PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. shop doing my wiring tells me there are no distributor wires on harness! HELP!!!
  2. Which seller for B18C5?
  3. got a first gen b16 long block with flywheel/pressue plate, hydro tranny work?
  4. alternator not gettin ne thing from my ignition or battery!?!
  5. wholesale importer?
  6. B16 Tranny on b18b?
  7. wishbone suspension q's
  8. Anyone have problems with a B20/VTEC using a GSR head?
  9. b18b vs b18a for lsvetec? what block is better
  10. what kinda b16a
  11. Valve reliefs insufficient on B20 pistons when using a VTEC head?
  12. car wont go into gear when running
  13. GSR 97EK swap, which AEM CAI application do I need again??
  14. OBD-0 b17a throwing code 23 (knock)? How?
  15. Need Pics of Various Motor Mounts(Civic/Integra)
  16. AXLE QUESTION... Searched and couldnt find a dead on answer....
  17. obd2 h22a fuel injectors in obd1 h22a? help
  18. GSR swap and car is not revving past 5 RPM
  19. ITR crank in B20 block
  20. 1st swap: B18b into an EG
  21. civic h22 ecu problem
  22. doing a swap 96 JDM GSR into 99 civic ex need Help!
  23. gsr swapping over to itr
  24. poorman r does it make power
  25. need help wiring a techOmeter
  26. poorman r does really make power
  27. can u have to much oil pressure for vtec
  28. wiring obd1 dizzy to obd2 ls
  29. how can you tell apart obd0 injectors vs obd2?
  30. B20/vtec oil pump/timing belt question
  31. Brake Proportioning Valve Question
  32. b16a sir2 into an ek chassis
  33. h22 hatch kills new cat
  34. damper rate tein ss for eg h22 civic
  35. How to move wires on ECU???
  36. 97 gsr complete swap into 94 eg. What parts are still useable??
  37. Help w/tranny change-did search
  38. Is this car worth $1,500 plus my GSR motor?
  39. H22 Del Sol LSD custom axles still bind--------------
  40. FAQ
  41. LS / VTEC Questions
  42. H22A in an EG civic???
  43. clicking from passemger side?
  44. just checking if i have everything for B18C1 in 90 crx si.......
  45. mini-me ?
  46. ks cel wont go off
  47. eclipse injectors on gsr
  48. Switching my 91 civic duel point to multipoint?
  49. H22 eg handling issues?
  50. I got my valve springs mixed up!
  51. Will Civic A/C bolt to a B motor for temp?
  52. Im I running rich or lean? CEL 45
  53. B16A1/2 swap cost? for in 95 Civic Hb
  54. ls/vtec vs gsr
  55. crx wont start ls swap and obd1 swap
  56. d16z6 / d16y7 mini me questions.....
  57. now what could this be.....
  58. 240cc oem injectors .... quick question ?
  59. Got our Osaka Motor today! Big Mistake dealing with them.
  60. HELP! i put an a 00 si motor in a 97 civic and its problem after problem
  61. convert d16z6 distributor to obd0?
  62. which head is better for ls/vtec b16a1 or b18c1
  63. gsr rods in ls will it work
  64. H22 Civic
  65. K20 into 88-91 crx?????
  66. obd2 car obd1 motor and harness. Integra chassis
  67. p28 ecu with gsr
  68. New Head, No Vtec ahhh!
  69. will gsr pistons on LS rods work in a gsr block???
  70. whats the compression numbers for the B16A2?
  71. who makes block braces?
  72. 97 ls motor in 99 civic with 99-00 si harness
  73. h22a swap coolant hoses
  74. K20 swap or get a 350Z?
  75. ITR BLOCK WITH GSR HEAD?
  76. whats the best tranny out of...
  77. wiring vtec into my 97 ex harness
  78. H22-EG more Knock sensor fun
  79. Distributors- how do you identify them?
  80. Axles binding ? (H22A in Integra)
  81. eg h22 times not to good
  82. "lost plugs"... please look at these pics and help!!
