View Full Version : Hybrid / Engine Swaps
- swap help please
- 93 civic shift stabilizer bracket
- Ek H22a
- IACV FITMENT
- HELP..anybody here who has a B20 swap in their EK? let me know
- GSR swap ?
- h22 ek swap problems--
- Mods to a ZC motor???
- B18B Oil Pan...
- d16y8 in 92 CX...vacuum/idle problems
- Cam timing offset of d15b2 with d16z6 head.
- JDM B16a2 engine swap
- What swap would be better..
- exhaust for b18 in a CRX
- need help on b20z swap in EK
- OIL FELL INTO CHAMBER!!
- Where does the RPM signal wire run to coming from the distributor?
- my fuel pump fuse keeps blowingggggggggggg???????????????
- EK with GSR, mount questions
- Clarify a Hasport Question
- good buy or not?
- wiring for k20a into 85 crx
- Check Engine Light when I coast or slow down
- 87' accord swap...
- your swap opinion
- non-vtec distributor on vtec engine
- HELP !! EG's with H22 WITH A/C problem
- Transmission gearing? change final drive?
- b16a 88-91 or 99-00
- b20/teg axle
- h22eg 0-60 times???
- First drives with the LS hatch....
- b16a1 iat sensor???
- best engine? need help !!
- b20 pistons?
- Need some info on LS/VTEC......
- EG B18b swap....Which cat do i use with civic exhaust??
- obd1 ls in 89 crx si, speedo not werking
- Swap up and running...
- CEL 41 hybrid wierdness
- IAT Sensor & Wiring Harness = No Match (ITR into EK)
- help with TB swap
- exuast system for h22a jdm swap
- old wiring harness work for h22a swap?
- wiring a obd1 gsr to my civic
- b20 Strength of Sleeves.
- Difference in B18 blocks?
- H22 ek w/ power steering?
- OBD I ECU Wiring To OBD 0 Harness, Distributor & Injectors - Questions??
- exhaust ?
- Needed: wiring diagram for a 98 JDM tpye r motor (obd2) into a 92 honda civic cx (obd1) (from honda
- ls/vtec in 97 hatch wire issues
- b16 swap need part list and wire help
- Missing Plugs?
- anybody have a kaaz lsd in a honda? fluid?
- D15B SOHC VTEC head on a D16Y7?
- redoing my h22ek swap
- B16 auto
- HX to turbo D16
- B16B into a 88 Civic HB?
- Does anyone know where to buy a CHEAP b20z!?
- code 8
- How much is my hybrid EF worth?
- Yea or Nea.......chipped p28/gsr
- Need 96-98 katman wiring guide
- temp gauge not working!
- RS machines head port n polishing
- Obd 2 conversion from obd1
- NEED HELP FAST
- Clutch Master Cylinder help needed
- B16A in 1990 integra, what ecu do you recommend?
- swaping heads????
- About to to pivk up my first gen B16. any ideas?
- Urgent Exhaust Question regarding swap
- H22 Swap... Which fuel rail to use???
- H22A Into 98-00 Accord
- Europe hybrid guys please help. Others welcome to help as well.
- H22 Balance Shaft Belt Installation Question
- H22 EK Questions (Searched)
- throwing a CEL code....help?
- how to identify shift linkage?
- crv integra
- best place to buy k-series swap
- D16z6 into rex, odb1 or what?
- Pullin the d16z6 (pics)
- LIMP MODE ON EK-22?
- b18c1 into 93 del sol S cluter questions
- Anyone have CTR cams in am LSVTEC?
- H22 with p72 obd1 problems
- obd2 si harness and 96-98 ex harness question..
- D-series with TECII possible to use B-series Pulley
- hydraulic tranny conversions!?!?
- i wanted to throw a jdm h23a vtec into a 94 prelude
- quick question
- ECU ERROR CODE QUESTION
- b18c-r
- b18c1 to b16a2
- jdm-usdm distributor cap/rotor
- diffrences in rods!?
- Crank pully upside down lol!
- H22 LSD?
- OBD1 Harness Connections
- aftermarket B series distributor caps and rotors
- OBD 2 - OBD 1
- PRELUDE CIVIC PICS
- b16a 2nd gen w/ Kaaz Lsd
- integra ac lines
- gear box swap
- headlights get bright when i let off gas
- B16A1 Swap Problems...help!!!
- CTR question for gsr
- $10,000 Hybrid Question..........
- No heater, IACV code
- OBD0 B18a1 to p28 ECU ?
- code 10 iat at 6k rpm!? no idea whats goin on?
- Need some help info of my LS swap...(pics)
- where is the fan switch??
- whats the valve clearence for a gsr head with typer cams
- CTR cams in an LSVTEC???
- swap is misfiring???
- Does anyone have a step by step guide to install a 00 SI motor into a 00 CX hatch..
- b16 swap code 3
- h22a 2 b18b1
- 6-AN vtec line question....
- what is rpm rev limit on a JDM P30 ECU?
- CRX/B16 CLUTCH/CABLE INFO
- I need an HCP h22 Mount kit for an EK!!!
- Ok guys need help...code 1, code 10 or bad ecu? On ITR swap with P28 ECU
- h22a DC SPORTS header
- exhaust issues on ej?
