PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. B16a2 wiring probs
  2. h22 in 96 civic dropped, AXLE binding problem??
  3. how does this setup sound ?
  4. Eng.swap for Realtime wagon?
  5. GSR vs. Type R; What's the difference?
  6. Which motor
  7. need help on swap
  8. This everything I need?
  9. engine serial number question.....
  10. Need yall's help, stuck w/ 98% swap DONE ?? Cant get Wheels To Turn!!
  11. mini me driving ME crazy
  12. C1 into 99 EK, how do i keep PS?
  13. hybrid radiator problems.
  14. Need help with deciding engine swap.....
  15. Automatic EX vtec harness
  16. Can I use my existing brake hose from my drum brakes on my new disc brakes?
  17. 92 LS ECU with 94 LS swap
  18. JDM P73 immobilizer?
  19. Please list H22 quarter mile times and h22 horsepower
  20. 92 civic hatch h22 swap help in Maryland!
  21. B18C5 Wiring Swap Help - HELP
  22. OBD2 JDM B18C into 92-95 civicHB, need swap info
  23. Mount kit for a 90-93 Teg..?
  24. Choking and dying motor HELP!
  25. obd2 h22 into civic, do i need a resistor box?
  26. Getting rid of A/C and P/S on k20a2 engine
  27. gsr tranny with ls 4th and 5th gear
  28. HELP ASAP, civic h22
  29. d16y8 into a 96 civic ex
  30. Where is the Electrical load detector sensor?
  31. engine codes
  32. Hyech H22 Header pics
  33. Newbie....Need help to decide Stick with stock engine or swap to h22
  34. 98 CX ENGINE IN A 96 EX BODY
  35. GSR And Ls
  36. 93' b16 Xsi clutch.
  37. h22a p13 CELs 4 and 9
  38. b16b
  39. B18C5 INTO 93 INTEGRA LS??
  40. if its not 1 its 10
  41. B18b into 91 crx Si
  42. JDM H22 P13 O2 Sensor Wiring Help
  43. mount kit bushing info
  44. can u put an intake from a 98 civic ex on a b18???
  45. Where to get a Euro R tranny?
  46. stock b20b in a integra
  47. B18C1 into a 4G civ hatch
  48. 99 d16y7 into a 96 civic ex
  49. B18C -> DelSol ???
  50. LS Vtec 1/4 times?
  51. Best/ cheapest place to get gsr or type r swap in NYC
  52. jdm b18c-r: jdm or usdm ecu?
  53. stock lsvtec
  54. cel code 91: evap...running rich as hell making me throw cel code 45
  55. K24 in EM2
  56. K24-R into Gs-R. Need Comments.
  57. sr20 into 94 accord??
  58. What parts am I forgetting?? (1st gen B16 from my eg to a 91 crx)
  59. witch power sdteering pump to use?
  60. What should i up grade next i got 500 to spend and looking for ideas
  61. KYB AGX shocks, NEUSPEED springs
  62. 12.90 allmotor ek forsale
  63. Attn: All JDM ITR Hybrids!!! Please help Me!!
  64. B20 swap
  65. OBD 1 Auto bsr ecu Pinouts
  66. Where can I find awsome b18c1 into an EG swap instructions?
  67. what short throw shifter ?
  68. H22 engine {USDM vs. JDM)
  69. DIY: B Series; How to Replace your headgasket!
  70. I did a search........B18c1 obd2a into Civic DX 1999 obd2b
  71. can you drop a K20a engine into a 96 civic?
  72. Wiring Harness Help!!!
  73. 0bd 0 to 0bd 1 conversion hasport, dx to mpfi d16z6, 02 sensor code HELP
  74. H22 engine {USDM vs. JDM)
  75. H22 AN-R header street or merge collector
  76. b18c-r --> 96 EK : A/C ?
  77. Which proportioning valve in EM1 with ABS?
  78. 92 CX hatch d16z6 swap
  79. swap issues (no start)
  80. b20z timing question???
  81. Need a p13
  82. different heads and motor swaps.....
