PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 [119] 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. should i buy from hmotorsonline?
  2. Swap Problems
  3. tranny???
  4. swap shops in MN?
  5. How much to balance a B20 crank
  6. Finally got a working ECU now for the secondaries?!? (p28)
  7. B18C1 IN 99 EX, PROBLEMS HELP !!!!!!
  8. B16a Swap. Need Heater hoses.
  9. Annoying tranny problem .. please help
  10. b16 swap question's crx to od1
  11. How to get TPS Sensor out?
  12. BARO sensor?? what is it how to fix it??
  13. B18C1 in Sol aftermarket parts question
  14. h22a help please!!!
  15. Which tranny to use in my new EG?
  16. Radiator swap needed??
  17. d15b vtec ecu
  18. quick Q about eagle rod bearings. need to know ASAP.
  19. i've decided to just go obd1.here's my ?'s
  20. B16 Swap Problems
  21. nonvtec cam question
  22. B17 arrived today!! ???
  23. H22 in 99 Si
  24. H22 obd1 soddering into 96 civ
  25. B18c swap ?
  26. swap problem?
  27. D16Z6 Suggestions
  28. need motor help?
  29. Who has a crazy swap?
  30. gsr in my 91 dx hatch
  31. Need help. Having a problem
  32. g2 integra(da9)..oil light on...well not fully but dim....
  33. thermostat problems???
  34. Head swap..what do yall think
  35. h22 eg woes... please help!
  36. 89 crx hf with b18c1 HELP PLEASE!!!!!!
  37. b16a1 into crx hf question
  38. H22 EG Reliability Issues
  39. intake manifold question and thr body
  40. latest news on osakajdmmotors.com
  41. b18a
  42. usdm gsr swap question into my 91 dx hatch
  43. h23 knock sensor needed I crushed mine :(
  44. F22 VTEC into a EH/EG
  45. ITR longblock swap into a civic...?
  46. itr axles problem
  47. O2 sensor compatability?
  48. h22 in EK, distributor QUESTION!
  49. 1998 Civic CX Hatch W/GSR Motor - Couple ?'s...
  50. H22a engine fit in place of a d16a9?????????
  51. stripped bolt in h22 head
  52. got mah h22 ej done!
  53. lame Q, but need an answer
  54. ECU vs Cars they come in.
  55. Resistor Box for H22 in EG - what cars came with the resistor box?
  56. H22 valve springs in H23?
  57. will an obd0 90 ls harness plug in to a p28 ecu
  58. Head gasket for JDM H22a, bumping compression ratio
  59. Daily Driver Compression Ratios
  60. Injen race division vs aem cold air v2?
  61. 99cx with 97 jdm integ type r; WIRING ????? and mounts
  62. Fuel Pressure and Timing
  63. purge question
  64. B16A2 in a 91 Integra
  65. h22 hasport mounts for EK???when released??
  66. best compatible commponents for ls vtec???.....cams,valves, valve springs,retainers,and pistons
  67. what else needs to be done when swap a B18c?
  68. d16z6 in 91 Crx Hf Questions
  69. Is my Eg/GSR Hybrid obd1 or obd2?
  70. inexpensive but decent swap????
  71. www.rcrewracing.com anybody know them?
  72. b18 axle problems in crx?? need help!!!
  73. Clutch Problems
  74. suspension setup for h22 civic hatches?
  75. B16A with not much potenial
  76. Si head
  77. Slack in shift-linkage/tranny?
  78. H22 Intake Secondaries???
  79. crx b16 o2 sensor question
  80. ls/vtec or 97 prelude motor
  81. hmotorsonline? what do ya think?
  82. theory on resistor box for H22
  83. new tranny?
  84. wire harness question
  85. b20/vtec reving issues
  86. B16 in EF hatch
  87. ecu in new swap
  88. Ek H22 hatches- Guys, question on axle bindage
  89. ls vtec setup... what power you think i can get from this
  90. h22 ek hatch vs gsr ek hatch???
  91. Resistor box on the Crx....change it to Prelude with H22?
  92. Motor swap question 86 crx si
  93. what o2 sensor for b16 sir1
  94. breaking in an engine in loop mode good or bad?
  95. skunk2 intake manifold for jdm b16a?
  96. what engine is stonger and last longer and bang for the buck
  97. LS swap in 93 delsol?
  98. help quick
  99. h23 vtec..good or bad and why??
  100. zc swap to 1st gen crx need more info on mounts and wiring
  101. replace d13b sohc with f22b dohc ????????????????
  102. vtec wiring pressure switch, knock sensor
  103. what is that thing behind the kick panel fusebox
  104. B18Ceg
  105. Few question about h22 swap...
  106. Where does the Air Intake Temp. sensor plug in to on a 1998 b16?
  107. B16A2 or B18C1 Need help deciding
  108. b20 swap?
  109. which ecu do i need
  110. problem with b20 swap need help!!!!!!!!!
  111. 90-93 ls swap into 89 civic?
  112. what a/c setup can i use for my 99 ex w/b18c1
  113. what ecu program are you using for high compression na?
  114. h22 injectors
  115. what fuel pump should i use
  116. Has anybody shipped parts Greyhound?
  117. re to A9Code 14 IACV help!!!
  118. how to make a obd2 to a obd1 motor
  119. Running in 'limp' mode and can't check CEL.
  120. Guys, will this work?
  121. Which ECU?? MPFI
  122. Pulled my ls/vtec today...pic
  123. ENDYN super chargers
  124. ps/ac
  125. h22 guys and moterhead i got another question
  126. H22 swap help
  127. Which fuel pump to use on jdm itr in civic hb cx?
  128. I need a little help with a swap!
  129. h22a budget valvetrain upgrade
  130. good reliable source for swaps?
