View Full Version : Hybrid / Engine Swaps
- timed from 60mph-100mph
- Updated video of my hybrid hatchback...
- Euro R intake mani
- GSR wiring harness on ls/vtec help.
- what timing belt cover to use
- help with swap
- B16 Compression
- Building a 200hp 160ft/lb h22 for a 4door 90accord
- braided stainless steel fuel line
- i need help guys with GSR swap
- Are ITR motors really worth the money?($4300-$5000)
- Anyone ever installed a b16 from a...
- Please Help: B16A1 Redline???
- Steve"Hmotorsonline.com" saved me again!!!
- Please help me decide, skunk2 stage 1, 2 or used supercharger for under $2,000
- 1.5L sohc vtec
- Can anyone vouch for JDMSHIT.com???
- CAI for b18a in 2nd gen CRX
- vacuum connections........
- D16Z6 into EF Series Clutch Question
- Got a question for you hybrid gurus.
- Anyone from texas?
- Best cams for a JDM H22
- cant decide for my ek, h22 vs k20 jdm type r
- b20 block and b16 vtec head questions
- b16a into 94 integra
- Im giving you $5k (hypothetical), wwud?
- build gsr or type-r swap??
- Prob with timing check, help!!
- Ls swap- Clearance
- big james!!??
- B16a Vaccum Lines
- ECU pinouts correct???
- what little things to buy when swapping?
- ls vtec setup all commets are welcomed
- What is best for my crx ?? (91SI)
- Something for those B-Series Owners
- '00 Accord procedure for MIL...
- Another Ecu question
- Opinions on Exedy Racing clutch for B18c
- should i wait for a pipe?
- crx b16b swap
- Can anyone vouch for GZR4DR??
- b16a2(sirII).....94 civic ex (92-95 civic)
- Another h22 Q
- included in swap?
- quick question
- B16a1 in an EG?
- 91 civic b16a1 compression ?
- random pics
- OBD1 ECU pinouts
- Opinions on Hasport Cable-Hydro conversion?
- Whats a second gen b16a cable?
- ls/vtec questions..
- SpeedO Is't working!
- 92 Civic EX Coupe
- LS/VTEC???????
- Anyone heard of http://andrewsimportperformance.com?
- ecu trouble
- Idle problem on start up with b16a2
- ALL b20 vtec guru's read this!
- Any Complaints?
- H22 civic guys: please help
- JDM B16 SIR2 swap AT p30 ecu vs. 5sp p30 ecu
- h22 engine mounts!!??
- GSR VTEC Solenoid Wiring...
- Helping a friend with his motor swap and i have a few questions
- De-stroke d16z to 1.5??
- AEM /timing on ZC HELP!
- Will any B series motor fit in a 83 Civic????
- my 94 cx hatch vtec wires with new swap
- A/C in my EK
- all motor b20 worth it???
- car keeps dying!
- My B20 GSR
- which clutch act or exedy
- need help on 92 ls b18a into a 88 crx dx
- Problems after swap! help
- HELP NEEDED on b20z/vtec project
- installed new axle.....problems..help
- My buddy is having problems with his swap
- Frankenstein Engine - VTEC solenoid
- Help!!! car w/ b16 idles high
- B21A1 Bottom with a VTEC head???
- 88 CRX AND 90 INTEGRA MAP SENSOR question???
- Where to find an obd-0 to obd-1 conversion harness kit?
- H22A swap in Civic... Pro's and Con's
- Timing with Kenji Chipped ECUs
- jdm d15b
- Integra exhaust fitment issue on EG?
- the tools involved in a d series swap to a b series
- Won't be long now...look at what came in the mail yesterday
- B18B1 swap Question, Will a stock 95 civic radiator be good enough??
- How would this work
- 1/4 mile
- Hmmm... Worried now about my order
- AC or PS please!
- help!89 prelude vtech swap
- H22 help
- passwordjdm.com h22???
- B18C5 swap... do I need knock sensor for OBD1 P28?
- Has anyone actually confirmed the ratio of fith gear in a JDM S1 by couting teeth?
- ticket for modified exhaust
- could be a dumb question but i'm gonna ask anyway..
- lsvtec, what header/exhaust?
- is your hybrid RELIABLE?
- swap
- Easy ?? that I can't find answer for in search...
- b16a block with b18b (nonvtec) head....?
- More info on Scooter (H22 Civic W/PS, A/C, Cruise, etc)
- LS Engine Swap into a 94 Civic
- b20 w/itr tranny
- engine starts but it turns off if it does not have me press the gas? what i need to do to keep it on
- OSAKA----------LOOK AT THIS!!!!!!!!!!!!!!!!!!!!
- Where do i get a S13-S14 swap?
- engine work...
- B16 w/ GSR tranny?
- B16 wont run, please help, ASAP
- Wiring Harness
- Installing cruise in a car not so equipped.. What to buy?
- How can u tell if its an LS tranny?
- So i went a placed a big order with PasswordJDM.com.......
- ANY SHOPS that will do this swap? 98v6 into a 93 accord......EVERYONE PLEASE READ
- any shops that will do this swap? 98v6 into a 93 accord.
