View Full Version : Hybrid / Engine Swaps
- Integra
- Is this price for a B18C Type R 98 good or bad?
- Parts Suggestion Request:Will a D17 fit into my 86 honda civic hatchback?
- Swap B20 block to B18b1 block: tune is necessary?
- H SWAP NEED HELP
- *POLL* b18c or b18cR in 92-95 civic CA/BAR/Ref
- Need some help
- 92 jdm d15b (auto) into 91 usdm crx (manual) swap
- engine harness question
- Need help, B20 vtec swap.
- Dpfi to mpfi injectors not firing help!
- 95 civic dx d15b7 to d16 vtec
- KB1 RL SH-AWD swap into BB6 Prelude
- No spark to engine
- 96 civic jdm b16 swap. Evap system
- Time to Swap?
- 05 Civic Hybrid K20 Swap???
- help identifying B series block
- What options do I have for intake tube on a B20 swap into a EJ6?
- d16y7 to d16y8
- H22a EG wiring issues
- O2 sensor wire terminals?
- H series 99 hatch need help!
- Rwd F20c into Prelude swap in process.
- B20 swap help please!.
- Trouble with my H23A swap in EK coupe
- Dorkenheimers H2B won't run....
- GSR IAB Wiring Question
- F20B swap problems please help
- 96-98 harness VTEC wires extend
- b18 or b20?
- Mystery overheating issue.
- 97 2 door ex swapped with d15b
- EF SI noob questions
- H swap rad hoses
- B16 or GSR
- Ok, so can you kswap an ek, boost it, and retain AC?
- B18B1 Too B20B
- Coolant line on FITV B series Swap
- 1992 Honda Civic SI oxygen sensor?
- CRX B Series VSS lines
- Civic f2b swap... idles at 3500rpm, can't figure it iut
- H22A or K24 swap ?
- Auto ls teg to 5 speed eg
- ek gsr swap
- G23 help and s2000 crank into a f23a1
- Stock B20B Chipping/Tuning ?
- ECU Wiring Questions
- Swap questions on vtec wiring if I can or can't ? help
- Need Info on Motor Swap
- Fresh b20 build crank but not start!
- F2H Jdm HELP.!!!
- mini me into ef
- H23A3 swap to H22A euro R
- Swap Shops in Tri-State area
- H2B in EE/EF Chassis - A/C Possible?
- auto to manual EG Hatch h22 swap help
- H23A EK SWAP HELP!
- obd1 swap in b16a ef wont crank fuel pump stays on.
- J30A4 swapped civic custom intake will provide pics
- Will a f20b cam work in a h22 head
- Fuel Line - B18C1 in '94 Civic EH3
- h23a vtec help 90 accord
- IMA, Battery, and Check Engine Light On
- B20v idle issue
- Assistance Needed: D16Y8 Block Y5 Head swap Questions
- B20B Kinda starts
- B18 spark plug wires on h22
- Obd2b diagnostic port
- What are the 3 other numbers next to engine year?
- Da7 b16a swap
- 96 accord h22 swap ghost issue
- Prelude s2000 swap
- Cylinder 3 problems.
- New guy here!
- Just completed my Civic swap
- J series V6 swap into 7th gen Civic EM2
- LS-VTEC oil pressure changing mystery
- h22 in 94 coupe has power won't turn over
- Need help with my ls/vtec
- k20z1 swap help!!!
- 2004 Honda Civic LX: Questions on swapping VTEC engines
- Honda accord engine swap
- Tegra-sol
- 96 civic ex swap h22a
- B18b1 swap help
- 99 Civic LS swap ecu idle question
- 94 integra Ls to gsr swap IAB question.
- 94 civic DX engine
- Ecu wire question
- No compression type r motor/trans for $800?
- ek hatch - GSR automatic/b20/b16
- Back at it Again. got some questions
- h2b crx
- ECU question b16a2 swap EJ6 hatch
- Hi i need help on a ecu questions
- D16Y7 engine in a 91 honda civic having issues
- 95 integra B18C1 SWAP
- Is my engine TYPE-R?
- 1990 honda accord motor swap from 1997 honda accord f22b1
- Ls vtec swap with ac in eg
- Need Assistance: 2000 Honda Civic with obd1 swap (P28) throws unknown code
- I need help trying to figure out which motor I really have!
- Issues with civic h22
- What do you guys think about this B20V build?
- what clutch should I get with my gsr motor with Ls trans?
- Should I buy- h22 del sol?
- Noob to CA & Hondas - Swap Question
- R18A1 to R18Z1 swap
- B16a into em1 code 7 and code 15
- '97 Honda Civic HX Swap
- F2B Ek Project full parts list help
- Ls vtec into a 95 EG vehicle brackets
- OBD2B B20Z into OBD2B civic CX with D16Y7 to pass emissions
- B18cr swap in 99 civic coupe, need help.
- OBD2 B20/93 DelSol || CEL Codes 4 and 6
- JDM Gsr RHD into Ls LHD swap
- 92 Civic/b18b1 swap - Timing belt tensioner bolt help
- 1999 civic ex d16y8
- B16y8 or swap
- Best Intake/Air Cleaner To Use - '94 Civic Si w/ ABS + B18C1 Swap
- Paying for a swap??
