PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 [126] 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. 4th gen accord strut problem?
  2. Code 9 CYP sensor
  3. Clutch cable problem after swap...
  4. h22 civic shift linkage question
  5. 89 HF motor going into 90 DX hatch--motor wiring harness problems. help please.
  6. What clutch for B20 w/ b16 tranny?
  7. B18B Into A Del Sol What Do I Need???
  8. Gen 2 Integra Automatic Transmission Swap Question
  9. 90-91 integra injectors VS. 94 GSR integra's??
  10. CEL code #9 with OBD1 swap, never had this code before
  11. b18c or H22a
  12. How hard
  13. Wire Harness lay outs
  14. secondary butterflies on gsr motor with obd1 p72 ecu wiring?
  15. Major H22a and Handling Help needed.
  16. just finished my gsr swap, motor dies out if you dont gas her.....
  17. Accord type R motor. PLease READ
  18. built dohc ZC with nos...swap help plz
  19. Please Help ! ASAP Jdm H22A T-Belt change !!
  20. Engine Swap or Auto to 5Spd Conversions in ATL, GA
  21. Man, i'm just full of questions today-- Just found a Local guy with a HONDA JUNKYARD
  22. LS/Vtec
  23. aem ems with h22/eg swap
  24. d15b7 to d16z6
  25. Where to buy swaps?
  26. Mileage on your swap
  27. new belt, started sqeaking........why?
  28. y7 to a y8 wiring?
  29. Euro Drive clutches?
  30. Cable tranny in a 93 Civic Hatch ?
  31. Dip stick length? Heh!
  32. Any 4th gen EFers with a jdm b16?(fuel line question)
  33. question for everyone
  34. new h22 in eg swap ?s
  35. OBDII to OBDI conversion harness: What is FANC, PSP SW, EL for?
  36. B18a into EK coupe... need help pls
  37. H22 hatch owners! suspension questions
  38. what are the diff. between the 92-95 B16 from the 96-00 B16?
  39. Build Ls/Vtec or Keep my B16A???
  40. still confused about IAB's...help me out...
  41. Euro R H22A in 5th Gen Accord
  42. Is GSR fuel pump direct replacement for Eg fule pump? Pics of GSR pump inside! 56k is ok!
  43. Help!!! Civic doesnt have a MAP sensor like my integra engine bay did. WHAT NOW????
  44. B20 Crank Pulley or B16a Crank Pulley for B20b in a 93 Civic CX???
  45. Tryin to show "hybrid" some pics of my ride....help!
  46. going rate for B18a/b motor swaps?
  47. anybody using haltech on their honda/acura
  48. parts list for H22 del Sol
  49. All Motor LS/VTEC or Built H22A turbo?
  50. d16z6 into 82 civic 1300?
  51. fuel pump swap
  52. ///// if you have done an H22 swap in a 5th gen civic CLICK HERE //////
  53. intergra tranny swaps s80 to a y80
  54. Turbo vs. Built-place ur bets
  55. Can i make alot of all motor power with a b18b w/ out lsvtec
  56. b16a2 in a 94 ex coupe
  57. HOW much did you guys pay for your swap
  58. question about hybrid transmissions
  59. Skunk2 IM...which intake????
  60. H22 EJ6 help
  61. Hybrid CRX..How much to cut off the shift linkage?
  62. help on ls vtec local shop in socal to install with head?
  63. temp ecu for ZC?
  64. shift linkage for sir2 int a 5th gen civic ?
  65. Need Source For Engine (wiring) Harness - B16
  66. B20B or Z into 94 LS ???
  67. weight difference between d16y7 and b18b1?
  68. Turbo/Super vtec SOHC (D16Y8) vs stock DOHC (B18B1)
  69. would b16a2 injectors work on b16a?
  70. swapping a h22 into my eg hatch soon...some ques....
  71. what type of wiring harness for a d16z6 head on d15b7 block?
  72. B18a swap into EF Crx done...now bouncing idle
  73. Need help!! asap!! P73 color coded diagram!
  74. Noobie question: is it really that "hard" to swap engines?
  75. this year .. what are your best b16 1/4 times?
