View Full Version : Hybrid / Engine Swaps
- DSM PEOPLE ATTENTION NEED HELP IF U EXSIST
- Intake manifold on Ls/vtec
- gsr cams, how to tell
- Hybrid ZC/SI Tranny - Who has one ? Feedback needed !
- GOOD Book for this section
- OK ONE MORE TIME HAS ANYONE EVER DONE A H22 SWAP IN 90-93 INTEGRA
- heater hose question (searched already)
- weird weird problem... need help
- What size bolt for HCP front crossmember?
- B18b in a 2000 Si
- Just bought a b16a2 for my 98 ek need help
- B16a SirII motor bolted to a m24a auto transmission...
- Help in LA????
- Del sol engine swap?
- del sol rear bracket
- inline four ecu
- Help!!!!!!!!
- mid-engined eg hatch? (similar to renault 5 turbo)
- JDM GSR in JDM EK D15B.
- B16A Into 92 Civic SI Problems
- H22 Swap in 5th gen accord, Transmisson help
- Axle lenght / spline / style thread
- Need help with a gsr in a ef hatch
- Free intake!!...AEM needs an EK w/b18c1 swap...Free intake!!
- 92-95 CX with GSR e-brake cables (rear disc swap)
- DC Sports Stainless JDM 4-1 Header, 2.5" Collector Special!!!!!!
- JDM B18C1 into a 94 civic Ex
- which would you choose to run for a crx
- B18b Swap Question
- 95 B18C OBD1 into 97 D16y7 Obd2 Sedan - Plug Change Questions PICS PICS PICS
- ITR swap done, a few problems... did search, need help, idle surging/dies... code 14 and 23- HELP!!!
- Part # b20b lwr timing belt cover
- Del Sol Engine swap
- b16a tranny issues in a crx
- o2 sensor question
- HELP WITH K20 IN CRX AND EG
- LS/VTEC HELP!!!!!!!!!!!!!!!!!!!!!!
- JDM Type R swap driveshafts
- Daven(dave) from Effin Motorworks ?
- any other ls/vtecs running Skunk2 Stage 1 cams? looking for cam gear settings.....
- H22 eg hatch swap?
- Auto 2 Manual Mount Question
- b16 vtec head to b18 vtec block?
- B18B into a 1999 EX Coupe - Questions
- EVAP CODE?
- Advice
- Do not buy from JDMsource.ca!!
- Full Race traction Bar review: H22 civic
- B20 into G3 integra? Worth wile?
- What does this connect to?
- b16a2 swap into 96 civic dx ek4
- b series in an ek civic.. anyone have a pic of the front tranny bracket?
- in a JDM ITR engine swap to a 95 civic coupe, which shift linkage is best? LS, GSR, or ITR?
- Peak power for JDM H22a?
- do some 1994 civic cx come with 4 wire o2 sensors?
- B18C1 HELP PLEASE
- hard choice, need help to decide!!!!
- gsr swap overheating
- H22 in honda 94 accord questions
- Placeracing engine swap parts..
- MOTOR QUESTION
- turbo ls vs. b18c5
- lsd causing axle to pop????
- need p05 ecu pinout and p75..... any takers!!!!!
- gsr swap: need throttle cable
- where is the o2 sensor located on a jdm b16 SIR II motor ?
- P28 or P30 for jdm Gsr w/hondata S200
- Whats better, Cable or Hydraulic tranny?
- H22A in EG...suggestions.
- My 12grand engine build...lsvtec
- ground control
- finished my swap, running rich
- Fast question...did search
- auto to manual hasport mount
- Please help with info
- new engine GSR pics
- LS into GSR
- H22A in a 92 accord LX wiring problems
- What makes a Gen2 B16 different then a Gen1?
- 92 dx + 00ls motor what ecu
- question about hose left over form swapping a b16sirII into a 93 civic ex
- Dyno'ed B18C
- axle problems with h22
- 92 VX B18C motor swap issue
- GSR Rods & Pistons in a LS
- H22A EG...P13 or P28?????
- P28 or P72 for H22??
- b16 swap wont start. HELP!!!
- b18b into ek- mount kit or stock mounts?
- have a Q on a engine code
- P28/ H22a Euro R
- rpm reading is not accurate??????????????
- JDM XSI b16a into 93 cx
- B20 block with GSR oil pan, wich dip stick???
- h22 suspension
- s100 p72 H22 EG, CEL 16 and 21
- K20A2 Wiring for EK CX??
- should i keep my cut harness?
- Is it possible to run a p72 distrib and ecu on a b18b1 as a temporary measure?
- P30 Ecu Problem??
- From Hasport : How to swap k20a , k20a2, k24a into EG or EK Yes
- Cat. Converter for 99 Coupe with b18c1 and JDM header
- what linkage do i use for my b16a into my 93 delsol?
- Which driver's side mount do I need for an h22 swap into an Accord/CL?
- ZC Internals
- Reliability of this set up?
- Intake Manifold Question?
- I need a motor asap
- Bad Alternator
- OBD2 F23 into my 92 accord
- rpm signal
- Searched, Question about TC code #36 running JDM p30
- K20/k24 info
- Wiring OBD2 Distributor in OBD1 car... anyone have distributor wiring diagrams?
- Wiring Alternator for H22 into EG
- Any one have any experience with Aeroquip StarLite hose?
- JDM ITR hub problem????
- CEL 19
- HELP!!! EG H22 PROBLEM!!
- Can I pass emmisions with OBD1 ECU
- Ls/vtec for dummies
- gsr/itr motor in a crx.. help..