- 95 dx hatch
- Obd1 gsr swap into 91 crx si
- 96 acccord ex euro r swap
- 86 Honda Civic Swap
- 94 integra Ls swap to gsr b18c
- HELP*!*! BATTERY KEEPS DYING ON MY 90' DB1 WITH 95'B20
- Jdm b16 ecu
- '96 CR-V B20 swap into a '00 Civic Hatch CX - Questions!
- H2B Swap
- Need help Identifying my zc motor and head
- Civic 3in exhaust
- B18 auto swap into auto Civic
- Civic hatch with b18b1 clutch issue
- f20b eg sedan swap questions
- g22 with h22 forged rods and pistons
- Axle replacement
- B20 vtec ecu
- Obd2 gsr swap into 93 eg si/ Ecu headache
- I need help doing a engine swap on a 2000 honda civic lx
- 93 EG bubble question
- JDM d15b vtec turbo build
- 1998 hatch b20b swap problems
- H22 automatic
- 93 Dx won't start
- 93 Eg swap question! Help!
- Im stuck!! Obd2 b16 into obd0
- EG b20 block w b18 head question
- B20 block w. B18 head question
- Crx D16z5 to D16Z6
- swap in b18a1 in 2000 civic
- Zc swap 2002 civic
- H22 swap into accord.... need to ID parts
- B18c GSR knocking
- Type R running way too rich!!!! Please Help!
- obd2 to obd1 won't go over 3000 rpms
- Real World Streetability for HASport Hydro Conversion in EF?
- B20 Cv axle error
- swap info on d16y7 into a 95 eg
- Jdm b18 swap no speedo
- 93 Del Sol Si J35Y4 Swap
- Vacuum leak to get idle
- No Fuel Pump No Spark 96 civic B20
- Benefits of this swap
- Need help ASAP
- 96 civic fuel pump problem plz help
- Bogging Under Engine Load under 3500 rpms after B18c swap
- B18C in a 85 CRX Axle Question
- f22 into civ help
- RMR-Mid Engine RWD-J Powered BB6
- B series with S40 gearbox
- B18C1 - Papers?
- Tach not working after swap
- help ls vtec sputtering 94 civic sedan
- what motor mounts can i use for a jdm d15b del sol?
- Erratic ignition/firing against starter
- Random "Stumble" Under Load - B18C1 swap in 1994 Civic Si
- Need Power steering for my civic
- Honda Logo VTEC Swap mini-me, some problems
- Can I put an f23a1 in my 97 Accord SE?
- Rebuilt head on b16a need help with problems
- B18c1 block
- Failed Smog Check, high Nox
- obd2a h22 into obd2b accord with obd1 ecu..best way to wire the distributor?
- F22a1 / f23a4 swap
- Swapping out D16Y7 with 96-99 ZC Question
- Rpm surging problem
- B18b swap
- Need help identifying plugs and hose
- Help...
- help choosing cams
- Corrosion in sleeves?
- B20Z into 2000 civic questions
- D15B7 Mini-Me Z6 Head Swap
- 95 civic no injector pulse
- No spark after finishing up vacuum lines - B18C1 in 2000 EX
- Getting rid of Check Engine light (D16 ZC)
- 1997 civic ex b20b swap
- H22A - 6th Gen Accord swap
- Honda City Turbo Swap into 2G Civic. Questions
- Going b-series for 1500$?
- Blown B16
- D15B7/D16Z6 mini me swap
- Frank_two's G23 Turbo Build
- Civic EG Integra LS swap race car build wiring question
- Can you identify this H series motor?
- J30a4 into ej8
- GSR swapped civic o2 sensor issue
- B16 w/ GSR head. How much Power?
- No spark need help
- Compression Ratio for GSR w/B16 head
- Desperate H22 help......bad cold start
- Which Ecu
- 2000 civic LSvtec (vtec wont disengage)
- B16 head identification?
- DD Swap for EG on a budget
- Stroked H22 with H23 parts or H23 with VTEC head?
- Need help b20b swap on ek civic
- Questions on a B series swap.
- Tachometer or gauge cluster for b16a
- B18b in ek civic?
- Swap related axle questions, expert info needed
- H22a intakes
- OBD2 GSR to 93 Dx
- EK civic j32 swap
- Which stainless steel oem clutch line for b18 type r swapped EG?
- 98 civic GSR issues
- Car start 50% of time?
- b series tensioner bolt thread size
- What engine bracket for f22 f2b eg swap?
- B20v head/fuel setup advice
- H22 swap - braided fuel lines to the tank - EG hatch
- k20a swap mounts question
- 91 Integra B18C Swao questions
- EJ1 F20B swap questions
- Some questions about putting an h22a head on my f23 swapped civic
- I have a dumb question about igniters
- Is it common to lower engine w/custom mounts?
- P28 resiststor burnt
- h22 accord won't start oil and battery lights stays on
- B20B Longblock into 99 EJ6(EK) [[Automatic]] ~~Need Help~~
- Help with h22 civic dizzy wiring please
- h22a injectors not spraying
- 1994 EJ1 GSR Swap Questions
- B18c5 into a 2000 hx ecu help
- 2000 Honda Civic Si B18 Swap
- 93 civic engine swap
- D15b for a d16y8 problem
