PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Installing Cable Transmission in a Hydrolic Civic
  2. What REAR bracket is used for a Cable tranny in a EG?
  3. installing 2nd gen dsm tsi talon injectors
  4. si or rsx suspension swap
  5. k24 into a ek?
  6. H22 vs K20 pics? Other questions, RWD related...
  7. OBD2 motor into a 92 hatch
  8. b16a distriutor on a gsr head
  9. k24 into EG
  10. CAM SWAP NEED INFO!!!!!!!!!!!!!!!!!!!!!!
  11. JDM B18C Automatic ECU Pinout Diagram
  12. HELP!! im looking 4 a place that sells blocks and heads separately 4 a frankenstein swap
  13. HELP! im looking 4 a company that sells blocks and heads separately for a frankenstein swap
  14. will si fit eg???help?????
  15. Problems with engine swap
  16. running GSR motor with OBD2 computer
  17. EG with a JDM B18C swap and cant get rid of code 41 also
  18. h22 in civic fuel pump went....
  19. JDM B18C from Password JDM
  20. JDM 98 Spec B18C-R engine swap guide for any 99-00 CX/DX Civic HB
  21. blown 00 gsr motor, can u use a 94 gsr motor and use the block and head to put it back together?
  22. Looking for wiring diagrams for a jdm b16a sir II
  23. OK, I need a definitive answer...
  24. do i have the right inj setup?
  25. B18C loud noise from under valve cover??
  26. ok where do these go?
  27. wonderin bout itr swap???
  28. can i turbo ??????????????
  29. Tenzo Big Brakes any good???
  30. Need Help B18B1 OBD1 into a 97 Civic EX (OBD2)
  31. Aright Where Did The Engine List Thread Go To?
  32. OBDII to OBDI wiring
  33. smog a jdm b16a
  34. B18B: new cams or swap in a VTEC head? (turbo application)
  35. B16 failed smog p28 ecu
  36. weird idle problem with b18c1 in ek
  37. PR3 Cam Gears
  38. fully built ls? or lsvtec? then want to add turbo in furture which is better?
  39. How can a 92-96 engine only have 35K miles???
  40. HOME MADE 5 LUG CONVERSION ANYONE? IDEAS??
  41. mount for H22 in a 98+ Accord
  42. Jumpered Wire?? What Is it
  43. H22 Mods
  44. Which power steering do I need?
  45. K-series swaps post your axle set-ups (& if you've had any problems)
  46. B20/vtec price tag... everyone throw out some prices of what it costed to go vtec
  47. Stage 1 Axels
  48. H22 swap into 93 civic hatch...HELP!!!
  49. 1 wire o2 to a 4 wire?
  50. B20/vtec setup question
  51. secondary o2 sensor wiring?
  52. d16z6 harness for jdm d15b
  53. Gator Racing alxes with H22 eg?
  54. b18c1 (GSR) into a 94 cpe dx.
  55. Can I run an OBD-1 p13 ecu?????
  56. what car is this harness from?
  57. JDM B18C swap into a 92 EG vtec will not work
  58. what ecu to run on b16a in crx si
  59. Rear Teg Mount doesn't line up???
  60. b18b in a 94 del sol
  61. integra suspensions into a 90 civic???
  62. please help, ECU question
  63. b20 into my '90 DA
  64. h22 and transmissions
  65. Banjo size on fuel line.
  66. which alternators for b16a1?
  67. K20A3 vs K20A2: Harnesses different?
  68. type r suspension into 97 hatch
  69. h22 swap into eg
  70. s2000 valve springs in a h22
  71. b18c1 in ek coolant problem (not a leak) and question
  72. Running 2 darn RICH $$$$$$
  73. Posting question.
  74. '99 H22 CIVIC WITH BLACK SMOKE AT VTEC
  75. Gsr camshaft fit in b16 head?
  76. 96 dc2 suspension 96 ek ?
