PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 [29] 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. H22 into EK - A/C?
  2. ac on h22 eg
  3. Which web site is the best/honestest to buy a JDM engine?
  4. where do the wires for the clutch sensor run to the car at
  5. 91 CRX HF Purge "cut-off" solenoid
  6. h22 in to civic 97
  7. Few H22a into EG6 questions
  8. Evo H2B Question
  9. ebay motor mounts
  10. 91 Civic with 93 Integra B18 Limp mode question
  11. d17a1 questions
  12. obd1 to obd0?
  13. Best Motor For My Hatch
  14. hydrogen fuel cell
  15. Axle is too short, need one that is 1-1.5 inch longer
  16. 92-95 civic a/c
  17. What's with the Acura Legend
  18. HHO
  19. Erratic idle at startup b16a1
  20. h22 headers
  21. K20A swap into my 1998 integra type r
  22. dual butterfly hookup wut does that mean
  23. need help wiring up my b18 c in my del sol its obd1
  24. K20 Swap EG with Air Conditioning?
  25. b16 in a 91 civic wagon
  26. obd2 harness using obd1 dizzy
  27. gsr swap with p28 limp mode
  28. main cap
  29. SWAp Qestion
  30. 1995 Civic with B18B swap PR4 ECU and I'm getting Code 12 EGR Lift Valve
  31. K20A swap
  32. H22 Swap in 94 Hatch
  33. ls vtec build questions HELP ASAP
  34. H22A7 in DC2, what kind of distributor?
  35. EG WITH A GSR SWAP, A/C HOOK -UP
  36. obdo to obd2
  37. im building a b20 vtec
  38. H22 problem
  39. Building H series bottem ends with F/K series cranks ???
  40. Running way to rich
  41. b20vtec overheating
  42. b18 in civic?
  43. Converting from ITR to LS/VTEC...parts list?
  44. Smoke coming from H22 tranny?
  45. Swap Nightmare Help
  46. OBD-I to OBD-II? B18B1 swap question
  47. ATTN: swapped VX only Hatchbacks
  48. b20 swap... i need advice.
  49. itr lsd in s4c trans
  50. Is it possible to put a sohc f series in a 1990 civic?
  51. h23a(bluetop) with S2P2's cant get to idle to save my life
  52. Anyone have a diagram on how to repin a obd2 dizzy to obd1
  53. cb7 f22 in a civic wagon ee2
  54. EK B16 swap and auto to manual at the same time lol
  55. H22 axles with Accord intermediate shaft
  56. GSR swap help ? Misfires!!!
  57. How to remove mount bracket studs?
  58. EX going from D16Y8 to D16Z6 as OBD2
  59. b20b swap question????
  60. Anyone in New York that can help me out?
  61. jsut got b16 swap in 88 civic and there is a grease leak near axle...
  62. I NEED HELP WITH B18C PROJECT
  63. H22 into DC
  64. have a b20z2 Q.
  65. no clutch after swap???
  66. Qsd / Evo Center of Gravity question . . . NOT a VS. thread . .
  67. bin for H23Vtec JDM
  68. Official H2B Hood Pics Thread QSD Kit
  69. BAR legal H2B?
  70. issue with water temp gauge after swap
  71. Trying to ref my k-swap
  72. What Altenator belt for H22 SWAP with NO AC/POWERSTEERING
  73. Gsr Swap Vaccum/Throttle cable questiosn
  74. What would the ECU be for a '96 EJ7 JDM?
  75. 2000 d16y8 into 97 hatch HELP ME
  76. Help needed from Ek Evo h2b guys!
  77. Pics of 88 civic with a b16 sir second gen
  78. GOING k Series what do i need
  79. QUESTION ABOUT CUSTOM VTEC OIL LINE SIZE. WHY 6AN?
  80. New to hondas, have a couple Q's
  81. can i use used arp head studs
  82. b18c1 and b18b1
  83. B16 in EG coupe, high idle question
  84. Distributor Woes... Could quite find the answer in other posts
  85. h22 swap in civic... NO SPARK????
