View Full Version : Hybrid / Engine Swaps
- b16 into a del sol.. looking for advice and search is not giving me any help
- maxbore on H22a resleeved??
- H22EK is alive... ALIIIIIVVE!!
- gsr brake swp????
- 00Si/LSVTEC wiring into a 96 hatch HELP
- B18C1 into a EH2.
- What do you guys do with your old engines?
- B16 into an american car?
- Header question...B18C GSR into EG, type r, ls?
- sohc vtec power?
- head swap: d15b7 w/d16z6 head
- best brake setup for 15" rims
- someone PLEASE help me!!
- 96 ex motor into 94 civic?
- Simple ?.. what timing belt for mini me (d16y7 block with d16y8 head)
- 85 accord? Swap options?
- what are the other 3 codes next to the year of the engine ....
- What was that link to run USDM block numbers????
- P30 or P28
- jdm b16a into 1999 Civic Si
- h23 worth it?
- Need a Helms manual for H22
- Gsr axles i think not what a crock of shit!!!!!!!!!!
- JDM SIRII into 93 Si Hatch. Which PS pump and AC compressor can I use?
- shift linkage
- Swap & Shift Linkage>>bad synchros???
- b18a into a 91 si hb
- EG d16z6 swap help please...urgent!!!
- Where can I go to find a B18A complete swap?
- ZC question?
- Getting a new motor... help with legal stuff
- d16 replacement, need help with codes
- what shop to swap
- need help please!
- Q about ITR rocker shaft
- shoping list for my B18C1 swap into 88 CRX...
- Ls/vtec
- 99SI engine in 98 Hatchback? I am new and don't know nothing
- JDM B16 into an EK
- can you keep a obd2 ecu in a obd1 car.
- help on a unfamiliar honda!!!!!!
- Diffrences between 92-96 and 9701 prelude motors??
- B16a
- Engine Swap Help Please
- Doin a h22a swap into a 92 civic sedan
- Cat-Back after swap
- good set up or not????
- Missing a plug on a B18B swap into a 99 civic lx. Please help!
- what do you guys think of this set up???
- Flywheel differences between D-series?
- Hondata 2 question
- What will fit into an '88 Civic
- ITR intake mani on b16
- Cable clutch tranny into an EK?
- rattle noise from crank
- b18b in to cx, what motor mounts do i need
- Uregent Help Please!
- 98 CX plug into 00 si ecu?
- ls tranny?
- any truth to the b20 oil pump being just like a gsr?
- What axel's do I have
- OBD0 / ODB1 Centralized Information - Please Contribute!
- will RC 370 injectors idle on a stock ecu?
- Help...dumb question about swap...
- B16 swap
- Which setup to go with?? Please Help!!!!!
- LSvtec and B20vtec compression
- Anyone who has put b18c into EK..
- Shifter skewed to the left
- 3 sensors on back of b16a block are 1 knock, 2 oil temp,3 ...???
- SOHC to DOHC head swap? D16Y8 to B16a, etc...
- building ls vtec
- RWD transmissions?
- b20 vtec ?'s
- ls-vtec motor mounts....
- Just a thought for Mods and Hybriders - please read
- Converting OBD1 JDM GSR to OBD2...Reveiw my checklist please
- Can I use abs rotors and calipers from an integra to upgrade my non-abs civic?
- Total Swap Cost
- diff betweeb ls and gsr tranny....
- Im back!!!!!
- h22 ek
- 1st gen B16 valve springs in a d series?
- Wireing Diagram help!
- 5G VX, DX or CX? Which is best for swap?
- itr in hatch
- ITR or GSR in a hatch?
- I bought my B20 from HMO today
- b20vtec?
- powertoweight
- Question on Civic SI Swap
- Ek H22 shifter Going South!
- need help on 99 jdm ITR swap into 90-91 LS w/ b18a
- How hard is it to get a gsr engine in an automatic ls?
- Motor Mounts?
- What lsd works on a 94 gsr
- Light weight flywheel chatter
- cheapest route to 13 seconds
- did a B16A (JDM)engine swap in my 94 civic SI--computer question--
- An OBD1 to OBD2 wire harness ecu conversion
- Need wiring Ecu help for 95 Integra LS w/97 type r motor
- B20/vtec help
- I need help identifying the origin of my Y8 head....
- car is screwy
- Are their differences in the motor mounts for USDM and JDM B16A's
- hybrid tranny: Ls & b16 tranny
- Are their any 240 sx converts out there ?
- Tools?
- 93 teg axels in a 90 DX
- Swap Questions: JDM 95 B16A Sec. Gen. into a 93 Civic Si HB
- Wiring a 95 JDM B16A Sec. Gen. into a 93 Civic Si Hatch
- wiring for injectors
- My head hurts!
- Boring out throttle bodies.
- D16Y7 and D16Y8 bottom end...same??
- B-series Throttle bodies
- b18b swap in 92 civic hatchback Help!!!! please
- b16a2 into 98 cx
- Wiring for Type Sh to 94 Civic ???
- PM9 ECU what is it?
- Motor swap for a 3g Prelude?!?
- ls/vtec ???????????? HEADS???????????
- Little help. . .
