PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 [54] 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. GSR in a What?
  2. Swap question.
  3. JDM B18C in a EJ6 problems. (searched for 1hr)
  4. F22/H23 crank and rods in a 93 JDM H22 block, which F22/H23 to use???Build up help!
  5. Swap axle length problem? EF B16A YS1-LSD
  6. JDM B16A A-Pipe crush washers: help
  7. Head gasket choices
  8. Which axles for CRX w/JDM b16a?
  9. throwing code 21 after fuel pump install
  10. SIRII swap/axle question
  11. Looking for a GSR or TYPE R COMPLETE swap for an eg(93 civic hatchback)
  12. i need yuor advice?
  13. radiator issues with b18c in ek coupe
  14. b16 head on gsr block... can i pass emissions ?
  15. 00 Si B16 into a EJ1 swap questions mounts, wiring.
  16. h22 long block with b16 tranny
  17. New h22 ek Problem Code 41, 65
  18. Idle surge/sputter at acceleration on my B16 swapped del sol
  19. Distributor Question for a 2000 Civic Ex w/ swap?
  20. b20 head
  21. B18c in 99 Civic O2 sensor question.
  22. Just A ?
  23. B18C4 and B16a2 HP?
  24. y7 swap in 90 crx.. help..
  25. Extra Coolant hose?
  26. Car won't start.... H22A4 into EJ8
  27. Need some ECU help on my swap!
  28. Help with info on Bastard Build!!!!!!!!!!!!!!!
  29. car just stop firing up ????
  30. obd0-obd1
  31. Any1 in CT area please help!!!!!!!!!!!
  32. JDM GSR - Which cap and rotor?
  33. s20 or not?
  34. High Idle in EK b18c...HELP!!!!!
  35. f20c into eg possible?
  36. H22a JDM from auto tr. car into H23 with manual tranny Q
  37. Hondata/Romulator/FJO Injector driver = nope
  38. JDM VSS ON HYDRO TRANNY W/ JDM EF8 SIR CLUSTER HELP!!
  39. can someone please help me b18a into a automatic once was 1992 civic hatch
  40. b20a5 swap into my eg hatchback
  41. need intel for a swap in my eg hatch...
  42. Where to get JDM h22a Sparkplug wires..
  43. H22 in EG hesitation question
  44. shiftbox for k24a4
  45. 3 plugs can reach the TPS... which one is correct?
  46. b18a1 w/ b16a2 head
  47. some advice about swap b20/vtec sleeved and boosted or b16 sleeved and boosted
  48. I got RC 1000cc injectors and need help
  49. H22 VS B18c in delsol
  50. Need HELP: Hasport 99-00 civic EK K20 adapter harness EMWK 3 Relay harness wiring
  51. which radiator hose?
  52. OBD 1 B18c into 97 EK, able to use stock civic wiring harness?
  53. Mid engine CRX
  54. Noob Question : Swap???
  55. ECU Code 2 .... Eh ?
  56. Engine swap to a non Honda car
  57. Popping noise...HELP!!!
  58. help!!!!!!!!!! on my ek, gsr swap and auto to manual
  59. PCV valve question
  60. a b16 what?
  61. Skunk 2 Intake Manifold Install...INFO
  62. HELP!!!!! 5th gen b16a2 OBD2 swap
  63. LS in a civic EG. Power steering question. ??? please help asap.
  64. b series hybrid question plz help!!!!!!!!!!!!
  65. F20B swap?
  66. b16a2 in 96 ek hatch
  67. will d16y8 auto ecu work for a manual car??
  68. JDM H22 HELP!!
  69. wat do i need to do to keep my ac and power steering wen i swap?
  70. stupid code 7! HELP please
  71. Honda Experts only Please
  72. LS swap 94 ex
  73. A couple of swap questions.
  74. swap not running properly, need advice please
  75. Searched h22 hasport axle keeps popping out
  76. b-series question
  77. Good Bye P28....
  78. H22 oil pump housing same as F22?
  79. Old gas
  80. wat els do i need for my swap????
