PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 [76] 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. obd2 D16y7 into 92 CX Need Help!!!
  2. 1/4 eg civic with h22?
  3. K-series EK mounts.
  4. h22 question
  5. what would be the best tranny?
  6. hmotorsonline.com
  7. b20b vtec what kind of head bolts
  8. GSR crank same as ITR?
  9. H22 guys... looks like I will be building my motor, wish me luck!!
  10. what engine is this and what will it drop into
  11. Please Help!!
  12. Help No start on B18c in Eg
  13. D15B auto swap to D16z6 manual how to do hard
  14. Problems on the track with my EG-B18C5
  15. f20b axle probs
  16. obd2 distributor ??
  17. recomended super quiet (stock almost)exhaust for b20vtec.....
  18. -89DX Hatch, 01 EX K20a Swap-
  19. d15block d16y8 head vtec ? will it fit ?
  20. ECU for H22 00' Si
  21. Did k20a.org get hacked???
  22. Are the obd2b auto wire harness the same as stick?
  23. problem with b18c1 into crx si
  24. alternator for my 1st gen b16
  25. GSR motor sensor?
  26. heed hepl fast b18c1 crx
  27. h22 woes help please
  28. Anyone ever put an F22 into a Civic???
  29. Anyone have an EG gauge cluster pinout?
  30. CRX W/B16 Help!
  31. LS throttole body on GSR manifold--Custom throttle cable bracket
  32. Older engine, Newer car
  33. f22 block h22 head
  34. Tired of searching-h22a swap into an eg civic
  35. RB26 into a 350z
  36. Installing a intake manifold on h22a in the car?
  37. Ek..K20a2 ...wiring info...help...
  38. Del Sol Si Engine Into Civic VX
  39. Best choice of Engine to Transplant into a 76 Austin Mini
  40. LS swap in an EG
  41. aall this talk about K-series
  42. crx/b16 swap help
  43. Ls/Vtec Gsr Rods
  44. automatic to manual change
  45. The early model all-whell drive civic......
  46. b16a2 problems all over the place please help me out guys
  47. D16 mini-me swap!!!
  48. OBD1 Conversion many CELs One problem?
  49. Double checking before i start my swap.
  50. F-series and H-series compatible?
  51. Newbie question: How can i tell if the head is a b16 or b18c1?
  52. 89 CR-X Si - B16A - OBD0 to OBD1 Problems
  53. need help with wiring b18a into my 90 civic si???
  54. CTR or ITR parts in my GS-R civic?
  55. 95mm crank which rod to use
  56. anyone here use a NSX airbox in their bseries EG?
  57. 1993 CX and OBD1(1995) GSR - O2 sensor question
  58. H22 with my suspension setup??
  59. is my ecu obd1 or obd2
  60. LS/VTEC Question!!
  61. h22 swap in 6th gen accord???
  62. diff
  63. quick question
  64. Compression of an ls-vtec ???
  65. CTR Suspension in a GSR?
  66. B20/LS vtec owners.. are you loosing oil??
  67. LS swap in a Canadian EK - ALT. wiring????
  68. ideas on ls/vtec
  69. gsr in to civic odb1 to odb2
  70. Possible to have A/C in DC2 with K20?????
  71. Can you identify these Motor Mounts??
  72. type R midpipe i need help!! very important question!!
  73. ADVice for swap preparation
  74. Best engine suppliers in the southwest area?
  75. New Darton Location!!!
  76. Brake Lines for cx/si swap
  77. Prothane Insert on EK
  78. 3th gen accord/5th gen prelude
  79. Best suspension for my situation?
  80. Fitment Problem
  81. eg h22 swap auto swap instead of 5 spd
  82. Rear Bracket help
  83. B20vtec or GSR????
  84. k20a swap in a EG
  85. 95 Prelude H23 to H22, axle problem...