- should i keep my b16?
- Motor mount problem
- B18b swap into a EG (92-25) Civic
- which spark plugs wires for jdm h22a? USDM didn't fit!
- Quick question on wiring O2 sensor.
- K20A into a 92-95 civic hatchback?
- H22 ek civic wiring
- Fuel Filter Questions???
- h22 hatch wont go in reverse???help!!
- enjo engine mounts yes? no?
- 1996 honda accord swap to h22a
- b18a swap into crx
- vacuum routing diagram
- ok i got the 88 crx hf with a b16 swap running BUT........
- Does a B16A Head fit onto a D16 Engine?
- Does a DC Sports 4-1 fit a B18c5??
- all motor b20 time slips non vtec (already did search)
- Need HELP with ZC swap
- ??? need help weird idle????
- OBD gurus please help!!!! OBD0-OBD1 conversion.......
- Smog Legal + Bar Sticker in Cali for Hybrids!
- JDM to USDM pinout differences?
- my bad...
- Exhaust manifold to long/short???????
- Ls vtec build up?
- Qiuck Q about skunk2 and crower compatability
- H22 Header Production Pics
- b17 into 88 crx si
- (B16a1)ECU problems
- Question about d15 swap
- H22A4 93 civic hatch
- swaping engine harness...... engine still in the car?
- Swapping H22 into a 95 cx..HELP!
- h22 Project almost nearing completion
- osakajdmmotors.com..... yay or nay?
- HELP! Info needed for 93 civic DX w/ 99 GSR swap
- Your friendly neighborhood Spiderman is back!!
- H22 into em1 total cost?
- Engine cranks but won't start!!!!!
- help... ran into problems w/ swap...
- Will a JDM ITR FD fit in a Cable YS1 Tranny?
- will a p13 OBD1 ECU run my GSR swapped 93 dx coupe??
- What mounts for B-series in EK?
- Where to get accord intermediate shaft?
- GSR FUEL PRESSURE
- question on h22 swap in cali, smog question
- gsr wiring problems help
- '94 ls and gsr axels the same?
- mini me swap ( i already did the search) need help ASAP
- Can I maintain my Civic rear LCA's with a 5 lug conversion?
- JDM b16a2 hybrid guys: What did you do for clutch line?
- Where to find a b16 or b18 automatic
- Tranny Mount Question
- Civic SI rad. hoses work on a EK with a GSR?
- Gear Ratios for JDM H22A Transmissions
- Changing Duty Cycle
- Need help...
- cam question for gsr?
- My project in progress
- a b20 equipped delsol.. well maybe
- 95 ls in 95 coupe axles keep goin bad why
- Which ECU
- JDM b20 same as USDM b20?
- H22 integra, distributor wiring question
- s1 cable transmission question
- K20a into EG
- b16 with auto tranny
- gsr swap question please help
- Pics of my b18b.
- B16 problems
- B16 with type r intake mani
- 4g63 in honda
- info on swapping DX intake manilfold onto VX? Did search...
- another update:car running but....
- Internal build-up?
- Wiring Question - 00' Hatch with 01' GSR motor
- Would a b20z need a different O2 than a d16y7?
- MR2 (new project) Where to find an 3SGTE?
- H22 into a Ek wiring questions
- shopping list check
- Maryland Car Meets
- Help! Took dizzy off and can't put it back on because...
- What is something in an EG that could cause voltage spikes?
- crx swap need help
- rebuilding b16a axles help
- ok guys sorry but a couple of QUICK questions.
- Resistor Box on an H22 Swap
- dx ecu on ls?
- 98 civic hb W/gsr engine harness help
- Hurricane Isabell couldn't stop the swap....
- H22a CX hatch swap wiring problems
- CEL 45
- LS and GSR axles interchangeable?? abs non-abs.. whats the difference???
- 5G Civic Coupe + B16A SiR-II engine mount question
- CEL 14 and 65: car wont start
- year of motor? b18b in 95 civic cx
- Problem....I need your input
- 1994 B18b
- Best way to remove stuck hoses/connectors?
- quick q's need gsr crank bridge bolt torque specs and rod bolts torque specs
- something fishy is going on here....
- Bad Valve???? Knock Knock (who's there)
- b18c1 throwing codes?
- Radiator Fluid Leak after B18C Swap
- dohc zc w/89 integra tranny + axles? in a crx??? will it work???? i need your help!
- power upgrade in 87 Civic AWD
- 89 integra motor in a 90 crx ???
- who makes the best swap kit for a H22 into a EK.
- anyone modify their auto ecu for 5 speed? (integra)
- custom powersteering bracket for ls or CR-vtec franks
- axels question
- Car wont start and only throws cel 10
- lighting up car
- finally gotta new pic of my ek h22 and its lil sis.
- f22a1 to h23 swap help with the black vaccum box?
- K20 swap in 2nd gen CRX possible?
- My ls/vtec engine is malfunctioning and i dont know why! HELP ME OUT PLEASE!!!
- Help!!! My car is broken and i do not know why!
- control arm?
- this odb shit freaks me out . what do i need 2 buy