- turbo d16y in 00 Si
- Anyone dynoed w/ the B20z intake manifold (w/ top chamber) ?
- Anybody know what to do with this stuff? *pics*
- which power steering pump? (b18b in 99 dx)
- wiring concerns for b16 swap
- A/C BRACKET BELT TENSIONER ?????????
- h22 swap for eg6
- JDM wire harnass question!!!
- ls/vtec dizzy?
- B16a3 into eg
- distributer "internals swap"
- swaping a H22 into an 92-95 civic
- swapping b16 into 99 civic, need help!
- i need help with a b18c1 vtec?
- Please Help - 2005 Grassroots Motorsports Challenge Entry
- Which is the best head for a b20 vtec
- H22 into EF... mounts? shift linkage?
- ls vtec
- TEIN RA's on DA Integra...what else do I need besides ITR rear LCA's?
- CUSH Honda San Diego
- Question...
- B18c5 into eg with b18b..help..thank you
- Can't rev to 8k?
- H22a Euro R
- the fun begins
- IACV SWAP....
- Need wiring help ASAP
- k20's into the eg series?
- need help
- K-SERIES DEL-SOL ???
- is it worth getting a h22obd2 than a h22a obd1
- ~~B18C into an LS~~ Difficulty rating please ????
- HEEEELLLPPP!!!!
- EG hatch engine swap
- anyone swapped a b-series motor in a 2nd Gen Civic?
- obd0 ls into crx 02 sensor question
- EK Swap tips?
- Louisville Swap Help
- Which header is better for the motor
- GSR throttle cable swap
- dizzy swap
- question about parts for sir1 motor
- i need help
- Having little problem with drive side axle, help greately appreciated
- Question: How to replace Oilpump.
- How Difficuit is it to swap the ITR JDM motor into a Si Coupe?
- Anybody seen a B-series swap into a first or second gen RX-7?
- Swap Info for a 97 B18C Type R into an EK
- Question about motor swaps...
- Is there any place on a harness that you can get an ecu pin (ie: an injector/distributor)
- Honda/Acura Engine Overview?
- interga suspension into 97 civic
- engine problems after swap
- What would it take to do this swap?
- 94 Integra GSR mid-engine RWD H22A4 conversion
- 92 Crx..
- C32A5 into Civic?
- New H22 ek problem
- A Little Video I Put Together
- hydro/cable clutches... any difference?
- EG auto-manual conversion help!
- GSR head on B16a2 block...What headbolts do I need?
- only one o2 sensor b16 swap?? help!! runs rich
- h23 prelude ? Auto to stick worth it? help asap
- f20b jdm dohc vtec into 98 accord?
- Redline on B18C 93 Civic EX
- crvtec head stud question *****need held ASAP*****
- rpm jumps
- 91 b18a into a 92 cx ?
- 90-93 accord halfshaft only? 90-97 is the same? wtf
- H22 swap in 94 Accord lx
- Axle dilemma with EK w/B16
- honda engine into an 87 hyundai excel
- just swapped need help
- 92 Civic CX, z6 swap complete, but keeps cutting out... PLEASE HELP!!!!!!!!
- JDM b16 in to eg hatch. which tranny mount?
- d15b crank no start
- Finally got my ek22 swap running good...
- Will an integra LS 1994 header fit ok on a b16 1993 SIR II motor cx
- WTF my IAB selenoid valve caught fire
- Do i need a new O2 sensor?
- B18c1 SWAP, whats best year?
- HELP! FAILED Smog with B18C at CA State REF.
- p28? what type of pcm is this?
- thread pitch on ek hard brake lines?
- any onwe have expierence with Rcrewracing in SF, ca???
- Can I use a 99 si dizzy on a 1996 gsr?? is the plug the same???
- OB2B civic, OBD2A EMS, OBD1 motor -> wiring questions
- automatic swap
- H22 Keeps Dying. :(
- Code 7 problem
- b18c1 turbo civic :-)
- integra civic dash swap -----------almost done.
- H22 in a EG Civic with H&R race springs and KYB's....is this ok?
- Crank Position Sensor... Code 4... Did search, different issues!
- Possible to BAR an H22 EG/EK in CALIFORNIA???
- JDM h22a 4door baseline dyno!!
- What parts are needed to swap gearsets from a hydro tranny to a cable tranny?
- CRX and best engine for boost??
- questions wit ls swap into 94 civic dx coupe???
- what axles for my swap?
- Hybrid brake setup question.
- motor swap weigh in's
- car wont start
- Which throtle cable?
- i have money what suspension do i buy?
- f22b vacuum routing
- OBD 2 Alternator Plug Wiring Diagram???
- HELP!!!!! TransMission?? or Vtec??? or ECU????
- What clutch to use w/ JDM YS1
- IACV and IDLE issues. everything possilble CHECKED! - give it your best shot. (video incl)
- iacv code 14 - problems with fixing it
- sir 1 swap in 93 civic si
- b20 in a del sol
- obd1 auto tranny into obd2 car
- Place Racing -- GOING OUT OF BUSINESS???
- B20z ==> EK, can I use the b20 alternator?
- what do you think about the B18C5 96-97 motor
- where/how to make custom clutch line for h22/ek swap?
- B18 into 89 Civic Troubleshoot
- Fuse boxes and Sensors and Wiring stuff!
- Looking for a Second Gen B16a Sir2 with an automatic Tranny
- Looking for a shop in So Cali.
- best swap for my 93 del sol si
- Q's about B16 longblock
- K20 in ef8/ee8 , block height issues
- Car Hesitate while driving. Help ...............................................
- Good deal on a K20/24 swap????
