View Full Version : Hybrid / Engine Swaps
- B16a1 to b18 conversion
- just swapped and starter/fuel pump quit on me!
- Got 92 Civic Vx Hatch.. Ls Motor or H22 wit Skunk 2 coilovers?
- GSR EF... help.
- h22 secondary butterflies???
- ECU code 5 (map sensor) HELP
- JDM H22A swap questions...Falken Azenis Sports, Flidyne radiator, etc.
- DOHC ZC engine starter???
- Is my gsr secondary butterflies openning up?
- 85mm B20vtec fuel requirement?
- IS P72 OK FOR H22A IN 93 HATCH???
- LS Swap final check
- need help
- '97 GSR swap into '97 7g Civic EX: MAP high voltage code??
- In SoCaL Suggest sum good swap shops!!!!!! plz help ::NoOb?::
- b20 motors????
- Suggestions and opinons on engine mounts for B series into CRX
- leaking something need help
- emissions parts
- eg prelude shift linkage
- ls wiring harness (o2 sensor)
- K20A2 in '99 Civic
- H22 -EG clutch throw question
- vtec problem after distributor went out.
- Leakdown test #'s
- secondary butterflies removal????
- All new Si motor mounts and place racing driver's side mount what do you think?
- obd1 GS-R Into 92 si hatch info wanted
- i noticed the install guy put a p72 in my h22a civic is that ok?
- ls turbo vs ls vtec turbo, whitch is more reliable and more powerful?
- Question Involving the Half Shaft
- obd1 and obd2 p72 ecu pin outs!
- Got a mean wobble that starts around 50mph after doing swap, any ideas????
- 1st Gen B16 swap into an EG EX
- secondary pins for p72/O2 sensors???
- Has anyone else seeing this crazy shit?? Someone must be mad
- D16Z6 Work
- HCP H22 Shift Box Info
- JDM GSR into 1992 Civic HB DX
- Looking to do a full Type R swap into a 96-99 Civic
- Swaping from a d16 to a b18a
- Anyone up for an H22 civic meet in orange county.
- H22 VSS problem can anyone help?
- b16b swaps in civic coupes
- difference between B16A engines only- in terms of OBD & sensor placement
- b16 XSI distributor
- D16Y8 Mini-Me
- Timiong Belt Replacement...H22
- b16 swap, rev limiter at 7500?? throwing code 22 (VTEC PRESS).... help please guys n gals
- B18B1 for B18C1 Both OBD2
- *sigh* crappy company. what can we do?
- questions before i boost...
- idle @700-600rpm and 3500rev limit?!?!
- h22a ecu
- Swapping B16a into my 92 Integra RS...questions!
- 96 EX coupe with b18c
- 94 accord 5speed to auto
- JDM H22A into a 1992 CX Hatchback...INTAKE QUESTION!!!!!
- NorthEast H22 Civic Meet - PICTURES! 56k maybe :-P
- b17 swap
- how much HP or what 1/4 time on ls vtec in 90 integra?
- B18C1 in EF - wiring harness or adaptor ?
- H22 runs in del sol BUT...
- B16 in a 1995 4 door civic
- jdm b16a into 97 civic ex Please help!
- VTEC-E wiring the EGR on H22 Swap
- GSR swap into a 93 civic dx.
- 98 Gsr swap in 00 Ls...please help!
- Just got a k20, What mount kit options do i have? (DC2)
- b18c1 -> EK o2 sensor question
- NEED TO MAKE H22 SMOG IN 92 EG6
- h22 swap in del sol throwin codes
- d16y8 swap problems in 89 civic hb (wiring problems)
- **HELP** H22 jdm vs usdm. How can they be told apart by looking
- IAB (secondary butterfly) Wiring????
- h22 owners.......what cold air intake do I need?
- NO VTEC HELP!!!!!!!!!!
- fuse size for IAB solenoid with rpm switch??
- Don't buy engines from Zerolift out of Ohio
- ls vtec
- good place to get mounts?
- awd del sol?
- k20 weight?
- B18C into a 92 Civic CHECKLIST?
- Noob help with 5th gen B16a swap and more!
- v-tec not working
- Help Please, VTEC Solenoid
- B18C into a 98 civic coupe
- IF I HAVE A B20B could i use a head from a B18 so i can run Vtec?
- 1992 dx swaping a d16z6 with p28......do i need to tap into the ecu for vtec?
- H22 swap... in civic..
- What intake for a B18C1 motor in a 99 Civic???
- cams for my b20 vtec
- h22 throwin these 4 codes!
- Where do engines come from???
- Head Question!
- timeing belt help needed
- B18c5 In A Crx
- k24 into 97 accord
- Vtec wont engage with p72.. but will with p28?
- Will K20 swap take over
- swaped b16a into 91 civic hatch problems ??????!!?!?!?!
- v-tec not workin, help guys!
- difference between 90-93 integra shift linkage vs. 94up shift linkage
- obd2 dizzy ? to many wires
- Frakenstein: B16a1 head to a B18c1 block w/ ITR Tran Q'S???????
- Grey plug in EF
- do i have a skunk2 IM
- EH2 B18C1 with p54 a/c bracket: which pulley?
- EGR Wiring on HX Civic for H22 Swap
- HELP - B20vtec starts then dies??
- mini me y8 head bolts to long
- Swapped B18c no vtec and bogging, need help
- If we had another "support me as a mod" thread would you support banning them?
- Free AEM Intake!
- How high compression on H22A & other questions.
- Exhaust for ZC motor in 91 crx si
- Compression Question B20B
- help mini me run right!
- B18c1 Automatic ECU???!!!???
- Radiator choice for h22 eg swap
- NEED ASAP! B20 into EG swap question!
