View Full Version : Hybrid / Engine Swaps
- Type R LSD in a LS Tranny
- what would i need for a b16a swap for a 91 civic si?????????????
- h22a distributor wires
- JDM ITR MOTOR MOUNTS? HELP PLEASE...
- which 02's to replace pw0 o2's
- First Gen B16a Driveshafts on B18c1? / Where to buy Driveshafts online?
- LSVTEC Guru's
- I need info on civic motor swaps!
- reccomended spring rates for H22A turbo
- b18 into a CRX shell then turboed? how possible?
- H23 swap in 96 EK... wiring questions
- d15b vtec SUCCESSFUL SWAP!!!!! YYYYYYYYYYEEEEEEEEEEAAAAAAAAAAAHHHHHHHHH
- LS-Vtec setup Qs
- NEED HELP
- Purchasing a B18 swap...will I need anything else?
- sohc vtec turbo swap into ef
- Need help with hatch
- h22a7 wiring diagram needed
- h22a ecu problem
- motor swap help??
- obd2b->a then obd2 ->obd1?? too many harnesses?
- Hydrolic Transmission To Cable Clutch Help?
- 99Si B16A2 into 96 coupe, need help
- Raxles hybid axels
- Do you need to replace your pistons when doing an lsvtec?
- h22a question for swap
- 2000 civic driverside mount.
- Need picture of Greddy EVO muffler on a EG hatch
- H22A fitting in a DC4
- EG/EK H22A Intake manifold nuts/studs - common problem w/ stiffer motor mounts?
- Hole in tranny - add ins (trans, transmission)
- zc swa to b18
- lsvtec: which timing belt
- ECU delema
- 2000 Teg ....what ecu to use?
- mini probs
- can i swap a k20 into a 92-95 civic hatch? any help or info
- Educate me about tranny swaps....
- M&R Racing??
- B18c5 into ej1 auto harness ?
- B18 Swap Question
- Helms Link
- Painting engine bay
- Few Questions? swap related
- k22a engine mounts
- Oil Pressure Switch Problem on LS/VTEC /Low Oil Pressure - PLEASE HELP!!
- ODB1 or OBD2 distributor?
- Gsr dipstick longer than b16?
- obd2b b18b into obd2a hx, how different are the obd's?
- H22 swap into EG hatch questions
- CA engine swap emission question
- auto to manual conversion in my eg with h22 swap. Do i need any auto to manual mounts?
- 90 Civic LX bolt in motor swap?
- will my stock cx 1994 radiator work with a b16 sir II swap in it?
- OBD0 B16A in EG OBD1 Hatch
- Civic engine swap
- Tranny mount help???
- Driver side torque mount. which one?
- 99-00 Civic SI aem cai intake fitment
- 92 Civic SIRII
- Does power steering pump fit B16 conversion in CRX??
- Finally some Dyno Numbers..
- Maybe Overheating?
- Swap D15B
- skunk2 intake manifold intalled in eg with h22 swap reveiw
- Swapping Just the GSR Rotor and Caliper on a 98 Civic DX? Can it swap over
- got a H22A1, made a list to see if it is all what i need. help me out
- D16 Turbo
- ITR manifold on b16 JDM SIRII vs b16 stock manifold
- Getting engine ready for storage?
- JDM B18C INTEGRA TYPE R $3000 Complete
- VTEC ISN'T ENGAGING!!!!HELPPPP
- head swap? B16A --> B18C or H22
- h22a fuel injector upgrade
- My project pics!!!
- o2 sensor question
- Which intake for h22 eg?
- ok throttle prob
- how to identify axles???
- B20 swap
- broken crank pully broke. any ideas how to get it out?
- Hybrid CV Boots Help
- H22 EG axle problems!!
- Question for all you Honda junkies...
- B-Series header question
- AEM/DC Sports needs EG/EK/DC2 w/k20 swap....
- Jdmshit.com
- obd1 vs obd0 resistor box for rc 550 p/h injectors
- install jdmshit chip in p28 for h22
- Enjo HCP or Hasport mounts for H22 into EG - What do you guys recommend?
- cx engine harness onto a d16z6?
- ls vtec question
- b18a1 motor into crx
- Good price for a used b20z2 short block assembly?
- Simple question, yes searched, yes looked in the sticky..
- Need some help...car bogs..kinda long
- Q? why do you lose your power steering with the k20 swap
- Supercharged b18c1 starting and idle problem
- ls-vtec budget setup
- LS head on a B20 bottom??
- TPS Sensor Issue
- LS/Vtec engagement
- Del-Sol Swap
- SIR-G Swap
- code 4- runs fine one day... shitty the next!
- How much weight B-series swaps add to a civic?
- H22 Tranny problem
- d15b vtec helppppp
- 92-95 Hatch H22A 3AB Computer trouble code 43
- Are you an emissions whore?
- OK !!!!!!! WHAT EFFIN ARP BOLTS FOR A B18A1 WITH A B16A1 HEAD !!!!!!!!!
- 96 prelude h22 swap!
- Custom ECU conversion harness for an........Odyssey?
- Is This The Wrong Mount?
- cel only when car turns off.. ek/k20a
- Converting obd2 motor to obd1
- good place for transmission
- EK's with B series swaps, i got a question about distributors
- k20 swap
- Front end help?
- Need help
- help me rid the last check engine light
- Timing belt tensioner difference? Poor man's r help!
- which motor
- Type R wiring harness: ? plug goes to ? sensor...
- flash codes b16a sir2 into eg
- Weird question about the TPS and Vtec on my h22
- swap help please
- HELP!!! getting tranny off, stuck at last step....
