PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 [87] 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. K20A swap into RSX BASE AUTO
  2. obd2 engine into obd1 car
  3. b16 rubbing hood
  4. Was looking for an Integra Type R engine.......
  5. best place to buy motors
  6. What are these belts/pulleys?
  7. Perfect pistons for B20/VTEC...
  8. d16z6 harness on b18b
  9. jdm b16 sir II swap question
  10. Where to get Del Sol B Series Linkage and Motor Mount / AC Compressor Mount
  11. how many daily drivers?
  12. Can motor mount *BOLTS* be reused?
  13. Looking for respectable motor swap company!
  14. h22 eg power steering install
  15. ZC Timing Belt
  16. 97 Civic b18c swap, obd1 or obd2
  17. How to wire vtec
  18. distributor and ECU HELP OBD0 TO OBD 2
  19. 90-93 Integra Rear Disks on a 92-95 Civic? Will it Work?
  20. engine change
  21. TPS?
  22. H22 EG Hatch finished
  23. Day 2: Swap Wiring....hmm
  24. Connector Plug Q?
  25. D and B series compressors
  26. F22B1 in a Hatch ???
  27. Help swapping a B18b int 93 EX
  28. h22 knock sensor(HELP)...
  29. obd2b harness into 96 ek?
  30. h22 or b18
  31. h22 turbo on a 93 del sol....need some info...!
  32. B16 crx, PR3 car runs bad, PM6 car runs good?????
  33. h22a or b16a2
  34. Now What...JDM B18C swap
  35. k20 mounts for EG
  36. Any Info On F22 swaps?
  37. y8 intake manifold (auto/manual question)
  38. H-Brace on EG with a H22 swap??
  39. what motors will work? 98 ex
  40. Oil Cooler on b18a1?
  41. K24 EG CUSTOM HEADER PICS.
  42. Import Life shop in So cali
  43. h22 eg exhaust setup?
  44. FITV? Only on OBD0 and OBD1?
  45. which tranny for all motor B18C1 CRX???
  46. GSR Crank in LS block
  47. OBD1----> OBD0 Swap?
  48. Question about compatibility of CAMS between Bseries
  49. Custom gearing???
  50. gsr swap
  51. P5M ECU w/immobilizer in a 99 Civic Coupe
  52. B16 Swap Questions?
  53. Lean Rich or Stoich? Spark Plug Check
  54. Wiring information needed for using a 1998 EX harness with a 2001 JDM ITR Motor
  55. OBD2 Motor, ecu , harness into a 92 vx wiring?
  56. h22 with accoed tranny HCP mount wont work. anyone using accord tranny with their H22
  57. which AEM intake to use on a GSR crx???
  58. need wiring info for JDM B18C swap....
  59. Finshed but had a problem
  60. b16a2 into 1999 Civic EX Coupe
  61. Integra Type R b18c OBD1 Conversion?
  62. JDM Sohc ZC (obd0) into 95 civic DX
  63. EG's with Bswaps: what header/cat will fit the oem B-pipe location?
  64. need info on dc sport exhaust!!!!!!!!!!!!!!!asap
  65. Will a gsr clutch fit a ls tranny?
  66. distributor problem
  67. what's the best way to splice wires???
  68. d16z6 swap question
  69. hood hits motor....help.
  70. im trying to figure something out, help me
  71. B20 or B18B
  72. 85-87 crx trans in 89-91 crx
  73. what sensor is this?
  74. [SEARCHED] Who has a BAR sticker for their h22 swap?
  75. 5lug VS 4 lug weight difference..here's your answer
  76. Will a 93 si shift linkage work with a gsr swap?
  77. CEL 41 driving me nuts
  78. GSR knuckle fit on Civic trailing arm?
  79. EK HATCH/RSX
  80. Lets get this straight (B18C1 swap)
  81. Wiring help b16 (obd1) > b18 (obd1)
  82. My B16A2 has no vtec oil pressure switch, but my P28 needs one!
  83. D15B JDM Vtec engines
  84. Type SH swap into 92-96 Prelude chasis?
  85. pwo vs pr3?
