View Full Version : Hybrid / Engine Swaps
- complications with obd1 engine and ecu in obd2 car?
- b20 w/vtec head or Ls/vtec?
- ~~13.9 on street tires~~
- CTR OR ITR pistons
- H22 IN A 96 CIVIC??????????
- how should i "break in" my b16a?
- Has anyone used JDM wholsale?
- Converting 00 Ex to 97 JDM B18c
- People with prelude motors in hb.....
- engine swap problems
- Best internals for Ls/vtec for HIGH C/R?!?!?!?!?!?!
- where can I find the least expensive B16A for motor swap to CRX?
- 1/4 times anyone
- Honda Techs - 5-bolt conversion, need help!
- wiring 95 OBD1 B18C1 engine into 96 OBD2 Hatchback
- H22A in 99 Integra Help!
- need everyones thoughts on this
- Need some help diagnosing weird problem with my hybrid!
- Which intake?
- Idle at 3-4K RPM's after hard driving?
- SWAP question, need help please!
- 99 B18C in Del Sol
- what kinda clutch should i get???
- HOKING UP VTEC??
- PR3 Injector style
- [::BOGGING:: B16A CRX]
- brake upgrade dilema's
- How much HP from a B20VTEC ?
- Stupid Alternator Problem...
- which mounts help
- Flaring Brake Line for GSR Master Cylinder Swap.
- Japanese motors have obd?
- jdm dc header on a 95 civic w/ B16A
- USDM GSR
- I want to go hybrid....i have pricing questions, and need opinions on my ideas.
- Mugen or Comptech Endlinks for rear swaybar..
- What kinda 1/4 times with B20/vtech
- B16A ( SIR 99 ) in 5Gen Civic... need wiring diagram of B16A..
- got my ls motor
- ek dash in eg
- different stock radiator for crx after swap? mine is overheating
- CR-VTEC Frankenstein questions
- 88-91 crossmember
- ITR Master Cylinder/ Booster on 6th Gen Hatch?
- Any substitute for a knock sensor?
- H22 punched to 2.5?
- car stalls and throwing codes after swap... help!
- need a high flow cat for when i get my swap
- Anyone ever used the RedShift Racing B-series mount kit?
- throttle cable?
- What harness do i use for a Civic cx97 with a 98 us INT type-R Motor
- Check engine light keeps coming on...
- O2 SENSOR PROBLEM: PLEASE HELP!!!
- USDM GSR B18C Engine Fit a JDM GSR tranny w/lsd?
- How much quicker will a b18c hatch be than a b16a hatch?
- 9000+ RPM what do I need?
- just got my first gen b16a and i got some questions
- Differences between b17 and b16a head
- simple: which intake will fit w/o losing diameter?
- USDM or JDM
- !!HELP!! ITR intake manifold on 1st gen. B16a, idling problem! (pics)
- Revving around and past the 9000 mark?
- OBD wiring problems
- Wiring Headaches
- NEED HELP! WIRING FOR OBD2 - to - OBD1
- which header
- b16a head for sale with work done to it
- PLEASE HELP!!!!!
- Rod'n'Piston question
- ::HOW CAN I TUNE OUT A V-AFC?::
- where can i buy a civic with no motor????
- Any way of finding LCA for EK to use ITR rear shock?
- SOHC VTEC Head Swap Complete! YAY!
- what oxygen sensor to use...
- 93' civic lx swaping in a 95' LS engine (wiring help)
- Need Help - Question RE: Code 2 - 2nd O2 Sensor
- Quick axle question for B16 swap .....
- Minime D16A6 head swap
- All wheel drive parts in 2 door civic ????
- What kinda of motor should I buy?????
- LS --> b16
- Plus/Minus of ZC vs. B16A(G1) for 90 CRX si?
- H22a Swap Mounts For 90 Integra?
- give me your thoughts on this
- update on b16a hesitation fix..
- Power steering in a H22 EK civic?
- jdm itr 4-1 header fit 4th gen. hybrid?
- crank pulley rubbing suspension & PR3 w/ b17-crx
- hey guys what do u think of this all motor setup?
- HELP!!! Need missing plugs for my B16a?
- Check out my setup and let me know what you think!!!!!
- FOR EF'S with B16a: What exhaust works best???
- Any good resources on H22A into 92-95 Hatch?
- stock compression ratio for a b18a1?
- anyone selling shiftlinkages?
- What does a 'KNOCK SENSOR' do? Help needed on transplant!!!!!!
- who knows how to swap motors in nj/ny area?
- engine swap
- dream swap
- NW Street Racing Site
- Which of these set ups would be the best???
- Header Tuning???
- CTR vs. B16a intake manifold - comparisons (pics)
- Oil Line for Ls/Vtec?? and some questions.
- 99 si in a 92cx
- Need help with my LS/VTEC please!
- JDM b16 vs JDM b16c swap..
- need a vtec solonoid or power steering pump brackets
- JDM or USDM motor swap??
- B18B HEAD HELP!!!!!!!
- b style engines.
- Super LS/VTEC? Need opinions
- tach jumping after 4K RPM
- HELP!
- New civic typer R motor swap???
- 95 LS Engine in 93 4 door LX civic
- Who has put in a motor+tranny in themselves before?
- B18B or B20Z?
