PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 [133] 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. Comprression Ratio: What would it be with ITR Head on GSR Block?
  2. 94 civic ..will itr master cylinder work with gsr discs
  3. B18B1 into a 87 civ body...clutch problems
  4. ls/vtec wont start..clueless
  5. Be all, end all...EGR/vacuum hosing! H22/Civic..
  6. How do you know what CAMs you have?
  7. What head is this? P72-2
  8. 99 si with B18c5= GHEY!
  9. Info on Ls swap
  10. A VID of my h22 coupe in AUTOX
  11. Nitrous on a GS-R motor with ctr pistons????
  12. help with intake man butterflys (IAB)
  13. people that are running no AC no heat.. i need some help
  14. 01 Type r cluster In 98 hatch help
  15. Question for Kenji or anyone as knowledgeable?????
  16. anyone deal with streetimport.com
  17. HCP Mounts
  18. B16A2 into 94 Civic Si (I searched)
  19. 1st gen b16a maintenance
  20. B17a into 92 civic...what all is needed???
  21. B18c into an "EG"
  22. Distributor compatability question
  23. How do you get the pin IN that connect the shift linkage...
  24. looking for specs and cost of a 91 B18b (ls motor) for my 91 dx hatch
  25. will 99-2000 JDM ecu's fit 96-98 obd2 wiring harness?
  26. need some advice
  27. New Swap (questions)
  28. Need Help!!! First time engine swap, what do you need.
  29. weight/speed ratio in hybrids (realistically)
  30. need advice on ls/vtec car?? what to look for?
  31. ITR swap into 94 Del Slo SOHC VTEC,, wiring questions!!
  32. no vtec after tranny swap...grrrr
  33. Idol is to high?
  34. where is sensor to wire a b16a1 into a 93 acura integ...???
  35. how to tell if my Y80 has LSD?
  36. str question
  37. lil wiring problem please help
  38. Car flipped over and motor was still running.... Worst case scenario?
  39. ZC Intermediate Axle Shaft
  40. 92 integra wit 98 gsr swap what Cold Air Intake???
  41. What to swap into 85 civic
  42. H22A Swap info.
  43. What to strip from a '96 JDM ITR? *URGENT*
  44. B18 into 2000 EX
  45. SPARKracing h22 mount kit?
  46. how do you guys blow your ls,crv/vtec?
  47. Help : Possible Axle problem
  48. which passenger mount to use
  49. Good Lord
  50. ENGINE SWAP integra b16 PR3 ecu??? Redline
  51. Swap info??
  52. Engine in the back
  53. help i need shift linkage and axles...
  54. hasport!!!???
  55. Transmission for a B20b/VTEC engine
  56. B16 into a 94 Civ, I need some help!!!
  57. What do I need for this swap?Please read guys!!!!!!!!!!!!!
  58. type r in an eg?
  59. 92 B18a into a 92 vx got some ?'s
  60. h22a or b18c5 in a dx civic coupe...
  61. Changin Muffler...help pickin one out...!!!!!
  62. B20B VTEC Hybrid conversion
  63. B16a Catalytic converter O2 ?
  64. HELP ASAP! timing belt question
  65. H22 mounts that allow a/c and p/s!!
  66. Where can I find HCP mounts
  67. intermediate shaft bolt question..
  68. H22a swap in 94 accord (P/S hose question)
  69. **how much would you pay for a b20 head and ls tranny????**
  70. online ls motor
  71. Is your Hybrid your daily driver?
  72. !!warning! buyin motors online
  73. My H22A Civic Coupe Suspension Problem (HELP!?!?)
  74. B16a w/ S2 Stage 1, what ecu for 8500rpm?
  75. Total co$t of swapping
  76. what kind of times should i get and who will i smote??
  77. b18b w/low miles or jdm b16 w/unknown miles/condition in my 4 door eg??
  78. Can i install a b16a1 from a 91 model into a b16a2 94 motor?
  79. 02 sensor problems
  80. Wiring Issues.. need a quick yay or naw
  81. What exactaly do I need for ls/vtec in DC4???
  82. Catback exhaust for a hybrid???
  83. K20A swap into EG
  84. Doing a jdm itr swap in a hatch... should i get the integra helms manual??
  85. ls/vtec smog issue
  86. B18a going in my CRX
  87. h22 swap in a 96 accord problems
  88. DSM Injectors in B16
  89. CTR pistons in B18a with B16 head and big cams????
  90. head gaskets for the zc
  91. what do i need to put a hydro tranny in a 90 hatch?
  92. OBD 1 VX, 99' GSR. Is this correct???
  93. Simple swap, no info on it however!
  94. hmo are homos
  95. junkyard swaps
  96. what makes a motor legal?
  97. Is the VX the best recipient for GS-R motor
  98. LS Vtec?
  99. turbo my 4 dr 92 civic or swap in a b18b??
  100. 1994 Civic Si swap to what?
  101. which should i go with?
  102. lsvtec clicking sound
  103. purpose of obd2-1 harness?? No luck on the search
  104. 1st gen BshiteenA LSD trans grinds, why?
  105. My Intermediate shaft support keeps comming off! HELP!!!!
  106. why is my clutch adjustment changing?
  107. HELP!!! Cant find leak!?!?!?
  108. OBD 0 to 1 Conversion, Code 20 ELD?????
  109. B16a Dis cap
  110. ITR swap into 4dr EH Civic
  111. ITR SWAP applied at a 94 Del SLO Si SOHC VTEC, --few final questions..
  112. Do i have everything needed ?????
  113. LS cat vs GSR cat in Swapped EG
  114. DX to ZC wiring?
  115. online motors
  116. going to osaka today!! any advice??
  117. b18cR into EF: run in OBD0 or OBD1
  118. removing ball join??
