F22 cam gear specs?
F22 cam gear specs?
I'm doing a custom build on a different engine and need a 40 tooth adjustable cam gear where there is no aftermarket available and have been searching other cars. Found that the F22 engine is 40 tooth as well.
I would appreciate it if somebody could provide the width of the groving 'valleys' and 'peaks' as well as the OD of the gear and the ID of the hole that the cam slides into.
Thanks!
Thanks!
Re: F22 cam gear specs?
Thanks!
Thanks!
Geo Tracker 16 valve g16 engine. Got the machine shop to put a d16z6 crank in, clearanced block for FJRspec custom length i beams, ACT race bearings, YCP 75.5mm Vitara pistons, PNP head, head decked .015", line honed, bored, honed, etc... the list goes on. I've got a lot of money into it and just want to play with the cam settings from the near 1 point drop in compression (now ~8.5:1) and just overall as I may get a regrind.
On that note, I purchased a $30 adjustable gear off ebay to give it a try and talk to the machine shop about makine a piece that would allow me to run it. The F22 has the same tooth pitch so the spacing is/should be the same and since it's a 40 tooth gear it 'should' be the same outside size.
