PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 [116] 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. h22a engine harness?????
  2. b16a1 in 94 civic...????
  3. need exhaust that will fit????
  4. help...swap wont start
  5. valve clearance on sir
  6. b16a1 when in neutral the rpm drops extremely low and cuts off
  7. need your opinion: b16 with p72 head and tranny?
  8. Info on swap
  9. Just completed b16a2 into eg... CEL keep popping up..
  10. HELP RYANE Motorsports lowering Steering Knuckle !!!!!
  11. JDM ITR B18C-R swap into my EK Need Advice and help
  12. ? 97 sohc into CRX ?
  13. Poison's Review -- H22 EG Balance Shaft Belt Removal
  14. My first swap: 01 LS into 1990 Integra, Timing stays advanced
  15. Couple new pictures of "new" H22 Civic hatch....
  16. H22/Civic Header Release
  17. stock exhuast re-used after swap?
  18. NGK plugs. Whats what
  19. How much does a motor weigh
  20. b18c1 in 89crx hf HELP PLEASE!!!!!
  21. i need help with axles on an h22 into a 97 cx hatch
  22. Why do I have 2 wires from my K.S. on OBD1 H22?
  23. code 20 on b16 swap
  24. Info on h22 swap on 4 door!
  25. itr into EJ. A/C question. Good experience needed
  26. Wtf CEL Code 16 Suddenly After hitting vtec Fuel Injector dead????
  27. A few questions for you D series people.....
  28. b16a into my 94 civic got ? help!!!!!
  29. what does a EG weigh?
  30. JDM B18c(GSR) stock whp
  31. b16a2 1991 ????
  32. P73 in a 95 civic
  33. is crvtech really that expensive?
  34. Anyone running RC 310 cc injectors?
  35. My JDM ITR Motor brought all the mounts, which ones are used for an EK
  36. h22 into eg..radiator fan, common problem, my fix..
  37. Quick EG Engine Swap Question
  38. EK / GSR Hybrid - Which Throttle Cable?
  39. gsr or b20/vtec??
  40. how to get the distributor workin
  41. HOW MANY ohms for vtec solonoid, oil pressure and knock sensor HELLLLPPP!!
  42. Shielded wire for 02? Is this a must?
  43. hey doing a itr b18c5 jdm swap in a 99 civic ex
  44. HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values?
  45. ran into some probs on a b16 swap into a 91 crx hf
  46. Vtec Oil Pressure Switch In JDM b18c GSR......HELP needed...pics!!
  47. ?Wiring Two O2 Sensors Into One
  48. Swap shop locations #2
  49. distributor
  50. H22ek Wiring problems mid-swap
  51. Need some serious help
  52. B16A (sirII) with soch injectors?
  53. b18c5 in 94 civic hatch vs. 94 civic coupe
  54. anyone here done an obd2 b18c1 swap into a obd2b civic?
  55. 99-00 b16a2 into 96 EK hatch
  56. Fast idle valve for 1st gen B16a..
  57. hcp clearance
  58. A HYDRO TRANNY
  59. cel question that really needs an answer... please read :-(
  60. About TO buy a b20 from Osaka
  61. First time at the track today. Help me get my 60 fts. down!!!!
  62. b20b in an EG
  63. 97' JDM ITR head on GSR
  64. iacv madness on a DX b20z
  65. motor being put in this week
  66. MAP-sensor B18C1 - Where?
  67. Wiring issues in a b16a2 into a 94 civic ex swap
  68. Engine cell in 99 civic with obd1 ecu?
  69. Rim Offset Questions....
  70. h22 into 2nd gen teg??? has any one done this???
  71. Best engine for EJ Civic Swap
  72. help... can a 92-95 ex starter work on a bseries swap??
  73. Does it matter what model civic for my h22 swap? EX vs LX vs DX, etc. Also, you recommend EG or EK?
  74. B18C5 into 94 Si ECU question
  75. b18b swap not running well at all, cant hold idle...
  76. throttle cable
  77. can i put a gsr crank into an ls block
  78. did search!! Need info on B20 or H22 into a eg
  79. weight of b18b1?
  80. where can I get this ...
