PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172 173 174
  1. Compression with these pistons in ls/vtec
  2. Where to get Trannys?!
  3. Just started my Hybrid---Need help with surging idle and clutch problem.
  4. Anybody know if the VIN # is stamped on Honda blocks?
  5. raxles / eg / b16 / front end shake?
  6. Perfect motor in a EK ! ! ! ! !
  7. camber kit for 5 lug conv
  8. Does anyone go to LACR?
  9. Stock dx shifter with b16a???? help???
  10. whats the running price for a.......
  11. i know you you guys will tell me to use the search but....
  12. clutch.......
  13. EX cluster question...for b18c1..in a EK
  14. gsr in 00 civic
  15. Spread the word!
  16. Some FYI...
  17. Florida Reputable Swap Shops....
  18. Chipped p28
  19. SWAP ? IN AN LS
  20. Would ITR manifold or Skunk2 help with the following mods?
  21. simple question on D16Y8 Driver's side mount
  22. integra ls with turbo, and b16 head how easy and how much
  23. When your swap arrives what should you check for?
  24. The best defense against car thieves.
  25. HOW TO CURB THIS CAR THEFT CRAP. WAYS TO HELP PROTECT YOURSELF...
  26. Stock bottom end safe for...
  27. b17 swap in a EK question
  28. Noisy engine after swap...............help........................... .d16y8 into 91 crx
  29. Just about to put in the B18c
  30. HELP 02 sensor problem
  31. B16A Harness and dis. Cap ??????
  32. d16z7 into 93 cx hatch
  33. please please help odb1 b18c1 into a odb2 car
  34. Block girdle for B16A block?
  35. Turbo help
  36. Types of Mugen Exhaust ?
  37. can i modify my shift linkage to work with b-series?
  38. Stright B20 in a EK, what parts do I need??
  39. motor
  40. B20 Oil Pan, search fails again...
  41. Weird Hybrid question
  42. h series in 92 ls teg
  43. where the hell is the knock sensor???
  44. What is up with hybrid.honda-perf.org?
  45. Want to knwo how to do a motorswap
  46. 95 Civic LX auto to manual B18b swap
  47. Ready for swap if i can get a motor
  48. b18c1 into 00 civic
  49. gotta stupid question
  50. Auto to manual with motor swap???
  51. whats a good tranny for a allmotor car
  52. mount help
  53. b20b/z, longblock vs shortblock
  54. ** DITCH THE B16 FOR A LS??**
  55. Need help on how to install a transmission
  56. '00 JDM ITR motor -> '96 EK hatch... What are the potential problems???
  57. My swaped 99 Gsr wont stay on.............
  58. b16 with a b18c crank and rods...
  59. gsr seats and carpet in a 5th gen civic hatch?
  60. Block girdle swap
  61. Anyone build a b16a with some civic r pistons? How does it feel?
  62. yo yo
  63. i wanna put a 96 obd2 d16y8 in a 94 eg obd1
  64. USDM B18C1 question
  65. Engine Source advice...please...
  66. H22 Accords.....Help please
  67. gsr short block
  68. How to tel lthe difference.....
  69. Spoon cams?
  70. ecu??yes or no
  71. CEL 22 QUESTION
  72. Where can I buy a...
  73. gimme some info on the type-r motor swaps please??
  74. b16a2 v.s. b18c v.s. b20
  75. whitch swap for my del sol????
  76. 97 b20b4 in my 89hatch
  77. Clutch all of the sudden grabs low....very low????
  78. Ls/vtec set up
  79. i have a turbo for my d16 but i am starting to wonder if i should buy a b20 and switch exhaust manif
  80. B18B Tranny ?
  81. 88 HB swap
  82. intake and header for a b18c crx?
  83. Where is the ECM tach input??
  84. obd-1 to obd-2 question!!!
  85. LS motor into '00 Si?
  86. H22A Accord (Auto tranny question) NEED HELP!
  87. update on the hybrid
  88. Head bolt q's
  89. Please post good Swap websites here..
  90. HELP! I give up. How do you get the new Vtec wires to go into the CPU connector?
  91. ummm, just finished the swap, cant hook up scantool!...