- low rpm studder?
- Help is needed
- Converting ODB1 H22A to OBD2 to pass smog test on EK
- PS Parts for B18C swapped EK
- OBD2b itr ecu in 99 civic. Have coded key and swapped pins. Still doesn't work
- anyone using placeracing mount for eg h22, please help
- what do i do about a map sensor? h22a into 94 accord lx?
- B16 swapped.
- p13 or p28
- highest/savest redline for a stock h22a
- EGR wiring for VTEC-E (HX model civic)
- anyone bought swap from...
- I need some help obd0 b16a into ob1 car....
- obd1 gsr into a 98 hatch...
- My first OBD-II swap NEED HELP!!!
- LIST SOME HONDA JUNKYARDS!!
- mini me
- b16 swap in 89 crx hf
- 94-95 B18C into 93 Integra helpful swap info
- Ever heard of removing the secondaries?
- gas milage for B20Z and B16 SI tranny
- h22 axle question
- what tranny?prelude or accord 2.2 with lsd?
- GSR swap getting CEL 20 why?
- gen1 obd0 b16a into gen2 obd1 del sol
- wiring harness problem
- OBD2b ECU and OBD1 Motor
- Parts
- engine swap
- which power steering pump do i need?
- JDM H22 into 92 CX Must do's
- Kind of LSD with a K20a?
- B18Ls into 95 hatch, Exhaust question
- H22A1 into a 93 del sol S questions.... pls help
- lsvtec...
- h22 shiftlinkage quick Question >>LOOK!!<<<
- OBD I JDM GSR swap into a 92 civic DX
- Engine Harness question
- California bar certifying a civic type r motor
- H22 Swap But I wanna go turbo, Should I Sleeve H23 block or sleeve H22?
- h22 redline kicking in at 6800????
- WHAT DO i DO WITH THIS
- what coil overs and spring rates should i get for a 1994 civic cx
- I'm installing a JDM GSR in a 99Ek Coupe Whats the best stock ECU to use?
- damage tps vacuum hose
- How restricting is Catco?
- lsvtec in 99 EK w/ 99 ek wire harness
- Correct me if i'm wrong... (dizzy Q)
- will a 2001 gsr plug and play in a 97 gs
- 94 GSR swap, Vtec not hitting till 5800rpm why??
- EUDM EK-GSR, slight problem with vtec.
- HASPORT mounts?
- Sup Guys
- k20 swap
- O2 censor on an H22 EG swap
- clogged catalytic converter ??
- LS Vtec or GS-R swap
- any H22ers runnin no cat and no resonator?
- Cams Question
- red line 7500 rpms with dohc ecu tell me whats wrong!
- Swapping A6 and A11 ecu pinouts for H22 swap.
- hybrid tranny, 4.73 final drive and boost???
- H22 guys... have you guys seen this?
- 91 integra / b16a need some info..
- Automatic Swap! IS IT POSSIBLE????????????????
- CHP Inspection?!?!?
- Parts
- Swaping obd1 B16 into OBD2 car please help
- Wiring ECU
- tubro on ls or ls vtec
- 94 GSR secondary butterflies help??
- Head Stud Torque Spec Question
- OEM intake for GSR swapped EK?
- LS swap help (into 6G HB)
- b20vtec fuel question guys...
- b20 vtec parts list
- Why is my engine choking?
- car won't crank over...help!!!!!
- Beware of HMOTORSONLINE.com
- tps replacment
- What program for eg22 with p28
- ? about vtec
- B18C5 into a LS?
- 93 honda del sol si with jdm b18c1 swap what axles do i use and rear motor mount
- b20b with b18b head
- H22 EK swap clearance problem.....
- Found a Problem with my vtec, need help
- valve ticking(adjusted 200miles ago)
- Will the Lude guage cluster work in an EK hatch???
- CRX B18A: FUEL PUMP PROBLEM
- wtb 92-95hatch in texas area
- hello everyone i new to honda tech
- looking for all the available LS/b20 vtec kits
- 98 h22 converted obd1 95 del sol map sensor ??
- eg h22 swap
- Experienced engine "swappers" HELP!
- d15bvtec cuts out at 75% throttle
- Dunno where to install the hyper ground wires
- Exhaust help. Please read.
- Want to drop h22 into ek in nyc...
- Gs-r Coupe Ex 95
- p13 auto?
- 94 grs vacuum canister thing under the intake manifold what is it??
- 94 B18C IN TO 93 INTEGRA LS WHAT DRIVERS SIDE MOUNT
- B18b swap into 1995 CX question
- i NEED mounts. WTF Hasport doesn't make (prelude) h22 mounts anymore???
- H22'd Ek Civic questions about injector resistor box....
- EGR valve on H22 EK Civic.....
- k24 block in a RSX type-S parts list!?
- Vtec not working problem
- h22 motor wont shift into reverse?!!!!
- *********** flashoptions.com ???? ever heard anything about them???????******
- d-series transmission inside b-series motor??????? HELP ME
- where to find Lude CV joints??
- Axle problems with 97 DX hatch - H22 (kinda long... cliff notes included)
- Do I need to change the Injector Connectors?
- swaped b16a into 91 civic hatch si axles giveing problem i think ??!?!?!!!!!!??!?!??!
- mabye you guys know better eg catback fit on a db8 teg?
- Is this b18c1 worth it????
- JDM GSR VS USDM GSR COMPADPILITY
- Help... Searching for competent swap shop in So Cal.
- Help me find a write up!!
- 00 gsr swap in 96 LS pulling my hair out please help---------------
- new temp gauge, now fan doesnt come on
- integra gsr lower sway bar into eg,need help
- My new motor acting up on me please help.
- GSR tranny and 92 ls axles.