  86. I-DTEC 2.2 Diesel Conversion into EK/EG
  87. OBD2A Motor into OBD2B car?
  88. H22 Civic Shifter Problems
  89. B16A in ef Misfire Problem.
  90. chipped sleeve, check this
  91. Need help bad! Interesting problem here
  92. OBDII or OBDI convression in B18C5 into EK coupe 96 (d16y8) ???
  93. injectors
  94. Toda Spec B valve-to-piston clearance???
  95. another b16 sir II into EK thread
  96. How much would i be lookin at for.....
  97. k20 for sale
  98. Trans re-gear for a rock stock B16a drag car, MFactory stuff. Opinions?
  99. civic coupe 96 swap into B18C ITR engine parts and electrical matters !!
  100. need part number help on rods for B18c. Same as B18c5?
  101. H22 CRX JDM Fuel line length needed?
  102. dohc vtec cam caps
  103. ITR with gsr 5th or Gsr tranny for my H2B??
  104. Need Help with a 93 H22 Civic Swap
  105. JDM B20B CPS
  106. new integra to hybrid conversion (not a swap, but electric/gas)
  107. Possible fuel delivery problem?
  108. h2b ek question
  109. fuel pump k series issue
  110. K20 Type S changeover with paper work and mounts for sale
  111. Transmission Stiffener
  112. A/C on a Civic with GSR
  113. Swap Issues
  114. Someone told me that you can run a B series compressor in EG if you switch one of the lines is this
  115. Stock H2B Dyno Results 216/166
  116. got some questions on a b18b into a 2000 civic
  117. need help with map sensor wiring and b16a problems. HELP
  118. lsvtec plug gap??
  119. Engine Sputtering please help!
  120. LS in EG and I want AC. But I dont want to use civic compressor.
  121. itr swap help
  122. engine swap
  123. hubcentric spacer for 90 DX Hub and 90 EX rotor
  124. obd 1 LS/2000 CIVIC
  125. Swapping b16a to b20b - wiring questions help needed asap.
  126. 1 quick questions to people who knows motor( 96-00 swap)
  127. Doing hydro conversion, need help with fittings and line.
  128. Vtec kicking in and out on a fresh ls/vtec build
  129. Help Ek b20 swap!!!!!!!!!!!!!!!!!!!!
  130. 1997 jdm h22a distributor part number, is it TD77u?
  131. help ls vtec wiring in a civic vx hatch?
  132. will my 90 integra hubs fit on my eg?
  133. B18C on the way, need emissions help to prep
  134. customers 96ek w/obd2 gsr bogging @7k (need help)
  135. power stearing pump relpcation kits? h22 del sol
  136. Shorter Inlet Manifold needed for my conversion
  137. what RAD HOSES should I use for K24 EK swap ?? ?? ?? ?? HELP please !!
  138. Mounts for b18b into EK
  139. K20A2+Civic Si 5spd???
  140. B18C into EG Problems Hard Startup and Limp Mode 7 Month Battle!
  141. Padawan PS Removal Kit
  142. obd2 to obd1 dizzy Re-Pin diagram
  143. engine harness question?
  144. LS swap into 96 Civic DX.. SEARCHED. question about wiring and A/C + power steering
  145. Couple b18b questions.
  146. Confused about crank sensor wiring for B20/VTEC!
  147. D16Y7 Head on a Y8?!
  148. Don't drill spotwelds at 2 in the morning... (I'm an idiot)
  149. crx ls swap...what am i missing?
  150. What stock intake to use in eg with b18 swap?
  151. JDM b18c Auto Cams?
  152. H22 EF Axles
  153. Need some Specs please!
  154. h22 shift shit
  155. EDM factory Honda parts
  156. 1991 honda civic with b18 b runns fine at idle but shuts off when u give it gas
  157. LS to GSR Question
  158. can i use a d16z6 IACV valve on my d16y8 auto manifold?
  159. acura cl type S 6 speed
  160. are these cams stock? take a look..... b16a2
  161. WIll thsy fit??
  162. h2b DA integra...banging frame necessary?
  163. 97 civic with h22 need radiator help
  164. Need help with gsr swap
  165. HELP PLEASE
  166. what do i need to do a k20 swap...