  131. How can I know Wether the motor I'm buying is OBD1 or OBD2 ?
  132. Weird Idle after swap...need help
  133. anyone ever heard of a b16 using 84mm pistons?
  134. IACV help....
  135. Need help with swap!!
  136. which axles and int. shaft
  137. Swapping B16a2 block for B18c5 block
  138. h22 civic Radiator HELP and ECU problem!!!!
  139. I'm ready to do my swap already but ...
  140. Anyone useing Clutchnet clutches?
  141. H22 civic not sparking?
  142. newman? anybody?
  143. Will any B series tranny's clutch/flywheel cover work on type R tranny?
  144. how to tell if motor/head is jdm and what year etc...i searched btw
  145. B17 cable tranny not mating to 95 LS block? WTF!
  146. Stupid Wiring Question
  147. What clutch kit??
  148. b20 Nonvtec n/a exhaust question??
  149. A bunch of dumb swap stuff..help me!
  150. VIN# on JDM Tranny?
  151. Made my self a oil catch can today...what do you guys think?
  152. 97 integra cluster in ef
  153. Search not helping... First gen CRX - D series vtec swap?
  154. 98 gsr into a 98 Civic Hatch Dx
  155. P13 KS bypass successfully done!
  156. spending 4500 on a motor?
  157. b18c pistons and rods into b18b engine
  158. b 16a in 93 coupe not starting
  159. H22 guys I have a question for you
  160. anyone using a AN-R header on there h22 civics??
  161. OT: Wich setup for my 97 240sx?
  162. why have some people needed to cut stuff for the shifter with h22 swaps in civics??
  163. Another IACV question. Should be easy...
  164. where can i pass smog?
  165. b16 integra VSS question
  166. what can i do my power steering pump freezes for a bit
  167. Revving an LS/VTEC, couple questions?
  168. Where do you get a turbo ready engine block etc.?????At good price
  169. HELP>> Wiring a 95 JDM H22 into a 2000 Integra GSR
  170. Does this mean im runin LEAN?
  171. Help with oil/ tranny fluid for my swap!
  172. GSR or b16a1 head????????????
  173. Inexpensive radiator upgrades?
  174. anyone with info or links: going dual point to mulitpoint for crx swap
  175. jg edelbrock short shifter any good?
  176. wiring question
  177. Can't makeup my mind, help me: B20/vtec or usdm b18c5
  178. Wondering if you guys could help me out here?
  179. Moving wires at ECU..how do you do it?
  180. any differences between B18a longblock from auto/manual car
  181. EK h22a Turbo questions?
  182. What in the world do i do? b18c question
  183. gsr turbo piston compressions??
  184. Apexi Type R headers in a B16A3?
  185. need help ASAP
  186. How to keep A/C in D16Z6 Swap
  187. Props to VTECVillian [02 wiring, OBD-II motor into VX]
  188. what are the best mounts for a h22 eh2
  189. what do u guys think about a 95 hatch with an h22 but wit an auto tranny
  190. OBD2 motor in OBD0 car...
  191. JDM b18a
  192. Anyone with a H22 in an EG in Northern VA?
  193. iacv code 14!? code 20 ELD!? and 41 o2 heater!?
  194. B18a into EG Wiring Question
  195. Add me to the list
  196. What AC Belt and Alternator Belt should I use for a b18C in 93si.
  197. 84mm piston selction
  198. What would you do?
  199. Another immobilizer question ....
  200. What do you all think about Spark Racing?
  201. Compression results
  202. wich is a good header
  203. 00 B16a2 into 92cx hatch
  204. what tranny got code
  205. hondata question
  206. i want to make this swap/trade, am i getting a good deal???
  207. wiring harness for a 99cx
  208. need help? Jdm d16z6 or Jdm dohc zc
  209. ppl with b18b eg's
  210. need H22 swap in Houston Area
  211. dc2 lsd fit into a ys1 cable tranny
  212. What should I look for?
  213. Idle problem, and rev limit problem, please help
  214. vtec head installed onto 91 tegra?
  215. engine ?: whats the difference?
  216. B16a block with GSR head power????
  217. anyone heard of JDMpower.net?
  218. Vtec at 4500 after doin swap????
  219. Need to know if i can use an accord intermediate shaft on sh tranny
  220. obd2a->obd2b jumper
  221. Explain this Dyno
  222. My race with a Civic Si
  223. H22 into 94-97 accord?
  224. 4th gen ls brake problems
  225. JDMHondaParts.com
  226. b20z swap into 5G hatch [have b18c1 already]
  227. i need the ht opinion
  228. Question about converting from obd0 to obd1
  229. h22 in a 97 ex coupe?
  230. b18c1 radiator hoses n stuff
  231. D17A2 SOHC VTEC Comparision Info Needed
  232. GSR head on B series block?
  233. PCV Valve? do I need it??
  234. JDMrecycler.com
  235. B16A2 into 94 Civic EX help!
  236. LS swap- need HELP!
  237. HELP!!!! Is this a bad axel?!?!
  238. Anyone know how to find Brian Wong (b18c1_powered_si)
  239. Gas mileage with a GSR swap.
  240. B16 into 91 EF
  241. Timing Belt cover Question????
  242. Need smog help
  243. 98 gsr master cylinder any other brake booster fit it????
  244. Resleeving...who did yours?
  245. will this tranny fit?
  246. getting code 20(ELD) please help...
  247. In a slump.. Either H22 or B18C
  248. Final Drive Kit
  249. obd0-obd1 conversion schematics reliable resources
  250. engine papers?