  83. h22 civic balance shaft seal accessible?
  84. B20vtec - Oil gushing out
  85. crx si, swappin to B18C1
  86. B16 block, LS head, see any problems?
  87. 94 civic shift linkage same as 94 del sol linkage?
  88. 94 B16a3 into a 99 HB CX
  89. ek wiring harness
  90. ls crank in gsr
  91. question about total price of sohc swap
  92. OBD1 DISTRIBUTOR TO OBD 2 HARNESS.
  93. IS there a way to put the 99-00 si harness with b16a2 motot into 96-98 civic and make the dash plug
  94. GSR ENGINE IN G2 TEG
  95. Hybrid EG exhaust question..
  96. da options
  97. B18b into 95 CX *New to Swaps*
  98. VG30ET swap..in crx
  99. HELP!!! B18a OBD1 crx swap done but won't start =\
  100. B20/VTEC swap....VTEC not kicking in.....
  101. h22 eg project finally done!
  102. d16y8 head for b18?
  103. B-series into EK questions
  104. having some more problems. h23->sol
  105. lsvtec vs gsr
  106. CRX HF Engine Swap/ Build
  107. newer prelude hubs fit type r
  108. 2001 JDM Euro R H22a and 95 D16z6 wiring
  109. NEED some help with wiring harness please, I got Ripped!!! B16a crx
  110. ??engine wiering from d16z5 to b16a1??
  111. Distributer Cap *pics?*
  112. Honda CBR 600 F2 F3
  113. need help doing a Gsr swap on 96 civic
  114. wiring question with my first swap
  115. How do I go about getting ahold of UK parts?
  116. Conversion Harness
  117. spec's on gsr and ctr cams!!!
  118. h22 90 accord transmission and other problems
  119. EF Swap
  120. having troble with my h22 in ek civic..
  121. lean minime trouble
  122. LS/VTEC emission
  123. My K20A EG civic
  124. Brake dorks, I need your help! Anybody ever done a 5 lug on EG and retained the stock abs stuff???
  125. Would it be possible to modify EG K mount kits for EF's?
  126. GSR Swap EK HELP!
  127. what is the average cost of a complete h22 swap in eg hatch?
  128. B18C1 into an EG
  129. cable/hydraulic tranny differences
  130. Frankenstien up for grabs
  131. 93 civic vx wiring
  132. 100-90-100-100 BAD!
  133. 91> down civics need to convert to OBD1 for b16 swap?
  134. Power mirrors and windows
  135. crx with b18a1
  136. integra help plzzz
  137. EGR Throwing Check Engine light ?
  138. Place in CA to find B16 engine
  139. zc alternator?
  140. 2000 Si Motor swap into a 92 Hatch CX...
  141. H22 in 94 integra.. need help. could this be a motor mount?
  142. DOHC ZC which wiring harness?
  143. Cluster Swap Question
  144. h22 hatch suspension-spring rate question??
  145. Mount Question
  146. h22 dead..... gettn free f22.... EG civic swap opinions
  147. anyone have a jdm f20a? anyone!?
  148. went to know about sohc zc to a ztec
  149. B20 into 94gsr
  150. b20 swap for prelude?
  151. obd2 usdm H22 into ek..what dizzy should i use? helpz!!
  152. need help something wrong
  153. My K20a Hasports mounts finally came for my eg *pics*
  154. OBD-0 B16a swap into a OBD-2 car? (searched)
  155. eg h22 swap**
  156. JDM f20a dohc idle problem
  157. upadated pix of the work done... H22EK --56k SORRRRRRY--
  158. Need help h22 eg lacking something?
  159. D16Y8 or B18B1 Swap
  160. after market exhaust for a swap
  161. just did the h22 swap and car is sending egr code
  162. Use stock prelude rear bracket for HASport motor mounts on H22 swap into EG?
  163. Need some help with a B20 swap
  164. what is the ecu pin out foe CEL
  165. Already a wire in A17, what to do?
  166. B18B into 98 Civic wiring question. Search function not working.
  167. need help on b16a!!!!