- mounts questions for b18c into an eh2...
- OBD II to I swap... Experience with smog check anyone?????????????
- Need opinions, Does this make sense???
- any one heard any more on osaka
- V-6 prelude
- b18c1 in to vx
- prestone plugs
- 98` JDM Accord F20B in a 91` Accord?
- ACL ROD/MAIN Bearing question, b18a same size as b18b?????
- I swear i did a search!
- Boring the B16a??? what will the outcome be?
- CTR cams
- is this true
- Need suspension swap info.
- ? about jdm engine and emissions
- h22 EG Type S Update..
- Best Axles for EG H22a?
- GSR tranny problems??
- piston/rod compatability
- Exhaust setup for B series EK with JDM 2.5" collector
- d series questions ,help me with my swap!!!!!
- Installing a Skunk2 intake manifold in a couple of days....
- 1st gen b16 in eg
- H22a, No start,but cranks OK,need help!
- which throttle cable and heater hoses? 2000 B16a2 into a 96 civic.
- Where to attach cherry picker to motor?
- B-series Brackets?
- Who is RESPONSIBLE!!!!!!!!!
- itr susp. on ef
- need some answers please
- eg + b-series = wiring questions
- what would you do with $12k.....
- ls 5th gear swap
- Swapping to B20 soon...any d-series parts that I need to keep? Selling old engine...
- Anyone want to buy my hybrid accord?
- b18b and $1,400! What to do?
- LS/Vtec. what's the point?
- this is answer a LOT of swap questions...
- H23 Dohc Vtec
- Question about osaka and Jdmhonda5
- jdm b18c guru's
- Anyone running a JDM F20B DOHC VTEC?
- Civic Hatch w/B20-Vtec?
- Which pistons
- Wiring 99' Teg to same Gen JDM GSR (different year), How??
- Building a motor... Piece by piece
- LS/VTEC How Tos Help!!!
- h22 or h23 swap in 6th gen accord?
- Conversion Harness
- Tried starting my H22 for the FIRST TIME tonight AND.....
- differences between auto and manual b18b?
- D16Y7 in a 1990 Civic DX auto
- doing a b18c swap?
- how to tell diffrence between b20b and b20z?
- purchase a long block or complete swap?
- Is it worth it?
- I need help with my 91 CRX b20b swap!!!!!!!!!
- B18B in 90 crx Si
- Has anyone in here bought just a bare chassis before?
- b18a swap
- Are B20b blocks/sleeves any stonger than a B20z or vice a versa?
- good shop for h22a swap in bay area?
- Is this supposed to happen?
- Another swap question
- 90-93 teg suspension into 89 crx dx
- Need help!, LS/VTEC vets only
- B18c1 hybrid hatch Dyno results
- 93 civic, 93 ls motor, knock sensor hookup required? are wires there?
- Wondering if LSvtEC TURBo is a good idea...
- USDM ITR Header with stock 93 delsol cat?
- ForSale:Built B20/Vtec Motor
- Turbo piping on hybrid civic
- which tranny is good for a B18B?
- Interesting dyno results and Ignition Timing.
- b18c5 Dis question
- best exaust for b16a na 4th gen hatch?
- How do i stop my axles from spinning?
- rev limiter engine from hmo!
- 97 jdm brakes to a 94 non abs sol, will it work?
- h22 setup
- What is the best engine to put in my civic
- ATT: Newman and other experts with HCP mounts and Shaft combo's !!!!
- vtech head
- Valve Spring compressor Question for B-Series heads
- direct drop-ins for 95 eg hatch
- Vibration after swap
- Tach/CC not working
- which ecu is the best to run with a h22 in a 93 hatch?
- VIN Question!!
- Best informative resources..
- Please Help! CEL Code 41 in 92 VX with 98 GS-R Swap
- tell me what you think of my lsvtec
- help b16a2 problem with oil pressure
- I was ripped off by HMO!!!!!!!!
- 92-93 DX hatch, ls vtec, P30 ecu, throwing code 7? help with ecu codes please!
- anything from a JDM GSR front clip..
- b16a1 vacume lines
- Resetting/rolling back miles on cluster
- how do i wire up this swap ?? 92 civic and 92-95 jdm b16
- b18c5 cams
- jdm b16 or b18b???
- ls/vtec done my allmotor civic pics
- Fuel pump
- ECU Chipping!!!!
- 1/4 Times...
- b16a vtec
- Possible Swap B16A (JDM SirII) into my 94 Si
- GSR head pics need help
- Hole in a H22 transmission! Help please.
- EG JDM H22A Swap Pics & Info - Its Done!
- best place for engine?
- B20b throttle body?
- 99 EX Intake Manifold on z6 head IACV problems.
- b16 in 92 teg wiring
- Road Trip to Osaka! Looking for some advice.
- h22a in 96 hatch.. please help!
- Can I use this shift linkage?
- jdm b16, is this a good deal?
- My Swap Checklist:
- HMO: My swap story
- problem with gsr tranny. plz help
- how did you do it?!
- List, anything else?? (Help!)
- mini-me questions
- B16a sir1 reliability?? and my swap decisions..(long)
- B20/Vtec...Ls/Vtec???
- H22a going into the EG
