View Full Version : Hybrid / Engine Swaps
- vtec not working (cel vtec pessure switch )
- h22a into 97 hatch
- junkyard in chicago
- Green sensor next to Vtec sensor
- H22A2 Tranny on a H22A engine
- swap budget what would be best????
- engine stsrts but wont rev
- Single o2 in obd-0
- Possible LS Vtec Setup
- hasport axles ?
- zc vs B16A
- anyone interested in purchasing a guide for K series into eg?
- good turbo kit for 1st gen B16a
- 1982 Civic CVCC >Engine swap<
- help with swapping an H22 into a 00 civic ex
- Need Help! Finished H22 swap in 97AccordAutomatic
- intermediate shaft, stripped bottom bolt hole. wtf now?
- someone please confirm this information i have
- JDM Integra R K20A vs. JDM CTR K20A
- Fs: 2002 K20A2 Motor (Type S)
- quick 5 lug swap question
- HELP; What CAI for a 88 Rex w/ B18c5?
- Mini-Me Swap info.
- gsr vs poorman type r
- zcvalve cover gasket
- H22a 4 Into 97 LS
- ECU Code 21, 41, jdm gsr into EG, first time swap, pls help!
- vtec controller question
- B16A2 Motor Swap to 88 Hatchback DX or 90 Hatchback SI
- h22 ek iac problems, i've already searched
- LS VTEC question
- swapped..now car wont start. NEED HELP
- Is there anyone who can help me put a JDM ITR cluster in my crx?
- Can't get freakin pass. side axle in Tranny WTF!!
- distributor brain fried...what to do??
- where to buy
- B16a Swap problems (Kinda long)
- the freakin crankshaft pully wont come off
- b16a1 turbo swap into 90 hatch- what clutch
- calling all 92-95 civic CX w/b16a
- dohc zc for 92-95 civic?
- B18C GSR JRSC or Vortech
- Building a daily / Weekend race car.
- ignition output signal
- No fuel pressure after engine swap
- Can Zydne convert a pm6 ecu to support b18c1 dual runners?
- RSX brake swap into eg??
- b16a swap question
- ODB0 hatchback +99 si B16A2 OBD1 programming. im confussed!
- are all the distributor bolts needed?
- Dropped the H22 in my ek today... pics of some of the tight points!
- can you use the endyn breather kit on an LS
- Question about converting jdm type r to OBD1
- 92 JDM b16a vtech in a 89 civic dx
- For all who were wondering... B16a harness into a 91 CRX...
- H22 civic axle question (92-95 civic)
- 97 civic h22a codes and wiring
- welding b16 mounts
- LsVtec whats the real deal??
- 99si in the itr
- B16A 2nd Gen OBD1 into 2000 Civic M/T..Mounts??
- 93 civic si prop. valve/master cylinder into eg dx?
- 98 usdm b18c1 swap wiring help plz
- Help me identify parts from this head
- K24 Frankenstein swap For Sale
- Progress springs for Civic w/h22 swap
- LS/VTEC
- Can I use a 99-00 Civic Si engine wire harness for my 99 Gsr swap?
- LOOKING FOR BEST ENGINE SWAP,FOR A 97 ACORD
- ECU numbers? Problem maybe...
- obd0 b16 in a 96 EK, few obd questions
- which belt ?
- da shocks in eg
- jdm b16 same as usdm b16a2
- Difference between B18B & B20 head?
- SHIFTING FOR H22 TRANNY IN EG BODY/ 3 OR 4 MOTOR MOUNTS?
- 220bhp h22??
- 4th gen. to 5th gen.?
- GSR Swap Pleeeasee help
- SNEEK PEEKS: TECH43'S K24 EG4 VTi AKA "ktwizzle"
- J's Racing intake application question...
- Unique swap situation, not your everyday deal...ideas?
- FS: H22 Bare block
- LS/VTEC VS GSR WITH CTR PISTONS
- ZC Swap 92-95 in a 88-91? Please help
- need ctr pistons help
- OBD2 Motor into OBD1 Car
- D-series motor swap online or bay area?
- Mount Bolt Breakage
- B16A (non-ODB) good or bad thing?
- 30000 miles on lsvtec
- HELP!! eg-gsr dying out at stop =(
- what would be the best swap for my 89 civic?
- 94 B18C1 into 00 Civiv DX
- Throwing a CEL 54 CODE, I need help..
- Trying to find out exactly what is needed to swap b16a1 into 88 CRX Si
- car still runnin hot,fan wont turn on!
- Small Hole in GSR tranny .. Can it be welded up and fixed?
- this is not a bolt in swap a lil welding is needed
- EG with b18a swap help with speedometer?
- Flywheel inspection/cover plate.
- Clean o2 wiring question.
- Pics of cable trannys in hydro chassis
- Cat problem, any suggestions?
- Question regarding CTR tranny
- H22A2 Vs H22a
- FITV , does obd1 ECU look for it?
- AC/power steering in a hatchback EG with an h22a
- motor throwin code 8, tdc position, how do i fix it?
- POST YOUR 1/4 MILE TIMES FOR B18C1 EK HATCHS HERE
- ECU chipping/reprogramming
- finally finished the h22
- H22 close ratio gear set
- June 12 Danbury meet, who's going?!
- Axles binding ? (H22A in Integra)
- b18c5 what ECU to use?
- B17A1-->(what car did it come from?)OR B16A1
- 02 sensors for jdm b16 in a crx
- H22 EG's 1/4 ET
- Possible Ls-Vtec setup
- D15B7/D16y8 Swap Timing Belt and Head Bolts
- code 20??????????
