PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. JDM f20b into a 2002 accord... We need some help!
  2. Eg Hatch Sir swap wire help
  3. Budget B20vtec help, first ever build
  4. Sputter after heavy part throttle
  5. distributer question
  6. Another ECU Problem? H22 Turbo Civic p28
  7. B16A2 into DC1 Integra
  8. OBD1 GSR Issues
  9. H22a gas?
  10. h2b question
  11. Starting my B20B swap to my eg! need help
  12. plm h2b header
  13. Motor swap, What will I need ?
  14. The dreaded H22 axle combination.....
  15. Lower timing belt cover b20vtec
  16. How To K20Z1 Swap OBD2B Civic 99-00
  17. b18c1 eg swap help
  18. 95 delsol ls swap build question
  19. $4100 for gsr swap?
  20. eg with 98gsr swap
  21. LS swap eg sedan swap
  22. h22a into 97 accord
  23. v8 swap on 94 teg
  24. I need f20b in a 96 ek coupe help ASAP!!
  25. H22 eg 4-1 drag header ?
  26. b18b1 swap into 97 civic help
  27. AC issues
  28. JDM GSR swap EG radiator question
  29. Any possible way with this swap
  30. B18 swap into 94 eg coupe
  31. Will this motor fit in my 98 Civic Ex?
  32. 99 civic gsr no start
  33. h22 swap shift linkage issues.
  34. giant long b20b oil dip stick
  35. race harness wiring diagram... anyone?
  36. 97 civic vss - f20b swapped
  37. B18C1 or K20A2 deal-breaker
  38. putting b16 headers on a d15b7 is it possible
  39. 1994 civic Ex B20B swap need help!
  40. Help. 1994 civic B20b swap miss firing
  41. B series swap into 99 civic question
  42. LSVTEC compression test/misfire
  43. F20b 1996 Honda civic what wire harness is the best way to go ???
  44. Lets see if i can get some real answers
  45. DBW J32a3 EK on a custom MSX3 ECU full rev 7200 rpms
  46. prb on a f20b
  47. Just bought a EJ8
  48. Time to swap
  49. Ls Help
  50. B16a2 AIT/IAT Location
  51. 98 civic ex f22 build. insight needed.
  52. warning light
  53. Del Sol 95 B18C1 leak near the oil filter
  54. 2003 Civic Hybrid- hard to shift
  55. 94 civic b20b swap rpm question
  56. b16b/b18c which is better for my car
  57. 95' civic dx engine swap
  58. B20b Gas mileage in eg hatch questions.. need input
  59. Anyone Found a Solution to Hasport Hydro to Cable Conversion?
  60. Question about axles for Innovative B series mounts/EF swaps
  61. Switched Injectors / Terrible Sputtering
  62. Hybrid Turbo Questions
  63. needing a cat for a 99 ek hatch jdm itr swap
  64. 91 civic lx sedan obd0 wiring harness b20b
  65. F/H ghetto tensioner
  66. Dead cylinder, need serious help...
  67. b18b swap in 97 american EX questions
  68. Considering H2D/F2D. Veterans please chime in!
  69. CRX H2B H23A Blue Top Build
  70. f20b f2b EG
  71. Can Anyone get a JDM H23A Blue Top PCF ECU Pinout!!??
  72. 1991 civic EF si. Goin b16
  73. '00 Civic EX FWD D16Y8 to RWD F22C1 conversion
  74. intermediate shaft? need help
  75. b17a1 swap into 97ex coupe
  76. 1998 Ej6 H2b
  77. Surging engine after mini me swap
  78. Idle surge after mini me swap
  79. Gsr turbo swap
  80. LSVTEC with RC injectors..HELP!
  81. b20b build question
  82. B16A2 with Auto B18 Tranny?
  83. P1337 code help!
  84. LSVTEC HELP
  85. engine swap help
  86. wtf are these mounts fer!?
  87. will b16 tranny fit f20
  88. B18c swap into crx
  89. LSvtec swap into my 90 CRX Si
  90. EF/GSR/VTEC issue
  91. f20 swap, which tranny to use
  92. EK w/b18c jerks on cold startup. Need help
  93. What should I do next for the most hp for my buck
  94. b20 eg8
  95. 95 civic ex/ h22a4 build
  96. EG8 with B20Z idles low and dies.
  97. b18b1 help
  98. EF gsr speed sensor
  99. F20B EG swap
  100. b18b1 fixed
  101. Help with passing inspection
  102. h2b idle problem need help ASA!!!
  103. ek b18c swap electrical issues
  104. Gsr swap into an 95 eg
  105. B18C Clarification, I Did Research, Just Need Clarification.
  106. OEM Bucket Seats
  107. g23
  108. Ls Swap Please anyone help
  109. my eg gsr cali ref inspection
  110. 98 ek swap
  111. Ls into 98 Ex Problem
  112. Questions about swapping an LS into a 96 EX coupe...
  113. what engine harness and ecu do i need for a 1999 civic hatch with an sir1 b16a
  114. bseries swap in my ek3...i need help!
  115. 98 JDM B18C5 in 97 EL
  116. ek b18c7 swap fuel pump issues
  117. d16z6 replacement
  118. H22 question
  119. jdm B18c in EF IAB/knock/02 sensor query
  120. b18b1 swap in a 93 del sol si.......what should I look out for???
  121. wiring issues 1995 integra b18b1 swap into 1996 honda civic nonvtec
  122. F20b 97 Prelude Distributor Question
  123. B18c7 into ek1 Q's
  124. B18c type r swap in 1994 eg; urgent help needed
  125. LS swapped EG. 6 MPGS. HELP.
  126. Please Help! B18cR Swap; Bad Compression No Start after LMA Install
  127. b18 distributor guts into b16?
