View Full Version : Hybrid / Engine Swaps
- RSX swap info
- B16 Swap Shift Linkage
- need help on b16a head w/ b18c block
- 99 head on a 97 block?
- Picking up my ZC on Sunday, need some transport tips
- workin on a 90 civic b16 swap need some help plz
- B16a into 91 CX wiring questions!
- need help with civic swap
- ITR shocks for EG6
- where to find a tranny
- vx-gsr ?
- VTEC Head?
- pics of h22 swap in my sol
- B16B, whats gotta change?
- Do I need a Integra throttle cable?
- Bolts that holds tranny to block?
- ob2ENGINE to 95si
- Gauge cluster install
- GSR Motor to ITR motor
- Tough fourth gear shift.
- which cai for a eg + b18c R
- 99 h22 :D
- H22ers PLease look
- Stripped Boltz
- need help with rear disc swap
- Custom Tach after swap?
- 99 gsr in 90-93 integra. help me out.
- 40K for a Prelude??
- CRV engines....
- thermostat question..
- 4-wire O2 with OBD-0
- My 97 Civic Coupe with H22 PICS updated
- what compression ratio do you get....
- Integ LS motor in a 95 hatch?
- need help, want to put limited slip diff. in a 2000 si
- How is your motor you bought from (insert company here) running after the install???
- I've been jacked for $1400!!!!Is there anything I can do?
- dist. for first gen b16 into a 95 civic
- b16 wiring question
- o2 sensor problem
- ECU Troubles: bogging, and no power !
- few pictures during my swap
- This is a repost, just trying to get some info here please.
- B18C/R Swap
- p-28 OBDI programs for GSR engine. whats the bets one?
- How can i tell if my ECU is chipped???
- confused obdi to obdii to hondata to p72 to...
- bolt on exhaust for 92 cx
- Idea for good gas miliage on chipped p28, will it work?
- Will i have to change plugs?
- help with b18c
- H22A 90 Accord Exhaust Options
- Ex coupe b18 ls vtec for sale, quick ass coupe
- Plugs
- Why would someone cut distributor wires?
- A/C Bracket Question!
- High compresion=high horsepower?
- 4-wire O2 conversion
- swap info
- Can u use a JDM B16 head on a USM B18C1 block
- B20B??
- I just ordered my b16 from HMO !
- B16 swap in to 91 civic: Running way rich + extra vacuum line
- Need swap information for 2 cars, please help.
- coolant problems
- anyone have bad experiance with Hondata?
- h22a civic axle ?s
- $4400 for a h22 swap......
- p28 Chipping
- real bad shaking at 30 miles per hour
- will this o2 sensor work?
- ATTN: Elite Hatch
- JDM b16a in 91 ef si, running too rich need help
- B16 w/VX Fuel pump lean?
- B18 into 97 civic dx
- Can i use a 96 up Wire harness with a 95 GSR ECU?
- JDM engine, wiring question
- Pics of the new motor in the car.
- 3 wires on injectors
- CR-Vtec
- Hondata vs. chipped P28
- h22 turbo tranny : accord or h22
- Are throttle body sensors interchangeable between B-series throttle bodies?
- anyone have pics of the back of their motor?
- NEED HELP...car is stranded...
- obd II distributor for obd I set up?
- state referee questions (need help) ASAP
- She's Done!
- sohc vtec ECU ????
- automatic b18b1 vs manual b18b1
- how much would it cost to swap in a 94-95 b18b into a 94 civic vx hb..?
- Anyone knows the front rotor's size of 92 Si?
- ITR carpet question
- JDM engine emissions
- engine swap question
- how can u tell if ur tranny is messed up?
- ECU switch Question
- A/C bracket for B18C into 93 CX hatch
- will 89 prelude Si axles work on my hybrid??
- 91hb si with h22a
- what ac belt for b18c using a b20 bracket and a sohc compressor in a 92 cx?
- Got to drive Itr-862`s Type R today
- h22a parts question
- H22 in 92 cx, need some help
- b16a2 in a gsr
- mugen valve cover?
- Finished H22 Swap: 2 Problems
- trying to do a mini me setup cant get d16a6 head off
- Wheels won't turn!!! '90 B18A1 into '91 CRX SI
- Suitable head gasket that will do the job and will not piss me off???
- with crv cams, 11.8:1 compression, and timing gears...
- code 23???
- h22 in coupe SI?
- OT: Trusted shops in nor. Cal?? Need a used car inspection...
- attention all tech pros.
- Which is easier/better, H22A into a EG civic hatch or a CRX?
- where can i buy instrument clusters
- Places to buy wiring harnesses?
- help with my hybrid!!!!!!!
- Swaping 1.5L del sol with 1.6L JDM Spec SIR2 - Instrument cluster question!!!
- b18b help..
- Igniter questions??
- Hybrid A/C question...
- HELP!! Check Engine Light Stays on constantly!!
- B17/LS VTEC stroker???