- Best route to take on H22/h23 swap into eg hatch
- Hybrid Automotive anyone? bay area
- pp5 on a d16a8 / same error codes?
- need mad help guyz anyone plz!!!
- Spark Problems
- d-series tranny bolts campatible with b-series?
- My H22 civic review with Hotshot header
- stock 28 for b16a3
- b18c1 CRX Tranny swap????
- h22 swap EK, STUDDERING/BOGGING problems!!!
- bad battery/no start troubles.. please help....
- oil pan help
- h22 ek swap
- A couple of questions for the JDM H22'ers
- H22 ecu question
- Tranny Swap...
- which sensor is this?
- Kseries mounts
- LS Vtec
- b16 head on b18 block
- B-series Axle question
- converting eg into OBD2 for smog...
- o2 question....try and help :(
- FINALLY COMPLETED MY H22 TURBO! CHECK IT OUT!
- what do you guys think about this K20a motor?
- H23 TB on H22
- chip auto pr3 to manuel?
- Auto/Manual Mount Bracket Hight
- Which exhaust to use
- 90-93 ls swap to gsr what is needed
- !!!!!!tach jumps around when driving, help with the problem
- h22a vs gsr
- sohc hybrid
- which ecu came out of a 1991 civic si?
- 99 gsr wire harness diagram
- ITR intake on h22
- b18b swap into 94 civic vx help!
- Can i swap final drives from an cable s1 to a y1?
- Help me figure out why my car is slow
- jdm type r B18C-R
- Distributer Wiring Question *LS Plugs into EX harness*
- Distributor fittament question
- B18b1 questions.......
- alternator for b16a1
- what do i need to put back ac in my b18 eg
- B16a Harness Wiring on a EF... help =(
- How long (time) should wiring take on a b16a/crx hf swap?
- OBD2 B16A2 wiring in OBD1 93 Civic DX
- gsr swap no power above 6 grand
- Question involving O2 sensor
- First problems of swap...
- CEL code 4 (crank angle sensor)
- throttle cable for ITR swap into 92 civic ex
- K20 --> 96 integra
- 91 Civic EX GSR swap ...keeping AC
- b20vtec timing belt off half tooth
- LS VTEC Info
- obd conversion question
- Problems with starting the car.
- h22 eg guys... heres something to protect our headers.
- b16a SIRII into a 99 dx
- Nice EK Hybrid for sale
- Need Help!!! w/ Rev Limit at 3k
- H22a or B18c ( JDM Type R)
- hey katman help plz
- Accord Swap Question (Need Help Quick!!)
- 88 crx dx, brake booster is gone, any options?
- compression is good and burning oil?
- Crx
- My first swap questions...
- 92 Si hatch with 96-97 JDM B18C-R question
- b20vtec or h22a in eg civic?
- Can someone tell me what ECU this is?
- how can tell if your b20 is JDM?
- WTF kinda ECU is this?(56k ?)
- GS-R Swap re-wiring
- newbie question.. 5 spd
- S2000 Steering rack swap into Integra
- Do JDM ECUs communicate with OBD2 scantools?
- h22 ek civic carbon monixode problem in car..
- How do I put A/C back into my h22 ek civic?
- Poor mans type r questions
- im a new kid with a question.... d16y8 swap into 95 dx coupe?
- ATTN: ki11a8ee
- 1995 Civic EX swap - D16Z to D15B JDM - worth it?
- bay area shop to do B16A2 motor swap..........
- questions on poor man itr setup?(b18c block with b16a head)
- SKUNK2 IM on a 1994 B18C
- JDM ITR complete swap into integra, legal smog and CARB
- what car did the j1 cable transmissions come out of?
- Tein SS for 98 Civic B18c1 swap...which spring rates, Civic or Integra?
- B18c1 in 98 Civic HB....Should I get Tein SS for Civic or Integra??
- f20b wire diagram
- disk brake swap...88 civic...
- rear motor mount bracket
- HUGE dilemma: Blown headgasket after GSR swap in EG..HELP!!!
- Helping friend with b16 swap can he use a Gsr wire harness?
- Obd 2 d16zc
- GSR Swap EK HELP!
- B20B HP numbers anyone??
- jdm parts (help)
- "chipped" ecu's and sensor issues...
- Is there a possible swap for this Honda??????
- jdm type R into american GS-R
- f22a6 into 92 EG hatch
- what is the part next to my rear mount on a b16a?
- CRX w/ B, changing clutch, drop trans or pull engine?
- What cars from other manufacturers can you bolt in a b-series?
- b20b... VTEC is not kicking
- CRX + B18C + JRSC (searched)
- H23A non-vtec in 92 accord...what drivers side axle do i use??
- ITR Aluminum A/C Mount
- b16a1 in to 91 civic si
- California BAR Sticker on a stock motor?
- intake swap???????
- will a 91 integra hub AND knuckle fit my b16a1/crx swap?
- Finally, the TRUTH regarding K-Series vs. B-Series engine weights!
- Down at the ECU on a 94-95 GSR what wire is the Tach wire?
- gsr harness??? a little help plz
- h22 civic which fuel filter?
- type r swap
- 99 civic si vtec wires
- b20 timing belt, b18b1 timing belt...same?
- Help Newbie
- a few questions pertaining to fluids with a B18b
- getting back into hondas again
- Start procedures after swap????