  128. Ignition Timing Question
  129. 68mm throttle body worth putting on?
  130. obd0 distributor on a B18C1?
  131. How to install b18c5 obd2a in a civic Lx 00 obd2b?
  132. K20A3 swap eg civic floods itself
  133. B16a swap to civic 93 cx NEED HELP
  134. 97 civic ex ls limp mode
  135. 2000 civic dx GSR swap questions
  136. Need Help.. OBD2 gsr swap into 00 si
  137. 93 cx b20 swap help ASAP
  138. 93 cx b20 swap help ASAP
  139. B18C swap in CRX, NO FIRE
  140. b18b1 is having trouble starting
  141. honda civic/ h22 won't stay running
  142. Simple Question
  143. Jdm H22a intake manny
  144. Need help with EVAP system
  145. 93 civic with 92 B18 swap
  146. Buying Civic EG6 with JDM B18C type R engine : How to BAR/Smog/Register ?
  147. 99 civic obd1 b18 nightmare!
  148. 90-93 or 94-95 B18
  149. Civic b20b now running smooth...details inside
  150. Need help please
  151. H22,b20/16,b18/16
  152. h23a vtec auto ecu, how to make it believe it's in drive?
  153. my built gsr won't stay on
  154. obd2 b20 in 94 civic ex wiring problems
  155. first gen b16 on a 92 cx
  156. Cel but no code
  157. need info!Civic88 swap Integra91
  158. ECU Pins
  159. h22 in carb Eg p5m ecu
  160. F22vs b18 vs h22
  161. P28 connector plug diagram needed!
  162. Vtec problem after JDM B18C-R swap.
  163. Weird idle/ accleration
  164. Need Wiring assistance
  165. Completely lost and about to shoot it...
  166. Wiring on GSR swap
  167. B18b1 obd2 swapped Ls won't start possibly the dizzy?
  168. Orangevirus1 J30 Turbo EG hatch build thread
  169. Power Steering on EK w B18C
  170. what motor should i go with?
  171. 92 civin dx swap
  172. Need help with beginning project
  173. AC + Pwr steering in EJ1 b18c swap..HELP!
  174. EK9 Civic - B18c1 to B18c6 conversion
  175. K? J? or V8?
  176. JDM B16A 1.8L conversion
  177. Auto ek to manual ls swap
  178. B20 swap questions
  179. Which axles for b20 vtec over 200 hp
  180. Swap. GSR vs Type R
  181. What do I need for AC in my Type R Del Sol?
  182. cv joint on eg hatch
  183. LSV-T
  184. stock b20 on ej1?
  185. LSV/mpfi swap...help!
  186. NEED HELP!! Plz
  187. best motors
  188. B17 swap in 92 Civic DX Help me please someone....
  189. 1990 b16 vtec sir swap
  190. evolution h2b folk adaptor
  191. Jdm B18c type r in 99 ex constant check engine light
  192. yep i need help with this swap and advise
  193. 93eg w/b18c1 issues
  194. Emissions/inspection question on JDM ITR Motor
  195. h22 swap uneven enigne
  196. Is resistor my box working?
  197. Used B20 vtec would you?
  198. Help about air conditioning system for a civic 97
  199. h2b/f2b/d2b for sale thread
  200. B18b1?B18c1?
  201. F20b swap in 91 civic hb
  202. obd0 b16a in 92 da wont pass emissions
  203. jdm 98 itr engine into 00 si
  204. B18c type r high idle and engine vibration
  205. Revs bounce between 1500-1700rpm when giving gas
  206. searching reliable ECU conversion harness brands
  207. h2b header
  208. 96-98 C131 engine to dash harness pinout?
  209. swapping plugs
  210. 91 EF GSR swap wont start!
  211. head build
  212. One problem fixed... Another one begins
  213. whats a better overall harness for a b20?
  214. EM1 A/C Question
  215. gsr ek won't start
  216. Need Help. 94 Del Sol, B18B1 swap, wont stay running
  217. Possible to drop a f20B(DOHC) F2b in 91 accord? PLEASEE HELP!!! cant find anything
  218. GSR with LS crank and..
  219. Timing Isuue B18B
  220. Eg with f20b swap won't start
  221. h22a engine swap problems
  222. B16A short block with a GSR head?
  223. b18c dizzy
  224. 96 del sol / b20b knock sensor
  225. 90 crx si swap b18a1
  226. Compression test results??????
  227. jdm engine swap, no spark, wont start
  228. JDM motors
  229. need help with crx b18b1 swap
  230. H22 thermal intake spacer fit a CRX chassis
  231. B16b changeover
  232. JDM B18C-R into EM1 2000 civic Si emissions help
  233. b20 swap in crx - wiring questions
  234. B18c swap no spark
  235. H2B Integra - H23A VTEC
  236. New project. 91 ef- si. With k20 swap ?
  237. B18c5 head w/ b20b4 block compression ratio?
  238. post mount
  239. HELP!! crx b18c type r start problems... kinda
  240. Y8/Y7 all 4 cylinders misfire
  241. help: i have a question about D series and B series shift linkages...
  242. b20 vtec and cable tranny..
  243. eg ls swap gsr trans
  244. Car wont start Randomly... Think Starter is going bad
  245. Where should i get a b18 full engine swap
  246. single cam f swaps
  247. H23v obd2 distributor in obd1 civic wiring PLEASE HELP!
  248. G23 in 98 Lude ?'s
  249. b18a1 obd0 swap into 96 DC4 coupe
  250. 96 civic b20b4 swap several ?'s