  83. How much does it cost to swap a JDM h22a in a 29-95 hatch?
  84. Best price on Hasport mounts
  85. Please send pics and info!!!!
  86. B18B into EK...help with drivers side mount
  87. Best swap for 98 Civic
  88. OBD-O to OBD-1 ?
  89. Going to be buildin a type r to put into a 88 CRX
  90. LS or GSR?
  91. AHHHHH b18b or b16a????
  92. 89 Si lude motor into a 89 S chassis
  93. B20 swap, what parts?
  94. Just did gsr swap in 91 integra, having idle problems????Video inside.
  95. H22 into 94 Dx hatch
  96. Knock sensor/Safeguard
  97. bouncy idle w/ p28, but not with pr4?
  98. Smog legal swaps...
  99. B18c
  100. CRV (B20) manual tranny with B18C. Is it possible? (-)
  101. What Offset?
  102. Erratic idling, wtf?
  103. 95 eg civic to 88-91 ef civic b16a dohc conversion
  104. Weird idle goes away in h22 civic with p28, Why? Help might get chiped Sat.
  105. B18B -Longblock-> 92 Integra Chasis
  106. JDM B18C into 92-95 civic HB si (wiring harness)
  107. need to know how to fit a integra radiator into a eg?
  108. K24 in a DC2 (Hasport Style)
  109. Question about B16 and B18
  110. ANY OTHER SOLUTIONS. AUTOMATIC TO STICK!
  111. b20a crank inside of b18 or b16?
  112. 88-91 hasport b series shift linkage
  113. need help with swap [jdm gsr back to sohc vtec]
  114. b20a prelude block with b series vtec head possible?
  115. d16y8 block with d16z6 head.. have a few parts compatability questions
  116. h22 in EK SPEDOMeter
  117. eg with itr swap
  118. b16a swap into 97 DX....
  119. is it possible to get a bad ecu
  120. Buckets of questions
  121. 90-93 Rear Disc brake swap onto 93 EG
  122. IACV power wire
  123. d16y8 value price
  124. What catalytic converter to use with 95 civic w/b16
  125. ls in a gsr problems
  126. Deciding what swap to do.
  127. just did an 2000 LS swap into my 1999 ex... need ECU HELP ASAP PLEASE!!!
  128. JDM B18C Type R into EG
  129. belt noise when starting car
  130. pics of my better half!!!
  131. looking for b16 swaps !!!!!!!!!!!!!!!!
  132. hooked up map sensor still getting code 3---- help
  133. code 14 - IAC
  134. POB ECU???
  135. b16 in a 5th gen : axles?
  136. b20a 88-91 prelude transmission
  137. Which tranny/axles for a JDM Accord H22A into a 99 Accord 2.3L?
  138. Questions about H22 Integra
  139. Nice quiet exhaust with power to boot..
  140. JDM Type S h22 EG....
  141. Why can't I use the driver's side mount from my 95 EX for a B18B swap?
  142. d16a1 DOHC head onto my d16z6 block questions. Anyone done it?
  143. Engine dieing + erratic idle
  144. OBD2 LS Motor, OBD1 Honda Del Sol.. what do i need for swap?
  145. VX civic head on D15B, can this be done?
  146. results?? for poor mans gsr?
  147. what tensioner pulley on the DOHC ZC
  148. will this work??
  149. Hasport Mounts
  150. If you were doin a B20 block what head would you use?
  151. 2000 EK w/ Euro Accord R H22A Swap... which mount kit?
  152. h22 h22a Civic 1/4 Quarter 1320 mile times (Search Friendly)
  153. code 8 - TDC Position
  154. distributer wiring
  155. B21A1 prelude engine into a DA integra chassis
  156. 96-00 civic with the J32 CL-S types motor swap???
  157. Is there a difference between Obd-2a and Obd-2b distributors?
  158. question about changing IM to pass smog
  159. 5 wire to 4 wire o2 conversion...
  160. does a b20 (crv) clutch work on a gsr tranny?
