View Full Version : Hybrid / Engine Swaps
- GSR swap....engine won't start
- Is the ITR engine a direct bolt in for ek?
- header need help asap
- you guys know a lot about brakes right...
- k20 in a 95 prelude
- B16 swap in EG crooked...
- P72 for H22?
- DO USDM H22s come with LSD...if so how to tell....??thank you
- quick o2 sensor question
- Need help finding wiring info for a JDM H22a into a 99 Civic SI
- Swap question... but not on search?
- vx head swap
- Need information about accessories
- jdm 98 b18c type-r engine to 96 hatch
- D16Z6 w/ AT into '90 CRX w/ AT?
- B16A INTO A CRX WILL NOT RUN!! I need help
- Please Help w/ Type R motor regarding oil pump and CKF Sensor!!!
- H22A Axles Problem! 92-95 Civic EG Hybrid H22A
- ACT clutch gives at 1500 miles...
- Can i run a cx d15b8 on a p28?
- motor mount threads
- strange problem with alternator clearance in ef
- getting a code
- 91 crx b16a1 swap: going to lose ac,what exactly do i need to do?
- P30J ecu code
- should i get a b16a for my 93 integra??
- What year LS Bottom End to use with P72 Gsr Head
- Post all the OEM Honda/Acura Part tricks and power adders you know will work....
- what gear can you h22 guys peel at?
- Anyone Know a Good Smog Shop in SoCal?
- Silvia 91-93 in civic??
- h23 swap..shops recommended MA,CT?
- Civic Swap Please help!!
- clucking noise!? please HELP H-T
- problems after swap
- WTF is wrong w/my Gsr swap? HELP!!!
- CRV crank pulley same as other B-series pulleys?
- fix 3rd gear sychros, how much to fix
- GSR intake fit in Civic engine bay?
- GSR dash into civic
- Is it illegal for dealership to sell swapped civic w/o paperwork for swap?
- Any ideas/suggestions as to why i keep getting code 22??
- Type R lsd into B16? Or should I buy a quaiff?
- H22 swap florida
- Performance/loss of power/hesitation problems!
- Steady CEL Light..p72 into vx (h22 eg)
- b18c1 backfiring and tuning?
- good head swap on my b20?
- 4th gen midshaft
- 98 USDM GSR w/ 98 JDM SiR-G ECU question
- KS wire location on Wiring Junction
- difference between ek and eg mounts for h22....will it work
- tranny swap into a accord
- ITR IMF on LS head
- b18c1 into 90 si hatch question
- h22 accord, no spark?
- h22 in to 97 accord ex problem
- b18c1 Problems! (searched)
- Fluids in swap?
- GSR crx, problems after OBD1 conv.
- obd2 wiring into a 92civic si!!
- type R alexs
- B18C 88 CRX Road Clearance Issues with this swap?
- K-series suprize.
- EG LS/VTEC Axle Replacment
- Is wiring the same for a jdm b16 as it would be for b16a2(99Si)
- The Code that wont die!, CEL 41 in H22 CX hatch
- Check out my K20a Type R swap into EG
- Swap help???
- Need to confirm
- How to get a/c in a 96-98 w/ B18c swap?
- GSR alternator w/ 96 DX wiring harness
- Swap Questions.
- b16a swap to rover 216gsi!!!
- b16 to 99 ex coupe
- 94 jdm B18C1 into 92 civic hatch vx
- ls/vtec need opinions
- vortech supercharger on B16A2............
- Doing LS Vtec, I have questions!!
- H22 axels
- obd2 gsr into 97 hatch...real easy...searched out.
- obd1 ls distributor into obd2 hx
- gsr into cx using EMS
- b20 v-tec which head
- k24 into 2000gsr
- 1995 accord tranny (f22) into h22 motor??
- Fully Built JDM H22A All Motor setup 12.5:1 CR, 88mm RS Sleeved, Portflow head, Skunk2
- hasport mounts
- smog ref won't inspect my car... SRS light non functional...
- GSR block fit B16 (Type R) head with no modification?
- Will Type R A/C Brackett fit 96 LS motor in EK?
- difference in header & cat flanges ...OBD0 vs OBD1 cars
- p28 hondata H22a ?
- b16 to b20, need help and info
- NC Bound this weekend so where is everyone?!
- ENJO B series engine mount kit?
- Check Engine light right after swap
- Need H22A Block...Please...Help
- Progress Coilovers for h22 hatch
- considering staying with a SOHC powerplant for a couple reasons...
- New Head Gasket Set
- flashoption.com customer. I ordered a front clip!
- flashoption customer. I ordered a front clip!
- Help Motor Mount INFO please!! PICS INSIDE
- 8 valve to 16 valve hybrid
- Some neat Hybrid's from the drift event at Road Atlanta.
- Where is my map sensor plug
- can 100+ octane hurt my motor?
- b20 sites?
- h22 jdm rear tranny mount?
- Anyone have a shift linkage pin + clip ?
- Cheapest OBD2 ECU I Can use for H22A (Smog Testing Only)
- K20A2 swap in NY
- OBD1 or OBD2 B18b in a 96 dx?
- friends car ran into problems...
- Code 41 O2 sensor help H22
- B18C or H22A?
- having problems with my b20b
- which CAI for b18c1 EG?
- b18c1 into eg questions.
- best engine for a daily beater?
