View Full Version : Hybrid / Engine Swaps
- OBD2a B18B into EG swap ?
- A true hybrid: How to build a Honda-based mid-engine sports car.
- 92 civic b16 swap harness question
- does anyone know if a f22a1 fit in civic eg6?? and a H2B question please help
- OBD1 B18c in OBD2 civic NY state inspection...
- keeping a/c with swap?
- BAR + LS VTEC = ?
- Questions and Opinions on H2B and H22
- OBD1-OBD2 conversion questions
- Possible to disable Knock Sensor in P13 ECU??
- Injector Issue
- b16a in da ls chassis wiring
- K20 swap in a EG
- FUEL PUMP QUESTION
- Whats the best site to buy a swap?
- P/S pump and pressure line issues ?
- obd2 tach signal?
- Misfire, rough running...
- b16b or a into EK coupe 96 (d16y8 engine) - belts ???
- H22 doodes needed..VTEC codes and stuff
- H23 Idle help?
- need help with bolt-on torque specs..
- h22a in ej1 pros & cons
- Transmission making scraping noises in 4th and 5th gear ...
- b18b turbo Q!
- 95 Integra Auto to Man swap wiring ?...Its not the ignition lock or reverse lights
- B16 swap making loud tapping noise!
- swap k20a2 in ej9-need help !
- h2b ecu and wiring help into 94 integra ls
- B20 with Gs-R head vtec not engauging all the time?
- H22 EG : Avid support & Hasport Axles
- starting issue
- GSR Cold Air Intake No Longer Fits With Skunk2 Intake Manifold
- will a dc2 front sway bar fit a 96-00 civic?
- K swap ECU question.
- clicking hard when braking/decelaration
- what color are the rings on 97 + h22 injectors
- what ever happened to that mid engine integra guy need link
- to everyone and anyone who knows
- please atleast look: question about gsr swap into a cx eg hatch
- B17 with LS crank?
- One Of My Noob Questions Regarding B-series Swap Into CRX
- 91 Intermediate shaft
- B16 vs B18A/B/C vs K Series vs LS/VTEC vs B20/Vtec vs ... (Research Paper)
- 4,000 dollars
- *****official h2b e.t. thread*****
- F20C FF EG/Del Sol
- B16A vs. B16B
- Motor helpp!!!
- Lightened Flywheel Tech. Question...
- OBDII to OBDI conversion harness (vtec pressure switch question) searched
- hydro trans in EF/CRX/CIVIC, what axles?
- ls/vtec in eg hatch, surges when idle and when trying to drive
- H2B costs if...............
- Headers
- Tach problem with type r ecu in 99 si em1.
- K series tranny compatibilities
- B16 plenum on d16 runners....
- dizzy question
- Jdm starter on gsr?
- same one help me pleeeeeeez
- b18c5 into 94 hatch dx, auto to manual.
- H22 w/ Bolt Ons or K20
- Head Gasket Dilemma
- OBD2-1
- starting my swap today
- Cali smog legal JDM B16 swap.
- total cost for a k20 in ej1?
- i have an 88 crx si engine harness and a 91 crx and one plug that is differnt ?
- Where does this go?? water pipe b16a2 near thermostat
- better for frankenstien...f23 or h23?
- auto ls in a (96) NEED HELP
- lets say i have an obd1 civic and an obd2 b18c....help?
- --NEED HELP-- ELECTRICAL LOAD DETECTOR!!!!
- Any body daily driveing their H2B and what to watch out for
- help with wiring gsr into dpfi crx
- 3700 for b18 swap? bout right or ripped off?
- H2B times
- What Engine and Mods for Honda Accord 2005
- Help: EF with OBD2 JDM ITR Swap, Throwing O2 and VSS Code
- Is this legal??
- great news everyone!
- OBD question
- help ls/vtec or h22w/h2b setup help please
- MAP Sensor? Please help identify
- WHICH H22,H2B RACE HEADERS are best hp gains,
- SSR H2B header is here
- Stock B16a header onto B18c?
- Poor mans type R water line hook up stuff
- rad hoses
- something is wrong...
- b18c into DA link
- Any Big Number Non-Vtec Engines?
- dizzy wiring diagram
- H22 seems slow...HELP
- b16 in EF HATCH surging
- jdm p72
- DIZZY PROBLEMS: jdm b16 in ek *help meeeeee
- B16a swap into EK 96 - trans questions ??
- 84-87 civic/crx (non si) Fuel system question
- Having trouble with my spedometer
- b20???
- SC h22a in eg
- OBD1 LS in 99EK (Wiring)
- h22a into a delsol eg2
- 95 B18B into my 99 integra
- H22 in 1996 honda civic, looking for suggestions!
- New and Need HP/Torque gains for 96 F22B1 VTEC
- ls vtec torque specs
- b18b or b20 swap in da
- swaps for a 94' delsol
- Need help with swap Idle surge at 1500 rpms
- LS Head on B20
- K24 Port Spacing
- obd0 ecu
- best place to get ecu for b16 eg i/h/e.
- build question
- LS Throttle Cable
- h22 help
- should i buy these
- P13 Chip on Ebay
- K24/K20 swap in DC Chassis.. need info
- Evolution H22 PCV bracket/relocator
- Problems with new Axle H22 DC2 *Old Hasport mount kit*
- H22, 5th gear grinds and no reverse... can i use F23 gears?
