View Full Version : Hybrid / Engine Swaps
- obd0 n obd1 dizzy
- Dropping the motor on a 00 Si
- NEED OPINIONS ASAP: D16Z6 head on the way, but what is the ideal block to bolt it onto?
- o2 sensor location on b18c swap in 95 hatch
- Identification on JDM motos/tranny?
- VTEC engagement problem
- hybrid tranny, is the combination good?
- Hybrid Dart Crvtec
- b20a/vtec
- Will these springs handle the wieght of this swap?
- ITR pistons and gsr rods?!
- Thottle Cable
- h22/eg HELP Clucth line...
- Question about cams
- compresion ratio of ZC block and d16z6 head
- will an ep3 tranny fit in a new crv to make an auto to manual conversion?
- tranny ratios, b16 b18
- sourcing for a B20B in 89 CRX
- need help wiring the engine harness
- vtec issues
- MASSIVE COOLANT LEAK
- Oil Sending Unit Problems, The Unit Broke Of Partially Threaded In The Block How Can I Fix This
- tranny swap in a g2 integra
- d16y8 ecu for a h22 swap
- Help with 01 GSR into 89 Crx Si (searched)
- The NEW and IMPROVED Swapped Car Poll!!! Re-Vote in this more ORGANIZED Poll!
- 91 B18a1 with a 99 Si B16 head
- K20 into a del sol
- b16 or b18 tranny internals in ls housing?
- k20 into a 94 ls integra
- Installing tb's type r cable tomorrow civicCoupe gsr97, need some quick advices
- need input: What size headgasket to help on set-up. (ls/vtec)
- What is the best mounts for this swap.
- Anyone ever get the clips off the injector harness?
- d16z6 head info needed
- b18c5 running on a p2t si ecu harmful?
- k series into ek..... who makes motor mounts?
- need comfirmation on swap
- Motor Swap Questions...
- vtec eg6 hatchback
- OBD1 Into OBD2 car...QUESTIONS
- b18a in 95 civic, ECU and Harness?
- wondering if someone can help me clarify something.
- h22 in 93 eg ,start up problems, lot of missfiring
- Power Steering EK Help
- Gsr into Civic95 coupe...TB's cable help
- got h22 swap need shift linkage.
- Skunk 2 IM for H22 civic...
- coolant help...
- B18c1 into EK mount problems
- Swap
- Motor mount comparisons
- how can i get an obd2 car to idle with a obd1 ecu
- 4 lug to 5 lug
- ZEX instal on B16 where is my TPS sensor wire I tap to
- B17A1 Combination, help!
- ecu swap
- NEED HELP!!! b18c swap into 2k civic cx
- what do i need to do to get a 94-01 integera B18C GSR into my 94 del sol
- 98' ITR steering rack in ej-not fitting?
- BLOX intake manifold on a JDM B20B CRX??
- b16a check engine light
- 96 1.6l sohc -into- 91 civic hatchback
- LSD QUAIFE OR HONDA for h22a civic
- have searched looking for answers i didnt get b18c1 into99 civic ex or should it be b16a
- ls/vtec question
- First timw swap going to do it myself instructions
- what is wrong with using an lsd tranny for commuting everyday??
- jdm b18c from totaljdm, Q about the ecu & swap(93 SI)
- The ultimate hybrid swap. Props to PirateMcFred
- b16a vtec acts funny
- b16a shoots flames plz help
- CRX with B18C5 engine not starting, please help !!!!
- anybody have any vids of b18c hatches?
- VTEC doesnt Work
- EF HB with AWD?
- Im 99% sure my tranny is shot, just need to see if it can be anything else.....
- throttle cable (searched)
- DESIGN ENGINEER
- K20a2 swap ek and keeping ps and ac
- ot: Who is actually performing K20 swaps in SoCal?
- Can't Get Swap to Start!
- auto to manual in civic dx 96 need a little help please
- any other additional wiring or sensors needed?
- F22b1 swap
- KAAZ limited Slip differential
- LOOKING FOR A USED BAR STICKER...
- would a B18C GSR motor fit into a 94 Del Sol
- My Mojo.
- WIRING DIAGRAMS EK to GSR
- DOHC ZC Flooding! burning to rich. need help
- Shock Height/Travel and Front Suspension Fork
- Do JDM B18C motors come with evap purge control solenoid?
- B18C5 IN A 94 CIVIC HATCH BRAKE PROBLEM...
- civic ex w/ jdm b16 quater mile
- question about spark plugs for b16 block with gsr head
- civic w/b16b stolen
- Cost of a swap?
- linkage or cables?
- need help b20b block with 90-91 ls tranny will it work??
- P28 ECU ? ? ?
- h22a in crx ? please help
- What to do with 94 cx hatch and $4500??
- anyone with h22a4 obd2 swap?
- H&R Race springs with H22 civic?
- has anyone attempted an automatic to manual conversion?
- b18c in to ek? got some questions(searched)
- h22 into an EK
- need help search already..diagram of an ecu for obd0 to wire vtec thanks
- 97 JDM ITR in a 95 civic EJ coupe - slight engine vibration on 2600-2900 rpm on 3rd gear.. help
- how do you do a crx d15 to d16 z6 i was wondering what parts i will need to complete
- Anyone Ref/Smog with OBD2 Carsound cat CARB legal????
- GSR cluster gas guage not accurate in ef
- for those with EG/EJ's with ITR engine swaps, how much is the stock tach off by?
