View Full Version : Hybrid / Engine Swaps
- Honda Motor Swap in the future
- Wiring help for b20vtec
- Running rich, long term negative effects?
- 00 y8 head swap on 00 y7 block
- Ek J Series ---
- Yonaka H swap mounts
- Looking for opinions, what's chassis for h22 swap
- 94 Del Sol swap thoughts... b16 or k24?
- D Series into Integra
- do i need a usdm intake manifold? evap purge valve question
- Top Secret honda axle spec list.
- Engine Swap Pouring Smoke
- jdm itr crank pulley chipped
- 2013 Honda Accord Engine Swap
- 98 Civic hx help
- B18b1 swap
- building a g23 turbo engine
- H22 bogging cold start up?
- Question 98 accord ex engine swap
- Calling All Honda Pros! Dreaded Code 43! Pulling my hair out!
- B16 vs H22 vs K20
- wiring b16a ef hatch
- Valve clearance milled head
- D15b7 d16y7 help??
- b18b1 automatic into 93 civic, wont shift
- Need help with engine harness for my h23a1
- P/S Bracket in an LS swap into 2000 EJ coupe
- Gsr b16 in 89 civic
- Help with del sol ls swap
- Poor mans type r
- J series Prelude swap-(5th Gen BB6-J35a8)
- D16y7 to D16z6
- h23a1 to h22
- H22a DC headers loud valves? Help
- JDM D15B Mini Me Swap "Code 22" Help Please
- Which power steering pump for GSR swapped del Sol?
- H22A light throttle bucking
- engine swap sites
- SWAP Problem!
- Fuel rail mounting hardware size
- Help!? 97 EX Vtech swap into 00 LX body
- B16 intake manifold on b18a1 head ?
- Need help with issues after D16Z6 Swap on '97 Civic DX
- Trying to solve new Code 43, please help!
- B16a2 intake manifold question
- B20 Swap in 1998 Civic - which OEM ECU to use?
- How cheap can I do a K swap?
- Turbo with vtec?
- F22 Crank in H22
- K24 EK, race build, some tips needed
- H22 Swapped civic, prelude forum seems more fitting.
- Head Gasket Bad, But What About Cylinder Heads?
- B20 ecu wiring trouble
- B20vtec fit
- f22a6 w h22 head advice
- Looking to make a reliable daily
- Ultra race Manifold h23
- Swap complete! JDM GSR with ITR S80 LSD - '93 Honda Civic del Sol Si
- Jdm B20 bad right off the truck?
- BRAINSTORM: Modern B-Series Commuter Swap/Budget Daily Build
- 2-bolt post doesn't line up with 2-bolt mount
- B16vtec swap on ls 95 integra
- ECU
- My b20 swap
- H22a5 ticking noise
- VEHICLE SPEED SENSOR HELP
- P1382 Fault Code - Chumpcar - Need Advice
- Question about ECU (B18 & B20)
- Exhaust for a '99 Civic with B20
- H22 swap issues
- Turbo B18C-Rhythmic Misfire
- help regarding k20a3
- LS crank in a GSR
- B20help please!!!
- h22a swap questions
- 2005 Honda Accord Hybrid, Check Engine Light and IMA light on.
- Trying to get engine swap to start for first time and starter won't engage.
- 93 civic vx engine into a 93 cx or dx car
- B18C1 Head on B20
- CV Shaft Knuckles Interchangeablity?
- '97 Civic DX - D16Y7 to D16Z6 Swap Help Needed
- Obd2b motor in to obd2a car and b20 swap questions
- F23 swap into 86 Accord LXi
- Civic shafts
- Y8 swap help
- Axle Won't Fully Slide In
- Help with eg4 swap d16y8
- B20b4 HELP PLEASE!!!!
- CTR N1 crankshaft pulley in weekend track car? JDM GSR
- Mini me swap issues
- eg b18b1 swap progress!!!
- 1990 Hatch b18 swap wiring
- Radiator - fan or no fan
- OEM part number for distributor cap and rotor for TD-44U distributor?
- D to b swap
- '98 GSR Swap Into '97 LS Integra
- B16 block, gsr head questions
- Power steering in JDM b18c swapped '93 del Sol Si (d16z6)
- Keeping AC: b-series swap into '93 del Sol
- 3.7 Intake and Throttle Body Swap into 9/9.5 gen accord?
- Exhaust Info: B-Series Swapped USDM 96-00Civic "EK" hatchbacks
- Obd2a injectors and starter compatible with obd2b harness?
- K24 A/C bypass belt size help
- 1994 Civic EX D16Z6 to D16Y7 swap?
- B18a1 into CRX Couple Quick Questions
- k24 into custom frame
- Need help with wiring diagram for 93 EG Hatch (Engine Swap)
- Civic Ej9 Auto to D16 Auto
- Wierd problem 99d16y8 swap in eg ex coupe
- B16a2 swap into my EK hatch
- 98 civic noon help
- B20v
- Questions about gsr internals in LS block
- Help me pick what car to build/swap
- OBD1 B18a1 swap what ECU do I need?
- Integra B20 Swap
- F20B head gasket blown
- obd2a motor, obd2b harness, obd1 ecu
- 92 civic b18c fuel pressure
- Need a little help.