  167. jdm b18c into 99 gsr teg vtec prob
  168. D15B7/D15B mini me
  169. info on b20 block using gsr or r internals
  170. need help with k20 swap.. into em1 look
  171. OBD1 SWAP INTO OBD2A CIVIC HAVING PROBLEMS
  172. 01 gsr swap in 99 ek
  173. prelude brakes on DA question
  174. I need advice on a K24-K20 into a 00-R
  175. What are all you Ls/Vtecs reving to?
  176. have fuel, but NO spark; no CEL; obd1 motor into obd2b chassis
  177. need advice on gsr build(ctr pistons w/skunk pro 2 cams??)
  178. H22 swap into EK (Fuel pump doesnt start) HELP!
  179. 95 eg civic sohc d15
  180. OBD II B18B1 into OBD1 eg
  181. LSvtec + Hondata OBD2->OBD1?
  182. solid check engine light
  183. Acceleration Issue
  184. Is this a upgrade for my obd1 h22 intake mani?
  185. taking off intemediate shaft bearing?
  186. B-Series Swap In A 98 Civic Ex Using An OBD-2 To OBD-1 Conversion Harness Now Tach Is Acting Weird
  187. H22 Fuel Problem
  188. cant find a obd0 ecu wiring diagram.... anyone have it?
  189. obd1 distributor help(i am an id10t)
  190. odd idea? will this even work
  191. K24a2 (TSX) engine experts: VISUAL differences-'04/'05 vs. '06>newer
  192. k20 into da9 integra
  193. k20A VS K20A2
  194. GSR-EG hose ??
  195. H22A Tranny Issues
  196. del sol swap D15B7 > B16A3
  197. h22 eg idle/vacuum questions
  198. OBD2 JDM b18c1 into 00 si swap questions (I searched)
  199. !Help! eg6 b16a p30 in ecu knock sensor pinout
  200. stupid noob question of the day.....
  201. anybody running???
  202. h22 engine swap questions?
  203. AP2 Cluster in an EG6 - Help!
  204. B20VTEC Swapped and having some problems.
  205. b18b into EG P/S and A/C Bracket help!
  206. Please help, got 96 LS engine can it pair with 90LS trans and will go onto 99 Ex
  207. idles but no throttle response
  208. LS VTEC
  209. d15b 3sVTEC into EG, how to make this work?
  210. converting an auto ecu to manual???
  211. b18b obd2 swap into 96 ek question
  212. Problems after camshaft swap
  213. jdm b16 in ef question
  214. quick question!
  215. ___LS vtec __ Will Pr4 pistons hit b16 head valves?
  216. 4-door teg prelude swap?
  217. ls vtec compression
  218. Swapping a B20z into a GSR (OBDII)
  219. k series--which engine is best in my eg?
  220. Engine Swap Need major help!!!!!
  221. Harsh vibration turning right.
  222. Transmission Swaps
  223. Engine Missing and I can't find it!!! f22B
  224. k20 swap??
  225. Motor mount question
  226. JDM K20a in Canada?
  227. civic vs. integra brake hardlines
  228. Hybrid between k20a and F20c!!!
  229. Rywire H22A EGR
  230. 90-00 ls 5th gear r the same???
  231. Looking into a SOHC ZC swap and need some things cleared up as well as an opinion
  232. alright !!!!!!!!!!!! now what ?
  233. quick question...
  234. h22block, f22 head?
  235. h22 engine
  236. keeping A/C, and power stering B20VTEC swap
  237. obd1 and obd2 dizzy
  238. Installing a B series Soon! HALP
  239. ls vtec or poor mans typ r
  240. B18b swap---> PR4 vs P75 ECU
  241. 1990 hatch zc swap question
  242. 94 Accord shifter - can I use it for H22 swap? In EF. How about EG? Thanks!
  243. min-me swap problem! need help!!!
  244. throtle cable for b18c1 in a eg hatch
  245. HELP!!!
  246. Keeping ac with h2b swap in 94 civic coupe
  247. New on the h-t with a recovered EM1... h2b ready but got many questions..
  248. What Water Pump
  249. H23 del sol
  250. Does skunk intake mani hurt hood clearence on h2b?
