. swap a D15 for a F22A1????
  171. 95jdm j22 crank into h22a4 block?
  172. V-AFC rewiring???
  173. 96-00 B18b1 swap Radiator Hoses?
  174. h22 swap question
  175. Ls/vtec Into EK. Some ????'s
  176. engine bogging, starting, and hesitation problems b16a
  177. occasional knock/click?? funny idle?? H22a4 EG
  178. budget swap advice.
  179. ls block with internals
  180. Longer geared cable tranny?
  181. Hp racing h22 header
  182. clutch pedals?
  183. ls vtec slow vtec ingagement
  184. K series Help??
  185. lsvtec vtec not engaging no check engine light HELP
  186. Please help me! : Which factory mount for this swap?
  187. New Project: 97 Civic Coupe - F23 Block/H23 Head Turbo (56K say no)...
  188. 93 Hatch DX swapped - what intake?
  189. b18c1 lsd tranny? whaaat?
  190. need help on axles
  191. Few questions for EG b16a conversion.
  192. need help already searched no answer found
  193. h22 in eg engine rocking under deaccelration and low rpm driving
  194. obdIIa pinouts for h22 in ek
  195. B18B idle low idle problem
  196. Connecting my A/C in my LSVTEC Swap
  197. B-series Tranny Find
  198. EK with integra front subframe which mounts for h22 swap?
  199. obd2 gsr into obd 1 crx. need "how to" info
  200. Im having a real hard time with my swap please help me!!!!
  201. turbo ls or turbo ls/vtec?
  202. NJ MVC Inspection and hybrid Honda
  203. 4-Wire to 5-Wire O2 Sensor (OBD1 VX ECU Pinouts?)...
  204. Swap problems.. Please help
  205. anyone running a hytech k20a ek/eg header? clearance question
  206. Obd-2 problem
  207. k20a2 into dc/eg/ek chassis pass cali emissions?
  208. H22a Eg civic power steering probs
  209. crx coverted to obd 1 with code 20
  210. h22 swap in ek hatch
  211. Mini me timing belt question
  212. a couple questions
  213. smoke after 10 mins of warm up
  214. CarbonFiber H22 Manifold update
  215. timing belt for mini me swap?
  216. does hybrid means
  217. dx ecu in a b20 motor
  218. Anyone have any feed back the H2B adapter setup?
  219. which obd1 ecu pin is for the CEL?
  220. D16 2 B18
  221. B-series into EK --> Which Header is a direct fit?
  222. mini me:d16a6 with d16y8
  223. How do you keep your Power Steering?
  224. B16A2 into 2000 civic.
  225. Head/cam questions for ZC block......
  226. K series ECU(s) & Hondata
  227. OBD0 motor to run OBD1 type conversion....
  228. viper integra??!!.........
  229. ek swap b18c What heater hose to get?
  230. D16 2 B18
  231. CRX HEATER CONTROL CONVERSION
  232. H22 EG w/ AC? (Tried to search)
  233. i need ur 2 cents
  234. Help: B20B rev limit
  235. inner pass side cv for a b16a
  236. automatic axles in a manual gsr tranny
  237. Help...Transmission questions with B18
  238. h22a4 in eg coupe.
  239. HCP Front Crossmember??
  240. JDM D15 into 98 Civic Si (Canadian Spec)
  241. k Series
  242. idle probs
  243. shift linkage???
  244. LS/VTEC help. please help
  245. Searched: Will B16 ExMani fit on an LS/VTEC?
  246. IM IN NYand in PA need a k !
  247. typr r problem
  248. EK K20 NEW DAILY
  249. SI tranny conversion...
  250. 02 senser extention where to get one?