  81. guage cluster for hybrid hatch
  82. Abs in a Eg6 with H22a7
  83. injector bad?
  84. speedo doesn't work
  85. hybrid problems
  86. 99 civic ex brakes on my 94 del sol?
  87. GSR head- $220? worth it?
  88. New to swaps, need some help, H22 swap into 00 Civic??
  89. Stock motor swap need help fast
  90. can you us ea hydro tranny on a b18a block
  91. Problems with ITR short block swap in Si
  92. H22 EURO TYPE R Head
  93. LS/vtec exhaust size
  94. jdm b18c difference between manual and auto
  95. 99 h22a4 in 98 accord problems
  96. H22 swap 1997 delsol questions
  97. HELP! is a b18/b20 hybrid build possible?
  98. Auto Motor
  99. Building a B20 Vtec
  100. swap problams. need help.
  101. VIDEO <H22 Eg 4 door> VIDEO
  102. did i get a good deal?
  103. b18b1 idle surge
  104. HELP! Vacuum lines!
  105. h22 rods
  106. Gauge Cluster and other electronics not working in CRX with b18 LS Swap
  107. Cool Auto Insurance Commparison Site!
  108. Reving problem on a b18 LS motor swapped into a 88 crx
  109. d15... what trannys will work
  110. civic vx w b18 02 problems
  111. Were to buy?
  112. LS/VTEC B16 head moved BACK to a B16 block...what about the dowel holes?
  113. O2 sensor and fuel pump questions?
  114. D16Y8 block, Y7 head Timing belt?
  115. dumbass question awd k20a2 civic?
  116. clutch cable to slave
  117. kseries swap in an EG with a/c?
  118. FAILED BAR Smog, Help me Diagnose the problem, 92 EG with 2001GSR
  119. k20a2 head swap onto a k24a4?
  120. looking for link to b20vtec write up
  121. I need some tips
  122. running rich, need some help. eh2 w/ h22a
  123. gsr civic
  124. Axle question, B-series
  125. where to buy ecu pins?
  126. H22a production years
  127. THE BIG BUILD UP [H22MONDO]
  128. Will a b16tranny bolt up to a h22a?
  129. Type r parts into EK?
  130. JDM b18b into a DA questions
  131. Engine Management in B18C EK
  132. Weird problem with Clutch/Tranny
  133. AHHHH!!! Please help me! (92-95 civic coupe hybrid)
  134. im trying to do obdo to obd1 swap
  135. Swapping 92 LS engine into a 92-95 civic?? What needs to be dont?? Is it a complete swap over??
  136. integra into a civic hb
  137. B20 GSR...how much boost can it hold?
  138. Dseries and Bseries Dizzy different?
  139. tranny question?
  140. H22A in an EJ questions
  141. 99 si B16 into EK lots of questions
  142. HELP HELP H22 swap problem
  143. Cant Remove The Woodruff Key On The Crank??
  144. lets have some fun
  145. another b20vtec setup question
  146. hey guys i putt h22 in my ek need to find out a few things
  147. B20 pulley/thermostat housing on a B16A2 ?
  148. will nybody help with some ???s doing a mini me on a d15b1 with a y8 head wat timing belt do i need
  149. is there ny way u could plug the 92-95 engine wiring in an ef
  150. ZCorBseries?
  151. Type R motor in a civic.
  152. How To do K20 into EG???
  153. YS1 compatible with ITR tranny parts?
  154. axles
  155. tps??
  156. help with conversion harness
  157. coolant oozing
  158. Intake Manifold Sensors - LS to b16?
  159. jdm b16 with a gsr head?
  160. will nybody help with some ???s doing a mini me on a d15b1 with a y8 head will i have ny timing prob
  161. to those w/ and h22 in their civic....
