PDA
View Full Version : Hybrid / Engine Swaps
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
  1. disk brake corversion for 97 dx coupe????
  2. retarded timing for b20/vtec.
  3. details on my swap!
  4. swapping out a final drive on tranny.....worth it???
  5. PLEASE PLEASE HELP ME!!
  6. b 20 intake manifold????
  7. Does H22 + EK Civic = no A/C
  8. Anyone purchase motor from k2engines in Baltimore, MD?
  9. Check Engine lights, my new idea.
  10. IF YOU HAVE DONE THIS PLEASE REPLY
  11. 1990 integra ls engine
  12. OT: Anyone interested in DYNO tuning in N. Cali?????
  13. need help with b16a2 to 96 cx
  14. CRVTEC project into an EG
  15. what master cylender will fit on my ek hb ?
  16. what do the b16a lsd trannys go for?
  17. MPG for b-series
  18. LSD tranny for b16a2
  19. Post Pic of your EG , EK hatchie!!! sorry i couldn't find them in search =P
  20. GSR transmision, S80 or y80???
  21. SOHC Vtec distributor on DOHC Vtec head?
  22. NEEDED: B18A vacuum lines diagram
  23. .........What is Better for LS Vtec.....Will individual throttle body help much???
  24. teg dash in an eg
  25. does anyone know anything about s2000 seats in a 93 civic? what i need to bolt in?
  26. H22A into 2001 civic
  27. Jdmclub.com
  28. need help with a sensor connection for a '00 gsr motor to a 94 civic
  29. JDM OBDII spec GSR doesn't have oil pressure switch?
  30. tranny question
  31. Car not starting need help???
  32. how to find out what year block you have?
  33. Which engine harness to buy for b20/vtec?
  34. camshafts(need help)
  35. D to D swap in a 91 Civic Si
  36. Any hooked up 4dr civics in chicago?
  37. Help please VTEC doesn't work
  38. 93 Civic LX w/ B18b motor Dyno
  39. B18b swap into 98 civc dx
  40. Civic brake swap - E-brake HELP!
  41. Jun/Crower/etc... Stroker kits
  42. B16A2 --> 92-95 Civic ... what parts needed?
  43. what is better: zc tranny or an si tranny?
  44. just got back with engine... pics.
  45. Intake on B18C
  46. hf crx header/cat fitment
  47. What clutch do I need?
  48. h22a wiring into EJ1
  49. P28-LSVtec oil pressure sensor?
  50. my fuel injector is spraying gas both ways into the air??????
  51. GSR exhaust to short in Civic swap
  52. Replace CV joints during swap???
  53. doesnt anybody know about the b16a1?????
  54. jdm b20 on its way
  55. ...............High compression Ls Vtec........................
  56. b16 smog
  57. would a H22a fit in a 90 - 93 accord wagon?
  58. Atlanta H-T Meet...where, when, what time?
  59. b16a1 powered CRX si
  60. 96 Civic CX Swap Questions
  61. Chicago Hybrids
  62. swapped d16z6 into crx, having problems!!
  63. question about this engine setup
  64. any recommand site for b20/vtec build up?
  65. Good Deal Or NOT
  66. H22 swap axle trouble...
  67. DOHC 5th Gens, help me out here fellas.
  68. H22 in DC2
  69. hey briang can you help me?
  70. is anybody out there???
  71. B16+turbo on CRX
  72. 1996 gsr donor ?'s
  73. anyone know of a place in Northern Va where i can get my emissions "passed"??
  74. pissing gasket!!
  75. What to look for??
  76. Which parts to use on a b20?
  77. Vtec solenoid/sensor same for all B16/B18 heads?
  78. type r pistons in a ls
  79. HELP........Obd-nothing B16 head....questions help
  80. Loosing antifreeze everyday.
  81. Code: 7 - Throttle Positioning Sensor...Why?
  82. How do you know when your engine isn't getting fuel?
  83. GS-R Girdle on an LS Help (HX_Guy or any other)
  84. Has anyone used the front traction bars for dragging.?
  85. Code 22 happens all time @ or around 8000 rpms in 4th gear
  86. All Wheel Drive Civic EG
  87. Kenji, I need to talk to you about a some swap stuff.
  88. atlanta hybrids---
  89. H22 distributor problems
  90. California ls/vtec
  91. how to know its a b16a2 head?
  92. Question about switching civic/integra interiors
  93. Thats it. Im done. Over. Done. Finished. Im sick of this.
  94. Is this possible?
  95. DX TPS pn B16A1 in EG?
  96. Engine break-in period?
  97. Hasport rear drag mount???
  98. vtec head or engine in a 84 to 87 crx
  99. trw high-fire rings and comp cams valve springs, anybody have any knowledge of these?
  100. FS: JDM B18B Swap 1695.00
  101. Which muffler for CRVTEC?
  102. Help with CTR pistons in a b16a1 engine!
  103. JDM ITR
  104. B16 Swap ECU?
  105. Ls/Vtec having problems please help
  106. determining wether synchros are good or bad.....
  107. JDM H22A Swap for 91 Accord
  108. Can anyone vouch for: salbaje??
  109. What I need to do a rear disc conversion on my EG.
  110. oil lines by speedo on b16 tranny????
  111. b18c1 into EG help...?
  112. Will Type R clutch and Flywheel fit on a 1st gen b16 tranny?
  113. CARLISLE!!!!!!!!!!!!!!!
  114. Crower cams breaking!!
  115. Best transmission for a CRV/Vtec
  116. Vtec wiring mystery??
  117. New Guy in the Forum
  118. Non Honda- Toyota Celica hybrid help please
  119. what else is needed for this swap?
  120. what shift linkage to use w/B20VTEC Swap in EG?
