PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. d15B vtec compared to d16a6 Si. which is better?
  2. ZC Crx swap
  3. Who makes exhaust for cars with swaps?
  4. 98EX with JDM B16A EK4 motor...WHAT FUEL LINE DO I USE?
  5. H22 bracket question
  6. 99 EX vtec into 97 DX ???
  7. VX Swap?
  8. Need help on my switching at->mt
  9. obd0 in obd1 car need a little help
  10. What the H is this thing, an alarm?
  11. b20 motor specs?
  12. ran into a problem while doing my suspension with my friend
  13. best engine to put in a 91 hatchback?
  14. Topline 84mm cast aluminum pistions!!! ATTN: B20 VTEC!!!!
  15. help!!! engine bogs when i shift over 5500 rpm
  16. Coil overs for h22 hatch
  17. b16 into a 89 crx si wiring questions
  18. 1996 Accord with 2000 F23A1 - Will not start.
  19. Swapping from an ITR to an EG..need advice pls
  20. Vtec wire on b18 swap.
  21. CEL codes in general question...
  22. 88crx D16z6 swap
  23. Anyone done cable clutch to hydro tranny conversion(searched)?
  24. half shaft axel need help fast
  25. no power in h22 higher rpm band?
  26. B16a Dohc into a 5G H/b civic
  27. How do I go about swapping the gas tank from DC into an EG?
  28. cable tranny in hydro car...speedo/reverse?? also ac mount?
  29. Which Header? (Dc or Greddy)
  30. decisions...decisions?
  31. AUTOMATIC GUYS...99 EX 5spd FULL swap.... .Selling my COMPLETE 5spd swap
  32. AUTOMATIC TO MANUAL CONV. 97 ACURA CL 3.0?????????????
  33. Yellow/Black and Red Wire on a 1994 Acura Integra...What does it do?
  34. something wrong?
  35. HARNESS HELP !!!!!!!!!!!!!!!!!!!!!!!!!! NEED INFO FAST !!!!!!!!!!!!!!!!!!!!!!! HELP
  36. Jdm b16a2 + eg coupe= ?
  37. b18 with b16a head, which ecu would u use if choice was yours
  38. 91 crx b16 skunk2 intake mani, aem fuel rail, pressure reg. need input from you almighty tech wiza
  39. can a 96-00 front rotor and caliper fit on 92-95 EG for better brakes??
  40. Anybody have any idea what this is on my IM?
  41. code 7 w/ h22 swap into 4th gen accord
  42. troubleshooters & techies read this!!!
  43. Question about B20Z Build-Up...
  44. What does my H22 TURBO need, not WANT, need in order to run?
  45. OBD2 to OBD1 adaptor?
  46. B16a SiR Del Sol Swap (Difficulties Starting)
  47. Finally got my car started.....!!! now it shoots up to 5k WTF???
  48. need a pics of 96 itr head!!!!!!!!!!
  49. Just got a CRX... NEED engine swap info!
  50. jdm H22a problem
  51. Automatic to Manual conversion on a 99 Honda Civic EX
  52. d15b7 y8 head 94 dx civic dist,oil questions,please help
  53. auto gsr
  54. map sensor broke off, can i start the motor? And wiring question
  55. Best head and block combo for most power
  56. need to finsh swap for H-T meet in ewnglish town
  57. type r swap
  58. swap problem
  59. Whats the best vtec head for a b18b or a b20?
  60. K20 K20A RSX EF Civic Hatchback Swap *Pics Inside*
  61. b20 swap in an LS integra
  62. Any views on P28-H22A Civic program from JDMSHIT?
  63. Throttle cables
  64. Crank and TDC wiring question for EF's HELP
  65. civic s2000 project
  66. Swap choice Assistance please
  67. Axles for Y1 LSD
  68. What clutch and axles
  69. b16 swap in, wont crank over
  70. A engine mount article I just finished tonight.
  71. ek h22 tachometer
  72. P30 running a GSR motor......better results?? NEED HELP
  73. ls vtec w/ b16 head and gsr obd 2 ecu.
  74. what trailing arms can i use
  75. need help car wont start!!!
  76. ****D16A9 into zc help!!*******
  77. will a NSX motor fit?