  86. SK7-7 JDM integra shaft or crx??
  87. H23 EG swap? anyone done it?
  88. Where can i take my H22A Motor in NOVA Virgina
  89. OBD 2 SOHC ZC engine WTF??
  90. WTB: mini me swap plugs, iacv 2 wire, vtec 2 wire, and vtec 1 wire.
  91. FWD platform to RWD platform
  92. guyages not reading.. just did a swap.
  93. h22 mounts
  94. Need Internal Specs
  95. k24 complete swap to gsr body will it fit?
  96. Anyone install a ITR trans to a B16A2?
  97. any help with a 3.0l v6 in an ek?
  98. D15 to German B16 swap
  99. price of a b-series tranny
  100. www.streetimports.com B-series engine mounts for an EF good? bad?
  101. LSD TRANNY
  102. D16A8/9 in EG4 Civic
  103. need help!!!!!!!!! wit B18
  104. B16 (USDM) Pass Emissions In CA?
  105. B18 engine harness HELP!!
  106. Throttle cable for 95 B18b swap?!! Help please
  107. jdm b18c ecu question
  108. another no spark thread..
  109. Can you swap a h22a head to a h22b block?
  110. How do you take of a h22 crank pulley?
  111. HCP H22 mount issue, anyone else have this prob????
  112. Hybrid H22 oil pan question....
  113. d series swap
  114. immobilizer problem
  115. Looking for DC5 ITR Motor
  116. Integra SE to JDM ITR motor swap....
  117. skunk2 h22 manifold in ek?
  118. vtec press.switch?
  119. vtec press.switch
  120. Doing a Great motor swap and build need help??????????
  121. ek civic with hasport mounts
  122. gsr tach into 92-95 civics
  123. which top radiator hose to use in an ek9 b20 swap
  124. Cable H-series VSS?
  125. JDM DOHC swap probs
  126. 98 Type R keeps Boiling Fluids, Help, Last Resort....
  127. k24a2 Tsx Engine
  128. Need help on parts I need for a Built Boosted K20a into a 2000 Si
  129. Making your own header for your hybrid? How Hard.
  130. Swaps, engines, steering racks, brakes, steering wheels and more...
  131. questions on weight distrubution
  132. Thanks
  133. i am a little lost on the ecus
  134. Check out this 2nd gen civic swap!
  135. JDM source in Calgary, www.jdmsource.ca for JDM motors?
  136. gsr disc onto 92 hatch
  137. 97 JDM B18C Type-R Motor in a Civic Si?
  138. b18c in 94 Civic ecu question
  139. HELP!!! Engine missing at 4000 after swap
  140. Civic hybrid(00 ITR) VTEC problems, please help!!!
  141. Anyone have a new 05 Civic Hybrid? and i do mean the gas/electric.
  142. 94 civiv EX with 95 LS motor won't rev past 6000
  143. stuff i need for an H22A Swap into a 98 civic hatchback
  144. b16 cams \ ITR cams
  145. 95 Accord Manual to Auto swap H22... engine not sitting level?
  146. RS*R EXMAG GTII cat back?
  147. HELP!! finished a LS swap but it wont rev past 2K RPM
  148. what year exactly is a JDM D16a???
  149. Engine for Ek9 Help
  150. ls v tec swap
  151. zc motor swap
  152. skunk2 camber kit from a civic to an integra?
  153. HELP!!! H22 swap into an EG hatch
  154. HELP NEED PARTS EG H22 SWAP
  155. H22 Civic ECU Reseting Problems
  156. B18c swap
  157. Yet Another No Spark Problem (searched)
  158. h23 manual tensioner install into swapped EK
  159. 99-00 Si harness, how can you tell?
  160. b18c in em1 chassis
  161. Things Needed For a LS in a 96-00 Honda Civic
  162. LS VTECH RELIABILITY
  163. need help with b18c into eg6!!!
  164. Integra LS with SI tranny swap
  165. help h22 swap eg missing at part throttle
  166. quick block question
  167. Whats up with all the extra wires on the OBD0--->OBD1 harness conversions??
  168. H22 CRX axle Question.
  169. h22ed coupe mix and match harness question.
