Trouble with h22 swap
the h22 swap is complete in my 94 civic,i had troubles with the wiring harness conversion, but i got that issue resolved. Something seems to be causing resistance as it warms up it runs worse and worse until it comes to an idol and dies, has good fuel pressure, new rotor button, cap, and wires. Seems like it's losing spark, but not to positive on what's going wrong.
Any help is majorly appreciated, just hoping someone has been in the same boat as me.
Thank you in advance for the help
Re: Trouble with h22 swap
could be yor ignition module. they have a heat dissipating grease that is under them. after awhile the grease breaks down and starts allowing heat to affect the ignition module. it then starts to fail only when warm or hot not when cold. buy a new module and make sure it has the grease packet with it. put the grease on the mating surface between module and dist. good even coverage.
also i believe auto zone or the like can test it for you. you can try just getting the grease and re greasing it but if it were me id just replace the module. the heat may have already damaged it to far to save.
adam jeffery
adam jeffery
adam jeffery
adam jeffery