  77. eg w/B16a3 swap vs mustang
  78. Making my own drive shafts
  79. H22A Header...
  80. s1 tranny
  81. OBD2 to OBD1 Distributer questions.
  82. EK dx w/ B-series swap
  83. OIL PRESSURE SWITCH BYPASS OBD I - PAPER CLIP METHOD
  84. H22 Just Quit Running
  85. is it possible to put the crv all whell drive on a ef hatch
  86. h22a4 crank pulley wobbles at idle
  87. b20 distributors
  88. 2nd gen b16a distributor question
  89. post your ls/crx 1/4 mile times!!!
  90. H22 swap. Some problem with O2 sensor.
  91. Code 22 at high rpms?
  92. b18c1 into 92 si hatch ecu ? ?
  93. fpr and gauge took a dump
  94. 93 ex with a jdm b16 what helms manual?
  95. B18C1 internals to a B16
  96. H22a4 into 98 integra. Need help.
  97. just wondering what mounts needed to swap b18b into eg coupe?
  98. B18C swap with a USDM Teg harness and P72 Automatic ECU question.
  99. throwing code 41
  100. D16Y8 to B16 head swap
  101. I really need wiring help! ASAP!
  102. H22 IDLE PROBLEM (SMOG REF. IS AFTER ME)
  103. k20 into EG header
  104. H22 Swap Axles
  105. B16a1 in 91 crx si
  106. the code 36 on h22 swap
  107. ls auto to ls 5speed???????????//
  108. Putting a ZC JDM from ARD Performance into a bone stock 1990 Civic d15b1 chasis
  109. 90 integra axles didnt fit my 1990 b16 crx.. what does?
  110. 1992 Civic Si b16a2 swap
  111. money for cr-vtec?
  112. h22 transmission fluid
  113. Quick exhaust ?
  114. bay area swap shops??
  115. h22 ek swap need help
  116. Timing Belt-H22A/Civic
  117. clutch question
  118. Running rich problem
  119. would this help to quiet a loud exhuast
  120. need help plz td04 turbo
  121. 92 Civic B18b Hybrid Swap
  122. b16a not passing emissions in texas
  123. K-Swap Fun
  124. check engine light, b16 into 92 si hatch
  125. grey integra w/k20a
  126. f22 non vtec motor to a vtec f22 head
  127. WEIRD CEL light problem - turns on, then off for 3 seconds, then on again.. ???
  128. B16a2 weight???
  129. HELP!!!!! CAR WONT START UP!!!!
  130. Which b20 block do u use for a b20/vtec swap??
  131. B17A swap in a 93 del sol
  132. ls/vtec in a crx?
  133. WHAT b16a1 do I have?.. Apparently I got jipped/hooked up, help me out!
  134. 94 itr suspension in 99 civic coupe
  135. Pedal Feel on Hydro to Cable Conversion?
  136. EX/GSR brakes on eg hatch question
  137. KA20A2 SWAP INTO EG
  138. B18B1 in an EK coupe. ECU code issues
  139. what's the best Clutch for 92 civic w/b18c motor?
  140. the rear suspension of my car is under the control of satan
  141. crx b16 hybrid need help on vtec hook up
  142. Hasport transmission side bracket-is it well designed?
  143. 2 layer B20B head gasket?
  144. problem with ab18b swap in my ek hatch
  145. ls/vtec and crv/vtec..does jdm block matter?
  146. 93 Civic CX swap
  147. AC on a 92 hatch with GSR SWAP? is it possible
  148. ILL BUY UR P72 CHIPPED WID H22 PROGRAM!!!!
  149. GOLDEN EAGLE FULL VTEC CONVERSION KIT FOR LS/VTEC
  150. were can I find the vin # of my engine
  151. 97 civic lx swap info
  152. h22 parts required
  153. does anyone have problems with the intake on this swap
  154. Eg/H22 Shifter… Help..
  155. k-series swap
  156. crv motor
  157. Intermittent VTEC?
  158. 93 VX (vtec) ENGINE wiring harness is it the same as..........
  159. MILLING A D16y8 HEAD
  160. long time no start procedure ?