  121. JDM ECUs and wire harness
  122. gsr seats into 98 dx
  123. which do i get?
  124. Shop in Seattle area
  125. h22 swap in the bay area?
  126. What else is needed for this swap??
  127. B16 in a 97 ex sedan
  128. who's got a boosted b18c EK?
  129. Stock air box.......
  130. How much for this swap?
  131. Advice on B16 wiring loom, look complete?
  132. New here, question about AC
  133. Dialing out overlap on cams
  134. wiring harnesses
  135. H22 itno 98 civic question
  136. how many bolts to remove tranny...
  137. Code 36 on JDM h22a 95 Prelude ECU?
  138. b16a in a 91 crx si, how to be sure that vtec is working? please help?
  139. b18b in 98 hatch....
  140. Is this a good deal from golden eagle?
  141. shift problem b16a2
  142. soch swap info
  143. OT: What is this worth?
  144. I need some help here, 1st Gen. B16A swap into a '98 EX coupe .....
  145. Will the HASport Cable to Hydro conversion work on a '98 Civic????
  146. Will a DC2 catback exhaust fit on a EG6?
  147. Typr R LSD
  148. G2 swap b18C, ECU wiring.
  149. B16 Swap??
  150. friends b16a2 died on him... any ideas?
  151. F20B in a 94 Civic
  152. Does anyone sell a mount kit for a h22 swap into a EK. But allows you to retain A/C and power steeri
  153. 15X6.5" TE37's
  154. VTEC wire plugged into the wrong plug for the PWO ECU. which one is it?????
  155. LS/VTEC, PCV problems
  156. ITR p/s rack fit in 92 Cx?
  157. I need everyones help!
  158. B16 swap in 2k civic ex 5spd w/ juice
  159. Turbo b20 Questions
  160. Help on a EK civic swap!
  161. B-series cable tranny parts interchangeable?
  162. time
  163. engine management
  164. what do you guys think of this setup?
  165. NEED SWAP HELP PLEASE
  166. Just bought H22A.com any suggestions??
  167. Maye you guys can help me out. (trouble shooting issue) Kinda long
  168. is this a good price?
  169. CRX SI dist. on B18A(92)
  170. Component Swapping
  171. b20 VTEC vs S2000
  172. Exhaust header question for b16a 91 civic
  173. Saturn Hybrid???
  174. Help!!! ? on droppin in an engine
  175. made up my mind jdm b20b
  176. b16a1 in a 91 hatch VS. b16a2 in a 93 hatch???
  177. HELP! cant find evap purge on jdm b18c1 and the knock sensor is broken HELP
  178. cRUncH!!!
  179. b20/vtec and the knock sensor...
  180. P28 pin outs (distributor sensors)
  181. Cousin's Hybrid got stolen last night! DAMN DAMN
  182. b20b vtec w/jun 3's not revving
  183. WTB: LS/VTEC parts
  184. Does Insurance cover swaps?
  185. 00 Type R LS swap
  186. FELLOW H22A CIVIC OWNERS... do me a favor
  187. SIR1 motor in LS
  188. Another problem...
  189. 3rd gen swap options/opinions...
  190. how can check and see if a motor is stolen or not?
  191. can i keep my a/c?
  192. VX shift light
  193. Help... CRX Runs Rough After MPFI Swap
  194. 1988 crx si with b18 help
  195. wiring
  196. non-vtec to vtec
  197. A B18a for my Civic.
  198. How much for labor on this engine?
  199. ls/vtec how far can you safely bore an ls block???
  200. how much $$ to go crvtec or lsvtec
  201. I got SREWED!!!! out of $2000
  202. Type R LS swap
  203. ATTN Matty Devine
  204. 00 type r question
  205. problem problem problem.....
  206. My all motor EG hatch project
  207. where can i find a usdm b20z or a jdm b20b
  208. Half shaft bolts ?? I need some where do I find them
  209. Running Rich
  210. Is this all I need? (ls/vtec list)
  211. F20 150hp into 90-93 accord
  212. swap tip: lower control arms on 99-00 civic si's are different from 92-98 civics
  213. WTF all ITR engines are OBDII How can you convert that to OBDI?
  214. JDM Tranny question
  215. Who drag races their car with an aluminum flywheel?
  216. 2002 Civic Coupe with 2002 RSX Type-R Engine, Can it be done? or it's just a dream?
  217. Dyno numbers on the Skunk2 Stage 3's
  218. Engines, somone help me out!
  219. H22 into 6th gen Accord coupe
  220. going rate for a civic cx with a gsr engine
  221. Im new
  222. OT: Times for a Civic/GSR Hybrid
  223. b20
  224. Chipped P28 pr Stock P72?
  225. B18C5-EH2
  226. What fuel pump should I use for 210 whp B18C5 in my 94 cx hatch?
  227. Weight??
  228. How to repin obd 1 ecu plugs???
  229. details on cr-vtec
  230. F22 to H22?
  231. axle question
  232. Equation fr 8000 RPM
  233. how much is too much???????
  234. Need to buy b16
  235. motor mounts for b18c1 into 96 hatch?
  236. How about this: Las Vegas Meet.
  237. ECU OBD1 where to buy?
  238. 2.0 Si Swap
  239. B20A5 in a 95 civic HB? how much work
  240. 94 honda accord with H22
  241. Blown Motor from over-revving (picts)
  242. Running off the headers
  243. valve spring/retainer/cam combo for b20vtec...
  244. no spark on my b16????
  245. Valve clearance issue with B20 + VTEC Head
  246. d16z6 in a 5g hatch???
  247. H22 in accord
  248. 93 civic, will 97 accord trans and axles work with b18c in it?
  249. 91 crx si swap into a 89 hatchback
  250. will a gsr distributor fit my DOHC VTEC sol??
