View Full Version : Hybrid / Engine Swaps
- EK Harness for B-series Q's
- does my friend have to change his harnest
- Having trouble w/ conversion harness, need help.
- MAP Sensor on Throttle Body question for swap on OBD1
- DFW GSR THEIVES!!!!!
- First Swap!
- what belt to use on a b16 block with gsr head?
- banging when turning/b16 in 93 civic... axles?
- B20b in del sol question
- H22 or b18c in a dc2?
- using the stock clutch in my b16 swap?
- B18b1 won't start in 99 SI?
- ugghhhh Hasport/Driveshaft shop axles binding badly!!!!!
- Help with JDM H22 engine swap (Wire harness) for my 95 honda civic
- LS 90-93 or 94+....
- im getting code 1 and 41 for Oxygen Sensor?!?!
- engine swap: how much should i look to get/ pay
- H22 In Eg Hatchback, which cold air intake fits better?
- Gsr engine in crx, can I run my obdo b16a alternator?
- help on b16 swap no power???!?!?! please help
- swapping to a 00 B18B and staying automatic
- ES mount inserts...
- YS1 Transmission ... Broken?
- 2002 Honda Civic K20A3
- Can anybody give me an idea as to what my setup will put down?
- H22 hp numbers
- b16b into a 98 cx hatch axel wont fit into cx hub HELP!!
- cotter pin size (yup I searched)
- Hybriders in North Carolina..
- Can anything fit in a N600?
- ecu advice please
- h22 troubleshooting...where to bring NORTHEAST!!!
- HASPORTS BUSINESS ETHICS WTF ?
- what Dizzy do i use?
- h22 to b16 drive train adapters..
- k20a vs k20a2 what the difference??
- Prelude Engine Swap
- h22a wiring, obd1, in 1993 accord...
- 2000 B18B in civic coupe..... Going Turbo Soon... which Tranny & help w/ problems PLZ
- ECU question
- h22 in a da teg.
- obd2 h22 swap problems
- b20b oil pump??
- hyrid axels
- What AC mount, are you guys using for H22 EG swaps.
- b16 block gsr head
- 90-93 halfshaft and axles into 99 civic ex?
- need help on a b18b swap in a DA
- What Headers are out there for K20 in EG/EK=BOLT ON
- k20 del sol.
- 99 ex w/99 Si swap?
- Swap Questions for a 90 CRX HF with a 98 Civic V-tec.
- 91 Civic 4door Conversion to 92-95 wiring
- Which OEM or Aftermarket Camshaft fits a D15
- d16a6 head on d16y7 block?
- K20A2 IN 90 INTEGRA DA...
- OBDII JDM P73 read knock sensor?
- CA Bar Sticker question
- H22/EG in car won't start, but ran last week?
- Best and or most reputable conversion harness- OBD0 to OBD1
- shift linkage for DELSOL
- b18A1 swap into a 92 civic DX HB. Need some advice!
- What intermediate shaft is this?
- any other intake manifold for b17a1??
- anyone have a hydro tranny in their ef? tranny seal question
- b20vtec or B16 turbo?
- what mount is this?
- GSR suspension and Civic Suspension
- H22 tranny for Cable Clutch
- b18c help me out please.
- San Diego heads up my 88 Gunmetal Crx was stolen!!!!
- JDM B16 (XSi) into a DA integra (91 LS)
- how much HP to the wheels do u think i'll make with my b20 vtec?
- LS/VTEC build up in EF sedan
- -bad lag in power at constant R's
- what slave cylinder for my swap
- PLEASE HELP: h22 distributor troubles
- to stroke or not to stoke
- I need parts for my H22A swap...PLEASE!!!!!
- '00 b18b1 going into '97 civic ex
- B18C5 or K20A into a 92 dx hatch
- axle problems
- noisy coilovers???
- civic hatch swap
- 97 GSR motor into a 94 LS integra
- H22 Civic Distributor
- People from NJ: 99 civic w/ Prelude motor...
- Ive searched! What mounts for GSR in EG??
- will a '90 integra ls rear brake swap fit a 93 civic cx hatch?
- 88 crx 94+ gsr motor...
- hybrid question
- 2000 EX engine swap
- Can I use my stock del sol si wiring harness to swap my B20b using a P75 ecu
- CAI after h22 swap into an 94 acccord
- D series Shift linkage on B series tranny
- B20B into 99 EK Sedan
- a few q's just finished friends swap
- Mounts for b18c1 into 93 Civic hatch
- h22a 200+ whp setup?
- B16 cost
- engine
- ECU
- Finding a shop to do a swap
- Questions about VTEC solenoid for my B18C swap
- crx b16 = no start
- Question about B16A2 wirng in my 97 civic hx
- JDM 36mm spline to USDM 32mm
- Problem with engine mounts :0(
- HCP mount with B18a question
- PCV on b20 vtec
- Car wont rev past 7200
- its k20eg's (eric) birthday :)
- 99 ex tranny mount fit 98 gsr tranny?
- 92 civic HB with B18B motor swap
- rear seat for 92 HB
- Need Help Quick!!! b18a into eg...wiring and sensor problems!!!
- D16Z5 into EK, best ECU?
- vtec is not working
- running rich but not?
- jdm b16 usdm gsr tranny?????
- b16a into a 90 civic si shift linkage
- YS1 small spline transmission?
- no Vtec crossover.....
- 92 Civic DX Shock Tower VTEC Wiring??
- H23 VTEC started... Now it won't...