  92. Mounting H22 into EF
  93. OT:PayPal
  94. How much hp from a stock ls/vtec
  95. FOUND - magical VTEC wire...
  96. ECU Pins
  97. CTR B16B swap complete somewhat!!
  98. Putting A/C back in my car.....
  99. will 89 integra fi fit on 90 crx?
  100. what turbo for b18b swap with b16 tranny?
  101. what drivers side mount for swap????
  102. Norcal hybrid meet...
  103. how much will it cost to put a b20 engine in my del sol
  104. Where did you run your Vtec/Knock sensor wires through the firewall?
  105. B16a in 89 CRX
  106. fuel pressure for B16a in an EF
  107. what do you think about this deal?
  108. H22A into a prelude Si........
  109. 94 b18c1 into a 97 civic
  110. H22a into a '97 Accord? or maybe a B16a?
  111. where to get a b16a1 around vancouver
  112. h22 in ek hatch??
  113. DelSol seats vs Type R seats
  114. is a type R swap,,worth the extra over a GSR swap iin a hatch
  115. B18c1 into a 92 civic VX
  116. B16A1 into a '91 Civic Hatchback (DX) - n00b here
  117. H22a ?'s
  118. SI engine code?
  119. Help H22 wiring
  120. Whats the best way to clean head and block?
  121. Wiring Guru's: 99-00 Si in 98 Dx Please HELP!
  122. What Camber Kit(s) should I go with for my auto-x/circuit '92 VX?
  123. Hybrids w/ power steering hooked up....
  124. JDM H22a busted sensors
  125. H22/23 on a F23
  126. EG Radiator swap
  127. B18C1 - Cams
  128. Hybrids...how are you getting around this winter?
  129. Doing my swap, have questions about AC bracket and compressor.
  130. H22A4 in 98 up accord?
  131. CROWER Cams SUCK! 10 Pics to Prove it Too!
  132. Where can I get a cable tranny for b-series motor (with lsd)?
  133. ???? Skunk 2 Maniford ??????
  134. does vtec matter for force induction engines?
  135. will 95 gsr air box intake tube fit 93 cx?
  136. could someone explain what all i need for a LS/VTEC
  137. LS swap in 92-95 Civic...
  138. Speed Limiter on JDM b16a6
  139. good setup?
  140. Attn: CEAS, your grandfather is looking for you!
  141. B20vtec into a EG wiring harness question.
  142. NY SWAP LAWS...who knows them?....did the search..
  143. Anyone bought a swap from Tom's Engines in Canada ???
  144. How To Tell If Genuine JDM GS-R Motor??????
  145. wont start damn it
  146. b18c1 into 96 civic EX swap question...
  147. Where did you mount your aftermarket tach? Got pics?
  148. wiring problems
  149. b16 in DC2??
  150. Finding ITR in Junkyard
  151. Whats the gas mileage on LS/VTEC!!!!
  152. when putting a first gen b16a into a crx, can the crx be a dx, or hf? or is this alot more..
  153. whats fastest
  154. Ideal hybrid setup?
  155. Spoon vs. Toda???
  156. Automatic tranny H22 into an automatic tranny del sol...
  157. jdm motor install
  158. Driveshaft for H22A EK Civic!
  159. S2000 engine in integra?
  160. my codes again
  161. CTR Front Sway on EK..
  162. Can some help me out here??
  163. INTAKE MANIFOLD swap from 2000 DX to 96-00 EX???
  164. is a d16a1 worth it?
  165. b18c/b16b swap into a 96 Hb
  166. DIY rear GSRtranny mount?
  167. secondary o2 sensor.....is it necessary?
  168. date stamped 9|1 0|0 2|1 9|0......wanna know if i got sir II or not
  169. im about to buy a rs teg motor is it good and fast
  170. Cams, cams, cams...
  171. B18c6 '99 in a Delsol Vtec '92(europe B16a2)
  172. 13 is a respectable time....