- Swap help...almost done...but need some help
- i need some help before monday rolls around
- B20b NON-vtec Smog Question
- Engine not level! - B17a into '90 LS 4 do'
- snapped alternator belt on b20vtec
- B18c Block Sleeving
- I have barely any experience with cars...Do i need to pay to get a swap?
- New b18C....
- d16/d17
- swap question???
- A few swap questions
- 94 p28, what rpm does vtec engage?
- Shops in So. Cal that finance swaps and parts????
- axle help please
- People that've swapped B16's into EG's...
- Does anybody make Weld in Mount Kits?
- Head lights = Dumb
- SRS Light!?
- Del Sol intake on a 1st gen B16a?
- 99 civic coupe to 94 civic hatch swap
- GSR question
- Any good tips for a seemingly simple swap?
- Radiator pressure problem?
- B16A2 head on B20 block??
- Help please need torque rating for cam plate on 1st gen b16
- What is the most reliable but not expensive way to hit 12.999 in the 1/4 mi?
- anyone places sell custom testpipes ?
- Vaccum line chart and locations for B18C
- How to identify a gsr tranny?
- check engine code 17???
- i have a 93 b18c hatch what radiator should i use pics inside of swap
- Ppl with B20 swaps...what intake manifold, fuel rail, injectors, etc did you use?
- Cable --> Hydro conversion kit
- Check Engine Light!?
- CRX Swaps
- finally done with swap!!!
- ecu specs
- Pic Request: Rear shot of B18C1
- Will GSR OBD2 cat work on OBD1? Need answer ASAP
- when buying an engine you should?
- DSM injectors...which year/car
- JDM B18C1 wiring questions...
- new swap problem!! :|
- How to Fix the secondary Vtec
- Valve specs for B18C
- mini-me swap which fuel pump?
- Anyone care to guess my Times for tomorrow night?
- JDM B18C misses and lacks power
- Places in SoCal for Swap!!!
- starting first swap friday, any pointers?
- what cat to use?
- seattle area??
- obd1 p72 running 94 d16z6,,,,,,,,
- crvtec/h22/gsr/ls-t?
- delsol a/c braket
- Will a 93 GSR master cylinder bolt up to a 90 teg RS ???
- Ideas for 2.5 inch exhaust??
- b20 injectors vs. OBD2 LS injectors
- Street Racing In Roanoke? I am at school in Radford VA I need street racing
- 2.5 exhaust??
- How to check if vtec opens up?
- CRX w/GSR:starts up, revs to about 1G then dies
- Help SOHC hybrid questions??
- jdm b16a 02 sensor
- Got a hot Hybrid ? You MIGHT want this....
- B20B
- B16B/b16a/b18c
- quick header question...jasma related
- Just ordered my JDM B20b from www.hondamotorsonline.com!!!
- Need to convert B18B1 to vtec head.
- anyone have instructions for changing auto computer to manual?
- intake camshaft not going back in rite?
- JDM GSR dynoed.... with zex
- anybody have a '92-95 EX/Si harness?
- 90-93 integra cat fit GSR swapped CX exhaust?
- 94 GSR Ecu what parts can i use with this for a CRVtec
- reputable shop to finish wiring in socal??
- JDM B18C in an EG, what cold air intake fits
- help , my car looses most of the power at high end
- B20 civic swap - quick question.
- More of Randy's products
- Which cams recommended for this setup?
- Better question, anyone seen an EG run a B18C1 with stock P28? How'd it go?
- b16a vs b18c in a CRX...which is the better bang for the buck???
- shift linkage help asap?!?!?
- B16 A1 vs B16A2
- ek swap help needed
- What should I do?
- 99 gsr motor in 2001 civic. complcations?
- Exhaust: Keep the Thermal or go with the Apex-i N1 w/silencer?
- Where do you mount your 4-pt harness in a EG?
- what do you think of my 5th gen hatch??? isn`t it coooool
- Vtec hits but no more speed????
- B20/LS motor questions
- CEL code?
- Mid-shaft question???
- Best Swap
- Help: H22 swap in an EK?
- need help with a code 7 and 22
- no gauges...?.... why?
- Not sure if you guys have seen this? Dart Blocks
- Shops around the SC, GA, NC area
- 1st Gen B16A in 98 Civic EX Coupe???Need some help guys!!!!
- have a swap?? b18c1 in a civic 93 hb dx please help
- HELP Jdm engines wire harness
- what do u think about this ideea ?
- What to Swap in?
- b16a2 with gs-r harness
- My car is all better now!!!
- B16a2 head??
- did search, mounts for b20 in EK?
- Problem with valve adjustment?
- Can someone confirm this B20b/z info?
- Opinions on my next project.
- ECU question
- How reliable is LSVTEC
- b18a help
- swap help please!
- did a search and did not find s2k Swap in an accord??
- ecu plugs?
- would thin oil cause low oil pressure?
- B18C2 map sensor problem in 92 lx
- intake manifold
- Eg Radiator in ef hybrid????
- B18C5 swap question, good question, not the like the rest of the B18C5 questions :)
