h22a in delsol wiring help for egr
okay guys i read i bit on the p13 ecu and p28/p06 well when i have to add the egr sensor to the wiring harness that goes in to the ecu there is other wires already in that spot so what do i do? relocate them to the appropriate spot? please i could use some advice on this
Re: h22a in delsol wiring help for egr
or would i splice into the wire that exist there? on the p28 ecu or the wireing for the ecu in the del sol has a wire in D19 and D20 D19= seonsor voltage for MAP D20= seonsor voltage for TPS this is on the p28 and on the p13 its D19= EGR valve lift sensor D20= TP sensor? yeah im confused on this part
blu3g
12
07-26-2006 11:17 AM
fizzbob7
02-16-2004 02:50 PM
streetlvlhatch
12-26-2003 12:59 PM