- Ecu
- temperature indicator remains lighting
- EK b18 swap p28
- 92 eg hatch b18c heat saturation intermittent no crank
- Qsd alternative bracket.
- is there an 01 jdm b18c type r head stamp?
- Help!?? B16a obd0 crx running like crap
- d15b 75mm pistons
- Looking for a reputable swap shop ......
- Wiring trouble!
- EK H22 civic starting issues HELP!!
- Gear box compatibility...
- Powerplant setups?
- HONDA LX E.G SWAP 2 A B18B1
- Considering H2B - would like confirmation of build details
- diff noise at 70km/h
- "A20" Gear box on a B16 Engine block Is this possible?
- swapping a 94 b18c1 into 96 integra ls help!!!
- K24a wiring help!!
- Swap d15z3
- Car won't start after running perfectly the night before
- H2B Injector wiring issues
- obd2a to obd2b same engine just different year
- Ignition problems
- B18c1 block w jdm b16a head help
- Which ECU for '95 Civic with JDM B20b?
- will this engine swap be possible?
- 6k rev limiter
- Turbo H2B cooling system issues
- F20B swap radiator fans
- HELP: semi new to swaps, 99 si to 94 eg
- Mid-Engine RWD V6 5th Gen Prelude
- 2000 Honda Civic Ex B18B1 Full Swap Auto-Manual
- 97 ex civic swap with b18c1
- A different Swap Idea: Using a Built B20 with a B18A head
- Teg won't go past 4500 rpm?
- F22B throttle body leaking coolant. Not sure what this(highlighted in pic) part is
- B16B EM1 swap
- ek hatch had h22 swap, now going b series. transmission bracket help???
- Anyone swapped a R18Z1 into an 8th Gen?
- F&H series motor mounts
- Pos.
- J35A4 in EK, No VTEC
- 2000 B18c1 GSR swap into 92 civic Si Throttle cable
- No start! :(
- which radiator and hoses?
- Civic B18B1 swap help
- Best engine harness to use in a 96/97 delsol
- '05 Honda Accord Hybrid Engine and IMA lights.
- 2006 accord k24a8 with k20z3 head swap help!
- Honda EP3 - shuts down after letting off gas
- manual gsr swap into auto eg sedan
- no power to IACV
- need help again....):
- b20 vtec cut at 6500-7000rpm
- F22b1 to f22b2
- No fuel, no start
- b18b civic coupe: issues with idle/running/possible misfire
- HELP H23a in 2000 EK Coupe
- MDMA OR MDLA?
- Integra B18B1 Swap into Honda Civic (Both Automatic)
- b18c type r tune up?
- Engine Swap
- J30A with a K20A merger
- ECU B20
- f20b ignition problems
- B20b swap
- 2004 civic engine swap
- J32a2 swap
- 3 wire IACV to 2 wire IACV harness
- zc block w/ y7 head timing issue?
- Crank sensor int-interruption + VTC phase gap.
- H2b no vtec
- Fuel Injector Problems
- i-CTDi engine
- i-CTDi engine
- Loss of power at 3000 rpm's
- CEL issues
- B18C1 Swap Idle issue
- H2b turbo on 92-93 si hatch
- 0bd2a to 0bd1 help needed!
- b16b inspection possible?
- can I use this transmission in a civic?
- Euro R H22A IACV Problems
- H22 swap won't start
- b16b vs b18c r rod stroke ratio
- 00 Civic with GSR dizzy help
- is putting a B18C1 in a 1999 CR-V legal in CA?
- b20b swap into 00 em1
- harness and dizzy problem
- b18c1 into da9 won't start
- Another Hunting/Surging Idle Post
- B18c1 swap into ek, Map issue
- 1997 Accord Wagon F22B DOHC swap
- transmission issues
- b18c5 preventative maintenance
- OBD2 GSR swap into EJ1. PCV hose install????
- Confused Civic
- d15 block d16 head help...
- B20b won't start
- Mounts ? Engine
- Non VTEC 1997 Honda Civic with VTEC
- jdm b18c r to usdm specs
- Emissions?
- 96 Civic Lx D17A1 swap
- cable accord throttle body on tsx manifold
- Overheating b20 now going b20vtec
- 93 del sol with J swap. Need a solution for a hood. Do not want to cut the hood
- B16 swapped out for B18c1
- Blue Top H23A VTEC or B20 VTEC for CRX?
- Evo H2b action clutch
- D15B7 motor and auto dune buggy harness Q?
- B20Vtec What Valves to use ?
- Longitudinal Mounted V6
- Options to consider Swap for my EK
- prelude TCM A10 pin ???????
- Hey guys question about h23 head on h22...
- AXLE SETUP H23 SiR EG HATCH
- SOHC VTEC Convertion
- tsx engine with an automatic crv?
- F20b Swap to a 1991 acura integra (HA)
- Engine Replacement- Help needed
- F22A4 To H23A1 Non-Vtec Swap Advice
- JDM ITR Idle Probems
- How do I k20z1 swap into my into my 96 Integra?
- changing to normal engine from Hybrid engine
- Bense's J32A2 + 6MT swap into 2001 F23A1/H23A 5MT Accord
- ENGINE NOISE NEED HELP
- DPFI OBD0 d16 to MPFI OBD0 B16a
- B20vtec issues.. HELP
