HELP: 1995 civic with h2b swap
Got h2b swap in today... Crank over has fuel but no spark... I used stock harness wired in resistor box and extended all nesserary connectors. Is the h and b Series wire the same to the distributor or can it be something else any idea anyone
Re: HELP: 1995 civic with h2b swap
Wiring is all the same. If you don't have spark. Maybe one of your ignition components is dead. Make sure your motor is properly grounded and your firing order is correct. Otherwise try and find a known working distributor and go from there.
I'M getting a code 8 TDC sensor that wouldnt have nothing to do with it... Read online jdm h22 don't have tdc sensor... I have a chipped ecu from pherable
I'd start by checking the wiring you extended. Did you mess with the distributor wiring? What year is the motor? are you using an obd2 or obd1 distributor?
Did not mess with distributor wiring... It obd 1 motor not sure what year of motor but also obd 1 distributor
Make sure its in the right way and your timing is spot on. I'm guessing it could be messed up if your dizzy is 180 degree's off. Or like i suggested earlier, try and find a known working unit to try.
Still waiting for new distributor hopefully be here tomorrow... But did some test... Distributor has power to it but still no spark... Making me believe it the distributor... Hopefully it fixes it dying to drive my car :-)