- Crosspost: M2K4 Transmission?
- Code 36, possible Bypass???? (H22 in civic)
- 1996 del sol manual swap info
- Will a H23A engine out of a JDM Accord Wagon fit in a 92-95 Civic?
- What are my chances???
- 1996 Integra w/ Jdm H22a using a place racing mount kit? Is the kit Junk?
- condenser replacement
- What other engines can be swapped with a D13C?
- Request for Diagram for B16 Mainshaft and Countershaft assembly from Helms
- Mean Wobble after Swap, Cant get rid of it. Need some IDeas
- help with b16a in crx hf in maryland
- NTB: engine mounts
- Is it worth it..for me!? my '96 d16y7 for a 91' b18a + CA$H?!
- Check engine on a 95 civic
- B16A or B16A2....
- jdm trans. on sh block
- Throwing Check Engine Light on my H22A in my accord.. please help!!!!!!!!!
- Does anyone know the terminology or model number of old hondata boxes??
- getting code 21
- Help with JDM ITR into 92 EG hatch
- ECU problems-94 Del Sol Si/H22A4
- gsr in civic axle Qs (searched)
- f22b2 to an f22b1 swap
- need a/c help
- which body
- d series question
- Pressure plate has heat spots
- newb topic: 97 accord header for my 0bd1h22?
- EK K20 Maintainece work!! How hard is it?
- F20A DOHC INFO?
- CR-VTEC, which header do I use?
- Easier to use proper ECU than wiring?
- Radiators
- h22 exhaust question
- JDM b16 shift linkage, will it fit on a del sol? -----------=====
- for the H22er's.......
- k series bore limits?
- Interchangeable A/C Compressor with other cars????
- Axles
- 02 sensor question?
- ls/vtec swap question?
- What will I need to change to fit tein coilovers on a 98 cx hatchback?
- Shawn Hilliers EK K20 All Motor Swap Pictures
- gear ratio
- B18C rev problems
- VX Harness missing A17 wire..wtf?
- After swap questions
- buy complete changeover or buy parts by part?
- ls/vtec quetsion?
- Can a h22a auto fit into a 97 CL 3.0 auto???
- MAP Sensor?
- Whats Better a H22a longblock or h22a shortblock??????????
- Can someone double check vac lines
- FBR K20-1
- Need help with B18c5 into LS Integra
- good or bad? b20 bottom end and b16 head
- Will my B20b throttle body fit on my LS intake manifold?
- A have a couple of questions before I begin my H22A swap...
- dx distributor pinout
- highest horsepower k series
- ECU Pin outs..Where can i find some information
- wire harness?
- Need a quick run down of 92+ Integra models and ECUs
- After market front LCA's
- Which would you buy????
- How much?
- are oil pans interchangable? B-series?
- Crazy ECU problems
- Screw the K20. Here's the latest trend in Honda swaps
- shops to do B1bc or B18c1 swaps in bay area....
- k24 block, k20a head swap... whats required?
- b16a1 tps wiring question
- EG B series mounts
- 99-00 dx to EX help!!!!
- h22 eg .. alternatives?
- k20A into DA (90-93) integra can it be done?
- 1st gen b16a into 96+ civic
- VSS and vtec related?
- crank angle sensor
- f series into a prelude
- How to test resistor box?
- Wiring GSR into EG Questions
- process of making custom motor mounts
- Starting up Help!!!
- Installing JDM B16 in 97 Del Sol..questions
- Recommendations for a shop that does good, reliable b16a1+tranny swaps in Seattle??
- Need K series wiring diagram
- 4TH GEN WITH B16 SIR I RUNNING RICH????
- EG Illumina coilovers-Will they fit my new 91 CRX Si? Searched,no help....
- b16/problems/help
- Best Place to get B18B Swap for Del Sol?
- Vacum Lines for Map Sensor (h22-EG)...help
- How much on average would an ls/vtec setup cost?
- Accord motor mount question
- K20A Type R
- b20 vtec timing belt
- Which L bracket for delsol b series swap?
- revlimiter Q on my 95 gsr ecu
- b16a Code 16
- What is this?
- ecu help needed
- crx b16 swap troubles that i am having
- K20
- Swap Differences/opinions, B16A (Vtec) or B18 LS non vtec
- need honest answer no bull
- Engine will not crank on H22 EG Swap, electrical?
- Do B16A Gaskets fit on B18b
- Modifying HCP crossbar (EK H22A) for traction bars?
- JDM b18c GS-R
- Few questions about B20zr swap into 00 SiR
- zc head d16a6 block
- B16a turbo or b18c GS-R?
- check out my set up and help me ...
- CALIFORNIA peepl. BAR questions
- EUREKA...Got the motor started (H22)
- Putting EGR system on JDM ITR motor...
- Question about my swap. 1995 civic hatch cx w/ jdm b16a
- ebay hasport replica h22 mm kit
- Will a 96 ex engine harness run a 98 b16 ecu with out modification???
- Looking for Swap Guide
- B18C1 into 90 EF hatch- need parts list
- JDM TypeR K20 to US EP3 swap, what is needed?
- b 16 intake manifold on a GSR
- axle issues (b16a1 into eg)
- zdyne install ?
- Auto to manual swap?
- Axel Moves Up/Down @ Intermediate Shaft? Half shaft Bad?
- Teggy-Civic gsr-type r??
- h22a woes
