PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. h2b swap
  2. 1990 Honda CRX Si Restoration/Time Attack Build
  3. b18c timing issue help
  4. Car was originally automatic but now has type r motor - question on how engine sits
  5. how to swap b20b from my ek ?
  6. Epiphany or Lunacy?
  7. K24z7 in em2 lots of progress crank sensor problems
  8. Process of finding a B16B type R motor.
  9. B18C ECU PROBLEM
  10. h2b evo kit question
  11. EK - J SWAP - 36mm hubs - WHAT AXLES?
  12. B20Vtec Sleeve Question
  13. Tranny type?
  14. D15B7 With Vtec?
  15. No idea what to do with my teg
  16. Idea for auto X engine
  17. just need some advice
  18. LS AUTO INTO 97 CIVIC HATCH
  19. Need expert advice, please!
  20. not sure why no one can answer this, help with my db2 gsr!
  21. H Swap in EG Cut Floor Issue - Opinions Needed
  22. AC deleted ?
  23. JDM b16a o2 sensor question
  24. compression problem
  25. Need Some Advice!
  26. h22 in a 94 civic with s300. speedo and vtec issue
  27. Auto to manual NO start!!!
  28. PLM. Tri-y or h2b header?
  29. b18c5 no cel no vtec HELP!
  30. Karr alarm goes off in heat
  31. F23A1 5 speed swap into 1995 civic (warning alot of pics)
  32. Comp clutch fitment??
  33. GSR Swap into 00 ex Problems
  34. B18c vacuum diagram needed
  35. Weird CEL on H22 EG
  36. Please Help! 98 HX swap
  37. Need help with h23a swap on my eg
  38. v6 swap noob answers and opinions
  39. Need Help 99 EJ6 with jdm B16A-pictures!!
  40. injectors question
  41. b20 build help
  42. d16y8 to d16y7 vtec question
  43. k24z3 / k20z4 rsp-2 head
  44. Ek 2000 euro r swap try pull out cel code
  45. B17a1 Build Help
  46. B18B1 from Auto LS in CX EG Hatch with Manual Trans.... the things no one told you.
  47. Pass side tower plug question obd2 ls auto into 92 cx hatch manual
  48. Please help f20b swap
  49. 94 eg hatch fuel issue - h22a turbo engine
  50. 6th Gen Accord JDM H22A Swap questions.
  51. B20 swap into eg (how to)
  52. 2000 honda ex upgrades
  53. Perfection from the Dirty South: TracerAcer's 2.2L EJ8 Build
  54. JDM B18B Compression Numbers
  55. K swap into DC2
  56. B20b swapped ek sputters.
  57. Ls vtec question
  58. Obd0 Block With obd2a GSR head, How to do this???
  59. JDM B20B into 98 CRV
  60. 01 b20z2 into 99 Civic CX
  61. Fluctuating idle
  62. Electric/Hybrid conversion
  63. GSR to LS/VTEC Questions
  64. 95 integra b16a2 swap
  65. Help! What engine should I swap into my 1997 Honda Civic DX Hatchback?
  66. 1991 Honda Civic SI, future engine swap
  67. Cheap throttle for type-r intake manifold?
  68. JDM OBD1 B16A in 00 Civic EX - trying to get rid of CEL for ckp
  69. f20b Clutch
  70. What do I need for a b16a2 swap into my 99 ex
  71. Need to know ITR throttle cable length
  72. Re-install AC
  73. ARP rod bolt install b18a
  74. 94 eg hatch h22 turbo issue
  75. Need help car wont start now after swap. thanks
  76. b16a2 no spark/running rough
  77. obd2 b18b into obd1 (b18a1) 92 integra
  78. what would i need for a H swap!
  79. re-swapping efficiency
  80. f20b civic eg or keep my dc2?
  81. Lsvtec feed line
  82. B16A wiring identification and help
  83. Vtec solenoid?
  84. 94 civic si Ls swap limp mode
  85. Looking for Honda Prelude Engine Wire Harness
  86. NEED HELP.DOING H22 SWAP IN EG
  87. cel code p0122&p0501
  88. H22a bogging out :(
  89. my H2B EJ1 build thread
  90. eg/eh gsr mounts?
  91. Help Car won't stay on?
  92. H22A ek coolant issue !!!
  93. r18z1 2012 civic lx CAI and Coilovers
  94. help h22a ek hatch axel problems
  95. K2H manifold fitment issue
  96. B20 VTEC FRESH BUILD PLEASE HELP
  97. ej1 swap tranny gears upside down!!!!!!!
  98. 95 civic ex EJ1 transmission gears upside down!!!!
  99. Plug-In and Hybrid performance
  100. Engine Dilemma f23a1 block f22b2 head?
  101. 1993 Del Sol S - Engine swap questions
  102. Radiator Size for J32A2, will civic work?
  103. H22 ek code 9 and jumpy tach
  104. LS SWAP FOR 98 CIVIC LX
  105. bogging and clicking issue???
  106. D2B EK swap. ADVICE NEEDED...
  107. K24a1 Build
  108. b18c bogging at low rpm.. fine on wot
  109. H22 swap in 2000 Honda Civic EX ek
  110. H22A/H23 FRM, which pistons & rings, cams
  111. need some help with this qsd h2b marking issues :(
  112. Engine/ Trans swap 93 Del Sol
  113. H22 swap into EG rear T bracket
  114. Axle swap
  115. richewerks 5150
  116. Gsr to B20 swap quirks and FAQ
  117. H22 accord CEL
  118. B20b over heating problems
  119. Weid MAP issue
  120. Reliable & "Inexpensive" 300hp??
  121. '98 DX hatch complete engine swap opinions.