  81. shift linkage little bolt stuck
  82. Do you have MA license plate 7448PK ?? Black 2nd Gen Integra??
  83. small hole at bottom of tranny ???
  84. b16a2 transmission oil capacity?
  85. AEM CAI swap
  86. What's needed 4 a JDM B18C-R into EK
  87. H22 Civic/ with integra shafts
  88. can i get soft mounts and still swap in an h22a?
  89. 6th gen civic h22a swap
  90. 5 lug conversion?
  91. cable or hydro?
  92. b16a swap
  93. b16a engine mounts and axles---HELP!!!
  94. H22 in a 96dx coupe/Will a/c pump fit?
  95. b18b swap 500 idle
  96. vtec , knock sensor wiring problem
  97. H22 going in my 93 CX, what wiring harness to use?
  98. How do you tell what car engine is from?
  99. b18c swap into eg not fitting.......
  100. dx-si engine swap
  101. ROD KNOCKing AFTER swap
  102. to whoever im'd me about the wiring......
  103. common ground to cluster
  104. I need your help right now THANK YOU b18c1 obd2 swap into 94 cx
  105. LS/VTEC recipe
  106. b16 throttle cable needed for swap?
  107. new swap motor touching hood
  108. Swap
  109. Where to get Hondata ecu socketing?
  110. Have question on my swap?
  111. Need Help w/ OBD2 B18C1 in an EK
  112. anyone heard of svp???
  113. first question from me. ^_^ about b16a2 wiring harness...
  114. JDM B16A 1st Gen Fuel Pressure
  115. Need help guys on swap
  116. Hybrid h22 guru's. help.
  117. h22 in civic
  118. B18A Problems in my CRX DX! HELP!
  119. does your center console get warm without a heat shield on the cat?
  120. Necessary to remove evaporator core and change expansion valve?
  121. Should there be any play in the shift lever (base bushings)
  122. 90 LS motor into 91 Civic, What all is needed?
  123. B20 into 96 hatch mount questions
  124. code 9 #1 cylinder position sensor-just did swap!!
  125. b18c5 with obd1 head
  126. Fair price for swap
  127. B20 swap info
  128. b series in EF crankshaft pulley rubbing tie rod end
  129. Anybody else depressed?
  130. hey guys, probably see alot of me in the near future... ;)
  131. 99-00 Civic SI Harness the same as a 99-00 Civic EX or DX harness?
  132. b18c1/c5 into a 99 EX
  133. Info on my H23 VTEC Type S build
  134. JDM b16a swap to 93 cx wiring questions.
  135. SWAP SHOPS IN NC???
  136. MINI ME HELP!!!
  137. Dyno Day for East Coast Hybriders... (H22 or B-series)
  138. Mini-Me: Auto dx tranny only shifts @ 6300 w/ P28 ecu- why!?
  139. Will a code 6 stop my radiator fan from coming on?
  140. starting problems
  141. 90 civic swap
  142. Everyone that HAS done AN engine SWAP help me out!!!
  143. HELP ME ASAP!!!
  144. B16a Swap into 94 civic DX
  145. About B18C5
  146. b20 swap into 2000 Civic DX Wiring/distributor??
  147. need info. on GSR swap into my EJ6!!
  148. Why cant you use 90-93 axles in 94+ Integra's ???
  149. On a GSR swap, when switching pins A17.....
  150. **is there a difference in HYDRO & CABLE (b-series) axles?
  151. O.T. any one have any info onsr 240sx?
  152. Bleeding Radiator
  153. Exhaust system for my hybrid
  154. ordering my b18c (5) got some q's
  155. erratic idle on fresh swap done today-d16y8 into 93 civic cx-need help!
  156. Venom H22 intake manifold
  157. any hope for d15?
  158. h22a injectors
  159. ?~OBD1 complete swap into OBD0 (pre-OBD)~?
  160. GSR swap in 96 civic coupe harness question
  161. motor mounts HELP!! have a 94 EX swap with a b16a2
  162. complete b16a swap for a 88 civic 3dr HB questions!