  161. San Francisco and NOR CAL heads, need your help!
  162. Crower 2.0 lt stroker kit for B16
  163. ls/vtechvs h22
  164. 2002 CIVIC Si 2.0 i-vtec engine into a 95 civic ex
  165. A/C on K-series hybrid
  166. Need help information on swap LS motor in 90 htach back
  167. d16z6 w/ d15b7 distributor 4 minime
  168. Stupid D16 Wiring Question..Please help!
  169. JDM D15B swap in EG
  170. Sounds like valves hitting pistons during idle....
  171. first jdm swap!!
  172. b16 all motor build question...
  173. Which chassis is the best for a road coarse/track minded Honda?
  174. Brian help me!! k20a in a dc2
  175. Went to performance shop today
  176. h22 swap into del sol
  177. Need help 94 EG swap
  178. engine swap question.
  179. LS VTEC STATS
  180. help with resister box
  181. H23A EG hybrid...FINALLY!!!!!
  182. Evap Purge and IAB Valve Question
  183. 89 Civic dx in bad need of an engine swap
  184. What Is The Difference
  185. Question about Hmotorsonline...TRANS?
  186. Closest place to/in Minnesota to buy motor
  187. b16a1 lsd tranny problem
  188. will a 96-98 d16y8 ecu work for a 00 d16y8?
  189. Bout to do a swap ! Going ALL MOTOR
  190. need info- b18 into hx, o2 sensor conversion and more...
  191. question about h22...
  192. b16a1 stutter/boggs on acceleration
  193. Did a B16 swap last week and engine is smoking
  194. cel 91
  195. another k20
  196. Hybrid transmission
  197. itr 5 lug conversion on my eg???
  198. wire question for swapping a b16sirII into a 93 civic ex
  199. Why haven't i seen anything about h22 in DC?
  200. pretty sure h22a tranny dies yesterday need help!
  201. Having problem, would appreciate any help!
  202. Tranny swap?
  203. 92 prelude...looking to swap a h22
  204. Initial impressions from my EG K24 swap...
  205. 'tricking' the VTEC pressure switch to cure code 22?
  206. 2k si cluster
  207. Can you swap an s2000 motor into a mazda????!!
  208. Pics of my 6th Gen accord with H22a LSD
  209. K20 Sighting
  210. Need to get in touch with an Administrator...
  211. hesitation/stutter on slight acceleration with b16a crx
  212. K into DC....
  213. Idle Problems . Please Read
  214. OBD2B -> OBD2A conversion, would it still pass emissions?
  215. jim fab motor mounts
  216. A Piece is missing from my Tranny.........
  217. ls swap
  218. Please help cel code 74 cylinder 4 misfire
  219. h22 injectors
  220. b18b w/gsr tranny-> ek coupe. what int. shaft/axles
  221. 96 b18c1 into a 96 ex civic coupe
  222. B16C5 swap on a Civic??
  223. lb for lb best honda swap
  224. 2.25 header vs. 2.5 header (4-1 vs. 4-2-1)
  225. Which Short ram for EG hatch with b18c1 ::::Noob question:::::
  226. lsvtec prob no vtec?????
  227. Any 01 b18c1 swaps in a 00 EK out there? ... help!!
  228. k20 swap in dc. Will AC and PS work?
  229. Oh God...What have I done. JDM LS (OBD1) swap into USDM EJ6 (OBD2)
  230. Automatic GSR swap in a 98 civic coupe??????
  231. ls/vtec problems
  232. P28 Code in B16 crx
  233. Problem with swap
  234. looking for a quality shop that does swaps
  235. does anyone have info on a poor man's type r build?
  236. JDM ITR swap - axle q's
  237. transmission blew up, hmmmmmm
  238. Which engine from which car
  239. Distibutor pins, HELP PLEASE
  240. Unique H22A EG suspension problems/questions...
  241. Anybody w/a stock OBD2b Integra GSR can you help me out really quick??? Ijust need to know the color
  242. Possible broken engine mount??????????? b16a CRX
  243. civic type r pistons, b16 block
  244. I'm an idiot!
  245. Can I beat an SVT? Other Q
  246. 92 GSR From B17A To B16A.LSD PROBLEMS!!!!
  247. jdm b18c and a cat?
  248. a little wiring help
  249. TRUE OR FLASE - B18b obd1 into a 00 civic Si
  250. which power steering pump/ bracket for lsvtec into a DC2.....