- b18 swap
- As far as WIRING/COMPLETE INSTALL/POWER POTENTIAL which is easier/better for a everyday drive 92 cx
- There are still some good businesses out there!
- B16b help/advice.
- Brand New CTR Pistons For Sale!!!!
- gsr fuel vs. cx fuel pump differnce?
- b20vtec????
- y7 block y8 head mini-me CEL
- Question on Hasport Driver-side Mount Doesn't Fit on JDM ITR(B18C) Motor
- any h22 EG/EJ1 guys autocross?
- which mounts for a crx
- hondata
- Need help with swap from D15b7 to D16z6 map sensor plug.
- can p28 unchipped run a h22a1
- 92cx hatch with 94 vx engine and wiring harness. Need wiring insight.
- need help with wiring h22 into 1990 crx si!
- Wiring Questions... OBD2 to OBD1
- Need pics of vaccum and coolant hoses from thermostat,throttle body
- Honda Civic Engine Change D15B1 to D15B
- what kind of cat do i need?
- H22A EK Still Not Starting.
- Anyone know which torque dampner
- Shifter question?
- Budget big brake how to
- Request some help with OBD0 B16 Dizzy?!? anyone please?!
- Obd2 h22 dizzy question. Will paypal $10 for answer
- 92-95 eg w/ jdm B16a swap... do i need the hasport cable hydro conv.?
- b18a block or b18c w/ gsr head
- turboing a SOHC VTEC f22b engine
- ** B20VTEC Write-Up ** Discussion, FAQs, and Personal Experience
- PLZ Help Me Just Bought A B16A2 For My 94 Civic CX
- whast the diff. between obd1 h22a(92-95) and obd2 97+ and which is beter for swapinto ej
- B16 Head Rebuild
- a couple questions about my del sol-gsr swap
- Axle & CV joint out of place...
- Ef swap trouble
- LS/Vtec with cable trans what mounts do i need?
- throttle sticking
- Gooved Piston and Cylinder wall need help PICS!!!!!!!!!!
- H22 problems on friends ride
- Need taller Final drive gear set for j4d lsd
- what Ecu are you's running on a b16 . P30 or P28
- First hybrid
- B18a into 92 civic dx
- What is the engine code of the insight? (search done)
- radiator hoses???? b18c into 00 civic ex...any factor hoses that are direct fit??
- JDM ITR 36mm axle heads/spindle to Stock EK axle?
- z6 head with y7 block
- No Fuel?
- Compression #'s on an 92-93 ls motor
- D15B7 block / D16Y8 Head OBD1 - dizzy?
- H22A EG with LSD and DSS STage 3 Wheel Wobbling
- What type R trans is Better for my B18c5
- some problems and questions reguarding my swap. obd1 shell obd2 motor.
- Alot of questions about a swap
- gaskets for my LS/VTEC, is there a kit ?? (not the conversion kit)
- H22 EG's and DC's I need your help
- B18B swap problem.
- INJECTOR HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
- F20B & obd2 h22a concerns
- H22 now in my teg - check it out
- H22 EG Axle Binding
- Just swapped, throwing codes HELP! VIDEO inside
- PLEASE HELP!!!
- Ls/vtec and h2b quesion
- Swap/ axle
- 97 Prelude Half Shaft work with 92 - 96 H22A
- Power card
- B18 swap no spark
- setting the new motor in the car
- Quick Help~!~!~~!~
- K guys i need help!!
- WTF!!! NO MOUNTS FOR K20Z3???
- vtec lockup silenoid
- Help: Back to stock with no spark!
- CEL will not go away HELP PLEASE?!
- Extended Fuel filter hose
- acura rdx engine swap?
- i have an obd2 gsr
- OBD2 to 1 Jumper Question ....
- GSR block with LS crank?
- Removing charcoal canister/EVAP solinoid
- GSR SWAP TIS WEEKEND 56k DIE
- GSR half shaft to replace H22A half shaft??
- H2B DA's?
- H22A LSD Tranny uses difference inner CV ????
- k20
- Wrong Inner CV Joint on DSS Stage 3 ???
- Quick B Series ?
- K20 Accord
- b20 ECU Question(s)
- prelude halfshaft differences
- cam gear
- please help !!!!!
- Secondary o2 Sensor question ....
- obd2b dizzy plug quedtion
- legalizing your jdm itr motor for emisions in northeast
- resistor box
- shift linkage gsr in a EG hatch??
- 5 wire to 4 wire O2 sensor Q's please help!!!
- H22 EG AVID AXEL PROBLEM WHAT HALF SHAFT?
- car starts then stutters and shuts off
- brake booster question?
- EG Front Brakes on an EF
- anyone with h22 swap 96'-00' civic
- gas gauge question
- Problems with idle and missing coolant line-HELP!!!
- gsr p72 head with a b16a block...which head gasket?
- Need Help!! swap searched!!
- 90 ls swap into a 90 hatch
- GSR swap Civic, BLOX IM- What throttle cable?
- ECU small and large pins
- h22 swap eg
- secondary obd2 o2 wire up
- Best Throttle Cable for my swap? 93 Hb w/ ITR Mani
- B18C5 with a b16 tranny?
- clutch question?
- vtec wiring
- obd1 dizzy and obd2b sohc dizzy ?
- i just need a little HELP on building my motor
- Best way to remove passenger engine mount for K20a2 swap?? (92-95 Civic)