  163. HELP WITH B18 QUESTION
  164. axles, whats the diffy on 96+ axles and inter shafts
  165. OBD 1 B18 into a 1991 CRX DX w/ points injection!! help!
  166. Ls swap into my 94 coupe?
  167. ITR swap 94 civic
  168. Shift Linkage Question
  169. ALL B20 Vtec
  170. B16a2 Swap Question
  171. which resistor box?
  172. How to kill $1K on Ek H22?
  173. cleaning vtec solenoid?
  174. Yet another issue with swap
  175. H22 swap/ what suspenstion mods?
  176. 94 Accord LX F22B swap wiring problems
  177. another great motor company.. Greanleaf used to be Eatmon Auto
  178. 1992 VX ---> 5-wire o2 sensor mods for 4 wire H22 o2 sensor (question)
  179. B20 Gasket advantages
  180. any swap good shops in Cali?
  181. finished car..what you think..what kind of power
  182. b-series into 94 si, fuel delivery question
  183. Question about axle clips and water pumps....
  184. H22 Ek wiring??
  185. hp to the wheels
  186. Fuel problem
  187. D16a1 into a crx??
  188. where could i find an ek hatch with no motor in so cal?
  189. how to determine LSD in tranny?
  190. what the compression
  191. jdm motors
  192. What are the lines out of the back of my H22 tranny... oil cooler lines??
  193. Cool/Small battery for all you Hybrid folks
  194. bck frm vacation...wiring civic H22
  195. Updated pics of the swap...
  196. H22A Distributor Cap
  197. 87 CRX Swap
  198. JDM Ac compressor on a B17 EG hatch??
  199. please help asap civic with sir2 swap have some troubles
  200. How about?
  201. 90 civic Si ,, H22 swap, place racing mounts,, some Q's
  202. Car won't start now after wiring secondaries! What did I do wrong?
  203. Need help with suspension setup for H22 EG...
  204. any with a ek with a cel 14
  205. h22 ek guys, what kind of exhaust setups are you using??
  206. differences in B18C-R
  207. LS Motor or 16A Motor
  208. D16Z6 Help!!!
  209. Crazy engine install question.
  210. Bee*R rev limiter?
  211. A "WIRING HOW TO" on a ITR motor swap into a EK
  212. H22 crank sensor
  213. i am swapping my accord engine for a h22a
  214. cx fuel rail/regulator
  215. is confused as hell?
  216. Tranny identification
  217. How much cutting is involved in a h22 eg swap?
  218. d16y8 into 93 cx-knock sensor & 4 wire o2 conversion///just need some clarification-no dumb question
  219. anyone have a h22 in a crx or 4g hatch????????
  220. , swap problems. CAR RUNS WEIRD! help me find the answer please
  221. 98 EX engine in 98 DX
  222. H22 guys..... who here runs the stock civic fuel pump?
  223. LS/Vtec wanna do it on my 97 LS. what do i need?
  224. Where to buy a engine in the NY metro area
  225. 94 integra and civic
  226. GSR tranny going into a b18a Block
  227. h22 integra turbo question
  228. aligning H22A balance shaft pulleys - (searched)
  229. B20 Horsepower info
  230. what do i need for a b16b swap into my 2000 si?
  231. f23a1 into ek??
  232. final swap list-please check and tell me if i'm missing somethin
  233. Who wants to trade me their H22 hatch?
  234. h22, b16, or b18c1 in my 94 civic dx coupe?
  235. how do i get ac connected in hatchy w/ gsr
  236. stupid question
  237. 1997 gsr fuel pump into civic? info need!
  238. wire both o2 sensors together and trick ecu???
  239. b-pipe differences(civic coupe vs integra gsr/type)
  240. Distributor Problems?
  241. h22 civic radiator fan problem, hits slave cylinder bleeder.... help thx
  242. B20 block ????
  243. question for all you hybrid junkies out there...
  244. FYI: Exedy cluches in higher hp applications
  245. Is It Possible
  246. In desperate need: engine harness side 02 elec. plug :(
  247. what is this sensor?
  248. Did Search...Vtec wiring for CTR B16B
  249. Worth it to take b16 out of CRX in 92/95 hatch?
  250. Finished GSR hatch swap, is the head RUINED????