  78. Fuel Pump Question
  79. LS swap in a 99 SI?
  80. harness issues
  81. doing a auto to manual swap and gsr swap same time on a 99 civic NEED HELP
  82. k20 swap?
  83. should I keep the gsr or get a h22
  84. d16z6 into eg, do I need to remove the axles from the hub?
  85. F20c swap
  86. Where to buy a b16a2 long block?
  87. !!! Need wiring help ASAP on my h22 ek!!!
  88. Which Motor is a good choice?
  89. idle problem
  90. Trade JDM B18C-R for USDM B18C1
  91. anyone dissect some fuel injectors?
  92. my b20 swap project diary
  93. check out this hybrid, k20 powered ef
  94. H22 into an EG related question
  95. need 84-87 CRX swap pics
  96. Will this work ???????
  97. question on wiring IAC sensor ANd iab
  98. The Newest K20eg SOCAL STYLE
  99. H22 EG RPM
  100. Intermediate shaft too big for 92 ls tranny?
  101. I'm burning a LOT of oil.
  102. K20EG scammed more than $8,000 from hybrid racing
  103. 95 vx...cable or hydro?
  104. Who makes final drive gears for j1 tranny? Anyone know?
  105. HighVelocity
  106. how reliable is the h23 h22 frankinstine engine
  107. '87 CRX B18C swap?
  108. 91crx w/ b16a JDM --> Need a accurate gauge cluster
  109. Speedo not working after swap. Need help.
  110. 96 civic hatchback B18C5 swap CKF sensor?
  111. 97 EX motor into 94 DX
  112. Will DA (90-93) teg front knuckle/hub assembly fit a 93 civic ex?
  113. how to run a b16a1 in a 99 SI?
  114. P54 ac bracket ... Does 97 del sol si have it?
  115. Converting a non vtec wiring harness to a vtec harness
  116. B16 Sir2 swap cost
  117. Question about tranny (driveshaft) seal on a car with a swap...
  118. Illinois ppl
  119. camshafts for b18c
  120. Mini-Me Swap
  121. Axle question
  122. wiring harness from vtech 95 civic into a 89 hb
  123. what yal think i'd be hittin???
  124. h22 swap in an eg dies at every stop light!!
  125. b16a1 VS b16a2
  126. Question about mileage on JDM motors
  127. Tips after AFC install on n/a car... base settings ?
  128. gen. 1 swap
  129. Who here has bought a motor from www.totaljdm.com???
  130. smog a jdm motor???
  131. fuel pump question
  132. Northe End Service Center!
  133. Did srch: DX civic, GSR swap, fuel pump suggestions, etc...
  134. anyone do a h22 in a crv yet?
  135. Should I swap the fuel pump when swaping a b16b into a 96 cx??
  136. ecu and jumper harness problems
  137. stick with B16 head or tuned B17 head?
  138. need to know what plug goes to iac sensor on gsr engine
  139. the unthinkable is going to happen
  140. Which car is better for my motor
  141. About to do my swap! Most common problems???
  142. Weight difference between b16a1 and b18c5
  143. NEED HELP want to swap b18c into 98 civic ex
  144. H22 into eg/dc people
  145. swapping auto to manual in a nissan
  146. GCC H22 spring rate
  147. What hybrid motor is this!?!?
  148. Wiring up IAB
  149. JDM swap ?'s octane? check engine light? seafoam? Please help!
  150. d16 -> JDM b16a2
  151. FPR vacume line goes . .
  152. not your normal lsvtec question
  153. Radiator ? for B18C1 swap into 93 Civic EX coupe
  154. h22 shift linkage conversion to B series.
