PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Axles for B16 swap
  2. SMS Header Prototype #5 Polished
  3. EK B20/LS swappers, why is my car is still leaking coolant?
  4. B20/Vtec swap installed and built by K20eg
  5. What axles for 2000 LS motor in my 1999 DX hatch?
  6. My new Header Hotshot installed (h22a-EK)
  7. Which wire harness for b16 EF swap?
  8. B18C1 is making a scratching/shutter noise at specific rpms on dry revs or under load
  9. anyone ever heard of a od2 p28??
  10. B16a1 into 95 ex !!help!!
  11. could i be starving my motor of fuel ?
  12. pins for the shift mehcanism ?
  13. h22 eg vaccum line diagrams?
  14. J's Racing on B18c in eg ????
  15. b18b swap in eg
  16. any plans to make a k20 mount kit for DA's and EF's?
  17. Where to get 90-93 Accord half-shaft?
  18. just got my eg
  19. Where to buy engine in South FL?
  20. D16 Y8 INTO A 89 CIVIC
  21. 2000 Si engine into 2000 EX
  22. motor mount help
  23. Electrical ground point for EJ6
  24. H22 guys... Header is in and me likey!!!!
  25. B16 SiR II into a 98 DX
  26. best model CRX for a B18C swap?
  27. 1990-93 Honda Accord H23 Swap Questions
  28. Euro R in EG Hatch What ECU or EMS Should I use?
  29. all wheel drive civic?
  30. Any Ek's with big Front Mount/stock front end??
  31. h22 swap problems
  32. LS VTEC or GSR in 95 Hatch...
  33. whoa found a good deal on a b18c type r do I do this or ls vtec?
  34. H22 INTO 92 CX HATCH NEED HELP.
  35. A Tein Question....Wheel hop
  36. Those with H series swaps... Read and answer these questions...
  37. b20z 85mm sleve or not
  38. obd0->obd1 conversion harness question
  39. obd0->obd1 conversion harness question
  40. EDM P28 and USDM P28 - difference?
  41. A25 and A6 on P28 questions...
  42. b16 swap in eg
  43. Spun Bearings in Ls/Vtec
  44. Question, what can you transfer from an EG to an EK??
  45. H22 w/ B series trans adapter... Axle and mount questions (Swap Experts Needed)
  46. CODE 22 VTEC OIL PRESSURE GSR EK!!!!!!!!
  47. p13 spoon or mugen chip?
  48. Difference Between OBD 0 and OBD 1 Distributor
  49. Emergency- ZC DOHC valve retainers? same as other D series?
  50. What exactly do I need for DC front discs on an EG?
  51. H22 in Teg...how to keep a/c+pwr steering?
  52. Just installed itr 5 lug into dc2, but have questions on ebrake cables.
  53. What is required for B16 swap in 94 Civic Sedan?
  54. Fuel To the Engine CRX w/Type R fuel pump
  55. p29 ecu?
  56. Somebody that have tyed this?
  57. Buying a LS swap soon, Question about immoblizer
  58. b16 all motor back from the shop! opinons....
  59. Hasport H22 eg
  60. is there any way to make my 89 SI tranny work for a d16a1 integ motor?
  61. b16 sluggish. . .
  62. h22 wiring question
  63. what is best
  64. h22 swap, tps is hitting fuel line..
  65. Team DeltaDreams Honda Civic 4G63T project
  66. did search, but need 2 know whats the difference in part #'s btwn usdm & jdm ecu (p30)
  67. Will a brown top ZC or D16A1 engine bolt to an 87 CRX Si tranny?
  68. so i buy an ls vtec ek the headgasket is blown HELP!!!
  69. OBD2 SOHC INTAKE MANIFOLD ON OBD0 CIVIC
  70. ctr pistons in b16
  71. chip swap p28 to a p78
  72. hmotorsonline or jdm inc?
  73. k20 EP3/DC5 engine on honda jazz
  74. Swapping engines.....parts compatiblity?
  75. Transmission types
  76. how much would you pay for...
  77. hybrid cars pass MD state inspection???