- H22 Civic - Highway driving
- cat-back system for hybrid
- tach and speedo inop in ek hatch after minime swap
- Duece Duece Powered Hatch
- cable to hydro kits... how well do they work?
- Toda K-series header fit in a DC2 chassis?
- ticking valves?
- check this out !
- I know it has prolly been covered but i need some really quick advice.
- COMPLETE D16Z6 into a 4th gen Civic?
- D16Z6 into 6th gen Civic (D14A4, European model)
- vtec
- HELP: Timing Marks
- p28 and b16 head
- Avid K-Series EK Mount Kit, AWESOME!
- Ls/vtec Power Steering Pump
- EG/H22 SWAP... FUEL PUMP...
- Best intake for a GSR motor in an ek
- mini me mystery
- Uberdata tuner in Ft. Lauderdale
- how to prepare cylinders before start up after a swap.
- H22 Civic Guys, Looking for Axles?
- HELP: 96 civic hatch with 97 ls motor need wiring info
- question about d series
- Xsi PR3-I Head Swap!
- h22 into 92-95 civic axle question
- b16 swap almost done, help me out!
- OBD 1 motor in OBD2 car
- 98 civic want a 99-00si conversion
- how to close off hole for h22 shifter in civic?
- b18c1-88 accord Need wireing harness
- Y1 tranny question
- obd0 oxy sensor bung location?
- Part Identification I really need your help plz.
- 88-91 b16a into 96 dx
- lsvtec Head Preparations?
- what ARP studs to use on minime?
- 93 ex coupe with jdm b16a which helms manual?
- searched this topic for days!
- H22 EG swap, WTF is this black box??????
- Axles to use for a K20 swap in an EG
- H-T SWAP GURU'S, I NEED YOUR HELP!
- D16z6 in a 92 CX
- odbI vs odb II how do you tell thanx osaka
- Crank pulley nut on H22 HELP!!!!!!!!!!!!!!!!!
- will dohc ecu work with sohc motor ???
- - EG Type R Front End - LS Swap -
- Shift linkage and base plate question
- a/c bracket
- what dizzy to use on 95vtec in a 91 si hatch swap ????
- D16 oil pump on a ZC?
- shift linkage 91 crx si
- Which car should i get???
- needed p-13 ecu for a h22a
- can i use this map sensor? NEED HELP ASAP!
- **Help on B18C1 on EG**
- Cel 9
- b18a swap in eg
- 93 honda prelude dash into 95 civic coupe
- Will a greddy turbo kit w intercooler fit in a 95hatch with b18c swap?
- *VID* H22 civic +75 shot vs. Big Block Mustang
- what pistons for b18b block with b16a head
- d16a6 motor, obd-1 dist
- 93 civic coupe, 98 GSR SWAP
- H22/23 swap into 95-98 HONDA ODYSSEY (AUTO)
- Is there a better ecu that I can throw in.
- Question for any h22'ed civic OWNer's
- H22 hondata Dyno...
- Quick help H-Series please!!
- Hybrid exhaust question.
- h23a vtec JDM problems
- trans swap problem, pics inside
- Where can i buy just a B20 block?
- HELP!!!! h22a ecu info needed
- ITR cams into my EM1
- Ignition Components
- car wont rev past 3k code 3 and 4 ????? help
- need help with my wiring
- Flashoptions.com
- ZC intermediate shaft Q?
- I have NSX brakes will it fit on my cx eg6
- swap help
- H22 aftermarket A/C
- half shalf questions.
- OK PLEASE CLUE ME IN...
- GSR civic hatch
- b20 vtec, type r cams
- 6MT + TL Type S engine swap into '98-'02 Accord
- k series ?
- H22, preferably H23 swapped EG's
- question about doing a ls swap in a ek
- H22a ECU swap question - into my 6th gen accord
- ls/vtec--- wiring vtec up need help
- rating 1-10
- OBD1 harness on a obd2 b18c1?
- H22A4 Flywheel ques
- what to do about vtec plugs
- B16 with b18a HEAD question
- integra hood
- LSD for '05 Accord V-6 Coupe?
- Need help with 93 civic Si wiring diagram?
- b16 and b18 vtec/non vtec rings the same?
- B18C5 into a 94 civic hatch exhaust problem...
- AN-R H22 civic header pics????
- USDM P30 ECU
- ECU
- Suspension question for 86 Civic 2WD wagon
- Need Help! Running to rich and crazy idle problems.
- 5 lug ques..
- b18b in a CRX?
- B18b in a CRX w/ non obd ecu, 7 deg of timming is the most.....? why?
- need help? b18&b16 hatch owners!?
- --- NEED HELP ASAP! P75 users ---
- Will nonABS rear wheel hub work fine on ABS equipped car?
- another freaking idle problem thread.
- H22A in a auto eg/eh chassis
- HCP Mount Stiffening
- Whats Needed To Self Tune W/ Hondata
- b20 or b16a1
- Finally broke 12's ALL MOTOR
- droppin type s swap in.
- HELP! DA-EF suspension.....
- Swapping a swapped civic
- added powersteering, how to hook up power steering pressure switch?
- H23A Vtec ECU ?s
- B20 into del sol – shopping list
- cel code help
- need a little belt help
- Car running really rich
- B16a or LS/VTEC: Best choice for EG
- ls crank in gsr problems
- Legend GS brakes - min. rim size
- 1996 Civic Hatchback DX with b18c1... will a name brand exhaust bolt perfectly?
- OK THis Shit just keeps getting better as we go.......HELP Please......
- Problem going over 5000rpm