  155. CEL 91 fix-- need help though
  156. EG6 - with with B16B installed problems help
  157. b20b vtec idles to low
  158. Auto to stick details
  159. Pr3 Head on B18c block
  160. JDM ITR in 93 SI... Wiring Questions
  161. JDM ITR pistons in LS block????
  162. Pistons in a LS/VTEC?
  163. Erradic Electrical Problems With Cluster and ELD
  164. Final Frive Explanation?
  165. B20 into Del Sol
  166. Need exhaust suggestions b16 hatch.
  167. My 1/4 Time
  168. Wiring for a JDM B16 in a 91 Integra Ls
  169. What's the best source for genuine ECU programs?
  170. what should I get for my ls/vtec setup $$$
  171. b16 ObdII into "EDM" 94 ObdI civic HELP
  172. LS swap into 4g.. axle question
  173. Driving impressions: h22 vs lsvtec (Your look on it)
  174. ITR 4 lug brake rotors and pads??
  175. h22 thermostat
  176. 92 hb- jdm b16a , swapping to b18b- thoughts?
  177. ecu question
  178. 1992 Honda civic si swap need some help on
  179. fitting a gsr girdle on an ls block HOW?
  180. B18C5 swap into 93 DA GSR...
  181. B18 or B16 or LS\VETC
  182. what h22 swaps need resistor box?
  183. HELP ON BEST WAY TO DO LS SWAP!
  184. B16 Wont start after swap.
  185. usdm b18c5 swap into 92-95 eg
  186. b16 intake manifold question
  187. No one seemed to know in the other forums, maybe you guys will here?
  188. 97 EX motor swap into a 98 DX Coupe
  189. B18C5 Swap Trade for D Series Swap
  190. Automatic swap in my 98 Coupe
  191. Is this a better way to get a b16?
  192. sohc itr
  193. h22 in a crx
  194. b16b vtec problem
  195. SoCal H22 Accord swap shops?
  196. Verification before soldering
  197. half shaft axel help me
  198. 92-95 civic CX with 98DX swap questions
  199. gsr swap in 93 integra running to rich
  200. f23 head on a d-series block?
  201. 1988 Honda Prelude swaps?
  202. OBD1 Motor Inside my Obd0 Car, Fan switch is just hanging by itself :(
  203. what's the difference between 94-99 GSR header and 00-01 GSR header?
  204. HELP - B18C5 into 1996-98 Civic EX
  205. 1990 honda WHAT SHOULD I SWAP IN?
  206. JDMB18CR into LS Integra
  207. b20 block/SI head specs?
  208. h22 over heating problems
  209. swapping compatible honda fuel injectors?
  210. Dyno results of Hybrid Motors
  211. Does anyone have a 1/4 mile tme for a stock B20?
  212. h22 EK finally running...
  213. eg what turbo manifold
  214. guy i need some help with this one
  215. help PLEASE del sol
  216. b18a dumb question...
  217. Cheap LS Motors??
  218. b17 into eg, rear bracket not lining up
  219. b16a to 20b!NEED HELP?ANY INFO WILL BE APPRECIATED!
  220. ZC timing belt walking off cams?
  221. CTR 5Lug on a 96EK, can i use the stock b-series axles?
  222. B18C1 Swap - What exhaust to complete project??
  223. ITR Pistons in B18A Block, Compression????
  224. need help wiring obd1 to obd2, searched and now i'm confused
  225. oil dowel under cam cap on b16 head, plz help!!
  226. cable transmission mount
  227. h22 motor mounts??
  228. California BAR Certification
  229. ls/vtec pistons
  230. H22 or B18C ????????
  231. what harness to use with ls/vtec setup ?
  232. H22 Civic Intake
  233. Finished swap (POWER LOSS)
  234. D16y7 to D16z6 swap ?
  235. 2000 b18c5 into a 95 dx
  236. Can I use an OBD2 H22 distributer on a F22b Sohc vtec
  237. 00ek dx with a 94 b18b wiring help!!!!!
  238. what linkage did u use
  239. HCP driver side mount for replacing the hydraulic stock mount on "Ek's"
  240. 2nd gen teg dash in 89 hatch?
  241. B18B into 96CX question
  242. How to tell the difference between a JDM b18c1 and a USDM b18c1
  243. b16tranny-b18c block?
  244. B18B into 96-00 Civic, Driverside mount need change?
  245. gsr in an ek
  246. Can i use my stock ls head bolts, studs on a ls/vtec head swap?????
  247. octane for stock jdm h22
  248. B16 and B18 engine wiring?
  249. 95' LS in a 91 IT
  250. want to rebuild my d16a from ef, and do a mini me swap