- for EG's w/ B18C motors: what exhaust?
- B16b questions...
- hybrid websites
- Most bang for the buck?- TOP End or BOTTOM End??
- got fuel, got air...spark to start?
- Are there any 5 speed tranny's that can go on a 97-99 CL 3.0?
- Engine Swap Step by Step Process
- which starter for 91 CRX-B17/S1 (or JDM S1) ?
- RSX Engine swap
- Engine Choices???
- b16a idle problem????
- slower than before
- b16a block and Type R head
- ZC clutch, what to buy and from where?
- interesting ? on Engine miles
- ls/vtech which head is better
- 90 teg motor
- bad corrosion around spark plug...HELP!
- How much did you pay for your LS/Vtec oil line and all fittings?
- OBDII -> OBDI conversion requirements
- 3RD Gen integra, LS --> GSR or just straight GSR
- 1st generation B16a motor questions
- ls vtec upgrade
- water around the spark plugs...HELP!!
- B16a head and B18c block....
- Honestly how fast?
- b16a Engine stumbling in a 4th gen
- 90-93 and 94+ shift linkages the same?
- USDM H22 vs JDM H22
- best b16a cams?
- Meaning of the different engine designators
- Checking if Motor is legal
- JDM H22A into 97hx coupe
- Difference between GSR and ITR master cylinder/booster
- Suggestions Please!
- beak in for new engine.
- Q about pump gas with jdm engines
- Hybrids & Emissions
- what sould I do with a LS??
- which axles and drive shaft?
- h22a in my del sol!!!
- Accord V6 in a Civic.............
- Question about engine swap!!!
- CRVTEC or B18C1???
- what a good crvtec setup???
- Registration for a '95 Civic w/ B18C engine
- rev limit on a ls/vtec or cr/vtec?
- 97 Civic EX automatic getting a 92 civic transmission
- short shifter with b16a swap
- Talk about a hybrid...
- any disadvatages to b20/b18c5 ?
- Is this a good idea?
- B16 bottom with GSR head?
- FUCK THIEF!!
- need help with tranny
- Burning oil ?
- what distributor do i use w/ a Z6 head on a crx si block?
- ZC help needed
- what is the code for the 98 jap type-r
- 00 Si brakes -> 92 Si HB
- Anybody got the OEM part number for the '89-'91 Si injector resistor??
- Which Alternator\Starter - B18B w\ Y1 Tranny
- mini-me swap 1/4 mile times
- non-OBD to OBD1
- UMMM anybody do their OWN LS/vtec at home?
- Help!!!
- H22a in an G3 Integra
- Desperately need P13 ECU!!!
- b16 sir2 swap into 5th generation civic ex
- How to splice in 2nd o2 sensor for b16a
- regular maintainence on a b16a hybrid?
- Anyone going to Sears Point this wednesday?
- CRX w/B16A hesitation problem..please READ!
- jdm gsr (b18c)??
- Deal of a life time, you gotta see this
- Doing an ls / vtec
- LS Engine for $650?
- What to do with axles?
- Helm Manual for LS/VTEC swap into EG (92Si)
- Doin another H23/Gen. 4 Accord swap...need help
- How well will a b20/vtec fit in a crx?
- what should i do..swap questions.
- Spring Choice in 1991 Civic with b16a ?!?
- B20 question
- h22 vs. b20 vtec
- Anyone else have this setup?
- B18A vs B18B
- what kinda time for a 90 civic SI HB with a
- code 22???
- High RPMs at start and check engine light
- Aftermarket crank pulley on zc ?
- anyone please help... compression question
- Where did you get your engine? Overall experience with company?
- hp difference in auto and 5-speed???
- MASS DYNO DAY???????
- Is there anyone from MN with a b16a in a 88-91 CRX????
- Wiring 92 ls w/ 95 gsr?????
- Alright, stupid, easy rookie question here ....... sorry!
- which driver's side mount??
- what do I need to rev safely on lsvtec
- code 3 problems
- WHAT WOULD COMPRESSION BE IN A LS VTEC
- Prelude engine Swap?
- B16A CRX hesitation problem..HELP!
- Can anyone tell me how to Check ECU codes?
- what parts do I use on a b16a with the cable tranny?
- Help with engine swap in Florida !
- D16A6 TO D16Z6 HEAD SWAP
- I am thinking about doing a GSR swap on my car.
- What to use?
- Prelude Type S swap
- dx w/gsr wont go pass 4K?
- Which swap?
- dx swap
- LS/Vtec Conversion shop in Southern California
- B16A waterpump fit in JDM B18C?
- Questions about my swap
- What else do I need to complete the swap ?? H22A in Accord 5-spd
- TEIN RA for ITR into 92 EG CIVIC CX HATCH Qs???
- need info
- will 95 ls injectors work on a stock 95 gsr motor?
- GEn 1 B16a distributor on ITR head...
- Dealings with Luangamat@aol.com
- B16a1 into 92-95 Civic.
- LEGIT???...FullThrottleNYC.com
- Costs involved with building a hybrid civic?
- Pics from the PacNW Hybrid Meet
- code 92
- How hard do you think this is.
- step by step swap for someone who's not car savvy b18->4g civic si
- here r some pics of my future hybrid,,and 96 GSR