  173. Swapping in B16A OBDI (JDM OR USDM) into 92 GSR; In place of USDM B17A OBDI VTEC (YS1 CABLE TRANNY,
  174. Swapping in B16A OBDI (JDM OR USDM) into 92 GSR; In place of USDM B17A OBDI VTEC (YS1 CABLE TRANNY,
  175. Anybody have pics of their hybrid exhaust? I'm curious how this 'cat-situation' is going to play ou
  176. A/C compressor hitting frame with "ZC" Swap. Normal?
  177. JUN valve cover
  178. help.....wiring problem
  179. which CM clutch/flywheel do i order for b20
  180. Staying legal...
  181. Can anyone tell me where to pick up a smsp header?
  182. Replacing clutch... which is easier... pull engine and trans out or just engine???
  183. CTR engine in my 98 EX: finally on the road (pics inside)
  184. where would I look for a 94 ls ecu....
  185. Where can I buy a B18C5 for under $4000?
  186. 98 Gsr in 95 Vx hatch
  187. my h22a was already in a 99 accord running obd I
  188. Has anyone ever put an H22/H23 into an 88-91 Civic/CRX?
  189. ls engine into 91 hatch...
  190. ARD performance?
  191. "i have a b16a2 and i am tryin to put it in a 2nd gen crx,(88) and i am using a has mount kit and fo
  192. B16a sizes??
  193. any one here with a stock clutch on a hybrid
  194. Where can I get a B20? What are good prices?
  195. Has anyone ever put a 2nd gen B16a into a 2nd gen. CRX?
  196. Night lighting for Greddy guages
  197. Wiring: Convert nonobd 91 teg to obd 1 94 gsr specs
  198. I'm about to buy this block...
  199. 1/4 mile time
  200. turbo b20 vs turbo ls reliablity
  201. just dropped a b16a3 into my hb vx need some help now!!!
  202. FYI - Compression ratio calculator
  203. D16z6 in 94cx (d15b8) - couple questions
  204. TPS, IAC or what? need my swap running
  205. backfiring swap help
  206. B16A1 in a 92-95 CivicHB
  207. ls swap map sensor ??? idle??
  208. Experience with Skunk2 ECU
  209. Okay. I need to figure out how to put the crank bolt back in while the motor is out of the car.
  210. what qtr miles times for a GSR swap in a 94 DX hatch??
  211. VSS install Question....need reply ASAP!!!
  212. japanese motor speed limited??? REALLY?????
  213. D16A1 head on D17A1 engine??
  214. need some help with h22 accord
  215. wiring genuises? help! want obd I
  216. Swap Question
  217. PICs of h22 in a 90 integra comming soon
  218. search for trans...
  219. where to get a B20?
  220. help with swap
  221. what motor do i need 94 ex civic
  222. What other ways can I get a 5-lug setup on my DC without paying the outrageous prices for ITR stuff?
  223. HELP I AM SO SCREWED!!!!
  224. Shift linkage issues for a b18c swap into a del sol?
  225. Smog Help - machine couldn't read my RPM's? Please Advise.
  226. S2000 Color Code ............
  227. Where to get h22a for cheap?
  228. alternator problem!!!!!!!!!
  229. looking for Jaker
  230. Need ECU plugs
  231. CA street legal engines for CRX?
  232. whiach starter???
  233. which is the best setup
  234. need price on hydrolic to cable clutch conv.
  235. Has anybody tried the Jax Light wheels at Discount Tire Direct?
  236. Info on h22a in a Teg
  237. 1.6 DX SOHC motor w/ 1.6 VTEC DOHC head?
  238. B20 Vtec on C-Speedracing
  239. LSVTEC fitting sizes and parts
  240. B20VTEC vs B20 non-VTEC
  241. What did you do with your original engine?
  242. Where to Buy JDM Engines in Georgia???
  243. what kind of valve sleeves does honda use??
  244. Weird Idle and Stalling? Please help!
  245. GSR bored to 84mm, which headgasket?
  246. stock eg mounts with b16a2???
  247. Legealize Engine Swaps??? Possible or not worth it???
  248. .Just got a Joopy... Trying to make it a sleeper...Help wit my question??
  249. This may be a little wierd...
  250. What shops in San Jose area are qualified to do a b18c5 swap into a 92 hatch?