  122. 98, dx hatch swap
  123. How to identify a J32A2 engine?
  124. d16a6 d16y8 mini me swap NEED HELP PLEASE
  125. K24 rebuilt
  126. EK9 OEM B series radiator...
  127. H22 axle issue
  128. B20VTEC YCP PISTON P2V CLEARANCE PLEASE HELP
  129. b18c5 in 96 integra HELP!
  130. Engine swap...h22 Vtec
  131. B18B1 Swap Help!
  132. H22 Motor to a B18 Transmission on a integra.
  133. OBD1 4th gen prelude Canadian G22
  134. Unknown wiring harness plug
  135. JDM B18C5 TYPE R Swap into Integra Question
  136. B20b into 99 civ swap
  137. Engine swap , Help needed...
  138. h2b swap refuses to starts up for furst time
  139. 91 hb auto X build
  140. 99 ls ecu into 98 civic
  141. Question Regarding kazino42 k series wiring
  142. EG H2B Any way to have a/c?
  143. Engine swap?
  144. B20 into EK mount question
  145. gsr swap wont start pls help!!!
  146. lsvtec questions AGAIN
  147. h23 vtec h2b qsd????
  148. what to do with D16A6 block and diff head
  149. bogging under load. h2b timing?
  150. Which axles to use on a H22a4 swap manual trans.?
  151. F20B EK 3 Point Strut Clearance Help
  152. b16 head parts help
  153. H to B series axles
  154. H22A4 swap into 97 Accord LX
  155. Mini-me Crank Pulley Questions
  156. What swap to do!!!
  157. Help guys!! D16y7
  158. OBDII GSR swap help
  159. OBD2b to OBD2a 00 civic ex B18cr dizzy wiring question
  160. What ecu to run?
  161. Help!!! Difficult swap!
  162. evap canister, is it a MUST?
  163. 98 honda accord
  164. need your help again techs
  165. H23 block with scored walls - Help.
  166. b20 water leak?
  167. EK B18C-R swap 36mm axle problem
  168. noob K24/k20 Q's
  169. I need help on my first car first swap
  170. 2001 honda accord engine swap
  171. GSR SWAP ECU HELP
  172. B18C Directions Please
  173. JDM 99 Civic - LS swap questions
  174. Ls vtec set up?
  175. Got no vtec and rev limit at 7k...b18c1
  176. What kind of motor do i have?
  177. B18c1 trouble after rewire
  178. Can i use transmission bolts from a d16 on an ls tranny?
  179. Front tie bar
  180. b18c5 bogging
  181. b18c1 into 99 civic automatic
  182. Gsr in a eg coupe. Starts and idles but won't rev up.
  183. K24 swap into EG. Wiring harness question
  184. quick question about side bracket
  185. b20b weird idle
  186. obd2a dizzy on obd1 harness!!!!!
  187. LS head on B16 Block?
  188. Have some questions...: Swapping b18b in for d16y7 with an automatic transmission.
  189. thread size?
  190. Default 90-93 integra engine bay misc wires and abs mounting questions
  191. 1987 accord f22 swap help!
  192. obd2 b20 into eg
  193. Strange idle issue on turbocharged lsvtec
  194. EG swapped h22
  195. Anyone got a map file for a J32?
  196. Next build?
  197. b18c1 into a 2002 civic ex?
  198. 6th Gen - ECU - Security issues / programming
  199. JDM b18c GSR swap into 94-95 or 96-97 civic
  200. Avid racing K mounts question
  201. ecu info
  202. Problem with k20 swap. Fuel pressure drops
  203. Swap question
  204. H22 in EK low idle knocking
  205. Headgasket problem or normal?
  206. 2000 SI with H22a Swap having problems
  207. D16Z6 Head and Throttle Body Swap
  208. D16Y7 Transmission Question (78 civic swap)
  209. B18c r not hitting vtec strangle cel
  210. h22a swap woes, idle/ acceleration issues on p13 ecu
  211. obd2 b18c1 in obd1 hatch idle/setup issues
  212. B20 rod bearings
  213. JDM D15B Into a 98 D16Y7 Honda Civic LX???
  214. B16/B18 specs.......
  215. H22A swap woes...
  216. New to this and in need of help
  217. Engine swap in Georgia or Jacksonville?
  218. Bought a 96 'Lude Si and 96 Civic DX Coupe... swap maybe?
  219. Looking for custom harness work
  220. online motor source
  221. Bubble Swap
  222. H22/civic:Prelude Int. Shaft + 94-01 DC axle
  223. Question for you b20 vtec guys
  224. EG/DC Subframe for K Swap in EK Civic
  225. Fresh built lsv shavings!
  226. Spoon & Hasport Mounts EK3 B16a
  227. 1997 swap
  228. Lsvtec crank timing belt drive help
  229. B16a2 into 96 ej8 questions
  230. Need help on sensor wiring
  231. quick GSR swap question
  232. alternator pulley interchangeability
  233. H22 powered 97 Civic LX sedan
  234. B20 AC aluminum bracket with PS
  235. H22/H23 Frank swap help!!!!!
  236. Hesitation/misfire in B20b between 2k and 3k rpm
  237. d15b with head d15z1 or d15b with head d15b7
  238. b20 swap misfire
  239. Vtec swap questions!!
  240. 95 del sol 1.5 non vtec to a 95 JDM GSR vtec AUTO
  241. Del Sol f23 swap
  242. Loud vtec but loss power ?? Please help :(
  243. H22A1 eg6 won't start! NEED HELP/ADVICE!
  244. 99 honda accord wireing harness need help asap
  245. H22 EG Engine placement test
  246. LS Swap into EG ran...not now
  247. integra rear transmission bracket in 96 civic ?
  248. First Swap Where to Start?
  249. help with b20/b17 vtec
  250. 99 accord auto to manuel swap wiring harness help