  162. B16 Stalls?
  163. Gsr SRI fit ---- DC/EG H22a swap?
  164. h22a civic TIMING problems
  165. 2002 H22 Swap
  166. Need help asap D15b swap not revinggg!!!
  167. Standard spec of b18c
  168. swapping usdm gsr with jdm b18c5
  169. B16 Speedometer Gear in Type R Transmission
  170. h23 intermediate shaft
  171. i've done a B16 swap and having radiator and hose fitting problems
  172. ls/vtec question.........
  173. CTR LSD into a 99-00 SI Trans!! Having Problems
  174. cold engine bogging/sputtering? jdm b16a in EK
  175. H22 EG ECT sensor
  176. my setup! want to know what u guys think?
  177. Help or tips with swap
  178. civic with gsr swap cuts out at 5000 rpm
  179. harness question
  180. bseries dseries crank angle sensor
  181. k-series swaps.......
  182. gsr trans on b16SiRII longblock
  183. motor is in but...
  184. read this
  185. rsx motor swap
  186. Trying to convert 97 civic cx harness to fit gsr swap into my hatch
  187. Bay Area Engine Swap Mechanic Needed
  188. help please d15b swap
  189. gsr and b20 block
  190. WTB for d16y8 swap
  191. attn: Central Florida techy swap people
  192. Is a DEL SOL VTEC distributer compatible with a GSR?
  193. MAP question...running rich, fouling plugs
  194. Intake Manifold Question
  195. f20b tranny-s2k f20c bolt up?
  196. 1999 B18c-R into 98 ek hatch... tips?
  197. gsr motor in 92 hatch...1/4 mile times?
  198. Anyone done mini-me with D16Y7 ?
  199. vtec-e engine from vx into crx hf
  200. GSR bogs down at high speeds
  201. Type R crx problem
  202. obd1 chassis, obd2 motor swap in there but going back to obd1?
  203. catch can q's lsvtec b18b1
  204. catch can
  205. ZC engine swap question
  206. problems with speedometer.
  207. odb1 gsr engine into obd2 nonvtec integra ?'s
  208. Swap Checklist
  209. heatercore problem
  210. swap?
  211. Motor Swap?
  212. h22 into an integra
  213. b18c1 head on a b16a3
  214. Engine Swap HELP NEEDED
  215. how is this KYB exel-g SHOCK??(need your advices)
  216. New to hondas
  217. MAP question...running rich, fouling plugs
  218. somethig I had a thought about
  219. 98 Jdm distributor wire colors and function need asap...thanks!!
  220. obd0-obd2 injector
  221. need to know once and for all what harness to buy...
  222. Gauge needels jumping
  223. The H22a civc suspension thread
  224. b16 cel 23 (knock sensor)
  225. WHICH IACV FITS THE B16 MANIFOLD
  226. b series swap into a 78 cvcc?
  227. k24 advice
  228. DOES A LS MANIFOLD FIT A B16
  229. h22 balance shafts
  230. obd1 integra gsr chassis, issues on swapping in obd2 itr motor?
  231. b16 stumbles off idle & runs rough
  232. h22 swap in my 98 ex need info
  233. NEED HELP PLS?
  234. FLYWHEEL RESURFACE????
  235. Question about conversio harness!
  236. 96 hatch w/gsr. IACV problem
  237. Something different. OBD 2 engine in your OBD 1 car.
  238. ting a 96 accord ex motor into a 91 accord lx help me someone
  239. obd1 engine into obd2 car
  240. H22 LMA shims....
  241. well
  242. Identifying an engine?
  243. no code for iat and map sensor
  244. H22 EG question about 5wire to 4wire 02
  245. h22 boosted accord axle question....
  246. Will running d16y8 (vtec) w/ p2e (nonvtec) ecu have performance issues!!!
  247. Linkage Question
  248. Will a stock LS Shift linkage work?
  249. GSR TB issue...
  250. b series block d seris trans??