- what should i do?
- H22 in my GSR???
- K series specs and EG/DC/EK swap FAQ's
- P06 ecu pinout -- please help
- Can i use a D16Z harness with a OBD1 B16a (both JDM)
- cam timing marks on skunk2
- CALLING ALL JDM ENGINES!!!!!!!! HOW DID YOU WIRE YOUR 4 WIRE O2 SENSOR TO TAKE AWAY CEL???
- Need help looking for a site with a GSR automatic trans. engine
- List your LS/VTEC buildup parts list?
- obd-0 jdm b16a. MAP SENSOR CODE? 5?
- '97 EK(dx), '99 B16A2, JDM P73 ECU
- Motor Swaps in San Antonio Area?
- H22 Swap Shops Recommended (NY/NJ Area)
- 94GSRswap into 98Ek
- anybody have these numbers...
- where to buy a obd2 to obd1 conversion harness?
- Am i crazy? Can i do this? 96-00 swap b18 non turbo
- 81.5/82mm bseries piston recomendations
- 96 civic gsr swap not going right...
- Brake and ABS indicators are "on" after my swap!
- whats the weight difference between a D and B series swap?? read why i need to know
- 94 LS swap into 92 DX hatch
- Just finished swap.....i need some help
- gsr swap into eg, whcih throttle cable?
- K20a in a ek....
- H22 Swap questions....did search
- B20b swap in del question
- using a p13, what is best chip program...who programs??
- swap in a 91 legend coupe?
- obd1 reads one o2 sensor??
- Pick a swap for my 98 ex
- Engine Sawps
- b16a obd-0 BAD IACV. what year motors are interchangeable?
- Do I Have Everything?
- Replacing a d15 with a d16z6 or y8... what problems
- Ls integra swap in 90 CRX
- one badass k20 header.LOL
- B16-T vs. n/a k20
- Question About My Swap????????
- OEM Thermostat
- Best shot of NOS to use in my H22....
- swapping
- Bad o2 Sim??
- B16a2 wiring probs?
- Engine Manufacturing Date question?
- A little help on my Boost/Vac gauge.
- swap of all swaps???
- B16A2
- how do i wire secondaries?
- D16 Swap Help - Searched but 56k Kills
- which alternator to buy???? b16a1
- Wiring Help on B16 Swap (HAVE SEARCHED)
- need to know where to splice the 7 wires for gsr swap
- usdm OBD IIb SI swap into a 98 OBDIIa shell need help
- h22 swap in a delsol
- mini me swap questions???? 89 CRX SI D16Y8 HEAD
- Binding still with h22 swap?
- 97 civic ex motor into a 99 civic ex
- zc swap???
- ecu: auto or manual? obd-?
- Some Swap guidance,please!!
- gettin ready to do my h22 integra.. hows my shopping list look?
- Going from a 98 h22 usdm to a 92 h22 jdm, Need OBD help!!!!!!!!!
- alternatives to a 5th gen b16a SiR2 swap?
- H22/Civic, P28 ECU, & IABs
- where to get a obd1 cable tranny b16 motor?
- Map sensor code on B20B
- '90 crx with b16a questions
- d15 help!
- dry sump
- which is better?
- weird motor swap question
- Negative effects of using GSR length rods on an LS crank?
- I am still a little confused
- B18a oil pans
- GSR motor swap into Civic
- Any ideas here:
- AXLE HELP
- LS rod stroke help
- Five Lug conversion on preludes
- b16a with gsr head...
- b18a EF Swap Code 9
- anyone had experience with them (site inside)
- LSvtec OR B20vtec
- del sol swap b18c1.... any good mechanics?
- P28 ECU for a JDM H22A...
- b18, b16 or h22 for a 95 civic hatch
- Type R into 93 gsr, need info please
- Can Anyone Help?!
- FAL slim fan...
- auto to 5 speed help me........
- JDM JDM JDM - ???
- Wiring an o2 Simulator, in a h22 swap
- How do you have your IAB (secondary butterflies) Wired up???
- Injector Resistor Box wiring help...
- Using VTEC internal coil on LS dizzy?
- k20 question??? flipping it around in ebgine bay
- ls/vtec or ls/turbo
- IAB question...
- Euro R Intake Manifold on H22A Civic Pics
- Road Raced the H22 Hatchback.... again (with better suspension)
- ok wierd question , has anyone attempted this before???
- H22 tranny on a B series motor possible?
- stuttering b18b.....
- H22 A/C and Power Steering Tweaking, motor already in.
- whats the diffenence between the 90-93 integra half shalft and the one that come off a b16a jdm moto
- B18C spec R wiring harness=B18C5 wiring harness???
- I have a 01 ITR ecu with the original coded key..can I use this for my swap?
- What exactly do i need for CRX/b16a swap? HELP ME PLEASE!!!
- Best place for USDM engines?
- What cold air intake for H22A in 93 Hatch / Avid mounts?
- B16 quick question before swap takes place
- what header for a B16 92-95 4 door civic?
- all I need 2 know about b18c swap
- Electromagnetic Radiation Danger
- b18c swap help!
- B16 crx swap, do I need a different ac bracket?
- doing ls swap...do i need ls throttle cable or can i use stock 95 civic ex's cable?
- FLORIDA H22/CIVIC MEET!
- Ecu code 36 ?????
- SportCompactCar
- what bracket to use for AC on B16A1 in 90' civic HB
- obd1 jdm b16a in EK....
- *******h22 in a ek please help******