  168. H22 P28 O2 sensor question?
  169. ls vtech set up please help me
  170. Any engine swap businesses in or near Clarksville, TN ? Need to find out if there is ASAP
  171. Where is a comprehensive list of Honda engines?
  172. sir2 into 2000 ex distributor clip problem
  173. B18A from 92 teg into 91 teg
  174. which engine is the most fuel efficient....?
  175. d15 non vtec oil fit on a d16Z6
  176. b20 swap into 99 si
  177. IACV problem like no other , B16a CRX
  178. Catback for 99 SI exhaust on 97 Civic Hatch?
  179. East Coast h22 hybrids...
  180. type r in 00 ex
  181. juss swapped in an LS, idles high, valves click
  182. car starts but then dies right away...help!
  183. JDM H22A Redline/Fuel Cutoff
  184. how to identify type r valves
  185. Is FPR for ITR same as FPR for gsr?
  186. CRX b16a swap no reverse lights
  187. 99 si with b18c5 idle problems
  188. h22a water pump numbers
  189. B20 Questions
  190. got swap running but...
  191. code 9.... car wont rev past 73k....
  192. i cant check my code on my hybrid
  193. 1986 CRX W B16 / Hasport/Zdyne one wire conversion - Need boost now...
  194. vacuum routing help
  195. 94 B18C w/ 93 YS1, which clutch cover?
  196. H22A into a 99 civic ex
  197. Need help with axle problems!!!
  198. 1st gen B16A into 91 CRX Si.. parts needed?
  199. how much would a ls turbo cost?
  200. B18C in 92 Integra
  201. h22 cel codes - 12, 20, 36
  202. b18b auto to 96 ex auto
  203. Mini Hybrid like no other!!!!!!!!!!!!!!1
  204. 00 B16a2 swap in a 98 Dx HELP!!!!
  205. How do you pull the pins out of the harness???
  206. 96 dx harness on obd0 b16, and few more questions
  207. h22a engine code 22
  208. jdm prelude front eb=nd
  209. Code 1...damnit
  210. July issue of Honda Tuning - K20A into DC2
  211. h22a into 92-95 mounts cheap
  212. b16 cam gears on integra???
  213. First guy to build Ls-Vtec
  214. FPR help!!!
  215. B16a crx wiring problem, hasport/hondata
  216. JDM D15B swap list
  217. Want swap info...1st gen crx..... not what u think...
  218. break disk for b16 swap to vti
  219. Help
  220. H22A2 or H22A
  221. Radiator for B18C Swap
  222. Why is my car starting to backfire??Help Please!!
  223. interesting idle problems, look in here
  224. SHORT SHIFTER
  225. Check out the engine that I got from Osaka and tell me what you think!
  226. b18b into hx ek?
  227. build block? different block? help me out! thanks
  228. h22 swap doesn't start sometimes please help
  229. code 19 on jdm gen 2 b16a into 1995 EJ
  230. worst shop in the world
  231. swap esi to vti questions
  232. very annoyed...h series in sol
  233. h22a ek PRE wire harness ARe they out there?
  234. What tranny do you guys recomend???
  235. F23 Head/F22 Block/H23 Intake Manifold
  236. overheating hatchy
  237. GSR head with B18c5 bottom
  238. no luck in integra forum...so ill try here
  239. how do i run my vtec in my 91 civic si
  240. how much would this engine go for
  241. H22A into 90-93 Accord (CB) - Nothing found - Anyone with links or help?
  242. help vtec not working
  243. Press Release: Hasport EGK kits now shipping
  244. h22 eg axles bent?
  245. BAR/smog problem - '98 ITR in an '00 EK
  246. What ignition coil for 1st Gen B16?
  247. what setup would u do??!!
  248. Need some opinions ...
  249. H22 into EG with B Series Tranny? Who had done it? Whats involved ? ETC......
  250. idle problem w/ my H22 EG hatch