  76. 5th gear grind
  77. looking to get some cams for the H22
  78. ::B20Z swap::: have questions!!
  79. wiring skematics for JDM OBDI GSR???
  80. H22 swap
  81. Re:New look for some HCP Mounts
  82. B18C6 into JDM EG4 VTI... mounting points
  83. Odyssey engine swap?
  84. Where does this plug into? Swap related (PICS included)
  85. problems with my swap
  86. B18b head bolts and valvles
  87. would anyone want to let me use there harness?
  88. Buaaing sounds in my b18c CRX????
  89. question about motor mount...
  90. need advice!
  91. what motors are you guys running ?
  92. swapped b18c into civic....started at first, now it wont
  93. engine shop buyer's guide
  94. extra items required to keep PS?
  95. help on a 94cx hatch with b18c to b18b
  96. Where is the Factory Tach wire in an EK??
  97. h22 eg running rough! please help!
  98. ls distributor?????????
  99. 2001 Type R Cluster into an EK
  100. Leaking...
  101. Possible to use an auto B20 wiring harness for my B20 into '96 CX?
  102. obd2 gsr harness into 93 civic dx
  103. Vibration when accelerating
  104. 92-93 Integra PR4 ECU is OBD-1 and should work with B20b right??
  105. Got stuck in the middle of my obd1 gsr swap
  106. 92 vx with swap cel ?'s
  107. looking for hybrids for engine swap book
  108. Best price on Hasport billets for h22 EG?
  109. d15b in 92hatch question
  110. d15b in 92hatch
  111. 97 Hatch swap to a 95 Gsr Engine...
  112. B18B with boost
  113. d15b2 block + d16z6 head = you tell me. Please help with some questions
  114. Really dumb question but what bolts for engine stand?!
  115. Cooling Issues..
  116. Swap Synopsis and Questions
  117. Need a picture of a GSR Block (Helms manual picture)!!! Please Help!!!
  118. ::NEED HELP JDM B20B or B18B::????
  119. Buzzing sound when i start my CRX?????
  120. Help with Customs!!! Don't let my engine get caught in the paperwork pipeline!!!!
  121. replacing fuel pump
  122. Yall goin too help me out or just read?
  123. d15b
  124. Help me out Peeps!
  125. How long before the buzzing subsides, somewhat?
  126. Getting A 91 si hatch with 163,000 mile on it HELP!
  127. crank angle sensor (yes i searched)
  128. Need HELP ASAP!!! H22a --> EG ECU wiring!!
  129. Accord owners: H23 swap opinions
  130. Jdm faze
  131. Quick ?: Will my 95 OBDI LS ecu look for a knock sensor?
  132. will Obd2 injectors work with OBD1 ECU?
  133. OBD1/2 Head with nonOBD ECU/distributor
  134. decent price for unmodded b18b 96-99???
  135. jdm vs usdm gear ratios? help please
  136. b18c1 is on it's way
  137. wiring q's?
  138. Extending HarnessWires
  139. would this fit?
  140. B18a swap into EG Question
  141. B18b mounts into EK
  142. When to upgrade injectors???
  143. how can i tell if Vtec is working?
  144. b16a swap sputtering...somethings wrong..
  145. Best Source for IAT and IAC?
  146. B18...difference in years make the motor different?
  147. fucked on H22a (Part II)
  148. New pix of Earthing system installed.
  149. GSR shifter & shift knob / Eg console --> What shift boot??
  150. H22 vs. B18c The choice is made
  151. crimping??
  152. 92 hatch swap
  153. H22 into 2.3 CL?
  154. What do I have to do to the ECU wire harness for my EG H22a swap?
  155. B18c4 header question
  156. evap purge control selenoid??????????????? HELP ME!!!
  157. need help!!!
  158. Need info on radiator swap...
  159. Idle problem, need help!
  160. No Vtec in just finished swap!
  161. swap help
  162. What starter on JDM B16?
  163. 92-95 civic ecu pinouts needed
  164. I need help FAST!
  165. B16 or LS swap (different type of question)
  166. <<< J1 Tranny Question >>>
  167. Finally my swap is underway! B20 into '96 Civic CX (56k proceed with caution)
  168. can i wire vtec into my tach?