  119. PASSWORD:JDM or Osaka for a swap???
  120. vx harness questions
  121. my h22a w/lsd
  122. GSR swap in 93 integra
  123. What compression do yuo think I'm @????
  124. secondary O2 sensor plug??
  125. GSR Pistons in B16A block
  126. B20z into an ITR
  127. B16A from 99 up Si in a 92 EG.... wiring etc.
  128. walbro pump, which one for H22 civic
  129. OBD2 b18cR into EF: run OBD0 with chipped pr3 or OBD1 with chipped p28?
  130. 97 D16Y8 into 90 DX hatch - What's needed for complete swap?
  131. can you run an OBD2 engine in an OBD1 car without changing dist. & injectors
  132. for those with ls/vtec (and u built it yourself, or u know of some knowledge or external oil passage
  133. How many USDM H22a owners here?
  134. B16A first gen install
  135. Best Reputable Place to Buy a Swap
  136. NEED HELP: EK with B16A1 and a P71 ECU... Smokes a lot! WHY???
  137. b18c1, obdII question...
  138. Best tranny for B20 or LSvtec all motor?
  139. 95 b18c1 into 2000 civic ex....wiring....already searched :)
  140. best header for b20b1... GSR manifold?
  141. jdm itr ecu to usdm ecu question
  142. 2 different kinds of OBD1 injectors?
  143. Help!! B20 VTEC..........
  144. which ecu???
  145. Want an LS swap for my CRX
  146. where are the good deals on b18b's?
  147. which offer is better for a swap???
  148. will this ECU work for my H22a swap
  149. 2000 ek with jdm b18b........cel....????
  150. The very far vacum line on the Skunk2 manifold????
  151. quick mount and hose question
  152. Skunks ECU VS Mugen ECU
  153. would u say i can run high 13's on my setup?
  154. Any1 in the Dallas area wanna help? $$$$
  155. BAR sticker holders click here
  156. B16A1 Idling at 3,000RPM ? ? ?
  157. 2001 gsr immobilizer
  158. what TB?
  159. Need info on swap?
  160. Crx with Ls to Gsr
  161. ne1 run a chipped p07 using a b16
  162. help car is idling rough
  163. Need Help with a b18c5 swap into a LS.
  164. IACU ???
  165. B16a is here, have a few Q's about its condition
  166. help, car wont go into reverse!
  167. Putting '96-spec b18c-r in my '95 CX....??????
  168. who here has LS/VTEC head bolts stripped before?
  169. H22/H23
  170. b16a in 90 ls integ
  171. opinions on crv set up
  172. How did you run your wires?
  173. LS swap wiring question. PLEASE HELP!!
  174. ls headgasket/b20vtec
  175. estimate a 1/4 mile time on this
  176. help!! My car w/ LS/VTEC losing torque
  177. need help obd 0 cel 23
  178. swap help????????????????????????
  179. ls into crx questions
  180. which mounts to go with
  181. Almost done with the motor guys.
  182. Looking for a Old JDM book!!
  183. is a new fuel pump neccesary when doing a swap?
  184. h22a vs b18c1 in a ek hatch???
  185. b18?
  186. ls/v-tech
  187. not sure if vtec is working
  188. H22 EK not as fast as thought?
  189. B18B into 99 civic?
  190. y8 on my crx
  191. Gsr in a crx
  192. HELP!!! car won't start after longblock swap...
  193. B!6a auto swap into auto 93 civic...
  194. Why wont this work......?
  195. usdm b16 into 97 dx hatch what's needed?
  196. Need technical input from a seasoned swap genius
  197. I'm terrified!!!
  198. 4 things I would like identified in a pic (GSR hatch)
  199. B16A problem no one can figure out HELP!
  200. Can I put a JDM B16A1 auto in a EK auto?
  201. obd1 harness and distributor ?
  202. hmo wants sales...lol
  203. Gen B16 into a 2000 Civic
  204. Torn motor mounts. Question about ES bushings.
  205. JDM H22 type S into a 4th gen Prelude Si???
  206. prelude head
  207. Question about getting bearing color?
  208. How many miles were on your swap from Import Auto Salvage?
  209. p73 or p28 ECU ?
  210. fucked on H22
  211. GSR options
  212. b20 header fitment
  213. Ls/Vtec: Pros and Cons?
  214. Extremly wierd p13 ecu
  215. How-to H22 in an EF chassis.
  216. b16a1 into 92 civic
  217. Plz answer these h22 ek questions
  218. Secondary Butterfly
  219. LS Vtec
  220. b series question-is this compatible??
  221. help ecu problem
  222. swap question
  223. B20Z EK 4-door exhaust setup question.
  224. skunk2 intake manifold????
  225. LS/Vtec or B20 Vtec?
  226. ZC Dipstick length?
  227. OBD 1 or 2 GSR motor for my 93 Civic Cx? ....or does it not matter?
  228. LS/vtec questions and ideas
  229. 99' Civ
  230. GSR header too short to reach stock cat.
  231. Junkyard motors
  232. Suspension setup on JDM H22A '94 Civic coupe dx
  233. H22 ecu programs... spoon vs mugen vs jun ?
  234. Tranny
  235. GSR ecu wiring
  236. Bolts to mount tranny to the block ??
  237. 99 DX to B18B1 swap details?
  238. TPS Question???
  239. knock sensor?
  240. what i need for my swap
  241. Parts list for B16a CRX swap
  242. Keep My CIVIC???
  243. quick laundry list for B18c-R?
  244. what else do i need
  245. evanshondaspecialist
  246. ground?
  247. H22 Hybrid Guys
  248. No VTEC oil pressure unit on B16??
  249. wireing problems in 89 civic w/ b18b
  250. Question about ls/vtec & CR-Vtec timing belt/water pump