- My new setup...will I be able to hit 200whp?
- b18c5 motor question .. .. ..
- DESPERATLY need help EG H22a problem NOT RUNNING ANYMORE
- (b18c swap) idle issues
- Does a B16 IM fit a B18B
- Help! Code 13, JDM H22A Civic
- Need Help H22 or Boosted LS?
- BIG PROBLEM need new motor mounts for H22A EG but stock locatation cut off
- HELP!!!....motor swap now trans wont engague into gear
- Where can I get factory wire harness plugs and pins?
- H22 and F22B2 wiring harness questions
- CEL 10...
- h22a axels question In 1994 CIVIC HATCH
- B-series suspension swap on EF hatch????? please help...
- B17a w/ sir1 head....rev problems
- b18c1 swap into EG(looking for step by step pictures)
- i am trading my gsr engine for a LS and a turbo kit have questions.
- slave cylinder
- New Shop feaature LIVE WEBcam Video Feed
- h22a obd2 injectors problem??
- P54 A/C bracket question?? help!!!!
- EGR lift valve solenoid
- h22a7 DC2 wiring problems (using LS Harness)
- engine harness?help
- tensioner b18c1
- 95 hatch with B series swap, and hydro Y21 tranny... axle question
- Need help to decide between H22/JDM F20B or K20 Swap into a 92-5 Civic
- HELP PLEASE with B18C Swap
- H22A Civic Tach and MPH question
- how 2 disconnect shift linkage 99 ls
- Has anybody SUCCESSFULLY had their ECU reprogrammed (immobilizer) at the dealer?
- b20z head parts interchangeable with gsr head?
- Throttle Cable on H22 civic 92-95?
- I am new to the Honda cars need some help!
- B16A3 / GSR Tranny / 95 Civic - Which axles?
- best wire harness???
- OBD1 motor in a 2000 si, possible?
- Power steering question
- NO VTec after rewiring
- H22eg "shakes"
- searched. K20 custom oil pan
- EG/H22a EURO R Manifold Vaccum (HELP)
- running verrrrry rich!
- got money in hand for B-series swap
- vafc on a stock motor???
- b16 in a 96 del sol
- b16 sirII into 99 Ek Hatch
- B18C5 eg hatch or h22a eg hatch
- d series thermostat and water pump b series compatable?
- did anyone know that its brian g's b-day today
- no spark or fuel with h22 in eg
- b16a into mini cooper, Tranny question!!!!!!!!!!!!!!!!!!!!!
- hey i need lsvtec help in the next 10 min lol (water pump)
- how do i wire up dsm injectors to my 96 civic harness?
- Questions about 95 gsr swap into eg
- Not Sure What To Name The Problem
- Turbo H22
- is it normal?
- '00 B18C5 INTO A 94 CIVIC HATCH (4 ?'S)
- 99-00 SI harness question
- B series in a Mini??? WTF???
- 2000 hatch throttle cable question
- gsr into em1/99-00 SI
- Primary o2 Male connector? Male connector on harness too?
- need help asap!!!!b18b to b18c5....Which rear bracket?
- WARNING for any one purchasing k20eg ,k20 / k20a / k24 mounts
- Problem wiring B16 distributor into Si CRX harness - engine conversion
- b18b block with b18c5 head?
- Re-drilling Prelude VTEC rotors to 4x100 - Share your techniques please
- evap Q?
- can i use an integra radiator with a b1.6 on my 1994 civic cx?
- GSR swap throwing codes, got some questions
- B-series into EK.... need rear Si mount?
- Turbo Question
- Radio Frequency Interference
- problems with the egr lift sensor
- b16 or h22a swap on a 92 eg! which one?
- 2nd gen JDM B16A with EDM B16A1 ECU
- D15B8 block with EX head
- broke an eh22 hcp mount....
- Strange situation
- Gauge cluster problem...
- 350 Small Block Chevy into a 90 Civic hatch,no joke.....
- issues with hubs/knuckles 91crx hf +b16a
- ITR sized B-pipe and axle back on EG???
- help with cel 21 on b18b.
- 99 jdm b20 longblock in 99 Si, not running please help
- H Series Swappers... (eg,delsol)
- turbo b18 startup...
- Code 43 help
- brake swap teggie to civ??
- Advice on removing front engine mount on B16 into CRX conversion????
- 1985 1500 to 1985 1600 ... I think ...
- Please assure me that I understand this correctly
- hiding safc or vafc for CA BAR reff
- 98 GS-R motor in 96 LS
- radiator hose differences
- CX rear brake swap
- ITR LCA's on gen2teg.
- reputable shops in sacramento?
- intermediate shaft pics?
- h22 seafoam carb
- will a 1 gen integra tranny fit any of the later models??????????please help
- delsol =civic
- d16z6 head with d16y8 bottom?
- every that has a swap...lets see who paid the least...
- Which lower timing belt cover do I use?
- How much could i sell my LS/vtec for
- h22 injectors on type r swap
- Fuel Delivery Problems
- insight B-Series swap
- Tranny/axle problems
- Who has gotten their ECU reprogrammed at the dealership here? I need help..
- 89 civic b16a swap wiring info
- Looking to buy an adapter harness for APEXI POWER FC for 92-95 civic
- 92 - 95 Civic HB Swap Question
- So... my car runs w/o the resistor box
- H22 in 93 CX hatch, wont rev past 2,000 still
- swap came in today....white stuff in head
- Hasport way of wiring O2 sensor (EF B16)
- h22 into 92 cx