  169. swap shops
  170. HASport mounts?- bushing
  171. Will Someone explain to me what the IAT is?
  172. Wiring diagram for an EDM cluster into a US CRX Si
  173. h22 into EG hatch...swap instructions..
  174. Tommy Gunn's Earthing system and my unwilling to start car.
  175. average price for drive in/drive out gsr swap into eg
  176. lsvtec headgasket woes
  177. doing a motor swap on a '97 hatch
  178. Hydro tranny..to cable..back to hydro? H22CRX, Help!
  179. Fixing a h22 eg
  180. Which ecu for b18c?
  181. Got too many CEL's
  182. b18c1 is in my friends civic but it idles weird why?
  183. all people who just got a motor and it isnt in the car yet, can you weigh it?
  184. Puck style clutch??
  185. will jdm pass smog in md?
  186. haha
  187. H22 EGR Civic question?
  188. No Vtec in 3rd Gear
  189. hydro trans in a 88 CRX??
  190. where is that p29 auto to manual conversion thread??
  191. Prelude Si H23...read
  192. New look for some HCP Mounts
  193. which AC bracket to keep AC in EK hybrid?
  194. 3.2 liter V6 into MR2
  195. Are these typical serial numbers on a jdm block
  196. chaning obd1 to obd2?
  197. hey have newbie question
  198. easiest way to get the pins out of the ECU clips
  199. Has anyone used a floor jack to lift the motor???
  200. sleeving a ls
  201. Question about swapping obd1 motor into obd2 hatch
  202. Non Turbo 1G Eclipse 240cc fuel injectors for N/A Crvtec motor????
  203. Swap pics finally in! 56k beware!
  204. what about a gsr motor
  205. LS motor questions---HELP!
  206. B16a manifold with extudehone VS. stock ITR intake manifold?
  207. jdm gsr swap
  208. B18 crx shift linkage prob, i have no shift gate
  209. CC: I can't find where they sell B18B's online...any help...did a search.
  210. lookin for a wiring diagram.......
  211. anyone know Gude's website?
  212. Gauge Cluster ?
  213. what shift linkage?
  214. SIR2 into a 94 VX. 5 wire o2 question ???
  215. OBD II to OBD I back to OBD II
  216. fuel injectors
  217. 92 HBcivic.....LS motor swap
  218. h22 q!? iab inq.
  219. ::need help finding a JDM B18B swap!
  220. Can it be done????
  221. preLUDE swaps
  222. im looking for mounts for my friend for 88 hatch with a 92 ls motor what does he need
  223. OT: Anybody import Nissan engines/trannies? (not SR20 stuff..)
  224. H22a prelude to 92 accord swap with v-tech not functioning
  225. Nissan SR20DE into 2nd gen integra
  226. Will a B16a header fit a B20?
  227. HELP!!! customs won't release my swap...
  228. Exhaust fitment on hybrids? Someone please help!
  229. Stock Teg Mounts Needed For the B20 Swap?
  230. Wtb b16a1 asap
  231. Spring Rates For Ground Controls on H22 Civic?
  232. B18C Swap: What's the real deal with wiring and motor mounts?
  233. south cali swap shops.
  234. Are all Dohc vtec water pump & oil pump the same?
  235. does cel 23 retard timing ??
  236. Best Place To Find A GSR Motor..... HELP
  237. Finally took the H22 to the track yesterday.
  238. what factory mounts do I need with HCP mounts?
  239. does it matter which side of a vtec solenoid gets wired to the ecu and to the ground?
  240. is it true that CALIFORNIA doesn't have 92-93 octane gas?
  241. LS/Vtec sputters, but won't start (Ideas)
  242. obd 2.5 swap ?
  243. B20/LS crank in B18C1...searched
  244. sites for how to swaps
  245. gsr or si tranny?
  246. B18B Swap Help
  247. D16Z6/Y8 head on CRX SI. already searched but could not find anything. HELP PLEASE
  248. no vtec! arg
  249. help restarting my rex project
  250. Dist wiring question....
