PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. why does my DA run like shizzle when I put vtec ecu in?
  2. f20b f22 hybrid swap question
  3. H2B EF
  4. what h22 parts are compatible with f22 parts? ie... valves, valve springs, retainers,
  5. JDM H22 Wiring Harness onto an F22A1?
  6. V6 EH2 information
  7. accord crank position sensor/tdc
  8. obd2 to obd1 question
  9. For TSX K24 swap in to EG, how do I get it going without drive by wire throttle cable?
  10. OBD2B Car & B16A2 OBD1 Wiring Guide
  11. SOHC DA Integra Questions..
  12. BUNK STARTER HOLE ON EF QSD PLATE
  13. ef with ek transmission..??
  14. jdm distributor question
  15. F22 into EG Question
  16. tranny squeal! what could it be?
  17. H22 blown up again.. details on F20 and SOHC replacements??
  18. H2B In A DB2?
  19. OBD2 D15B 3-Stage VTEC-E Into A 91 Civic - Swap Gurus ASSEMBLE!!!
  20. BAR'd??
  21. Alt Question
  22. stock da rear crossmember mount?
  23. How do I get hold of QSD ???
  24. obd1 jdm gsr swap into '93 civic dx wiring?
  25. So i went to get my car fixed today... 56k die i think
  26. Taking crank pulley off long block??
  27. 2000 GSR swap into 95 DX hatch??????? Please Help!!!!!
  28. B18c not running to potential!!! HELP!!
  29. Integra DC - possible to keep air conditioning w/h2b swap?
  30. need help with k20 swap into dc2
  31. need help with k20 swap into dc2
  32. Quick Harness Question
  33. h22 civic idle air control valve.
  34. Possible Lameness - Anyone Make SOFT B Series Mounts for EF?
  35. what do i need for H22 swap??
  36. swap and speedometer problems
  37. clutch for h22
  38. 88 CRX SI, OBD-0 USDM P30-A00, wierd VTEC problem?
  39. K to EK swap blah no info
  40. Driving impressions balance shaft on/off??
  41. rywire subharness package
  42. Car won't rev out
  43. Jumper Harness
  44. need your opinion
  45. WHAT can i swap? RSX and EP3 to a EM2
  46. My H2B build (Brown Kids H2R)
  47. h22 95 civic skunk2 mani
  48. h22 civic harness nees asistances...?
  49. CEL, code 43, What To Do?
  50. H2B starter question.
  51. H swapped Civic - can I put a used CV joint on a new axle?
  52. B16a2 obd2b engine in a 96 coupe obd2a car.
  53. Engine breaking up past 7K RPM please help ASAP
  54. I need an f20 or f22c swap for my Datsun 510
  55. EF b16a crankcase seal
  56. new here looking for g series info
  57. I'm going h2b. questions.
  58. 97 EK with b18b to gsr swap
  59. OBD2b head and a OBD2a wiring harness...
  60. k20 eg wont run right
  61. Skunk2 manifold problem
  62. very quick h22 4th gen civic ????????
  63. Crazy Speedo Needle After Swap?!
  64. Tranny Swap Between D Series Help
  65. H22 EG civic mount issue?!? Advice needed
  66. 97cx hatch swap need some help
  67. <<<<< SWAP NOT STARTING!!!!! >>>>>
  68. Automatic H22 swap?
  69. BAR State Ref law Passed
  70. Passing inspection with swap?
  71. 95 civic hatch with a 95 integra gsr engine swap issues
  72. alternator for b16a obd-0
  73. Quick Advice Please, D16V6 stock vs. D15B swapped in by shop
  74. Pr3-1? What kind of head if this?
  75. 83mm LS bottom w/ B20 P8R head... Possible???
  76. distributor for h22a
  77. Automatic P28 ECU to Run D15B 3 stage vtec?
  78. Bar Question (Cali)
  79. Brand new K20A Retailers
  80. need help with alternator wiring
  81. BRAICH BUILT A/M H2B Build
  82. 1st time swap ?