  78. CTR final drive?
  79. Stage 1 dss axles minor vibration
  80. Car wont start...ECU/electrical issues...help!!
  81. How to Swap 92 Civic DX motor in 90 CRX Si.
  82. what are your setups on your gsr swapped hatches?
  83. ef swap
  84. Help on 6th Gen Accord H22 Swap
  85. B16 head on B18A block..
  86. HELP ME WITH MY B20
  87. Short throw for h22/eg?!?
  88. JDM ITR into crx wiring
  89. Where can i find a B20z
  90. would sohc vtec eg exhaust work if i swapped to a gsr engine
  91. trany swap
  92. Where do I cut the holes?
  93. a 93 vx d16 vtec-e motor in a 91 dx hb?
  94. b18c1 crx throttle body problem
  95. h22 Transmission Codes
  96. ITR tranny on LS sucks
  97. mini me swap timing belt
  98. H22 swap:people who have done it...LOOK please!
  99. Looking to find a garage to finish car....NYYYY
  100. Wiring v-tec for a b16 in a 1991 si crx
  101. H22 eg turbo project what pistons should I use and what manifold?
  102. Ls/Vtec Swap Successful
  103. NEED FEEDBACK ASAP ON A LS VTEC SWAP!!!!!!!!!!!!
  104. need help.. 02 sensor on GSR swap
  105. teg suspension on a civic
  106. gauge problems
  107. AWD crv headers?
  108. 1986 Acura Integra Suspension?
  109. Evap purge???
  110. H22 EGR Questions.
  111. Pics of an h22 with a/c in a 92-95 civic?
  112. Code 15 ingnitor / coil
  113. b20b or b20z bored out..... did search
  114. finally got my Imagine Engineering header for the H22.
  115. B18cR
  116. where to buy swap?
  117. pls. help with b16 swap info!
  118. h22 civic
  119. 91 HF b16 swap, is it multi point?
  120. h22 GURUs -- help me fix my codes. POISON, NEWMAN, WHO ELSE?
  121. CRX B16 SWAP
  122. H22 people...HELP!
  123. H22 in 94-01 integra?
  124. what should this car be worth?
  125. anyone ever do a swap VIDEO?
  126. What kind of suspension do I need?..
  127. JRSCed b18C1 and ITR LSD tranny all fit into a 89 CRX HF?
  128. b-series motor in EK (mounts question)
  129. H22 shifter cables and exhaust piping
  130. JDM Sh!t H22 / p28 program
  131. P28 and secondries
  132. del sol vtec engine in my 99 civic dx hatchback????
  133. Mini-me in EF swap woes
  134. how to swap LS crank into GSR block with ITR pistons?
  135. h22a4 into EK -- What Distributor To Use??
  136. B20 install into EG question...
  137. Jdm f22b dohc, go with h23 tranny?
  138. Best Place to buy a Quaife LSD
  139. h22 into a 93 civic hb but using a prelude tiptronic tranny? Put a h22 into a civic but using a pre
  140. What OBD1 distributor bolts onto a B18A head?
  141. B17 into a 92-95 EG hatch (motor mount and bolts)?
  142. 96 civic harness on gsr...please help ( crank postiioning sensor???) HELP
  143. which headstuds are used for LS/VTEC
  144. OSAKA JDM MOTORS
  145. last question
  146. GSR/Si hydrolic tranny question
  147. Where to buy
  148. JDM d15b
  149. h22 finished shaking like a mofo
  150. Hybrid axles???
  151. Question: about going obd1 when I swap in my motor.
  152. Need to know what I need for H22 Swap into a crx
  153. cam gears
  154. f series motor in a eg hatch?
  155. oilpump questions..
  156. from D17 to K20
  157. What distributor is this? TD53U?
  158. CEL Code 6 After Swap...HELP PLEASE!!
  159. h22 guys.... fizanza flywheel and balancer belt removal review.
  160. ls/vtec or h22 or b16
  161. 1990 CRX doin a JDM b16
  162. Clutch got stuck!!!
  163. b16a with skunk 2 intake manifold, in 97 civic.