  86. what fuel pump to use on a h22a/EG???
  87. B16A2 in a 92 CX hatch, Whats up with my throttle cable?
  88. Looking for a Florida JDM engine Importer
  89. d16y8 with obd1
  90. swapping b16a2 into EJ6 with JDM h22
  91. HELP: Got hood popped by the cops!!
  92. ODB0 Integra LS Distributor Wiring Questions - Help.
  93. intake air bypass. vacuum?
  94. oil pressure switch location?
  95. LS/VTEC fuel line???
  96. CRV and Integra Oil Pan Question
  97. jdm 4-1 dc sport header?
  98. <==========new problem....
  99. Looking for the best info for B swap(b18a) into a 95 ex
  100. jdm b16a2?
  101. civic injectors vs. Gsr injectors?
  102. 98 DX with 94 Gsr swap...obd1 p72
  103. Whats better running in a h22 ek civic p13 vs p72 ecu?.
  104. ITR in Ek, do I have everything I need?
  105. OBDII GSR swap into 5G Civic Wiring Question
  106. jdm h22 (obd1) into a 96 prelude srv (obd2).. possible or not?
  107. H22 swap diagrams
  108. H22 injector resistor box for eg???
  109. are ther really any difference from one header too another
  110. Will a ls tranny work ok with a gsr?
  111. knock sensor location? need help
  112. H23 into a 5th gen Accord...NEED HELP PLEASE
  113. WTB Crx ext. molding and tails
  114. head of B16A2 on a block B20A7??
  115. C.E.L. need help ASAP please
  116. can anyone confirm what an obd1 code 1 is for?
  117. MINI ME SWAP
  118. B16A2 need HELP!!!! Distributor problem
  119. i have a problem...help!
  120. B18B1 into a OBD-2a CIVIC EX HELP!!!
  121. short vid of my car nothing special kineg
  122. REALLY needing help, throttle is hard to move.
  123. built b16 problem
  124. mini-me need answers!
  125. who makes aftermarket rocker arms?
  126. B16A good tranny for B18C swap? Issues?
  127. Throwing codes need HELP ASAP!!!
  128. civic hybrid 04
  129. help with cable to hydro swap
  130. K-Series Understeer?
  131. Golf G60 brake rotors with legend calipers. Plz help!
  132. ZC engine into an EF civic hb
  133. MY EG Hatch H23/H22 Runs 10's!
  134. will a d15 tranni fit on a b18b?
  135. Motor Mounts which ones to use?
  136. All Motor Creation
  137. East san francisco bay shop????
  138. d-series gears interchangable with b series?
  139. DSS axles, CV boots split wide open after a year...why??
  140. timing belt being to tight!
  141. DA Teg, GSR swap, what throttle cable?
  142. need to change axles (?) in a YS1 cable tranny to S80 (98 GSR) hydro tranny Hasport conversion?
  143. h22a or f20b for 95 accord?
  144. Need help, H22 in eg not running right
  145. '88-'91 B_SERIES MOTOR MOUNTS F/S
  146. B16a(what do get to beat) b18c
  147. Crank bolt wont come off!!!
  148. jump from h22 to k20a?
  149. wiring with existing wires
  150. GSR crossmember swapped onto Civic
  151. Difficulty of b16c1 US to b16c1 JDM engine swap
  152. Difference between JDM and US b16c1 motor?
  153. Busted Tap in H22 Tranny . . . now what?
  154. IACV help? Which car is this from?
  155. itr and ctr cams
  156. IAC Sensor question????
  157. clutch and flywheel help with b20
  158. h22a tranny
  159. Hondata Stage 3 with Boost and Datalogging with P72 Ecu
  160. cant get vtec to work. I need help with wiring
  161. h22 crx
  162. Anyone know for sure if the Comp Engineering traction bars fit an h22 eg?
  163. Hasport Press Release: EG-K and EK-K axles available
  164. I SEARCHED CANT FIND SHIT IM LOOKING FOR A 4-1 HEADER FOR A H22A IN A 93 CIVIC ANY KINDSSS
  165. What will my compression be??
  166. JR supercharger with stock boost on my set up....help....
  167. My K20a R into EG at NOPI pics.
  168. VTEC WIRING, STILL NOT RIGH!!!
  169. Golden Eagle ls/vtec dowel pins
  170. where do i get the times
  171. 8 grand and an eg shell! what would you do?