  83. evo vs qsd h2b kit
  84. Swap Help!! (00 Civic SI motor into 95 Civic EG)
  85. VSS Speed Sensor K20 swap
  86. What harness is this
  87. H22A1 into 92 EG
  88. obd0 b18 swap rev limiter issue
  89. obd0 motor 96 ek
  90. 3 wire iacv and need 2 wire HELP !SEARCHED!
  91. EG B18C Swap
  92. Power steering with b18b1 swap
  93. LS vtec oil leak need help asap
  94. K20 swap to dc2
  95. did my first swap.. upgrade the thermostat?
  96. B18 not going pass 4k rpm
  97. Car wont start. Any ideas?
  98. k2o help wont pass 2k rpm
  99. h22 swap=slow?
  100. g23 question
  101. Confused on obd2a/obd2b/obd1 conversion...??help plz
  102. D15B AC HELP
  103. F22(SOHC) in a EJ8 MPG?
  104. Not your typical Swap (Project Del Slow)
  105. F20B what is this thing?
  106. A Selfish, Single-Serving Request - Links or FAQs for 96-98 EK B18C-R Swap?
  107. H2B help needed!!!!
  108. Mounts don't line up?
  109. obd o to obd 1 dizzy jumper harness
  110. Confused Myself doing to much B20 into EG research NEED final answers
  111. F23/H22 Hybrid Engine Bugdet Build
  112. tach wire
  113. 84 dx hatch
  114. Finished H22 swap into EG, battery light always on
  115. F23 SOHC Vtec into EG Questions.
  116. Tachometer not working?? OBDII b18c1 into an integra RS
  117. ls vtec????
  118. coolant hoses off thermostat h22???
  119. Almost done
  120. K series crank pulley fits on an H Motor
  121. B18a and B18b wireing harness plugs
  122. itr swap got a problem when the car is warm or the weather hot
  123. i need help with mounts
  124. LS VTEC Removing Lower Timing Gear. Searched
  125. Bah.. getting frustrated searching...
  126. my ecu is reading code 21 on my itr swap
  127. ?? What Cat to use ??
  128. JDM B16 integra XSi Engine Swap to '91 CRX - Engine Mounts Help
  129. obd2 b18b1 into 94 civic ex IACV help
  130. 00 Civic H22 HAsport axle issue (ride height or wrong axles?)
  131. MOTOR MOUNTS for EG??? HASPORT vs INNOVATIVE. SWAP QUESTION?
  132. Simple F2b build
  133. OBD2 to OBD1 Swap D14A4-D16Y2 Please Help Me
  134. B16a G2 swap help!
  135. H22a Powered EG HB PROBLEMS
  136. Honda D series Flywheels... have they changed since 1990?
  137. itr swap vtec wont engage
  138. Wiring o2 sensor
  139. car looses power..
  140. Need someone who knows 94-97 Accord motors WELL. f22b2
  141. s2000 trans will it work with any other engines
  142. keeping AC with H2b in Em1?
  143. 92' jdm h22a distributor cap/rotor replacement help
  144. Swaping my ls/vtec into a integra
  145. H2b EM1 Ready to be swap in but massive help needed!!
  146. rsx radiator in eg hatch
  147. Map sensor and starting issues
  148. JDM TYPE R MOTOR INSTALL WENT WRONG
  149. Innovative mounts, stock bolts wont work....
  150. p28 best ecu to use in a 98 civic ex lsvtec?
  151. OBD2 GSR DRIVE CYCLE
  152. No speedometer after swap???
  153. 96 civic dx with d16z6 engine and p2p (d16y8) ecu
  154. b18c1 smoking after high rev's
  155. gsr head or b16 head with gsr tranny lsvtec
  156. CRV power steering pump and bracket into an ek chassis
  157. f2b driver side mount help
  158. Want wiring info for b18c into ek3 civic
  159. help with h22
  160. H22a into 92 GS-R Wiring questions
  161. Older B16 Head on a Newer B20 block
  162. Knock Sensor Question
  163. Do I have to get BAR certified?
  164. b18 c5 into my 89 civic
  165. ITR DC 4-1 Header Question
  166. h2b with braided flex pipe??