  170. Using a P72 ecu on an LS swap
  171. need help!!!! IAT
  172. Tranny Parts swap question
  173. h22 swap questions.
  174. Calling all experienced H22 Civic owners...what has been the best suspension for this set up?
  175. Can I trust these guys?
  176. Need help diagnosing my Check Engine light issues..
  177. Adding a crank fluxuation sensor onto a OBD1 block
  178. wich ecu to use?
  179. b20vtec pcv system
  180. for those who swapped a b20 in place of there sohc vtec Q
  181. 2nd Gen Jdm B16a Problem In Friends Hatch...
  182. Shop in Tri-state area (Northeast)
  183. obd1 dizzy on obd 2 vehicle??
  184. please help h22a into 90 accord
  185. 96 ITR conversion on 99 civic hatch????????????????????????????
  186. Differential Questions
  187. I searched... cant find what i need (b20 intermediate shaft)
  188. Integra B18 RS to B18C5 Type R swap
  189. Boosted B20 VTEC or Boosted K20a?
  190. B18c Auto into EG dx auto???
  191. Need a step by step parts and procedure listing for a LS swap into a 89 CRX Si
  192. VTEC problems
  193. LS/VTEC & Oil Squirters
  194. the story of the 94cx hatch, the p28 and the 2001 gsr motor....come, and live the adventrure!
  195. New engine, now throwing codes.
  196. im gonna b lookin at a h22 swapped eg,,tips on what to look for??
  197. hondata and ecu prob
  198. got the engine running but the battery will not charge
  199. where can i find these parts?
  200. Belt squeal after putting in a B18C into a 98 civic
  201. 96 Civic with 98 LS swap...NEED HELP
  202. wondering about a swap
  203. 99 ek h22 swap "sputtering"
  204. Will F20a trans fit F20b?
  205. LS Block / Type R Trans
  206. dc linkage for b series in my ek, would it cause this??
  207. Oldie....
  208. h22_hatch_trans_axle_sensor_hoses_ecu Q's
  209. Just Installed Comptech ITR Header and ITR Cat. on my 95 Coupe****LOTS of PICS***
  210. i searched and need help fast
  211. clutch/master cylinder for b-series swap??
  212. jdm h22 into 92 civic ex sedan,what header can i use?
  213. 5cyl turbo civic?
  214. k20a? b18? h22?
  215. B16A2 into EG.... which axles?
  216. 94 del sol linkage question
  217. SEARCHING FOR BEV !!!!
  218. B18c5 into 98 LS
  219. Newbie needs some help/advice.
  220. ecu pin out
  221. Cold lower radiator hose?
  222. Golden Eagle LS-VTEC conversion kit
  223. My Hybrid 95ex Civic Coupe GSR-96 missing EVAP and Solenoid can i use other
  224. Possible V-Tec problem
  225. p72 & p30 oil pans?
  226. obd2a car---obd2b motor-->obd1
  227. can you guys tell me what kind of harness this is?
  228. what is this? under the throttle body? victor x install!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
  229. Hoistless engine swap?
  230. b16 into DA chassis!
  231. Throttle position sensor question
  232. 94-95 OBD-I motor in a 00 teg..possible?
  233. I think i have fuel problems.
  234. Anyone know what mounts these are?
  235. Ideas to help me build up h22a swap???????
  236. My K20 EK mounts stolen!!!
  237. gas problem help please
  238. d15b
  239. K20 into EG/EK, what axles to use?
  240. si rear mount for b series...i dont get it...
  241. Mikes01GSR is the most HONEST SELLER on H-T, llok what I got from him....
  242. b18a1 swap
  243. Shops in MD that do b-series swaps?
  244. honda civic will not start
  245. H22a4 swap, TDC&CKP sensor locations OBD2-OBD1
  246. mini me problems
  247. 93 Integra axles when Swaping H22 into EK... Need Help Please!!!!
  248. will 95 gsr axles and half shaft work in a crx si swap?
  249. convert JDM to USDM
  250. b20 vtec fuel in exaughst manifold. need help