  172. B16a in CRX DX, Rev cuts off at 3200 rpms
  173. P30 - no VTEC on an OBD2B B16A2
  174. Searched and still not sure...
  175. my RB25DET 240sx
  176. need new bearings for the f22b
  177. EGR sensor H23 accord question
  178. ls/vtek or turbo?
  179. gsr to itr conversion
  180. Anyone been to the College of Alameda smog Ref?
  181. JDM Type-R in eg
  182. what throttle cable for b16 in eg
  183. ODB2 to ODB1 distributor converting problem
  184. b18cR crx problem
  185. all motor H22a or JRSC B18C5 in a eg..............
  186. HOW DO I WIRE (! LS MOTOR INTO ($ SI DELSOL?? HELP
  187. just finished b20vtec 12.5.1 compression into crx. got a couple ?
  188. whats da defference between k20 si and k20 rsx
  189. proportioning valve question for rear disc conversion on my eg
  190. cam gauges
  191. s1 tranny ?'s
  192. HOW CAN I RE- WIRE 98 LS HARNES .TO A 92 CIVIC DX .INSIDE THE CAR.
  193. HF Swap Knuckle Questions
  194. B16A2 in a 92 Hatch, AEM cold air which one?
  195. real quick exhaust question......
  196. Gearbox Speedsensor PROBLEM
  197. PLEASE HELP! -- How to Swap H22A with a turbo into a 99' EK Civic Coupe
  198. Valve lash for my B20
  199. Fuel Line Compatability - B & D Series...
  200. newbie accord swap question
  201. h22a axles on a 94 integra? please help
  202. Another Vtech issue
  203. Axle Question
  204. Tming belt assistance needed!!
  205. h22/EK: crankshaft rubbing frame?!??!
  206. b16 and b18b questions?
  207. 02 si should i go with turbo or a type-s motor
  208. rpms jump up and down at idle
  209. Quick Q! mounts
  210. 99 EX harness compatible with 99 LS motor???
  211. gtech 0-60 times for itr swap
  212. Composite Head Gasket for B20 Vtec???
  213. my h22 swap into my 92 prelude si
  214. Bottom line... built B20 or B16 (R/S ratio's)
  215. power steering probelm (b18b in a 93 EG Dx)
  216. vtec/nonvtec ?'s
  217. 96 ITR Swap
  218. Surging idle fix for chipped P28 running an OBD2 LS with Uberdata
  219. what do i need to get this running?
  220. Switching to hydro tranny from YS1 cable tranny in B18c 89 CRX Si. What do I need?
  221. Unorthodox motor swaps
  222. B20?
  223. h22a integra problems
  224. shift linkage
  225. ECU swapping...
  226. What cams gears for ls vtec?
  227. why does an h22a cost less that a B18C........
  228. Hasport Press Release: New K-swap parts
  229. Hasport Press Release: Auto to Manual mount
  230. Suspension Question
  231. motor mounts and axles
  232. legalizing your jdm itr motor!
  233. h22a swap on a 92-94 eg please help..!
  234. ecu electronics question
  235. 96 jdm gsr swap in 94 gsr chasis??
  236. Qustion about rust....CRX b16a
  237. what exaclty will i need to swap a d15 with a d16
  238. sohc Axle interchangability
  239. A20A3 into Ef?
  240. AVID SHIFT LINKAGES, ANY GOOD???
  241. Harness guru's I need your help answering a question
  242. Looking to get a b20/vtec built
  243. torque specs on LSD
  244. K20EG Vouch Thread
  245. h22a integra/civic fuel line problem
  246. K20A2 oil squirters on a K20A3?
  247. Prelude injector ID
  248. HELP ON TAKING PINS OUT OF THE PLUGS
  249. CIVIC H22 WIRING (HELP)
  250. Skunk2 K series ECU
