View Full Version : Hybrid / Engine Swaps
- which mounts?
- 90 ls b18a1 to a b18b1 sensor trouble
- Chipping a p28 my self, where do get the socket?
- obd plugs?
- H22a hose routing?
- Question about JDM B18c1
- Possible to adapt LS PS mount and timming belt cover to work with Vtec head?
- will a gsr motor swap fit in my 02 ex
- what is needed to put a h22 in a 90 accord?
- H22a swap questions
- 86 integra ls; just curious
- WTB: Vtec oil pump!
- How hard to move dowle pins on Vtec head?
- Group buy on quaifes
- GS-R engine wiring harness???
- ecu for 91 civic
- 99-00 b16 in 92cx questions?
- Any one who has done a swap, need part & help
- H22a - EG Swap this weekend..
- ITR intake manifold help!!
- Closed Loop?
- DC JDM ITR header on LS/Vtec: Will if fit?
- guess what. ready this!!
- Easier for swap: DX or VX - 5th gen hatch??
- LS conversion questions...
- How quick is a CRX hybrid SOHC VTEC (EX)?
- ITR tranny with b20??????
- gsr n1 would it fit a EG?
- 2002 si hybrid
- LS/Vtec oil line?
- crank and rod bearings....... all the same for B- motors?
- EP3/K20a2 Hybird
- LS TB, fuel rail, and injectors on B16 IM?
- Steering wheel vibrates after swap HELP
- Flywheel/Clutch combo for hybrid
- 3rd gen civic swap
- must i redo my bottom end if i put a vtec head?!
- Any fast N/A B18B's out there?
- B16A1 build up....need some ideas
- A question for all of the Hybrid Experts
- check code
- GSR header with O2 sensor for hybrid
- LS to GSR.....change exhaust catback?
- nippon motors
- "shimming" LS oil pump.
- Gsr into ek questions please help
- How far will I need to mill head?
- LS\Type-R hybrid
- 1st gen B16 intake manifold for LS/Vtec?
- What ecu to get???
- Re: LS/VTEC
- OT: Not a Honda but a Lexus hybrid
- b series motor on a 90CRX SI??" what kind of mounts?
- deck height of B20B???``
- VAFC apexi?
- ok will a first gen b16a head work on a b20 help!!!!
- Pre-OBD distributer in OBD 1 car???
- Alberta Hybrids!
- can anybody answer this question
- what should i go with?????
- anyone heard of Infinite Motorsports for swaps?
- B18C or B16B
- S1, J1 or Y1 tranny on 92 B18A...
- Hybrid guys?
- V6 Civic ???
- Does anyone know how to disable the speed limiter on jdm ecu's?
- b18c1 in my cxhatchback what AEM intake???
- Oil Squirters
- when you bore your block do u need a new head gasket??
- need help on a swap
- Crvtec vs. ls/vtec
- www.importbuilders.com???
- WTB: GSR parts!!!
- B18 A/B
- radiator
- Need a bit of LS/VTEC info?
- Any ZC experts?
- Is the ZC a bad engine?
- b18a1 into 90 civic dx hb - what do i need?
- WTB: GSR or SI tranny!
- which o2 sensor should i use for pr3 ecu?
- Questions on B18c in EK???
- B series tranny weight and deminsions?
- Nice EG with a LS-VTEC swap on ebay
- H22 Head on H23 block?
- Gutting a GSR IM.....has anyone done this before???
- hasport linkage and b16 starter
- power steering on a swapped car....PLEASE HELP!!!
- Hybrid Swap
- Power steering on a swapped car...PLEASE HELP!!
- B16A1 with Y1 trans = which clutch & flywheel (by vehicle & eng. model pls) - what works?
- Making your own shiftlinkage pin pressing out tool?
- just joined
- any b20 dynos out there
- 88 CRX Hf with H22a
- what upper radiator hose to use for H22/Civic?
- considering b20
- Capabilities of the c5
- where to get thick head gasket?
- ES oval sound?
- disconnected VTEC?
- Low Compression Turbo'ed LS/VTEC Hybird?
- Has anyone used an SIR shift linkage and Hasport mounts or.....
- 240sx w/SR20DET to Super Silvia
- type R exhaust on 92 hybrid hatch?
- what engine to put in 90 dx?
- PR3 and P72s
- b16B or gsr
- problems with 1st gen b16 in 2g integ
- need help with wiring (blownhatch)
- B16 block with b18c1 head?
- Cylinder & Booster Upgrade Questions??
- part # for del sol AC bracket
- Cali BAR sticker?
- Lowering Compression?????
- Which engine takes more Boost??????
- LSD tranny, worth the extra $$$$ ?
- GSR block shot... Use a B16 or LS block w/ GSR internals ?
- Need your experience with the state ref pleaseeeeeee help
- code 4
- B20 Info
- Frankenstein Motor Build-up Question
- ITR ecu problem
- b16 downpipe in 88-91?
- Thoughts of Vtec head on stock b18b block?
- how much hp does an ls/vtec motor have??? more details inside....
- need help somebody please help me
- Possible GB on Skunk2 Intake manifolds
- Any hybrids running a b16 head with a GSR block? pics?
