View Full Version : Hybrid / Engine Swaps
- 89 Integra driver axle for h22 eg swap question
- ecu & wire harness???
- 93 h22 tubo fuel management???
- what exhaust to buy?
- 97 civic dx radiator
- h22 ????? motor
- h22 no vtec
- LS into 92 CX... somethings very wrong
- LS/VTEC - B18B/B16A/OBD-0 intake - VAC LINES >>?
- Quick question 01 gsr motor in 99 civic si intake
- B20vtec idle problem....?!?! HELP!!
- civic disc break conversion
- b18b1 Knock sensor.??
- Need little help knock sensor and idle
- Cable Clutch Pedal swap into a EG?
- WOW..swap is harder than i thought it was..need pics please
- h22a swaped ek turbo ????
- H22A into EG.
- h22 swap axles??
- b into eg swap question
- lsvtec timiing belt is a little loose is this normal ??
- vin checking...i think itll help all
- What Axles?
- d15 tranny onto an h23 motor?
- Need help with wiring on b series swap
- what does a leaking header affcet performance-wise?
- obd1 ls motor into obd2a 97 civic coupe
- whats the 1/4 mile.?
- h2b kit supecharger anyone???
- SWAP HELP
- b16 block mated with gsr head...thoughts
- B20 Vtec Question ?
- k20a2 swap worth the money?
- h22 civic idle problems
- ls swap... any suggestions
- idle problem
- B block opinions
- JDM Source
- k20 in a DB2 - Need Help.
- headstuds
- difference between 90-93 teg linkage and 94-01 teg linkage...EG swap concerns
- Hybrid Axles?!!?!!
- Harness FOR B16!!!
- Car runs fine then engine loses all power/dies
- Check this out if youve swaped a b18 into your ef.
- My H22A 94 LS Integra Build
- Question- GSR head on my b18c5 ITR block
- B16 Swap into EK hatch!!!!
- CEL question... pretty easy im sure
- EK Coupe midpipe the same as EK Hatch?
- GSR B18C1 cams into B20A7 vtec head?
- Which B series distributor do i have???
- How much heavier with K-swap?
- Missing a rear mount?
- tps sensor broke on delivery... help!
- will an h22 aftermarket LSD fit f22 tranny?
- Getting "Communication Error" with a scanner after swap...
- K20 in a eg hatch
- help with gas mileage
- b20 in ef tranny questions
- VTEC solenoiD wiring problems
- 90 integra gsr swap
- Question for swap h22A in to Civic 92 VX
- B20vtec CODE 10(IAT)
- dyno results are in .... k20a2 EG
- tranny for b20 question?
- dual to multi point wiring conversion
- crooked motor...CRAP!!!
- swapping a prelude motor into a Ek ?????
- i want to do a f20c with itr tranny
- B18b ruff low idle too rich
- ZC in a GSR, begin flaming
- I have a problem with B18c5 swap, HELP :(
- confused on rear mount setup for LS swap into EG hatch
- b20z or b20b with a vtec head?
- Exhaust for swap?
- radiator issues with swap
- B20/vtec wiring??
- Looking for "stand-alone" harness for OBD 1 engine
- HElp CEL 96 ek with gsr swap
- Chipping p72.
- wrx motors for sale.
- VTEC quit on dyno?
- Question: 97gsr into a 98ex will it be plug and play?
- clutch and transmission between a series
- engine list
- OIL PAN FITMENT QUESTION-
- Is it possible?
- f23 swap into a ej1
- HELP TRANSMISSION BOLT PATTERN
- b18c5 swap to 96 civic ex?
- LS Turbo Questions
- h22a1 head on a f22 block...
- 99 JDM ITR into a 94 civic coupe EX
- 96 ek gsr hatch cel code 65 losing power?
- Need help swapping 99jdm integra type R motor into eg civic
- Question on making the motor legal
- Code 43 Fuel supply help
- another EK swap question
- shotpeened LS rods
- EG6 H22A1: Setting your TPS?
- Euro R head on H23 block
- jdm motors and smog?
- Sir I b16 in 92 integra. IM,harness,Dizzy?
- power steering bracket
- k20 into a 98 hx
- Lights on The Dash
- gsr swap in 90 integra
- b15b7 into my 98 civic ex
- CD7 Suspension on a DC2?
- obd0 b16 head
- Help with wiring GSR motor into 99 civic DX..
- h23 crank in a h22???
- OBD2b car to OBD2a motor
- best frankenstein engine
- h22 on accord 99 help!!!
- what do i need to do for a k-swap on eg civic
- Mount bracket?
- Help with LS swap in EF
- B18c1 into a 94 civic ex
- ctr head/b20 or gsr
- H22-EG wiring harness question
- Correct timing belt for GSR head / ITR block
- EG6------B18b?????
- I got a “check engine” light, looking for some help.
- want h22 swap info. (searched)
- engine & tras' brackets needed in B16B/A into 96 EK4 ??
- Need a reliable, GOOD New Jersey Speed Shop.
- need help with swap
- Updateing Honda powered Sand Rail
- b18b bottom end rebuild
- jasmine (sp?) header??