  161. Euro-R into '94 civic
  162. OVERHEAT at higher rpm! why?
  163. Help me identify this rear mount
  164. o2 sensor in a b16 civic CX
  165. activating vtec sensor si harness system
  166. G series motors?
  167. 90-93 accord AUTO intermediate shaft for a EG H22 swap, orrrr
  168. LS swap into EG
  169. Need help on swap AHH!!!
  170. testing the waters>>>>>>>possible honda swap contest<<<<<<<
  171. rear motor mount removal in a 90 si
  172. F22B1 into 1990 Accord...Motor Mounts help!
  173. gsr harness....help me identify this
  174. LS tranny. How much torque can it handle?
  175. chipped ecu help
  176. HELP camber kit
  177. Need help ASAP! IAT Sensor Error Code!!!
  178. Smogging a JDM motor in CA
  179. h22 in EK gauge problem
  180. hasport axles for an h22 eg
  181. 1996 SiR-G swap in 1992 CX. searched and confused.
  182. O2 sensor location?
  183. B18C swap in 91 crx Si, lots of questions
  184. h22 swap and ac
  185. Mini-me woes - Need Help
  186. Need to know?
  187. Secondary Butterly Pinouts please help
  188. hp numbers for b20z2 VTEC...
  189. dyno tunnig
  190. h22 civic mount kit
  191. b16a1 into 1990 crx dx with SiR harness.
  192. B16a 2gen engine swap into 98 Civic SI (Vtech) Problem
  193. Swaps into a '81 accord hatch?
  194. OBD 1 wiring, searched, resitor box question for obd1 injector wiring...
  195. LS Swap
  196. h23 swap into 94 accord : power steering
  197. B20 Frankenstein motor help
  198. K-Serie in Civic 1996-2000
  199. Won't start
  200. LSD speed sensor gear (swap?)
  201. My H22/EK is finished. But my dyno results are crazy!
  202. how to wire a 1990 ls into a 98 civic ex coupe...pls help i need all the info i can get!!!!!!!!!!!!
  203. b16 related
  204. distributor cap (interchangeability?)
  205. B18c into EG Civic writeup?
  206. f23 in civic, running rough.
  207. B20 into 94 DX Coupe
  208. Type r into a 91 crx
  209. Do you NEED the a/c bracket for a b series swap into eg?
  210. b20vtec starting issues...help guys
  211. manifold or cam gears?
  212. Greddy header b16 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  213. JDM motors getting it BAR....
  214. h22 swap in delsol
  215. d16 head swap
  216. somebody tell me that my conversion harness is wrong!!!
  217. p72 question...
  218. How do i take out ecu pins?
  219. 8 valve civic??
  220. 600/600 spring rate for h22 turbo??
  221. Q on P/S with B16A swap into 98 Ex Coupe
  222. b18c1/5 into 99-00 coupe si
  223. Si swap
  224. ckp sensor help........PLEASE!
  225. B18c1 or a JDM B18c
  226. 96 B18b + 97 EK + 99B18b dizzy = HELP!
  227. Wiring Harness
  228. distributor repin
  229. h22 swap on integra, civic, or hatchback
  230. Valve Springs
  231. no spark?!
  232. Concernin a hot swap.......
  233. VIS hood hitting B18C
  234. Redline Cutoff Question
  235. working air conditioner & ps with H22 in a civic.........................................?
  236. Tach doesnt work after b18c1 swap in EG Si
  237. next step b20z
  238. About to Change my headgasket tomorrow any tips?
  239. pcv valve on a crvtec..Is it used?
  240. ecu pinout
  241. Interchange parts from B18A to B20?
  242. WTB--Chipped P28 ECU for CASH...
  243. Dizzy Wiring Confusion (External -> Internal)
  244. need help with wiring/swap
  245. a few questions.....b20z/b??
  246. wtb: b-series mount...
  247. obd 1 motor into obd2 civic hx
  248. Help on finding wire diagrame
  249. I need help in deciding which flywheel to get?? 7.5lbs v.s. 12.5 lbs??
  250. which rear main seal?
