What o2 to use?
Re: What o2 to use?
heated 02 sensor, 4wire
Jeff says
You should already have it all wired in depending on your chassis harness, it will just have to be extended likely to reach where it goes since stock location is just over the trans to the manifold. I used the one off of my D-series for my h-swap, no code, its obd1 so yeah, take it as you wish.
search suggestion "ls vtec o2 sensor"
Jeff says
If the head is a 1st gen B16 head, then you'll need the one wire O2 sensor from any 88-91 Civic/CRX, or 90-91 Integra.
If the head is OBD-1/OBD-2, then you will need the 4 wire 02 sensor, in that case, any 92+ Honda/Acura 02 sensor will work.
HTH
-Jeff
HTH
-Jeff