- Just curious, about my new swap
- K20 in 5th generation prelude??
- B18c1 in 00 civic...intake...
- P/S pump from integra 4 b16b swap into EK4 need pulley too ??
- 92 si rears vs 94-01 integra rears?
- gsr IM question?
- help a homeslice out
- 99 b16 w/ ls trans
- b16 and b18c1 camplates and cam caps the same??
- b16 swap shift linkage
- need help on obd conversion
- lsvtec vtec wire wiring harness question for my ek civic hatch
- b18c5 into 00 ek
- h22 gurus: PLEASE HELP
- Another Noob OBD Conversion Question
- B18C5 FROM THE UK
- F22 VTEC Harness for use on H22 long block
- CIVIC HYBRID 2006 DIAGNOSIS CAN LINE
- where is the knock sensor wire?
- b16 eg swap air intake question
- help cant diagnose o2 sensor problem
- can i use a automatic with a b18c5 head
- umm so i was thinking....
- H22 cap???
- Replacment D series?
- Engine Assembly question help!
- rear disc brakes convertion in civic EK4 - 96 coupe??
- D16Y8 Intake Manifold on D16Z6 - Converting 3 wire IACV to 2 Wire?
- JDM Factory B16 mounts in EG
- AF-Performance EG Swap Progress and Build
- b16 swap problems
- caddilac exclade motor hybrid
- HUGE problem w/ 94 Ls integra h22a swap
- Frankenstein Engine :(
- SiR-II into Ek hatch...
- Is my kamakazi header too much for my ls/vtec
- where to get EGR solenoid and how to connect it
- h22 in 01-04 civic si hatch
- my car wont start
- h22 swap into civic ex exhaust???
- DC2 suspension on an 99 civic?
- worth of b16?
- Swaping a B16 from a 90crxsi to an 88crxsi
- Radical Idle when stepping on brakes??? JDM H22A...help...
- shifter question
- Search down, question on axle seals.
- help with k24/k20
- h22 swap custom exhaust or no
- need help with h22 shifter cable routing in my eg!!!!
- EM1 vs 94+ B18 rear trans bracket
- Legal to have a b20 swap ?
- will bad ECT throw code?
- info
- Whose all using Innovative Motor Mounts? Post your reviews
- Ls-vtec, is it worth it?
- legal k20 swap in california
- dual core radiator, b16 swap, do I really need it?
- I NEED HELP WITH A GSR SWAPPED 94' civic
- Distributors...
- interchangeable intermediate&main shafts?
- b16a into a 99 civic axle problems HELP??
- transmissions
- H2B?
- Where can I buy a OBDIIB to OBDIIA Conversion Harness?
- Need help with a crappy running SiR-II swap in a 99EX
- B18c CRX Si. Need new head gasket. Do I ask for a B18c5?
- Need HELP ASAP! integra distributor TROUBLE!!!
- H22/H23 swap info
- h22? in a del sol?
- concerns... 99 b18c into 96 dx
- h22 swap on del sol help...
- obd0-obd1...checking codes
- 98+ JDM ITR into DB2... Q's.
- K-series in eg
- H23 Head on F22A1
- Ask your H22 Questions Here (Technical Only)
- SOld my DB8 and picked up a b18 EK
- B18c with skunk2 intake manifold pass state ref?
- valves for a b16a
- h22 swap help
- innovated or avid motor mount ????
- About to swap and build my first B16
- Alright. Heres my final try on this one (I SERIOUSLY NEED HELP)-H22 swap Q's
- 99-00 Civic With B18B OBD2B Integra ECU - Immobilzer?
- b18c GSR swap BAR
- motor mount inserts
- b16 swap, j1 tranny, 88crxsi, which axles/shaft to use?
- in am looking for an 92 to 95 civic hatch or coupe cheap please help
- Convince me to swap
- GSR synchro and ITR syncho the same?
- B20b/ 97' EX Swap Problem ***Searched***
- B18C GSR Motor
- Motherf**king Motor Mounts
- obd1 d15 into crx si
- 92 si D/S shock tower pinouts
- H2B
- obd1 b18b1 swap in a 98 ek question
- EGR wiring Harness
- B18A1 EG Swap
- EJ9 D14A4 adapter harness that i made from "P3Y" obd2 to obd1 D14
- Throttle cable
- DOHC ZC Wireingharness
- b18 EG exhaust/header
- Have you seen Honda's first factory Turbo
- Cheapest DOHC swap for 98 Civic DX
- No reverse after H22 swap
- How to get a BAR legal swap
- H22 wiring into 1998 EK civic 4 door
- brake and fuel lines for a 93 civic
- OBD2A and 2B 8 wire dist. 9 wire dist. NEED HELP!
- b18b1 into 91 integra?
- gsr to si-r ?'s
- OBD and Emissions.
- AC and PS in H22 swapped DC?
- NEED HELP WITH ARP HEAD STUDS!!!!
- Eric Japan on Elston in Chicago swap?
- Question regarding Knock Sensor Obd0-Obd1 jumper to p13 H22A engine