  164. hypothetical questoin, please respon
  165. Need Help with Car choice
  166. Need H22
  167. complete y8 head on cx engine?
  168. Which stock intake can i use for a b18c in EG?
  169. H22 eg hatch exhaust
  170. How difficult is this?
  171. no CEL ECU code 5
  172. Ls/vtec overheating
  173. Turbo on a d16 and then moved to a k20 swap????
  174. 91 Civic HB swapping in a H22 can I keep AC
  175. O2 sensors on a B16A1
  176. does anyone make a chipped p28 w/ h22 specs?
  177. jdmpower.net riped me off
  178. Major help needed, Car won't start
  179. Direct Swap? SIR1 B16 into 94 Civic?
  180. 1-wire to 4-wire 02 sensor wiring??? HELP!
  181. CTR Crank Pulley on H22
  182. gsr p72 ,h22 engine
  183. Swapped motor/trans shuts down momentarily while driving...help
  184. b18c5 rebuild
  185. ENGINES IN ORLANDO
  186. B17 w/ gsr tranny?
  187. JDM H22a going into a 01 Accord
  188. oil pan??
  189. b16 axle ???
  190. H22 in EK - HARDCORE axle problem...
  191. Question
  192. 92-95 Sir rear disk brakes= what usdm car?
  193. Wiring Woes! Someone help please!
  194. The Build!!! Thanks IAS! pic intensive
  195. Buyers guide help!?! please
  196. B18C5 engine bore question...
  197. Do these look like stock cams?
  198. Code 14+20 in a 90 EF8
  199. few quick question about jdm h22 smog
  200. H22 swap into civic - surging idle
  201. b16a swap questions
  202. b16a2 or b18c1
  203. motor website
  204. Problems with del Sol VTEC radiator in EG H22
  205. h22 in 92 prelude?
  206. JDM b18c... knock sensor wired... but CEL is on...?
  207. b16 in 98 civic HELP
  208. 93 ls vtec
  209. callinG ODB1 ls SWAPS IN A EG/EK
  210. Automatic Swap
  211. anyone ever done an auto to manual tranny swap in an integra 98+
  212. Simple swap question.... 98 dx motor into 92 DX
  213. crv vtec vs b17
  214. Idle Surge Problem on h22a w/jdm p13 ecu
  215. ARP RodBolts
  216. 92-95 civic springs fit 94-01 teg?
  217. Hasport mount ek?
  218. H23-->H22 Injector help
  219. Where to remove sensors?
  220. h22 tranny question
  221. h22 in eg problems... help on wiring!!
  222. looking for hybrids to feature in book
  223. Compression tests on a b16
  224. how do you check engine codes W/out scanner
  225. H22 civic with competition enginering traction bars
  226. Just got done with swap but axles don't fit!!!
  227. H22 eg Hasport mounts $$$
  228. mounts for k20 in dc2 for sale
  229. I am gona clone an 1993 accord with an 1994 prelude 2.2vtec 4ws
  230. Need help with ECU question?
  231. h22 computer
  232. h22a4 into 4th gen lude
  233. What are these 3 missing wires from 92dx hatchback for gsr swap(!!!pics inside!!!)
  234. NEED ANSWERs will be doing accord 5g lx drum to ex rear brake conversion HOW TO
  235. B18C into 95 EX Coupe
  236. details on swap h22 into 91 ls, any help....
  237. Engine problemo???
  238. tech problem?????
  239. What MC and Booster can I use
  240. STOLEN: Hybrid EG from Arizona State U. Parking lot!!
  241. Hawaii guys, where you get your engines from?
  242. H22A into '92 Integra LS?
  243. Shift linkage
  244. I need HELP!!!!!!!!!!!!!!!!!!!!!!!!!
  245. o2 Sensor is gone bad, suggestions for replacement?!
  246. Need help. what would this swap kit be worth on the market..... (h22 civic)
  247. Import Auto Salvage!!! WOW
  248. B16 into 91 CRX help...
  249. since VAFC install - Car is much slower, and slow to climb through the RPMS
  250. D16A6 in EG need some help