- Question for u all motor guys
- Why wouldnt a B20 intake manifold work?
- 94cx + 96 b18b now what stock intake (already have LS short ram).
- Accord Intermediate Shaft
- Please help with a Nissan swap question....
- Removing axle from intermediate shaft?
- What's the best header for an H22a?
- Motor Mounts-n00b
- h22/23 into 96 civic hatch
- h22a into a teg
- b18c eg VS h22 coupe...
- sorry guys...NOOB question
- which trans do you perferr
- Distributor shaft question
- just bought a 92' hatch, with sir2 motor..
- can u buy????
- B18c5 bottom end with b16a head I just bought it!
- JDM B20B Swap into 92 Civic Si
- Help , is this is gsr harness?
- B20 turbo VS B20Vtec
- where to find cheap LS motor?
- my experince with a/c brackets and my Ek
- jdm f22b
- Should I buy this GSR motor? 70k miles for $4,000!
- Any advice to drop a 1st Gen. b16A into a 90 GS?
- How many of you got a receipt with your swap? Kind of strange....
- d16y7 into '95 civic cx
- 93 civic hb vx swap jdm itr engine
- zc problem: axle and hub assy
- B16 OEM stroking ??????????????
- VTEC-E SOHC 1.6? Ever heard of it?
- Need a little help with wiring...
- b20 vtec experts
- Hybrid hatch + autox + 2nd gear = Tire slipping everytime vtec kicks in.
- b16 ecu wont run right
- How many kind of ZC motors are there? (did search)
- code 22!!
- Wiring questions...any opinions?
- will my car start w/out......
- doing a swap right at this moment question?
- HELP! OBD1-OBD2? 96 gsr motor into 92 dx hb ***
- ... need swap info for 86 crx si
- tools requied to remove engine mounts?
- Jdm B16a
- Auto to manual?
- h23 in ek??
- B16/B18c1 Hybrid??????
- ls in a crx
- itr intake box(or icebox) in eg?
- Hybrid Garage
- Someone HELP me out
- anyone with a gsr tb on y8 intake manifold???
- Should I get a new a car or change the transmission?
- b20 vtec experts??????? Balance and polish crank????????????
- dynoed my hatch today, 1994 Si w/jdm b18c
- any one want to trade there ride teg or lude! for my hatchback
- Civic 92 rad in an '88 CRX
- noob needs motor info
- DIY Links
- anyway to tell if ecu is obd2 or obd 1 by looking @ the outside
- ITR tps sensor
- obd-1 car, can i put in a obd2 motor?
- b18c1 sawp in 98 ek, which AEM CAI?
- testing to see if pic shows up
- need a little interior hybrid help
- radiator question"hybrid"
- 2nd gen b16 knock sensor location
- Performance Motor Mounts?
- need help!! How do i wire up a 99Si motor in a 94 HB cx using a 99 type R engine harness
- P72 problems on H22
- GSR Motor swap question/help
- Hasport Vs. HCP Vs. Place racing
- k20 into a eg hatch .... how soon do you think we'll see this....
- Password:JDM is awesome!
- Flat or Dead spot
- Meet Scooter! (Pic of newest H22 Civic)
- hesitation problems with b20 crx
- All that is going to be need for the 2nd gen b16 into 2nd gen teg
- zc clutch spec with lsd
- H22 in Ek help please.
- fs: complete ac system plus cruise control.
- jsut a question about cams and vtec and turboing
- waring: k20a on ebay
- CRX DX, got it today...!!!!!!!
- buying h22 axle combo, left/right w/ ABS or w/o ABS???? help!!
- is it possable to go from a cable speedo to an electric speedo? i need pics of the back of your gau
- ZC and nos combo, good or bad (did search)
- Question about H22a swap???
- Wiring a b16a1 into a 90' LS, HELP!
- ECU help?!?!??!
- integra a-pipe question
- Osaka = shitty
- whos all motor?
- is an h22 in an EK CA smog legal?
- Anyone Running ES OVAL with .....
- What header/cat combo will i need to use on a GSR motor in a GS ?
- Instructions on how to convert an engine from OBD-0 to OBD-1....
- its here
- Civic H22 swap
- LS Swap problems...help
- Integra RS engine swap
- Newbie Swap Help
- Fidanza or AASCO Flywheel???
- lsvtec or crvtec?
- fuel pump problems
- Wheres K-Wantanabe?
- jdm p13 into integra
- Help with swap sorry for newbie questions
- Finished my civic
- EK Civic Meets K20 Type-R Power
- My Hondamotors online story.
- fluidyne radiator question?
- Who did there swaps with hand tools?
- h22 head on a h23 block
- HELP!!!! Car wont start!?!?!?!!?!?
- re-wiring the vtec...NOVA ppl...
- Need help with ls swap????
- Which distributor can i use?
- Sticking Idle/Throttle problem..HELP!
- is my headgasket gone??or worste??
- Man did I get LUCKY!!!!
- parts needed to do ITR swap in 4dr EG
- Help b16a2 JDM Harness not compatible!!!
- anyone get their swap off of ebay?
- is this a good deal for a swap ? NEED youR imput