- 88 crx dx with si tranny and engine dpfi intake high revving need help
- 92 civic si-gsr swap ?
- swap question!
- Vtec Solenoid
- Coupe or Hatch fer this?
- my list, need help
- SWAP QUESTION;for a 95 CX Hatchback!!!
- IT'S ALIVE!
- Just did swap, distribuiter probs....
- List of problems after swap
- pics of b20vtec in a 2000 si.. enjoy!!
- IDing gsr tranny
- TOOK MY HYBRID EG6 TO THE TRACK AND DYNO "post opinions and comments"
- first swap
- Question about halfshafts
- secondary butterflies(IAB)
- a little help..fiels related
- Skunk 2 manifold??
- Bck in the game, B20b
- speedo 10 MPH off.....any ideas?????
- Which engine to swap into Del Sol??
- C.R. B16A2 head on B18c1 bottom end?
- b20 turbo
- [ To swap or not to Swap ]
- Swap's running, heater doesn't work.
- B20/vtec Build up - PVC valve
- in a ls vtec.. would you guys rather have b16a2 pistons or R pistons???
- crv/vtec in 95 integra ?
- HELP WITH SWAP
- will ls integra obd 0 distributor work for a gsr sicrx????
- Bads of short shifts.
- will this work?
- b16a block differences
- ZC into an automatic EF DX ... need some help for wiring ASAP!
- B20 Vtec turbo info needed!
- B16 head differences?
- Still not going into 4th gear.
- please help!!! small problem with b16
- ******shiftlinakge help!!!! and looking for wire harness.
- Normal Compression #'s and Flywheel recommendations?
- new master cylin. resv.
- What chasis for a b20?
- Pics of my new swap
- How do I build a reliable B20-VTEC?
- What tranny do I have on my RS? It says Y80.
- s20 and s40 transmissions
- ATTN Illinois members
- Which header to use with my Civic Hybrid??
- 02 Sensor for my '95 B18C1, anyone have a Honda part number.
- LS valve cver on type R head???
- 4G Civic hatch swap Q
- SRS light is ON, any suggestions, using ctr srs & cluster
- 1st gen B16 distributor... will a 90 teg cap and rotor work?
- Motor Mount Inserts.... what is your experience on this?
- Type-R head Alpha numeric ID?
- where to get step by step directions?
- Looking for writeup on LS\VTEC Hybrid
- Need help with CEL on my B18C1 Hybrid hatch
- LS cam profiles?
- Wiring up gsr motor in 92 civic DX.....
- Best place for B18C engine w/ low miles?
- how much power and what kinda times
- 2001 civic SWAP?????
- H22 in EJ likes to break axles any help????
- H22 or B18C in 91 Integra
- B16 in a G2 integra?
- b16a in a Mitsu Mirage????
- Why do you need a Del Sol AC bracket for b18C1 swap?
- ls nos in a first gen integra
- USDM Accord or JDM V-8 Accord?!?!
- H-T Atlanta Meet May 25th
- b20 specifics.
- LS and B20 crank pullies the same....
- Will The GSR AEM CAI fit in my CIVIC with the GSR engine?
- Day 1 of Project EK h22a hybrid
- Couple of maintenance questions for 1st gen b16
- can i use my Civic CX Distributor on my B20VTEC Swap? How bout my CRV distributor?
- recommendations for my situation
- help me
- d15 build up
- My b18b hybrid times - Inside... What is yours??
- JDM B16A swap into '94 Civic EX...what will be needed?
- NEED HELP. just got parts in but missing stuff. i think
- '94 B18C1 into '92 Si wiring question.
- Just got my gsr motor today
- What trans. mount.....
- anyone know tony montoya
- B20 turbo or B20vtec or H22a turbo
- is anyone /and or company working on a new k series crv/vtec ??
- B16 Head onto B18C1 block?
- Skunk2 Manifold and JDM R Header power gains???
- JDM Swaps in Connecticut??? Smog Legal???
- H22A/Civic axle ?'s
- Who has a Civic VX with an OBDII engine and ECU?
- si A/C mounting brackets needed for swap into EX 6th gen?
- Who do I need to speak with on starting a FAQ/How-to section on Honda-Tech?
- B20Z in a 5th gen civic
- Civic HX Swap Questions????
- pulling b16a out of the car...
- B18C into my 96 EJ...
- How do you hook up the JDM ITR 4 -1 Header on to a USDM CAT and APEXI WS ???
- My new setup. Judge it...
- Need an idea on cost of a H22 + manual tranny swap
- How can you tell if GSR Tranny?
- Finally got my hands on a civic
- Best bolt on B16a setup?
- JDM B16 in EF9 doesn't fit! HELP!!!
- How much should you pay for a 92-95 EG front clip w/b16
- What happens if the ref finds out your motor is stolen?
- b16 swap into eg
- d16->b16a->b18c part swap ?'s
- Vtec Problem
- GSR or Del Sol/SI tranny.....
- OT: Motorex coming to Northern California on April 26th, 2002!!!!!!!!!!
- CRVTEC in 94 civic ex
- si head on dx
- 90-93 teg...
- I just bought my motor before the car!
- Mini Me Ques?
- p28 or p08 with hondata?
- SMSP/Moroso B Series Production Oil Pan Now Ready