  167. Knock Sensor code after GSR swap
  168. 93 civic / obd1 jdm b16 swap..... 2 extra chassis harness plugs
  169. h2b f2b swap wiring help
  170. h22a Wiring
  171. Mustang Throttle Body
  172. Acura TL Brakes on My Integra
  173. EF Sedan with GSR Questions
  174. will prelude spindle fit accord?
  175. obd2 distributor pinout?
  176. Adding pins to ECU plugs? Where to get pins?
  177. h22 in civic issues
  178. GSR block on B16 head?
  179. drivers side mount doesnt line up? help!
  180. OE Sensor/ECU Pins
  181. b18a1 into 1998 honda civic
  182. 4 Door H2b build HELP!
  183. eg/dc chassis
  184. h2b or type r
  185. which dizzy
  186. GSR rods in ITR
  187. H2B is it hard? How is it done?
  188. K20 worth it?
  189. need help !!! swaping b18c into 98 ek hatchback.
  190. h22a hatch leaky axle seal issues
  191. H22 CRX VSS Not operating
  192. B16a Idle After Vtec Problem
  193. possible to pass bar with a poor mans r
  194. I think my rear T bracket is an auto DC and not a manual
  195. axles length - civic EK h22
  196. Project S.W.A.G. Mid Rear Del Sol W/B18C1
  197. quick question about a hybrid swap
  198. h22 head on a f22 bottem end???
  199. integra midshaft
  200. Washington Emissions question with gsr swap???
  201. h22a
  202. h22 Axle problem
  203. How i should go about installing a OBD1 GSR motor into OBD2B LS chassis
  204. 1990 CRX DX with 199? B18A1 - what did I get myself into? Wiring help needed. *PICS*
  205. H22 in a wagovan?? has it been done and what needed to be done???
  206. NEED SOME WIRING HELP FIRST TIME SWAPPING IN A GSR!!!
  207. B16A OBD0 problem, studder & high idle
  208. HELP h2d ef
  209. F2B? Benefits and cons of the F20B vs. H22A
  210. Why to incress idle rpm when a/c on?
  211. Help... OBD plug won't read for emissions test (1996 EK w/ JDM B16)
  212. k swap issues...bent valve??
  213. h22 into del sol wiring
  214. has anyone done this???
  215. H2B Clutch Problem. . . HELP
  216. bigcalidave s2000 convertor order's.....crazy wait times!!
  217. b18a1 engine issues need HELP
  218. Need help with a D-series Hybrid
  219. h22 question please help
  220. JDM K20A on sale on ebay
  221. K series valve cover gasket kits compatible with each other?
  222. B18C (OBD1) into 93 Del Slo
  223. >>>>>>>>>>POST THEM UP CRX H2B evolution kits!<<<<<<
  224. Reading TPS voltage
  225. h22 eg with a/c possible?
  226. im new to the B16A, should be an easy question here
  227. Obd2a obd2 Reset after swap into EK
  228. 2000 Civic Hatch Swaping b16a2 Q's
  229. ls motor
  230. OBD2B to OBD2A Question ; Civic 99-00 with engine 96-98
  231. Type R motor in to EK with Type R 5 lug suspenion.
  232. 1987 A20A3 Motor and/or tranny into a '90 Accord?
  233. NEED HELP WIT VTEC
  234. LS/Vtec question
  235. auto obd2a to obd1 questions,
  236. Wiring a potentiometer to manage my fuel air ratio...
  237. CAN I RUN A B17 CRANKSHAFT IN A B16 BLOCK????????????????
  238. 8 valve 2 16 valve d15
  239. D15 Stock Exhaust Sound !! What do you guys think ?
  240. high idling with no vac leaks
  241. D SERIES VS GSR FUEL PUMP
  242. GSR compression???
  243. JDM D15B EF6 to B18C conversion
  244. H2B smoking
  245. obd2 to obd1 engine swap need help
  246. WIRING FOR A AUTO VTEC
  247. LS/VTEC Timing Covers? Which ones?
  248. b20 ef cluster problems
  249. no vtec b16a
  250. Map sensor plug in on B18c1 in EG
